bali
December 6, 2025, 5:47am
41
julianharbeck:
87: TmGps
102: ObcTemperatures_TB
131: TmAocsStateEstimationA
143: TmAocsStateControl
169: SolarPanel_TB
177: Pcu_v2
178: Battery_v2
21: StdTmOBC_v3
trying decode using gr_satellites and get this data:
Summary
-> Packet from 4k8 FSK downlink
Container:
control = Container:
message_type = (enum) regular 1
num_blocks = 31
address = (enum) gs 0
sub_address = (enum) broadcast 3
ack = False
baud = (enum) baud_4k8 0
callsign = u'DP0TBN' (total 6)
callsign_crc = 0x15C0
transfer_frame = b'\x14\x99(}\x00\x11\x110\xc6\x0e\x1a\x05N\x00\x0fL,$&"\xb1\x1f"<`(\x9a\x88\xaf\xfb\x12\xd8(\x00\x8bh\x04\xceO\xdd1V\xdc\x8c\xbe\rI\x87\xb3\xddR\t\x0c\x97\xcc\xe0{\x05eD!\x12\x0bs\xad\xf1\xbb\x8f\xc2.\x1f\'I\\A\xac\x82\x19\x10\x0b\xf5\xf3\x9b\x00\xd7;\x19\xf3\xdf\xc5\xed\xd6\xa9\xed\x1b\xban@a\xb9f(5hw\x05\xac\x00\x8b\xccZ\xd3\x90K\x00j:\xcfj\x0b\xac24J.6\x95\x91F\x10\xce\x19Z\x8b\x93\x97\xcc\xdd\xd0\xfc\xb7py\xd8\xc6\xa3\xf3\x9feb\xfd\xf2b,\xcaO\x8e\xd5V\x90\x19\xa1\xec\xf6\x14\x87\x19\xab\xf9\x03\x90\xb5L&\x1a\xfdJmh\xa8%\xe2b\xdd\xe9Fr\xd1\xc7\xa6\xda\xe7\x0c\x02\xb3\x0b9\x92\xa0\x96\x9b\xc8Y\x921=H$&\xee\x809\xac\xc6$s\xd7c\x9a\xa7V\xb4\x83F\x8ep\xfd\r\xef\x1ao\xdfL&\xdb\xd7\x1f\'\x13\xbf\x9a\x9c\x88\xa0\x9da\x16&\xdc\x16\xd0\x0c\xcc,bi[t\xc4\xfa\xac\x11\xc5\'\xa5ZG\xc4p\xbe\x9a\xd0\x94\x9a\xa6\xc8hPd\x7f\x8e&rC\x1d\x97\xbf*\x1c\xba\xb3\xbe\x9e\xfc\n\xe6\x8e\x04\xc9\xc6`\xb1e\x1a\xd4\'\xc3@\x89\xdcv\xe0\x97\xd9,!^XL\xe7\xa92.!\xc5\xca\xa6\xc6,\x9a\xdcVDj\xb9:9\xb6\xa9\xfc\x02\xcd \xe2]B\x16\x83\xa02\x9do\xcf5T\xcd\x90v"|hZ\x0c\xe0\x9b\xb2\xe0\xa2@\xb4\x1e$q\x9e\x81\xa4\xeb\xe5\xa2\xbd\xae\x1dj\x9e\xb3\xcanFm\x0c\xc0*\xbc_\xfd\x08\xa5\xc9\xad*\x82E\xc1\xf8N\xef"\x03n!\xf7\xde\x1eZ+\x8d\x14\x89\x84\xeeWJ\xc1\x05Xh\xa11J\x16\x04i\x07\x85\xac\xfc\xbc\xee\x80\x11\x85\xa932I\x8e\x0c\x0f\xf5\xa6h\xafI@\xf6V\x81v\x97\xfd?\xb4\xd6\x18B\xce\xa0\xd0\xb2{f\x8d\xcf=\x06Bc\xa6\x00\xe9Y\xd4e\xf9\x80U\noI\x19\xba\x01H\xec\x817\\\xdac\xd4\x1c\x06"\xbb\xe96\xf4\xcf1\xd4\xffp\xf7\x82\x19k&&]\x9fy\xbd\x04Q\x18\x8e|\xe2+\'\xb5`s8\x06\xdev\xe8\xd4\x17\xa0\x93@-;\x97\x1d\xb4\xcc\x85\xfe\x8bFj\xb50\xc7\x15\xa3\xec\x05Bn5tl\xebdY\x83F\xb6\xc6\xa7\xc8L' (total 576)
reserved0 = b'\xaa' (total 1)
error_marker = b'\xff\xff\xff\xff' (total 4)
reserved1 = b'\xbb' (total 1)
any script to translate this data into telemetry, or maybe online dashboard?
Sorry for the late reply. Awesome that you were able to decode so many frames. We have a document the describes the telemetry format and source packets, but it is outdated as a lot of source packets now have a newer version:
TechnoSat_TUBIN_Telemetry_Format.ods
@kerel also asked about something similar recently and a colleague created the following document, a bit different format:
TUBiX20_Telemetry_Format.zip (78.4 KB)
You should be able to get all needed information out of it, but I know it is not very convenient. I would love to have a kaitai, then we could also decode the telemetry in SatNOGS DB directly, but no one had time for that yet. Maybe after the re-entry? I think @kerel wrote a small script to handle that, maybe he is open to share it?
I updated the first message in this thread with additional information about:
Current re-entry prediction by GSSAC: 2025-12-16 10:09:02 (UTC) ± 30 h
Modulation and decoders
Framing of telemetry
How we will distribute our TLEs
SiDS server
QSL cards
sv2hwm
December 11, 2025, 6:34pm
45
2025-12-11T17:58z - Just one frame decoded and uploaded to both SatNOGS and TU-Berlin databases, at 7.9° max el. in Greece.
dl7ndr
December 12, 2025, 5:45am
46
2025-12-12 05:2x UTC
23 packets fully decoded at max. 27° el. at 237 km.
The other half decoded only partially due to fading.
Upped to SatNOGS and TU-Berlin.
sv2hwm
December 12, 2025, 7:12pm
47
2025-12-12T17:44z rx in Greece.
fredy
December 14, 2025, 9:24am
48
Updated TLE based on space-track.org latest TLE and Network observations:
TUBIN
1 48900U 21059X 25348.36622942 .00000000 00000-0 80389-3 0 08
2 48900 97.6632 177.1517 0005024 268.7256 18.2698 16.27508467 02
tubin_348_v1.dat (1.4 KB)
sites.txt (11.9 KB)
fredy
December 14, 2025, 10:27am
49
A little more accurate calculated TLE:
TUBIN
1 48900U 21059X 25348.36622943 .00000000 00000-0 83013-3 0 06
2 48900 97.6632 177.1676 0005024 122.6586 164.3852 16.27229293 04
fredy
December 14, 2025, 4:16pm
50
TLE update:
TUBIN
1 48900U 21059X 25348.56908512 .00000000 00000-0 69822-3 0 09
2 48900 97.6632 177.4656 0005024 122.6586 272.6431 16.29025490 06
sites.txt (11.9 KB)
tubin_348_v4.dat (1.9 KB)
There is also a new TLE from space-track.org but it has started to deviate.
sv2hwm
December 14, 2025, 5:35pm
51
2025-12-14T17:03z rx in Greece with manual Doppler correction.
dh1ok
December 14, 2025, 5:46pm
52
Please, is there a way to download the right Soundmodem for Technosat 4800bd here? I can’t find it online….
PE0SAT
December 14, 2025, 5:55pm
53
Here the link for the HS Soundmodem TechnoSat 4800
This seems to be an older version, if someone has a more recent please share this release.
fredy
December 14, 2025, 6:04pm
54
One more TLE update:
TUBIN
1 48900U 21059X 25348.70806518 .00000000 00000-0 69845-3 0 03
2 48900 97.6632 177.6677 0005024 122.6586 6.9388 16.29422271 08
tubin_348_v5.dat (2.1 KB)
sites.txt (12.0 KB)
Worked perfect, according to our calculations the offset to GPS was 0.3 seconds, many thanks
dh1ok
December 14, 2025, 6:41pm
57
So sad to say. It was a perfect pass over JN48 but the Soundmodem (Technosat 4800bd) didn’t encode a byte here. Once i got a “undecoded blocks” messge from Soundmodem and that was all. There must be something wrong in my setup here.
PE0SAT
December 14, 2025, 6:48pm
58
Did you create and IQ file so we can try again?
dh1ok
December 14, 2025, 7:01pm
59
Hi Jan,
gladly i have the complete pass in the baseband recorded. And after a restart of the soundmodem, i could decode the blocks without errors.
Also i get the blocks in GetKISS
but i am not sure, if the TU received my sended blocks, because i didn’t receive a HTTP OK
EU1SAT
December 14, 2025, 7:07pm
60
dl7ndr
December 14, 2025, 7:13pm
61
2025-12-14 18:2x UTC
21 fully decoded packets uploaded to SatNOGS and TU-Berlin.
