BEESAT-2 [1] (NoradID 39136) is expected to re-enter into Earth’s atmosphere in the evening of next Wednesday, 2024-01-31, or during Thursday, 2024-02-01. As with BEESAT-4 [2] last September we will try to activate worldwide transmission of standard telemetry (APID 41,1,2,4, see our Information for Radio Amateurs [3] and Telemetry Format [4]) every 10 seconds, beginning about two days prior (we will notify). If SatNOGS stations are not running gr-satellites with MobiTUB-2 decoder it would be nice to record IQ data. We then could decode telemetry locally and submit decoded telemetry afterwards. Also running STRF scans at 435.95 MHz during passes over our Berlin, Germany, ground station (and later worldwide) could help to determinate TLEs as from BEESAT-4 and -3 we know that they will be change fast once we are getting closer to re-erntry.
To all helping HAMs: Many thanks in advance for your support!
Hi dernasherbrezon,
I didn’t know leosatdata before, but thanks for activating BEESAT-2 by default When I understand it, from my brief look, correctly to get actual frames a GMSK decoder in the jradio project would be necessary? Despite that also the waterfall plots can be useful to detect until when the satellite is alive. And I saw there are already some succesfull observations
Thank you EU1SAT for all your recordings and uploads We have received your data well At a later time when all this is behind us I can give you csv files with the decoded telemetry from your station if you are interested in that. But we also plan to add a ksy file to SatNOGS so they should be also decoded there.
Our sources are saying that BEESAT-2 will burn up at about 09:51 UTC at 2024-02-01. Today in the evening we encountered the first problems with doppler shift drift and sadly neither our own nor other STRF ground station (that we know of) functioned correctly or was active. We will have to see how good the reception is tomorrow. First Berlin pass will be at around 10:50 UTC.
I think BEESAT-2 has decayed. As mentioned above 09:51 UTC was the prediction given to us on Tuesday and we also did not receive anything during the 10:17 and 11:45 passes over Berlin. I will write later today a little bit more.
Hi everyone,
is had been a while since BEESAT-2 re-entered Earth’s atmosphere. We presented our analysis of the BEESAT-2/-3/-4 re-entries at this years 4S symposium titled “Lessons Learned from Operating Three CubeSats until Their Consecutive Re-Entries” and recently we made the paper publicly available [1]. Additionally my colleague Anton Große Siestrup and I will present the findings from all our BEESAT re-entry campaigns in this month’s edition of NASA Small Spacecraft Systems Virtual Institutes (S3VI) “Small Spacecraft Community of Practice” webinar. The webinar will be streamed online on the coming Wednesday, 13th November at 10:00 PST / 18:00 UTC / 19:00 CET and is titled “Lessons Learned from Executing End-of-Life Operations with 4 CubeSats until their Consecutive Re-Entries (BEESAT-2/-3/-4/-9)”. More information can be found on the S3VI website [2].
Webinar details: When: Wednesday, 13th November at 10:00 PST / 18:00 UTC / 19:00 CET Where: Microsoft Teams, link / meeting details will be available on the website and shared as a comment to this post
The webinar will be stream on Microsoft Teams with the following login details:
Link: Microsoft Teams Meeting
Meeting ID: 242 271 510 60
Passcode: jhZ3Uu
