I thought this would be only necessary als long as applications are accepted.
This time ended yesterday 23:59 utc.
That makes sense. 73
Sophia Smirnovaβs cat βΠΠΈΠΊΠΈΡβ was one of the images of the first stage (from 15th to 17th).
Is this image part of the Sputnix space radio quest?
Did anyone get the code word from RS15S or RS40S to start the telegram bot?
I get codeβ¦
2024-04-11 19:31utc
Image received from RS38S in IO90KU at 2024-04-11 20:59UTC
Hi John,
Welcome to libre space community and thank you for your image post.
Iβve created a new topic April 11~13 World Aviation and Cosmonautics Day (SSTV event) since those images are not only transmitted by RS40S (UMKA-1).
SSTV PU2UHD GG66PM BRAZIL
In honor of World Amateur Radio Day, the team of the UMKA-1 RS40S school space telescope congratulates the international amateur radio community!![]()
The interval between the start of each broadcast is 300 seconds.
Frequency 437.625 MHz GMSK USP 9600/4800
SSTV Robot 72
The broadcast began on April 18, 08:02 UTC and will end on April 18 at 18:55 UTC
18:55 utc, the probably last image.
18:55 UTC. Local time 20:55 Trondheim Norway.
The only decent pass since i discovered there was a event. Just used a horizontal 435mhz tuned dipole. I consider myself lucky.
Got diploma [typos corrected version] for receiving childrenβs drawings in SSTV (2024-03).
UMKA is transmitting SSTV again.
Took me by surprise so i had to use the wideband Moonraker Mobile antenna that i had connected up at that moment. Not a good choice. If its transmitting on the next pass later ill use something more suitable.
I received this image around 9pm local time here in Laos. Using a homebrew 5 element Yagi, SDR dongle, Black Cat SSTV software.
Hi Simon,
Same image here over Europe.
2024-05-04 19:01 utc SSTV Margerita Popova (8)
Unrelated, but as I was listening for Nanozond-1 (57190) TM bursts on 437.000 MHz this morning (0215 UTC), it sent a TM burst and then sent a Robot 72 image
I donβt think that this sending of SSTV images has been announced.
Perhaps itβs still from Sputnix Cosmonautics Day Radio Quest.
