Yes, I received BDSat! Doppler measurement on the CW part and the previous measurement:
Fitting for MA and MM gives a good fit. Overlaying this new TLE on the last measurement:
Please ignore, the noise signal in the bottom of the picture.
The fitted, renumbered, propagated TLE:
BDSat
1 99409U 22033H 22094.29377315 .00000000 00000-0 45608-2 0 03
2 99409 97.3913 177.1008 0012847 191.3780 179.9186 15.21934660000008
# 20220402.85-20220403.91, 79 measurements, 0.029 kHz rms
Thanks again for switching on the CW beacon! That is really helpful in doing accurate doppler measurements! I hope this new TLE will help your mission! And congrats to the whole team!! @ok2pnq @marcelfr
fredy
April 4, 2022, 7:46am
42
TLE set is now updated on both DB and Network. Thank you @EelkeVisser
K4KDR
April 5, 2022, 2:05am
43
Have there been any reports at all of either the 2m or 70cm digipeater being active on BDSat?
-Scott, K4KDR
PE0SAT
April 5, 2022, 8:32am
44
Good day Scott,
No I haven’t but up in this topic I see a remark that it should be active on “both frequencies”
marcelfr Digipeater is active on both frequencies
K4KDR
April 5, 2022, 2:16pm
45
Thank you!
I’ve tried both on multiple passes but no luck so far.
-Scott
I noticed that the TLE of BDSat started to deviate. I received a few CW points in observation: SatNOGS Network - Observation 5730738
Using the artifacts viewer, that is under current development, I could extract some STRF points:
Fitting the previous TLE for MA and MM showed high residuals. Apparently the other parameters are not good anymore. As experiment I constructed a circular orbit that fitted nicely and gave a low residual. The inclination angle and the ascending node are slightly different. I did a few checks with ikhnos of other observations, and it looks like an improvement. Let’s try this new TLE for a while:
BDSat circular fit
1 99409U 22033H 22094.40040600 .00000000 00000-0 50000-4 0 04
2 99409 97.1888 176.8987 0001000 0.0000 234.9049 15.21746238000001
# 20220402.85-20220405.95, 89 measurements, 0.037 kHz rms
fredy
April 6, 2022, 1:05pm
47
TLE have been updated on both Network and DB. Thank you @EelkeVisser
Also we have some updated TLE by @PE0SAT for AlfaCrux.
ALFACRUX
1 99408U 22093.60969907 .00000000 00000-0 46655-2 0 03
2 99408 97.3912 176.4241 0008790 169.7998 42.3582 15.20359149 04
Hi guys, I have TLE update for BDSat
BDSat-Spacemanic
1 99409U 22033H 22093.49516635 +.00000000 00000-0 10000-4 0 04
2 99409 97.3875 176.3102 0011024 264.8703 51.9521 15.21421253000009
fredy
April 6, 2022, 4:58pm
49
31 TLE sets from spacetrack, still in TBA mode (to be assigned):
0 TBA - TO BE ASSIGNED
1 52157U 22033A 22096.54630064 .00001412 00000-0 22083-3 0 9993
2 52157 97.9486 179.7808 0012187 237.7630 122.2398 14.74261033 729
1 52158U 22033B 22096.54450514 .00001817 00000-0 27853-3 0 9993
2 52158 97.9496 179.7840 0011588 249.5963 110.4002 14.74808729 721
1 52159U 22033C 22096.54253174 .00000412 00000-0 68603-4 0 9996
2 52159 97.9512 179.7873 0009354 264.9451 95.0691 14.75089108 723
1 52160U 22033D 22096.53234950 .00010734 00000-0 49737-3 0 9992
2 52160 97.3895 179.2892 0008884 281.8025 78.2214 15.20229354 747
1 52161U 22033E 22096.53210818 .00006234 00000-0 28994-3 0 9992
2 52161 97.3882 179.2870 0008629 278.1529 81.8727 15.20281352 740
1 52162U 22033F 22096.53045280 .00005516 00000-0 25306-3 0 9998
2 52162 97.3873 179.2859 0009112 260.1133 99.9074 15.20802455 746
1 52163U 22033G 22096.53057184 .00003744 00000-0 17303-3 0 9994
2 52163 97.3875 179.2868 0009074 260.9749 99.0460 15.20754965 749
1 52164U 22033H 22096.46446463 .00015641 00000-0 70852-3 0 9996
2 52164 97.3825 179.2176 0008539 266.5502 93.4757 15.20919723 732
1 52165U 22033J 22096.53054619 .00010781 00000-0 49136-3 0 9994
2 52165 97.3877 179.2896 0009190 264.8888 95.1298 15.20794776 740
1 52166U 22033K 22096.53035813 .00016408 00000-0 74354-3 0 9992
2 52166 97.3846 179.2835 0010022 256.8735 103.1382 15.20884555 747
1 52167U 22033L 22096.53075388 .00011033 00000-0 50375-3 0 9990
2 52167 97.3872 179.2873 0008780 263.4659 96.5578 15.20729899 747
1 52168U 22033M 22096.53116803 .00007752 00000-0 35653-3 0 9994
2 52168 97.3859 179.2841 0008343 266.8875 93.1406 15.20587342 748
1 52169U 22033N 22096.52924402 .00008140 00000-0 36739-3 0 9994
2 52169 97.3876 179.2927 0010941 263.3221 96.6769 15.21198840 749
1 52170U 22033P 22096.52917483 .00005598 00000-0 25364-3 0 9993
2 52170 97.3872 179.2884 0010823 257.9002 102.1021 15.21206460 746
1 52171U 22033Q 22096.52883261 .00008270 00000-0 37172-3 0 9990
2 52171 97.3878 179.2913 0011315 257.8014 102.1954 15.21329284 740
1 52172U 22033R 22096.52850548 .00008628 00000-0 38653-3 0 9995
2 52172 97.3862 179.2883 0011145 252.7321 107.2696 15.21434260 746
1 52173U 22033S 22096.46223032 .00010858 00000-0 48281-3 0 9997
2 52173 97.3911 179.2336 0012456 255.5732 104.4122 15.21609665 733
1 52174U 22033T 22096.52749169 .00011436 00000-0 50596-3 0 9994
2 52174 97.3865 179.2904 0012320 249.5139 110.4775 15.21768608 742
1 52175U 22033U 22096.46166330 .00011561 00000-0 51098-3 0 9998
2 52175 97.3893 179.2313 0012787 252.0859 107.8983 15.21794711 737
1 52176U 22033V 22093.49206260 .02349791 00000-0 32232+0 0 9992
2 52176 97.9184 176.8384 0008622 278.3680 81.5426 14.74328277 281
1 52177U 22033W 22095.59609497 -.00002334 00000-0 -34534-3 0 9995
2 52177 97.9498 178.8481 0012081 242.5865 117.4127 14.74249290 590
1 52178U 22033X 22096.53111096 .00007563 00000-0 34772-3 0 9995
2 52178 97.3886 179.2902 0008952 269.3021 90.7189 15.20604451 724
1 52179U 22033Y 22096.39943747 .00322807 00000-0 14003-1 0 9990
2 52179 97.3806 179.1569 0009432 279.0195 81.0484 15.20832240 718
1 52180U 22033Z 22095.18886340 .00012328 00000-0 18663-2 0 9994
2 52180 97.9490 178.4548 0012640 233.1109 126.9106 14.74274467 534
1 52181U 22033AA 22096.46524560 .00081071 00000-0 36476-2 0 9993
2 52181 97.3837 179.2163 0007830 268.6435 91.4101 15.20735870 720
1 52182U 22033AB 22096.07044226 .00092329 00000-0 41553-2 0 9997
2 52182 97.3847 178.8366 0007762 267.2010 92.8212 15.20670899 660
1 52183U 22033AC 22095.67557877 .00015100 00000-0 68970-3 0 9999
2 52183 97.3843 178.4439 0008182 270.5644 89.4654 15.20647570 595
1 52184U 22033AD 22096.53082878 .00007622 00000-0 34952-3 0 9993
2 52184 97.3871 179.2863 0008674 263.5766 96.4482 15.20693878 746
1 52185U 22033AE 22094.91738048 -.00009334 00000-0 -14056-2 0 9997
2 52185 97.9490 178.1810 0012050 238.1960 121.8142 14.74238535 498
1 52186U 22033AF 22096.20694181 .00000449 00000-0 75457-4 0 9991
2 52186 97.9492 179.4494 0012251 232.6051 127.4057 14.74256545 685
1 52187U 22033AG 22096.27481370 -.00001343 00000-0 -19541-3 0 9990
2 52187 97.9442 179.5137 0012148 236.5843 123.4253 14.74251887 692
By @EelkeVisser and @PE0SAT analysis:
BDSat best fit for now is OBJECT U(52175)
AlphaCrux best fit for now is OBJECT D(52160)
EDIT: Both NORAD IDs have been assigned to be followed for these satellites. Will wait for the TLE assignment and some more separation before any final identification. We need also to make sure that these are all the objects that have been deployed and that we don’t expect any more, if anyone has this information please let us know.
Hi guys,
could you please schedule some VHF beacon obs for BDSat? We would need some info about the VHF TRX from the beacon (received packets).
EU1SAT
April 13, 2022, 9:25pm
51
Temporary TLE for PlantSat
PLANTSAT
1 99407U 22033N 22102.51502921 .00007168 00000-0 32308-3 0 9992
2 99407 97.3879 185.1667 0011175 239.6553 118.2068 15.21285803 1659
Obtained by modifying #52169 TLE in order to meet data 2 days of observations.
EU1SAT
April 14, 2022, 6:59am
52
It would be necessary to put in the base of Suchai2 and Suchai3 satellites. Some information here:
fredy
April 14, 2022, 10:38am
53
I’ve just updated the TLE with this set. Thanks!
fredy
April 14, 2022, 10:39am
54
Feel free to create suggestions for these satellites in DB.
PE0SAT
April 14, 2022, 5:04pm
55
Done, both satellites added to the DB and needs moderation.
fredy
April 14, 2022, 6:41pm
56
The entries have been reviewed. For scheduling we will need transmitters and TLE sets.
PE0SAT
April 14, 2022, 6:54pm
57
Transmitters have been added
EU1SAT
April 14, 2022, 9:07pm
58
Adjusted on today’s data
PLANTSAT
1 99407U 22033N 22103.83054567 .00005539 00000-0 25032-3 0 9992
2 99407 97.3880 186.4576 0011267 234.5277 123.3938 15.21297599 1853
fredy
April 14, 2022, 10:12pm
59
Propagated and used in DB and Network. Thank @EU1SAT !
fredy
April 16, 2022, 6:49pm
60
BDSat is now identified as OBJECT U(52175) , here are the results of ikhnos on observation 5797290 .
