Hello Bill,
Looking at the API information of the RTL-SDR, the value should be:
SATNOGS_SOAPY_RX_DEVICE="driver=rtlsdr,biastee=1"
RTL-SDR Settings and value:
SoapySDRUtil --probe="driver=rtlsdr"
## Soapy SDR -- the SDR abstraction library ##
Probe device driver=rtlsdr
Found Rafael Micro R828D tuner
RTL-SDR Blog V4 Detected
usb_claim_interface error -6
[INFO] Opening Generic RTL2832U OEM :: 40004541...
-- Device identification
driver=RTLSDR
hardware=R828D
index=0
origin=https://github.com/pothosware/SoapyRTLSDR
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: YES
Time sources: sw_ticks
Other Settings:
* Test Mode - RTL-SDR Test Mode
[key=testmode, default=false, type=bool]
* Bias Tee - RTL-SDR Blog V.3 Bias-Tee Mode
[key=biastee, default=false, type=bool]
-- RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream args:
Antennas: RX
Full gain range: [0, 49.6] dB
Full freq range: [-0.001, 1764] MHz
RF freq range: [0, 1764] MHz
Sample rates: [0.225001, 0.3], [0.900001, 3.2] MSps
Filter bandwidths: [0, 8] MHz
