Hi everyone,
we now expect the next re-entry of a TU Berlin satellite, this time of TUBIN (project website). The latest prediction by GSSAC is around 2025-12-16 07:11:54 (UTC) ± 11 h. Following the great success we had with the BEESAT re-entries (see respective posts: BEESAT-2, BEESAT-4, and BEESAT-9) we will try to repeat it with this bigger and more capable satellite.
Orbit Determination
For orbit determination we will rely both on GNSS data and UHF STRF measurements conducted with our Berlin ground station (SLR could be another very precise measurements, but OD has to be already quite good to hit with the laser and most likely this is not the case in the last days). Any TLEs we create we will publish here, the SatNOGS DB and our public TLE GitLab repository (be aware this could include multiple TLEs with different NORAD IDs as we want to have the ability to shift between those live in a pass). But of course we are also appreciating any TLEs generated by the SatNOGS community, only through them we were able to follow BEESAT-9 up to an altitude of ~100 km.
Communication
TUBIN will utilize the same communication bands as throughout its lifetime with the addition of an UHF beacon as described below.
UHF Communication
- Frequency: 435.95 MHz
- Modulation: GMSK BT=0.3 with 4800 bd
- Framing: MobiTUB, details see answer #42
We just conducted the final software update for TUBIN, which implements a telemetry beacon similar to the one on the BEESATs. This will allow us to automatically transmit telemetry also outside of our ground station contacts (Berlin, Germany and Longyearbyen, Svalbard, Norway). If you are interested in decoding the UHF telemetry, @kerel recently wrote a functional MobiTUB decoder for gr-satellites with GNUradio 3.10 which is now also included in the 2.1 release of the SatNOGS client.
The auto send feature is now enabled until the end. Currently we are transmitting every 20 seconds one beacon, but that will be soon increased to every 10 seconds. The content of the beacons is described in answer #37.
S band Communication
- Frequency: 2263 MHz and 2266 MHz (two independent transmitters)
- Modulation: DQPSK with BPSK preamble
- Framing: Custom, see decoder and example IQ file in answer #17
- Recommended IQ recording settings for both bands:
- Sample rate: 6 Msps
- Center frequency: 2264.5 MHz
TUBIN also transmits telemetry and payload images in the S band. When I asked earlier this year how recordings of this high data band could be achieved we came to the conclusion that transmitting IQ files to us, we decode them and sent the telemetry back is not very feasible due to the file size of 5-15 GB/pass. Luckily our colleague PistonMiner recently developed a HiSPiCO modem in GNUradio/Rust. A preliminary version was published recently, for more information see answer #17.
As the opening angle of the HiSPiCO transmitters is around 45° (half-angle) and the ADCS system is more powerful than on the CubeSats we are quite confident that the satellite will be able to conduct attitude control and to transmit data. Our biggest concern currently is the pointing of our ground station antenna as its opening angle is only a few degrees. To mitigate the risk of misalignment we will also have support from some other S band ground stations (AFUTUB, TU Graz, maybe something with ESOC) which then can use different TLEs. But any further support from the SatNOGS community is of course very much appreciated.
X band Communication
To our knowledge there are no SatNOGS ground station suitable for X band and as this band is limited to payload data, this is less of a focus of the End of Life campaign.
Telemetry forwarding
You can forward telemetry to us via our SiDS server:
- URL: http://radio.space.tu-berlin.de/telemetry/send
- Explanation of the SiDS protocol by @PE0SAT: janvgils/sids: Simple Downlink Share Convention (SIDS)
Also we have prepared specialized TUBIN re-entry QSL cards, just reach out to us via this thread or PM if you want one.
That is it for now, if you have any questions feel free to reach out ![]()
Julian for the TUBIN Ops Team
Change Log:
2025-12-11 01:14: Updated outdated information, added links to relevant answers in this thread and other sites and added information about modulation of signals.
2025-12-14 19:53 Updated predicted re-entry time.
