2024-10-06 09:27 UTC
2024-10-06 11:19UTC
2024-10-06 11:22UTC
UmKA-1 over Brazil ![]()
2024-10-06 12:53UTC
2024-10-06 12:56UTC
With max elevation of 9.8 degrees for my QTH her in Brazil ![]()
07/10/24
09:16 UTC
Jomjom79
2024-10-07 12:43UTC
2024-10-07 12:45UTC
2024-10-07 12:47UTC
Pass with max elevation of 13.3 degrees to my QTH in Brazil ![]()
2024-10-08 00:29UTC
2024-10-08 00:31UTC
2024-10-08 00:33UTC
2024-10-08 00:35UTC
All passes were low at my location. I did receive 3 images this morning, but poor quality. I’m using an Arrow 5 2m/70m yagi, but without a rotator - so the antenna is fixed directly upwards,which is far from ideal,
I need an antenna rotator! Can anyone suggest a ‘cheap’ az/el rotator solution for my lightweight antenna? Thanks.
In this repo: GitHub - YohanHadji/SuperAntennaz: SuperAntennaz is an Antenna Rotator for Satellite Tracking.
You may try to get your hands on a used SARCTRAC.
They are no longer built due to component supply problems.
Last 2 images received. Orbit 7056. Over Madrid, Spain
After the image with the mission logo, the satellite stopped SSTV transmissions
On October 19, 2024, the Korolev Scientific and Engineering Lyceum celebrates its 35th anniversary. At the request of the Lyceum students, the UMKA-1 (RS40S) spacecraft has been used to broadcast images in SSTV format.
SSTV broadcast schedule:
- Transmission start: October 18, 2024 at 16:55 UTC.
- Transmission end: October 19, 2024 at 09:05 UTC.
Format – SSTV Robot 36
Interval between transmissions 150 seconds (can be adjusted later).
Frequency of the MKA “UMKA-1 (RS40S)”
- 437.625 MHz
See the post made on the r4uab website HERE
Immediately after the SSTV broadcast on October 19, UMKA-1 will take part in the “space race”; the conditions for participation can be read in the topic.
In addition, the UMKA telescope satellite team will send a special eQSL card dedicated to this event.
To receive it, you must send an application by email:
Application form:
Call sign (if you have one)
Name
Surname
The code word you accepted. (For example RACE:T9!rt2rA)
Reception time in UTC.
Date.
QTH-loc.
Applications are accepted from October 19 to 21.
The eQSL is expected to be sent out in early November.
2024-10-18 18:29UTC
2024-10-18 18:29UTC
2024-10-18 18:32UTC
18.10.24 - 18:32UTC
Jomjom79
Was the 18:29 transmission in a B/W mode? I got the same picture just after 18:30 and that was in color.
Jomjom79
Yes, it was in B/W.
2024-10-18 20:02UTC
2024-10-18_20.07.05 UTC
18.10.24 -
20:06UTC. Strongest signal i have ever had from Umka 1!
20:10UTC. Just touching the coast of Greenland.
Jomjom79
