CODEC2
HADES-SA over Brazil :brazil: around 18:11UTC
SSDV image I managed to receive:
CODEC2 audio I managed to receive:
Unfortunately, my reception wasn’t the best. Very cool bird :star_struck:
Awesome! I’ve now also exported a C2 file.
But I’m not sure how to use SSDV—when I open it with CMD, it doesn’t work
Depending on what version of SSDV you have, and what operating system, normally on linux it’s run with the ‘-d’ switch to decode a file:
I am currently using Windows 10 22H2 Professional Workstation Edition :smiling_face_with_tear:
Hi @K4KDR ,
I misunderstood and thought you borrowed the test binary file from the pull request.
It seems to be a framing issue, it has a ‘ character in front of the callsign.
Thanks so much! I had formatted the decodes pasted here earlier as a .KSS file since that is normally what the online parser uses. I’ll re-check that decode… there was a 2nd one posted as well, plus I could probably find some in the SatNogs observations by now. Thanks for the guidance!
I also had trouble with those decodes from earlier. I extracted the text from your posted screenshot and it decoded well.
I guess this is the stored image intended to be transmitted when no image has been taken with the on board camera. It was transmitted at 12:09 UTC shortly after the satellite was deployed. I managed to receive 34 from the 58 packets with my turnstile antenna from a 31 degrees pass.
hades_sa_image_000
Hi @fredy
The downlink frequency of the LUNA-2 is incorrect, must be 401.725. We has a suggestion on it.
At the moment, all the observations uses the incorrent frequency and all of them will definitely fail.
Could you please review.
The suggestion is approved and set to 401.725 MHz
HADES-SA
SAL-E ACTIVE and DEMODULATED!
1 Frame uploaded
JACK-002 ACTIVE and DEMODULATED!
47 Frames uploaded
I’ve been spot-checking the SatNogs observations all day not seeing anything from EMISAR. Just saw this one - it’s alive!!
https://network.satnogs.org/observations/13695255/
HADES-SA 01:10-01:20 UTC Got an SSDV picture (№ 224) and voice (inaudible) transmissions. Also some tlm frames
hades_sa.zip (160.2 KB)
archieved .wav
PARUS-6U1??? ACTIVE and DEMODULATED!
15 Frames uploaded
Post launch TLE from celestrak:
LUNA-2
1 71932C 26067A   26089.49717544 -.00020143  00000+0 -10413-2 0    04
2 71932  97.4415  49.1596 0006852   1.3378 337.6612 15.16338967    19
FEMTO-1
1 71924C 26067B   26089.49733053  .00007708  00000+0  37723-3 0    02
2 71924  97.4478  49.1573 0002393 131.9216 207.9073 15.18266825    16
JACK-002
1 71927C 26067C   26089.49750414 -.00013014  00000+0 -63498-3 0    02
2 71927  97.4500  49.1567 0002681 143.8886 196.8842 15.18377566    18
DECIMALSAT-1 & VEGAFLY-*
1 71958C 26067D   26089.49758863 -.00009989  00000+0 -51655-3 0    00
2 71958  97.4320  49.1630 0007687  13.6276 327.6456 15.16316797    13
ERMIS1
1 71907C 26067E   26089.49766502 -.00018436  00000+0 -95154-3 0    02
2 71907  97.4499  49.1570 0006234 350.4783 351.1750 15.16395581    16
VIREON-2
1 71954C 26067F   26089.49773563 -.00014857  00000+0 -72769-3 0    09
2 71954  97.4450  49.1587 0002503 123.2850 218.7612 15.18244923    19
COSMO
1 71948C 26067G   26089.49785831 -.00002824  00000+0 -14512-3 0    06
2 71948  97.4441  49.1590 0005887   2.6609 340.0604 15.16542163    11
ERMIS2
1 71934C 26067H   26089.49798910 -.00017388  00000+0 -85072-3 0    03
2 71934  97.4425  49.1596 0002896 119.4852 223.9504 15.18283476    17
TES-23
1 71903C 26067J   26089.49818701 -.00011477  00000+0 -59299-3 0    05
2 71903  97.4474  49.1584 0006533 356.2178 348.2906 15.16356392    11
PEAKSAT
1 71931C 26067K   26089.49832127 -.00008334  00000+0 -40615-3 0    04
2 71931  97.4483  49.1583 0002774 147.1256 198.1107 15.18418055    10
SAL-E
1 71904C 26067L   26089.49846595 -.00007742  00000+0 -39877-3 0    08
2 71904  97.4412  49.1602 0006442   8.2554 337.7892 15.16462720    16
ERMIS3
1 71935C 26067M   26089.49852845 -.00016540  00000+0 -81576-3 0    06
2 71935  97.4524  49.1575 0000806 158.7644 187.5945 15.18005787    10
BRO-19
1 71910C 26067N   26089.49880044 -.00007103  00000+0 -34837-3 0    04
2 71910  97.4410  49.1604 0002636 115.0356 232.8319 15.18192650    14
OPTISAT
1 71916C 26067P   26089.49885947 -.00008093  00000+0 -39809-3 0    00
2 71916  97.4504  49.1584 0001213 150.1331 198.0367 15.18094424    10
PARUS-TX
1 71919C 26067Q   26089.49893470 -.00013781  00000+0 -70600-3 0    07
2 71919  97.4488  49.1589 0005235 359.3198 349.2677 15.16662579    15
TMICROSAT-2
1 71937C 26067R   26089.49920090 -.00016479  00000+0 -84504-3 0    01
2 71937  97.4515  49.1587 0005344 355.2313 354.8043 15.16629075    12
SPOCQ
1 71902C 26067S   26089.49928076 -.00014712  00000+0 -72297-3 0    09
2 71902  97.4441  49.1601 0001988 119.9326 230.5514 15.18131007    16
CYCLOPS-1
1 71951C 26067T   26089.49942544 -.00020853  00000+0 -10285-2 0    00
2 71951  97.4520  49.1589 0000707 161.0262 190.2316 15.18005631    13
DISCO-2
1 71908C 26067U   26089.49955160 -.00011726  00000+0 -58129-3 0    09
2 71908  97.4541  49.1588 0000289 282.0588  69.8834 15.17826845    10
SHARJAH-SAT 2
1 71906C 26067V   26089.49984326 -.00012757  00000+0 -63026-3 0    00
2 71906  97.4513  49.1596 0000455 143.3402 210.2007 15.17945209    15
PHOBOS
1 71949C 26067W   26089.50004581 -.00010065  00000+0 -51560-3 0    05
2 71949  97.4514  49.1599 0005260 358.6296 356.0189 15.16664465    18
SM 1-2
1 71918C 26067X   26089.50017428 -.00016953  00000+0 -83632-3 0    02
2 71918  97.4437  49.1608 0001555 107.7071 247.6555 15.17998052    11
HARBINGER
1 71909C 26067Y   26089.50064419 -.00011328  00000+0 -58177-3 0    01
2 71909  97.4426  49.1611 0005982  15.2118 342.7209 15.16570644    11
OUT OF THE BOX
1 71920C 26067Z   26089.50070438 -.00004111  00000+0 -20342-3 0    07
2 71920  97.4509  49.1609 0000265 100.4948 257.7494 15.17885499    19
NEWSAT 54
1 71971C 26067AA  26089.50101456 -.00016818  00000+0 -85625-3 0    00
2 71971  97.4483  49.1613 0004409   8.2732 351.6692 15.16884711    10
EMISAR & AIGLONSAT-1 & *
1 71963C 26067AB  26089.50121132 -.00002881  00000+0 -14288-3 0    06
2 71963  97.4481  49.1615 0000600  62.6153 298.4005 15.17814587    12
LILIUM-4
1 71922C 26067AC  26089.50133053 -.00014632  00000+0 -74472-3 0    04
2 71922  97.4497  49.1617 0004341   5.9603 355.7042 15.16896692    16
IRIDE-MS1-EAG2-14
1 71979C 26067AD  26089.50149373 -.00006711  00000+0 -33236-3 0    00
2 71979  97.4460  49.1618 0000807  84.9950 277.5663 15.17860080    17
AISSAT-4
1 71921C 26067AE  26089.50169512 -.00011934  00000+0 -60737-3 0    03
2 71921  97.4459  49.1620 0004438  14.8912 348.7706 15.16895764    14
IRIDE-MS1-EAG2-9
1 71969C 26067AF  26089.50192197 -.00008101  00000+0 -41128-3 0    05
2 71969  97.4456  49.1621 0004086  17.7970 347.1042 15.16982693    13
IRIDE-MS1-EAG2-13
1 71981C 26067AG  26089.50204234 -.00007698  00000+0 -38280-3 0    00
2 71981  97.4497  49.1626 0000780   9.2741 356.2747 15.17714655    11
GHOST RIDER
1 71961C 26067AH  26089.50222405 -.00017920  00000+0 -91030-3 0    09
2 71961  97.4485  49.1627 0004089  10.8260 355.7182 15.16965993    16
IRIDE-MS1-EAG2-10
1 71967C 26067AJ  26089.50263377 -.00007803  00000+0 -38720-3 0    04
2 71967  97.4443  49.1626 0000925  68.3678 300.4197 15.17791350    19
IRIDE-MS1-EAG2-16
1 71980C 26067AK  26089.50280044 -.00008790  00000+0 -44550-3 0    03
2 71980  97.4491  49.1635 0003753   8.0470   1.6404 15.17044017    12
IRIDE-MS1-EAG2-11
1 71968C 26067AL  26089.50317313 -.00008710  00000+0 -43315-3 0    09
2 71968  97.4496  49.1641 0000904 347.5846  24.1353 15.17712628    16
DREAM BIG-PFW & DREAM B*
1 71960C 26067AM  26089.50336178  .00000917  00000+0  45625-4 0    07
2 71960  97.4448  49.1632 0001106  51.2940 321.4682 15.17705818    15
GARAI B
1 71940C 26067AN  26089.50366734 -.00003564  00000+0 -18032-3 0    00
2 71940  97.4484  49.1644 0003509  15.7336 358.6906 15.17105218    18
IRIDE-MS1-EAG2-12
1 71970C 26067AP  26089.50406086 -.00009898  00000+0 -50094-3 0    08
2 71970  97.4488  49.1650 0003584  11.0006   5.5678 15.17094878    11
IRIDE-MS1-EAG2-15
1 71982C 26067AQ  26089.50454813 -.00009925  00000+0 -49456-3 0    03
2 71982  97.4493  49.1658 0001312 350.5810  28.6455 15.17645737    14
FGN 100 D3
1 71957C 26067AR  26089.50501456 -.00022081  00000+0 -11164-2 0    03
2 71957  97.4449  49.1646 0003388  23.7550 358.0272 15.17137345    17
VIGORIDE
1 71964C 26067AS  26089.50508863 -.00005592  00000+0 -27873-3 0    03
2 71964  97.4471  49.1656 0001260   5.2842  16.8972 15.17631829    19
HOTSAT-2
1 71941C 26067AT  26089.50524951 -.00018892  00000+0 -95479-3 0    08
2 71941  97.4454  49.1650 0003330  22.3144   0.7492 15.17148849    18
NEWSAT 53
1 71972C 26067AU  26089.50531086 -.00020275  00000+0 -10119-2 0    04
2 71972  97.4477  49.1661 0001486   2.8654  20.5279 15.17590425    12
HAWK-14A
1 71977C 26067AV  26089.50539072 -.00021858  00000+0 -11036-2 0    09
2 71977  97.4454  49.1652 0003182  22.6672   1.1673 15.17182513    15
SPACEVAN 2
1 71943C 26067AW  26089.50572637 -.00012700  00000+0 -63414-3 0    00
2 71943  97.4451  49.1653 0001464  20.5120   5.1549 15.17572442    12
WINNEBAGO 06
1 71945C 26067AX  26089.50594743 -.00021253  00000+0 -10726-2 0    04
2 71945  97.4471  49.1665 0003135  17.1515   9.7183 15.17199969    19
SCV-019
1 71944C 26067AY  26089.50659095 -.00020495  00000+0 -10248-2 0    01
2 71944  97.4476  49.1676 0001820   3.6290  26.7521 15.17528045    10
HAWK-14B
1 71978C 26067AZ  26089.50672984 -.00023071  00000+0 -11545-2 0    04
2 71978  97.4475  49.1677 0001922   5.9632  25.1764 15.17500844    14
HAWK-14C
1 71976C 26067BA  26089.50796711 -.00024565  00000+0 -12381-2 0    05
2 71976  97.4448  49.1670 0002822  27.8713  10.0290 15.17247155    18
GRAVITAS
1 71901C 26067BB  26089.55357313 -.00066244  00000+0 -66921-2 0    08
2 71901  97.7542  49.0571 0001186 283.4333   2.1468 14.91172198    17
FLYLAB-2
1 71933C 26067BC  26089.56028840 -.00077567  00000+0 -79291-2 0    08
2 71933  97.7501  49.0676 0003498 338.6228 343.0023 14.90698041    10
LEMUR-2-SEJONG-3
1 71926C 26067BD  26089.56035322 -.00072328  00000+0 -70739-2 0    01
2 71926  97.7500  49.0678 0004572 134.2284 187.7400 14.92460442    15
GEMS2 AMETHYST
1 71917C 26067BE  26089.56042613 -.00079064  00000+0 -80718-2 0    04
2 71917  97.7540  49.0647 0003117 324.8675 357.4861 14.90750914    11
BLACK KITE-2
1 71953C 26067BF  26089.56048401 -.00081975  00000+0 -80671-2 0    07
2 71953  97.7470  49.0701 0003696 121.6165 201.0620 14.92220090    19
LEMUR-2-IRINA
1 71923C 26067BG  26089.56056155 -.00073183  00000+0 -71539-2 0    04
2 71923  97.7554  49.0637 0004630 148.0822 174.9918 14.92480735    11
UNICORN-2R & UNICORN-2S
1 71959C 26067BH  26089.56063215 -.00072091  00000+0 -73836-2 0    07
2 71959  97.7465  49.0705 0004127 349.1024 334.3763 14.90616544    13
FLYLAB-1
1 71911C 26067BJ  26089.56070854 -.00077568  00000+0 -79230-2 0    00
2 71911  97.7568  49.0629 0003246 316.6107   7.2517 14.90729669    18
LEMUR-2-CLARA
1 71928C 26067BK  26089.56077799 -.00075371  00000+0 -74139-2 0    06
2 71928  97.7577  49.0623 0003595 156.6041 167.6268 14.92235887    16
AE1A
1 71936C 26067BL  26089.56085553 -.00077470  00000+0 -76466-2 0    09
2 71936  97.7474  49.0698 0003216 119.3308 205.3417 14.92100718    15
LEMUR-2-JULIA-JOEL
1 71913C 26067BM  26089.56098053 -.00077271  00000+0 -78665-2 0    05
2 71913  97.7518  49.0668 0002704 339.3269 346.0076 14.90864455    14
N1-ATLAS
1 71905C 26067BN  26089.56104998 -.00081484  00000+0 -82645-2 0    06
2 71905  97.7572  49.0631 0002008 311.5064  14.1870 14.91016520    15
LEMUR-2-DELOITTE-2
1 71915C 26067BP  26089.56111595 -.00077368  00000+0 -78551-2 0    05
2 71915  97.7499  49.0682 0002314 348.5298 337.5341 14.90973829    17
IO-1
1 71950C 26067BQ  26089.56125831 -.00083000  00000+0 -84054-2 0    07
2 71950  97.7477  49.0697 0002170   6.1545 320.6790 14.91078349    15
TORO3
1 71952C 26067BR  26089.56131618 -.00083206  00000+0 -82358-2 0    02
2 71952  97.7598  49.0618 0002736 175.4377 151.6747 14.91992209    19
LEMUR-2-POLO-11
1 71929C 26067BS  26089.56137637 -.00075970  00000+0 -76968-2 0    02
2 71929  97.7591  49.0623 0001992 299.8373  27.6024 14.91058437    18
FOSSASAT-2E
1 71962C 26067BT  26089.56152220 -.00073743  00000+0 -73055-2 0    04
2 71962  97.7527  49.0666 0002264 140.9448 187.2918 14.91955055    10
ADIS
1 71973C 26067BU  26089.56162868 -.00077722  00000+0 -78357-2 0    06
2 71973  97.7546  49.0656 0000882 329.4482 359.3563 14.91257672    16
LEMUR-2-PEGGY-2004
1 71912C 26067BV  26089.56170044 -.00077484  00000+0 -76749-2 0    02
2 71912  97.7479  49.0697 0002652 117.8991 211.3067 14.91961633    15
LEMUR-2-DELOITTE-3
1 71914C 26067BW  26089.56183586 -.00077535  00000+0 -76407-2 0    07
2 71914  97.7490  49.0691 0003325 132.3467 197.5815 14.92164909    10
LEMUR-2-EMARCHIA
1 71930C 26067BX  26089.56197243 -.00076473  00000+0 -77723-2 0    02
2 71930  97.7503  49.0684 0002578 354.7740 335.8873 14.90930979    15
ICEYE-X71
1 71956C 26067BY  26089.56208470 -.00072068  00000+0 -72496-2 0    03
2 71956  97.7546  49.0661 0000520 345.2454 346.0074 14.91344494    16
LEMUR-2-CARROLLEMO
1 71925C 26067BZ  26089.56227683 -.00079455  00000+0 -80168-2 0    08
2 71925  97.7466  49.0705 0001941  29.6294 302.6721 14.91225510    19
ICEYE-X73
1 71946C 26067CA  26089.56239604 -.00071910  00000+0 -71349-2 0    06
2 71946  97.7540  49.0667 0001943 150.9166 182.0062 14.91892861    17
ICEYE-X75
1 71939C 26067CB  26089.56251294 -.00071979  00000+0 -71472-2 0    09
2 71939  97.7521  49.0678 0001850 140.6144 192.9398 14.91862471    15
VINDLER 2 2
1 71966C 26067CC  26089.56280692 -.00074843  00000+0 -74487-2 0    05
2 71966  97.7548  49.0668 0001396 155.0197 180.1069 14.91772771    13
SERT3
1 71974C 26067CD  26089.56288215 -.00074719  00000+0 -75087-2 0    02
2 71974  97.7513  49.0685 0000749  38.8339 296.7042 14.91386090    10
ICEYE-X74
1 71947C 26067CE  26089.56310090 -.00072635  00000+0 -73079-2 0    03
2 71947  97.7546  49.0672 0000576 348.9408 347.7646 14.91338138    19
ACADIA 10
1 71942C 26067CF  26089.56317729 -.00076352  00000+0 -76011-2 0    03
2 71942  97.7515  49.0687 0001457 132.7517 204.3693 14.91761302    18
ICEYE-X76
1 71938C 26067CG  26089.56339141 -.00072769  00000+0 -73031-2 0    07
2 71938  97.7556  49.0671 0000133 355.3517 342.9115 14.91438015    14
VINDLER 2 3
1 71975C 26067CH  26089.56360785 -.00075275  00000+0 -74914-2 0    02
2 71975  97.7514  49.0690 0001533 132.4256 207.0068 14.91773948    14
ICEYE-X72
1 71955C 26067CJ  26089.56386942 -.00072698  00000+0 -72495-2 0    01
2 71955  97.7557  49.0677 0001012 169.7273 171.0987 14.91693485    15
VINDLER 2 1
1 71965C 26067CK  26089.56451178 -.00075975  00000+0 -76163-2 0    03
2 71965  97.7507  49.0699 0000917  76.4803 267.8049 14.91483780    19
can you do your magic with “our” temporary numbers :grin:
TLE update for PEAKSAT:
PEAKSAT
1 98378U 26066K   26090.36120638  .00000000  00000-0  46983-3 0    07
2 98378  97.4432  50.0953 0003312 155.9961 223.1662 15.18586317    00
TLE updates based on celestrak post launch TLE with the changed temporary NORAD IDs are coming in the next minutes
