Ogg replay
1: [HADES-R] [13:50:03R]
[frm_type:1 len:29]
1D 30 1E 01 00 80 5F 96 02 37 00 FB B5 6B 65 03 D4 63 40 0F FA 01 FF 67 30 00 00 00 00
*** Power packet received on local time 20250123-13:50:03 ***
sat_id : 13 (HADES-R)
sclock : 73264 seconds (0 days and 20:21:04 hh:mm:ss)
spi : 110 mW (total instant power)
spa : 256 mW (last 3 mins peak)
spb : 190 mW (last 3 mins peak)
spc : 300 mW (last 3 mins peak)
spd : 4 mW (last 3 mins peak)
vbus1 : 4075 mV bus voltage read in CPU.ADC
vbus2 : 4108 mV bus voltage read in EPS.I2C
vbus3 : 4120 mV bus voltage read in CPU.I2C
vbat1 : 4083 mV bat voltage read in EPS.ADC
vbat2 : 4072 mV bat voltage read in EPS.I2C
vbus1-vbat1 : -8 mV
vbus3-vbus2 : 12 mV
vcpu : 2873 mV
icpu : 19 mA @DCDCinput
icpu : 27 mA @DCDCoutput (estimation)
ipl : 103 mA (Last payload current)
ibat : -1 mA (Current flowing into the battery)
peaksignal : 0 dB
modasignal : 0 dB
lastcmdsignal : 0 dB
lastcmdnoise : 0 dB
Replay IQ
*** Status packet received on local time 20250123-13:54:57 ***
sclock : 73174 seconds satellite has been active (0 days and 2
0:19:34 hh:mm:ss)
uptime : 73174 seconds since the last CPU reset (0 days and 2
0:19:34 hh:mm:ss)
nrun : 1 times satellite CPU was started
npayload : 1 times payload was activated
nwire : 5 times antenna deployment was tried
ntransponder : 0 times transponder was activated
nPayloadsFails : OK
last_reset_cause : 5 Power-on reset (POR) / Power-down reset (PDR)
bate (battery) : 1 Charged (Between 3550 mV and 4200 mV)
mote (transponder) : 0 Disabled
nTasksNotExecuted : OK
nExtEepromErrors : OK
antennaDeployed : UNKNOWN
last_failed_task_id :
messaging enabled : No
strfwd0 (id) : FF (255)
strfwd1 (key) : FFFF (65535)
strfwd2 (value) : FFFF (65535)
strfwd3 (num_tcmds) : 0 (0)
*** Temp packet received on local time 20250123-13:55:16 ***
sclock : 73114 seconds (0 days and 20:18:34 hh:mm:ss)
tpa : -4.0 degC temperature in SPA.I2C
tpb : -4.0 degC temperature in SPB.I2C
tpc : -4.0 degC temperature in SPC.I2C
tpd : -4.0 degC temperature in SPD.I2C
teps :
ttx : -3.0 degC temperature in TX.I2C
ttx2 : -2.0 degC temperature in TX.NTC
trx : -6.0 degC temperature in RX.NTC
tcpu : +0.5 degC temperature in CPU.ADC
*** Power packet received on local time 20250123-13:55:33 ***
vbus1-vbat1 : -8 mV
vbus3-vbus2 : 12 mV
vcpu : 2873 mV
peaksignal : 0 dB
modasignal : 0 dB
lastcmdnoise : 0 dB
