@K4KDR The ones shared are missing the checksum.
Below the TLE including the checksum.
1 88077U 26 95.63710272 +.00011343 +00000+0 +58215-3 0 00154
2 88077 97.4446 55.1862 0005140 338.8950 21.2070 15.16674997000938
From analysis on the latest Network’s observations with ikhnos tool, it seems that 88049, 88075 (best fit in my opinion and the one chosen to be followed for SAL-E in DB) or 88123 is fitting better, below you can see the red line showing the expected line that signal should follow according to the used TLE set and how in 88049, 88075, 88123 cases fits much better than 88077 and 88067:
Hello Fredy,
Thank you for making the list! Our team also believes that 88049 corresponds to our T.MicroSat-2.
We updated the TLE to the one below and were able to read telemetry pretty well.
T.Microsat-2
1 98379U 26096.49449200 .00007590 00000-0 39028-3 0 112
2 98379 97.4521 56.0336 0004591 327.8422 32.2531 15.16726503 1065
Updated “Unknown -1” to match the mission’s name - “ARQSAT-1”, also known as “FEMTO-1” on the SpaceX listing.
We are still trying to identify which one is EMISAR. We currently suspect it’s 88060, but we don’t have any confirmation.
@fredy: Would it be possible to schedule some observations with an additional 2-3 minutes before and after the passes, to try and observe the rise/dawn time? Unfortunately we’re not able to have reliable communication with our satellite at this time. Thank you!
Please share tle for 88060. Thanks. bob
The official one from SpaceTrack is:
1 88060U 26 97.87264666 +.00006529 +00000+0 +32363-3 0 0017
2 88060 97.4516 57.4047 0001251 145.9965 214.1349 15.1807835800127
To make it fully valid, I modified it slightly (added a random launch designator + checksums) to get this:
88060
1 88060U 26001A 26097.87264666 +.00006529 00000-0 +32363-3 0 00173
2 88060 97.4516 57.4047 0001251 145.9965 214.1349 15.18078358001271
Thanks @emisarrise I’ve added the TLE in DB with changed NORAD ID to follow the one we use in DB:
EMISAR
1 98362U 26001A 26097.87264666 +.00006529 00000-0 +32363-3 0 00179
2 98362 97.4516 57.4047 0001251 145.9965 214.1349 15.18078358001277
Thanks @emisarrise
PEAKSAT updated TLE based on analyst list by space-track.org:
PEAKSAT
1 98378U 26098.99014095 +.00006068 +00000+0 +29658-3 0 00293
2 98378 97.4490 58.5089 0003608 124.3087 235.8490 15.18592339001443
Here is one more batch of checks on space-track analyst list:
| Satellite | NORAD ID from Analyst List | Other Possible |
| PEAKSAT | 88032 | - |
| PARUS-6U1 | 88061 | 88072(unlikely),88073(unlikely),88084(unlikely) |
| SAL-E | 88075 | 88049,88084(unlikely) |
| DISCO-2 | 88047 | - |
| HADES-SA | 88062 | 88083(unlikely) |
| JACK-002 | 88033 | - |
And here are the TLE with changed to use the temporary NORAD IDs we use in DB:
PEAKSAT
JACK-002
1 98365U 26098.99048500 +.00005812 +00000+0 +28472-3 0 00241
2 98365 97.4511 58.5102 0003410 125.9515 234.2036 15.18532858001442
DISCO-2
1 98381U 26098.99347596 +.00006614 +00000+0 +32789-3 0 00210
2 98381 97.4548 58.5112 0001343 171.1799 188.9459 15.18067769001449
PARUS-6U1
1 98392U 26099.00081678 +.00003536 +00000+0 +18312-3 0 00217
2 98392 97.4465 58.4918 0004054 339.2528 20.8540 15.16846094001440
HADES-SA
1 98380U 26099.06814649 +.00015814 +00000+0 +80663-3 0 00199
2 98380 97.4362 58.5460 0005592 334.5267 25.5690 15.16810518001442
SAL-E
1 98382U 26099.00153764 +.00005999 +00000+0 +30880-3 0 00222
2 98382 97.4426 58.4875 0004671 332.9853 27.1137 15.16776948001446
Hello, we have TLE update for T.MicroSat-2. Could you please help update it to DB? Thanks!
T.Microsat-2
1 98379U 26100.05701029 +.00005150 +00000+0 26574-3 0 00212
2 98379 97.4517 59.5347 0004206 312.2756 47.8121 15.16764430001609
and community reception through networks such as SatNOGS.
hello @tron_satellite . can you share a script to decode and convert your raw hex data into usefull data for community to learn?
im wondering what inside. the signal is very good.
Update BLACK KITE-2 TLE
BLACKKITE-2
1 88092U 26102.13048642 .00000000 00000-0 43958-3 0 01
2 88092 97.7492 63.8867 0003570 110.8291 17.1074 14.92229783 09
# 20260412.13-20260412.13, 15 measurements, 0.284 kHz rms
PeakSat TLE update from space-track.org analyst list changed to follow the temporary NORAD ID we use in DB:
PEAKSAT
1 98378U 26104.12963830 +.00004204 +00000+0 +20619-3 0 00373
2 98378 97.4492 63.5723 0003897 114.6467 245.5173 15.18652635002229
Hi @fredy,
Thanks for tracking these! Regarding PARUS-6U1, I’m from the team, and our recent orbital analysis show that it actually matches NORAD ID 88073 better than 88061.
Could you please help switch the tracking to 88073 and update the DB with the following TLE?
PARUS-6U1
1 88073U 26104.14685082 +.00003585 +00000+0 +18563-3 0 0030
2 88073 97.4499 63.5510 0003837 295.5561 64.5275 15.1684655000222
Thanks for your help!
Thanks for the TLE @eric_huang here is the same with the temporary NORAD ID we use in DB:
PARUS-6U1
1 98392U 26104.14685082 +.00003585 +00000+0 +18563-3 0 00300
2 98392 97.4499 63.5510 0003837 295.5561 64.5275 15.16846550002225
And also an update for PEAKSAT:
PEAKSAT
1 98378U 26104.92031550 +.00004048 +00000+0 +19860-3 0 00389
2 98378 97.4494 64.3514 0003935 113.0634 247.1015 15.18658552002340
We now have a list of TLE in space-track.org:
0 OBJECT A
1 68416U 26067A 26104.12963830 .00004204 00000-0 20619-3 0 9992
2 68416 97.4492 63.5723 0003897 114.6467 245.5173 15.18652635 2229
0 OBJECT B
1 68417U 26067B 26104.13018993 .00003854 00000-0 18963-3 0 9994
2 68417 97.4513 63.5748 0003724 116.5386 243.6230 15.18589786 2220
0 OBJECT C
1 68418U 26067C 26104.13080777 .00002924 00000-0 14505-3 0 9999
2 68418 97.4531 63.5776 0003545 128.9478 231.2072 15.18499519 2223
0 OBJECT D
1 68419U 26067D 26104.13069388 .00001777 00000-0 89370-4 0 9993
2 68419 97.4490 63.5703 0003341 108.0089 252.1510 15.18515636 2227
0 OBJECT E
1 68420U 26067E 26104.13061050 .00005787 00000-0 28301-3 0 9994
2 68420 97.4433 63.5619 0003582 97.4122 262.7519 15.18592725 2228
0 OBJECT F
1 68421U 26067F 26104.13233643 .00002710 00000-0 13532-3 0 9997
2 68421 97.4464 63.5641 0002883 98.4001 261.7560 15.18330052 2226
0 OBJECT G
1 68422U 26067G 26104.13265363 .00002336 00000-0 11720-3 0 9993
2 68422 97.4431 63.5576 0002812 94.5078 265.6477 15.18299949 2220
0 OBJECT H
1 68423U 26067H 26104.13319345 .00002796 00000-0 13986-3 0 9990
2 68423 97.4450 63.5604 0002491 104.0414 256.1097 15.18250080 2224
0 OBJECT J
1 68424U 26067J 26104.13828826 .00003234 00000-0 16363-3 0 9990
2 68424 97.4469 63.5565 0000053 204.7381 155.3850 15.17731330 2222
0 OBJECT K
1 68425U 26067K 26104.00219541 .00003144 00000-0 15723-3 0 9994
2 68425 97.4536 63.4441 0002115 136.2398 223.9004 15.18166414 2205
0 OBJECT L
1 68426U 26067L 26104.13294854 .00006471 00000-0 31809-3 0 9998
2 68426 97.4494 63.5689 0002261 138.3566 221.7841 15.18374642 2227
0 OBJECT M
1 68427U 26067M 26104.13342092 .00005266 00000-0 26009-3 0 9994
2 68427 97.4495 63.5685 0002125 137.9931 222.1466 15.18289784 2225
0 OBJECT N
1 68428U 26067N 26104.13527134 .00002475 00000-0 12496-3 0 9991
2 68428 97.4518 63.5700 0001533 148.6556 211.4770 15.18024978 2225
0 OBJECT P
1 68429U 26067P 26104.13620262 .00006029 00000-0 29947-3 0 9996
2 68429 97.4463 63.5565 0000922 197.7744 162.3458 15.18039562 2221
0 OBJECT Q
1 68430U 26067Q 26104.13402597 .00004671 00000-0 23163-3 0 9992
2 68430 97.4450 63.5596 0001915 106.4163 253.7282 15.18211472 2220
0 OBJECT R
1 68431U 26067R 26104.13472281 .00004701 00000-0 23359-3 0 9991
2 68431 97.4549 63.5761 0001985 159.0525 201.0791 15.18139933 2229
0 OBJECT S
1 68432U 26067S 26104.13672320 .00003309 00000-0 16656-3 0 9993
2 68432 97.4504 63.5668 0000993 192.3900 167.7310 15.17896664 2227
0 OBJECT T
1 68433U 26067T 26104.14721627 .00003297 00000-0 17122-3 0 9995
2 68433 97.4520 63.5545 0003972 292.4049 67.6763 15.16795244 2227
0 OBJECT U
1 68434U 26067U 26104.13401380 .00002513 00000-0 12638-3 0 9993
2 68434 97.4529 63.5730 0002133 139.3021 220.8372 15.18153651 2221
0 OBJECT V
1 68435U 26067V 26104.13912787 .00001988 00000-0 10224-3 0 9996
2 68435 97.4496 63.5618 0000677 267.3808 92.7348 15.17606330 2221
0 OBJECT W
1 68436U 26067W 26104.13972951 .00002062 00000-0 10683-3 0 9999
2 68436 97.4493 63.5606 0000665 272.2403 87.8754 15.17291439 2225
0 OBJECT X
1 68437U 26067X 26104.13733934 .00007899 00000-0 39204-3 0 9999
2 68437 97.4457 63.5539 0000309 215.2445 144.8768 15.17967799 2227
0 OBJECT Y
1 68438U 26067Y 26104.13751879 .00009887 00000-0 48952-3 0 9997
2 68438 97.4473 63.5581 0000717 260.0933 100.0220 15.17982976 2227
0 OBJECT Z
1 68439U 26067Z 26104.13911780 .00008661 00000-0 43169-3 0 9991
2 68439 97.4469 63.5552 0000595 344.0367 16.0848 15.17787042 2228
0 OBJECT AA
1 68440U 26067AA 26104.13871805 .00011772 00000-0 58389-3 0 9993
2 68440 97.4467 63.5552 0000571 343.7655 16.3560 15.17874801 2222
0 OBJECT AB
1 68441U 26067AB 26104.14127564 .00017581 00000-0 87299-3 0 9997
2 68441 97.4467 63.5509 0001313 346.5728 13.5470 15.17741518 2229
0 OBJECT AC
1 68442U 26067AC 26104.14435656 .00003324 00000-0 17111-3 0 9998
2 68442 97.4487 63.5525 0002715 307.3229 52.7757 15.17102452 2229
0 OBJECT AD
1 68443U 26067AD 26104.07893666 .00003226 00000-0 16647-3 0 9994
2 68443 97.4496 63.4887 0002998 310.2138 49.8833 15.17036860 2215
0 OBJECT AE
1 68444U 26067AE 26104.13440891 .00003332 00000-0 16654-3 0 9996
2 68444 97.4517 63.5713 0001839 141.6339 218.5026 15.18140700 2221
0 OBJECT AF
1 68445U 26067AF 26104.14626828 .00002861 00000-0 14866-3 0 9993
2 68445 97.4467 63.5459 0003582 316.4859 43.6091 15.16883264 2225
0 OBJECT AG
1 68446U 26067AG 26104.14754476 .00010917 00000-0 55598-3 0 9993
2 68446 97.4363 63.5285 0005085 311.4083 48.6713 15.16956596 2216
0 OBJECT AH
1 68447U 26067AH 26104.13552066 .00004408 00000-0 21982-3 0 9992
2 68447 97.4471 63.5612 0001241 125.4554 234.6795 15.18048210 2222
0 OBJECT AJ
1 68448U 26067AJ 26104.14200914 .00003684 00000-0 18636-3 0 9993
2 68448 97.4470 63.5518 0001784 331.2213 28.8922 15.17648278 2222
0 OBJECT AK
1 68449U 26067AK 26104.14347269 .00004380 00000-0 22363-3 0 9995
2 68449 97.4463 63.5490 0002380 320.9286 39.1776 15.17219477 2229
0 OBJECT AL
1 68450U 26067AL 26104.13654009 .00004332 00000-0 21675-3 0 9991
2 68450 97.4498 63.5653 0000862 158.3037 201.8233 15.17940895 2221
0 OBJECT AM
1 68451U 26067AM 26104.13596442 .00004407 00000-0 22003-3 0 9997
2 68451 97.4456 63.5575 0001049 120.8485 239.2852 15.18001697 2229
0 OBJECT AN
1 68452U 26067AN 26104.14295063 .00004337 00000-0 22115-3 0 9990
2 68452 97.4498 63.5571 0002168 308.1266 51.9771 15.17272830 2220
0 OBJECT AP
1 68453U 26067AP 26104.13673057 .00004296 00000-0 21511-3 0 9996
2 68453 97.4501 63.5659 0000865 176.2668 183.8572 15.17920780 2223
0 OBJECT AQ
1 68454U 26067AQ 26104.07974629 .00004468 00000-0 22958-3 0 9996
2 68454 97.4523 63.4931 0003529 297.1990 62.8883 15.16985062 2214
0 OBJECT AR
1 68455U 26067AR 26104.14693356 .00003122 00000-0 16217-3 0 9997
2 68455 97.4525 63.5558 0003929 294.3675 65.7148 15.16823117 2225
0 OBJECT AS
1 68456U 26067AS 26104.14685082 .00003585 00000-0 18563-3 0 9994
2 68456 97.4499 63.5510 0003837 295.5561 64.5275 15.16846550 2223
0 OBJECT AT
1 68457U 26067AT 26104.13360433 .00005750 00000-0 28374-3 0 9991
2 68457 97.4494 63.5681 0002017 138.4965 221.6423 15.18283651 2220
0 OBJECT AU
1 68458U 26067AU 26104.14716482 .00004845 00000-0 24962-3 0 9995
2 68458 97.4426 63.5383 0004156 309.6240 50.4626 15.16844999 2228
0 OBJECT AV
1 68459U 26067AV 26104.14772216 .00003824 00000-0 19822-3 0 9998
2 68459 97.4480 63.5467 0004231 296.0846 63.9952 15.16761079 2225
0 OBJECT AW
1 68460U 26067AW 26104.14757510 .00004570 00000-0 23596-3 0 9992
2 68460 97.4448 63.5418 0004289 302.0289 58.0528 15.16796021 2228
0 OBJECT AX
1 68461U 26067AX 26104.14277098 .00004359 00000-0 22211-3 0 9999
2 68461 97.4501 63.5583 0002118 311.3332 48.7719 15.17292500 2225
0 OBJECT AY
1 68462U 26067AY 26104.13738924 .00004307 00000-0 21606-3 0 9999
2 68462 97.4503 63.5660 0000811 202.3868 157.7331 15.17852373 2226
0 OBJECT AZ
1 68463U 26067AZ 26104.14265424 .00003869 00000-0 19754-3 0 9994
2 68463 97.4485 63.5548 0001967 318.2380 41.8703 15.17293752 2226
0 OBJECT BA
1 68464U 26067BA 26104.14270008 .00002939 00000-0 15100-3 0 9997
2 68464 97.4467 63.5503 0001970 332.1363 27.9765 15.17260578 2221
0 OBJECT BB
1 68465U 26067BB 26104.14279584 .00002032 00000-0 10551-3 0 9995
2 68465 97.4472 63.5513 0001916 328.7758 31.3361 15.17231654 2222
0 OBJECT BC
1 68466U 26067BC 26104.25002315 .00083601 00000-0 40992-2 0 9996
2 68466 97.4502 63.6764 0000985 192.2845 65.2682 15.17762560 2184
0 OBJECT BD
1 68467U 26067BD 26104.14640675 .00009888 00000-0 50253-3 0 9999
2 68467 97.4367 63.5304 0004457 314.6482 45.4388 15.17058500 2228
0 OBJECT BE
1 68468U 26067BE 26104.14890293 .00005410 00000-0 27964-3 0 9993
2 68468 97.4508 63.5497 0004762 285.6118 74.4589 15.16676952 2222
0 OBJECT BF
1 68469U 26067BF 26104.14226470 .00002043 00000-0 10590-3 0 9990
2 68469 97.4489 63.5560 0001772 316.8236 43.2859 15.17283859 2223
0 OBJECT BG
1 68470U 26067BG 26104.14926508 .00005191 00000-0 26875-3 0 9991
2 68470 97.4426 63.5364 0005144 301.0012 59.0715 15.16637828 2227
0 OBJECT BH
1 68471U 26067BH 26103.93002531 .00001490 00000-0 15645-3 0 9990
2 68471 97.7527 63.1796 0002035 264.0823 96.0163 14.90957127 2150
0 OBJECT BJ
1 68472U 26067BJ 26103.93093618 .00001561 00000-0 16411-3 0 9998
2 68472 97.7580 63.1841 0002869 244.9986 115.0934 14.90845854 2154
0 OBJECT BK
1 68473U 26067BK 26097.33335648 .00091047 00000-0 45462-2 0 9992
2 68473 97.4464 56.8557 0003027 348.9648 278.0336 15.17085369 2482
0 OBJECT BL
1 68474U 26067BL 26103.91718706 .00001756 00000-0 17747-3 0 9999
2 68474 97.7497 63.1931 0003939 93.2647 266.9022 14.92284797 2149
0 OBJECT BM
1 68475U 26067BM 26105.80910150 -.00000511 00000-0 -46147-4 0 9994
2 68475 97.7488 65.0188 0001989 273.3135 86.7856 14.91036486 1906
0 OBJECT BN
1 68476U 26067BN 26103.91743317 .00002113 00000-0 21248-3 0 9996
2 68476 97.7512 63.1938 0003913 104.3776 255.7877 14.92272762 2148
0 OBJECT BP
1 68477U 26067BP 26105.80899117 .00002542 00000-0 26253-3 0 9994
2 68477 97.7484 65.0197 0002330 269.6111 90.4840 14.91029729 1836
0 OBJECT BQ
1 68478U 26067BQ 26103.91940113 .00000166 00000-0 21841-4 0 9997
2 68478 97.7549 63.1956 0003141 114.6812 245.4734 14.92022325 2144
0 OBJECT BR
1 68479U 26067BR 26105.86401153 .00003322 00000-0 33241-3 0 9993
2 68479 97.7501 65.1032 0003076 94.7918 265.3652 14.92090196 2435
0 OBJECT BS
1 68480U 26067BS 26103.91480817 .00001933 00000-0 19361-3 0 9996
2 68480 97.7577 63.2047 0005354 112.7999 247.3786 14.92536438 2146
0 OBJECT BT
1 68481U 26067BT 26103.92013991 .00001268 00000-0 13069-3 0 9993
2 68481 97.7618 63.2025 0003468 140.7319 219.4152 14.91962819 2142
0 OBJECT BU
1 68482U 26067BU 26105.85901663 .00001944 00000-0 19467-3 0 9999
2 68482 97.7525 65.1138 0005086 94.4932 265.6868 14.92540366 2439
0 OBJECT BV
1 68483U 26067BV 26103.85014301 .00001056 00000-0 10889-3 0 9995
2 68483 97.7598 63.1378 0004401 123.5501 236.6139 14.92283725 2139
0 OBJECT BW
1 68484U 26067BW 26105.86667851 .00000642 00000-0 69092-4 0 9994
2 68484 97.7576 65.1102 0002523 128.9871 231.1572 14.91820185 2435
0 OBJECT BX
1 68485U 26067BX 26105.86586388 .00003340 00000-0 33522-3 0 9996
2 68485 97.7542 65.1050 0002424 119.0658 241.0803 14.91967357 2435
0 OBJECT BY
1 68486U 26067BY 26105.86722653 .00000283 00000-0 33586-4 0 9998
2 68486 97.7539 65.1036 0002032 118.5094 241.6330 14.91769087 2430
0 OBJECT BZ
1 68487U 26067BZ 26105.86270677 .00001595 00000-0 16200-3 0 9993
2 68487 97.7496 65.1046 0003431 90.6606 269.5006 14.92212167 2439
0 OBJECT CA
1 68488U 26067CA 26105.87036957 .00000231 00000-0 28582-4 0 9999
2 68488 97.7533 65.0982 0000837 123.2991 236.8308 14.91481297 2430
0 OBJECT CB
1 68489U 26067CB 26105.87284152 .00001277 00000-0 13388-3 0 9990
2 68489 97.7495 65.0895 0000495 306.7342 53.3831 14.91264794 2433
0 OBJECT CC
1 68490U 26067CC 26105.87193288 .00000570 00000-0 62700-4 0 9999
2 68490 97.7570 65.1022 0001289 187.6401 172.4798 14.91342813 2430
0 OBJECT CD
1 68491U 26067CD 26105.87468242 -.00000146 00000-0 -91616-5 0 9995
2 68491 97.7515 65.0914 0001421 255.9469 104.1592 14.91114877 2431
0 OBJECT CE
1 68492U 26067CE 26105.80829101 .00000953 00000-0 10180-3 0 9993
2 68492 97.7521 65.0248 0001732 257.9732 102.1292 14.91061226 2422
0 OBJECT CF
1 68493U 26067CF 26103.92852014 .00001713 00000-0 17837-3 0 9995
2 68493 97.7602 63.1902 0002469 221.8745 138.2285 14.91114555 2146
0 OBJECT CG
1 68494U 26067CG 26105.87159073 .00002101 00000-0 21613-3 0 9996
2 68494 97.7566 65.1023 0001165 181.3978 178.7237 14.91375552 2436
0 OBJECT CH
1 68495U 26067CH 26103.93297755 .00000450 00000-0 53487-4 0 9992
2 68495 97.7560 63.1781 0001892 193.5780 166.5387 14.89054368 2148
0 OBJECT CJ
1 68496U 26067CJ 26105.86561818 .00001112 00000-0 11544-3 0 9994
2 68496 97.7562 65.1097 0002808 121.1643 238.9851 14.91923233 2437
0 OBJECT CK
1 68497U 26067CK 26103.92084177 .00001609 00000-0 16464-3 0 9995
2 68497 97.7542 63.1928 0002476 118.3185 241.8284 14.91898012 2144
0 OBJECT CL
1 68498U 26067CL 26103.92746049 .00001270 00000-0 13332-3 0 9994
2 68498 97.7494 63.1790 0000851 295.8274 64.2857 14.91215242 2144
0 OBJECT CM
1 68499U 26067CM 26105.87140299 .00002153 00000-0 22125-3 0 9997
2 68499 97.7539 65.0981 0000499 140.1447 219.9808 14.91380919 2431
0 OBJECT CN
1 68500U 26067CN 26105.73694113 .00001326 00000-0 13824-3 0 9991
2 68500 97.7574 64.9721 0001199 172.4524 187.6713 14.91420095 2419
0 OBJECT CP
1 68501U 26067CP 26105.67227353 .00003807 00000-0 38844-3 0 9998
2 68501 97.7588 64.9041 0002004 211.8179 148.2918 14.91227302 2405
0 OBJECT CQ
1 68502U 26067CQ 26103.92481518 .00001537 00000-0 15914-3 0 9991
2 68502 97.7575 63.1921 0001242 169.7010 190.4235 14.91483961 2145
0 OBJECT CR
1 68503U 26067CR 26105.81144892 .00001022 00000-0 10968-3 0 9996
2 68503 97.7523 65.0213 0002864 260.2241 99.8654 14.90731848 2425
0 OBJECT CS
1 68504U 26067CS 26105.80050885 .00000398 00000-0 44988-4 0 9999
2 68504 97.7576 65.0433 0002275 139.2346 220.9044 14.91744424 2420
0 OBJECT CT
1 68505U 26067CT 26103.93332450 .00002476 00000-0 25848-3 0 9995
2 68505 97.7555 63.1783 0003733 255.6922 104.3882 14.90621545 2149
The TLE are already assigned, so we can start the identification process
PeakSat is now identified as 68416, here are the ikhnos evidence.
More identifications will follow in next posts.
Hi @fredy ,
Can you please update the TLE for EMISAR? We believe it’s 88043, (it could also be 88042). I used the TLEs from space-track:
EMISAR
1 98362U 26104.92428640 +.00005094 +00000+0 +25167-3 0 00347
2 98362 97.4497 64.3474 0002181 137.3796 222.7608 15.18297401002340
Thank you!
