Launch targeting April 1, 2022 on Falcon 9 (booster 1061.7) from Cape Canaveral Space Force Station SLC-40 to SSO. Fairing recovery is expected from the water.
On this flight are 40 spacecraft, including CubeSats, Microsats, picosats, hosted payloads, and an orbital transfer vehicle.
Going over the list, I have found a satellite that is coordinated.
I found PlantSat https://plantsat.spel.cl/ which is on the list and as a request for coordination. Have not been accepted or declined and also they have not posted any freq info. IARU Sat Coordinator
Also feel free to join the other communication channels like the matrix channel that will help you to communicate more directly with the community.
Finally if you have any info for preliminary TLE let us know here. Probably there will be produced some by celestrak as in the previous transporter launches but until now I don’t see anything.
For adding the rest of the satellites for this launch to anyone who wants to help, please either open an issue in gitlab or suggest directly the satellites in DB by being logged in and hit the edit button in the satellites page. For temporary NORAD IDs please use values from 99408 and bellow.
April 1: 40% GO w/ primary concerns being cumulus/thick clouds, electric field rule
24hr delay: 40% GO w/ concerns being the same as the 1st w/ low-mod upper lvl wind risk
72hr delay: 70% GO w/ primary concern being cumulus clouds
April 1: 30% GO w/ primary concerns being cumulus/thick clouds, electric field rule w/ solar activity low-mod
24hr delay: 50% GO w/ concerns being the same as the 1st w/ low-mod upper lvl wind risk and low-mod solar activity
72hr delay: 80% GO w/ primary concern being cumulus clouds
BDSat is now available for scheduling in Network. Reminder for station owners, as the TLE set is preliminary don’t schedule to far in the future as the TLE may change. Also use the custom option in observations/new page and select horizon to 0, this will allow to schedule the whole pass increasing the chances to receive the satellite if passes earlier or later than the expected.
One more reminder, if you are interested on any other of the payloads of this launch, either open an issue in gitlab or suggest directly the satellites in DB by being logged in and hit the edit button in the satellites page. For temporary NORAD IDs please use values from 99408 and bellow.
A distinct lack of detailed information on that site. e.g. Telemetry formats, exact details on framing, which of the multiple modulations listed is actually going to be used initially…
