Ground station hardware report
The ground station hardware referred to all hardware “things” to set up a stationary or not ground tation. Also referred to documentation in SatNOGS wiki. The repositories for that, are placed in GitLab.
- Description:
It contains source files and BOM to build rotary position encoders
for SatNOGS rotator. - Status:
All files are ready for release, the remaining issues are for better
documentation.
- Description:
It contains source files for a FM notch filter. Also contains
a simulation in QUCS and a report from mini VNA. - Status:
better documentation. The filter is tested also with rtl-sdr.
It is better to re design the board in order to placed in
a shielded box, like this.
- Description:
It contains source files for a diplexer in VHF and UHF (only for
RX). Also contains a simulation in QUCS and a report from mini VNA. - Status:
better documentation. The 2 filters are tested also with rtl-sdr. - Related projects:
@ar3itrary also develop a VHF/UHF diplexer with bias-t, for more details and in repository.
Other interesting community posts:
- Description: It contains the firmware for different set-up of SatNOGS rotator. Also contains doxygen-files and documentation.
- Status:
The master branch is working with stepper motors without encoders
and DC motors with encoders. Some of remaining issues are critical
like #21, others add functionality and makes more optimal and robust the rotator system.
The master branch runs with all SatNOGS rotator controller if the user change the rotator_pins.h. Also the master brunch contains the firmware for the latest release of rotator controller.
- Description: It contains source files and BOM to build the motor driver of SatNOGS rotator.
- Status: The latest release is v2.2. The remaining issues are not so critical. For example #39 resolve a problem with arduino pro-mini clones (chinisium), (take a look in wiki). Most of the issues are referred for better documentation. I think it is a good point to build a new version that supports different rotators like yaesu G5500 (AC motors) and SPID, BIG-RAS (high power DC motor), that is low cost ~100E, and other specification that it’s under discussion.
- Description: It contains all source files and BOM to build the SatNOGS rotator.
- Status: The latest pre-release v3.1 contains all the fabrication files for the build and the release notes. The remaining issues are not so critical. For example the issue with the biggest priority is #73. The other issues almost are referred to documentation. The issues #17 and #51 will make the rotator more robust. A wear test is running in station 200. For now it has 1086 observations in ~3 months (2 months was offline). The major problem was a broken corona gear in azimuth axis. This gear had narrow infill and after strong winds are broken. Now the load of the rotator is a wimo x-quad VHF antenna (~2.3Kg) with counter balance weights ~2.5Kg. The DC motor version is capable to rotate two WIMO x-quad antennas VHF and UHF, back mounted and balanced. Also it is weather proof as tested in station 200. The documentation is under development in rotator wiki page. The reference design does not support imperial parts. In community you can find related posts, how to modify parts for imperial parts:
- satnogs-partchanger
- Using T-Slot profile instead of tube (proposal)
- Version 3.1 Stepper Varient with V2 Controller
imperial parts are noted in wiki
Satnogs rotators in network: - station 9
- station 200
station 123
Related projects: - kd8qwt rotator
- Metal antenna rotator, station 43
- Integrating Satnogs with other rotators , sarcnet.org
- Description: Various hardware components for SatNOGS ground station. Take a look in issues to understand the content of this repository. Also in this repository we can develop “things” for no rotator setup or omnidirectional station.
- Related projects:
To be continued with repositories:
Now it is time to open a discussion about priorities for GS hardware development, according to SatNOGS goals.
