Station Demoded Data Az/El Plot with data until 2019-09-18
Bellow you can see az/el plots by https://gitlab.com/kerel-fs/satnogs-AzEl-plots script of @kerel based on @pierros initial script . Data used for these plots were extracted from satnogs-network and can be found in their csv format in this zipped file: 2019-09-18.zip (9.4 MB) .
So in this diagram you can get an idea on which Az/El a station performs good enough to demodulate data. Have in mind that the sum of data (colored areas) are shown in logarithmic scale.
Data includes one entry for each data with unique timestamp of good observations with data. This means that data frames with the same timestamp are logged once. Also it doesn’t include data from png uploads, like SSTV or NOAA ones and CW decoded frames.
There are plans to have, in the future, page with stats like that but it needs some work before that.
For the past plots check this old thread.
Thanks to all for your contributions!
Station 1
Station 2
Station 6
Station 7
Station 9
Station 10
Station 12
Station 15
Station 16
Station 21
Station 22
Station 23
Station 24
Station 25
Station 26
Station 27
Station 28
Station 31
Station 32
Station 33
Station 34
Station 35
Station 36
Station 37
Station 38
Station 39
Station 40
Station 41
Station 43
Station 46
Station 47
Station 48
Station 49
Station 50
Station 56
Station 61
Station 62
Station 65
Station 66
Station 67
Station 70
Station 72
Station 75
Station 77
Station 83
Station 85
Station 86
Station 87
Station 89
Station 91
Station 92
Station 95
Station 96
Station 98
Station 100
Station 101
Station 102
Station 105
Station 106
Station 110
Station 111
Station 123
Station 129
Station 130
Station 133
Station 141
Station 142
Station 146
Station 147
Station 150
Station 152
Station 158
Station 162
Station 164
Station 165
Station 167
Station 171
Station 173
Station 175
Station 176
Station 177
Station 183
Station 187
Station 189
Station 196
Station 200
Station 201
Station 203
Station 207
Station 211
Station 212
Station 213
Station 216
Station 217
Station 221
Station 223
Station 227
Station 229
Station 232
Station 233
Station 234
Station 237
Station 238
Station 246
Station 248
Station 254
Station 255
Station 256
Station 271
Station 272
Station 282
Station 285
Station 291
Station 296
Station 299
Station 300
Station 305
Station 306
Station 307
Station 308
Station 318
Station 327
Station 328
Station 329
Station 330
Station 331
Station 334
Station 335
Station 339
Station 342
Station 343
Station 347
Station 348
Station 351
Station 353
Station 355
Station 356
Station 359
Station 361
Station 365
Station 368
Station 376
Station 377
Station 380
Station 384
Station 385
Station 387
Station 399
Station 400
Station 404
Station 406
Station 411
Station 413
Station 418
Station 420
Station 423
Station 427
Station 430
Station 431
Station 438
Station 439
Station 440
Station 442
Station 444
Station 446
Station 447
Station 449
Station 451
Station 452
Station 458
Station 462
Station 479
Station 480
Station 488
Station 489
Station 490
Station 492
Station 498
Station 499
Station 500
Station 509
Station 511
Station 512
Station 517
Station 519
Station 526
Station 531
Station 539
Station 540
Station 544
Station 546
Station 548
Station 551
Station 554
Station 555
Station 558
Station 567
Station 568
Station 569
Station 570
Station 572
Station 574
Station 579
Station 600
Station 605
Station 611
Station 613
Station 617
Station 618
Station 619
Station 620
Station 632
Station 636
Station 642
Station 644
Station 645
Station 647
Station 655
Station 657
Station 663
Station 667
Station 669
Station 673
Station 674
Station 678
Station 692
Station 693
Station 702
Station 704
Station 706
Station 709
Station 711
Station 713
Station 715
Station 724
Station 727
Station 730
Station 731
Station 732
Station 733
Station 735
Station 737
Station 738
Station 749
Station 754
Station 760
Station 763
Station 766
Station 771
Station 772
Station 777
Station 780
Station 788
Station 796
Station 797
Station 802
Station 804
Station 806
Station 812
Station 818
Station 819
Station 820
Station 822
Station 826
Station 829
Station 830
Station 834
Station 837
Station 839
Station 842
Station 845
Station 853
Station 858
Station 861
Station 863
Station 866
Station 867
Station 868
Station 871
Station 874
Station 884
Station 888
Station 901
Station 905
Station 906
Station 908
Station 909
Station 913
Station 917
Station 918
Station 921
Station 923
Station 927
Station 930
Station 935
Station 939
Station 964
Station 966
Station 969
Station 972
Station 977
Station 981
Impressive. Mny tnx 73 Oliver
Hi Fredy,
This is awesome!
A free drink at OSCW to the first person who can explain why most data is received between 10° and 40° elevation :smiley:
your latitude 55.634 ?
Correct, it is station 49 :slight_smile:
Do you know the answer, Alex? Or is this a true mystery?
My guess would be interference from the building where the antennas are located? As the yagi’s start to point more upward you are picking up interference off the back lobe?
Yes, I do have an answer, or at least a good guess :slight_smile:
At your latitude, you see a lot of satellites low on the horizon, is that it?
I would say due to the fact that most satellite passes are in that range of elevation (assuming cut off at 10 for horizon).
It is logical to assume that if we do a graph for satellite occurrence per elevation it would be approximating an cumulative exponential distribution.
It’s the combination of distance and angular velocity. The angular velocity determines how long a satellite stays within a certain elevation range. Though the distance is smaller near zenith, the angular velocity is higher, so the satellite spends less time there. At very low elevations more time is spent there, but the distance is too far and hence the SNR to decode is lower.
Indeed, this is what I have been thinking too! You win!
That’s a good point, although, in such a case, I would expect the yellow band to be less symmetric in Azimuth. However, this is likely a contributing factor, so you get a drink too :grin:
This really helps my research on The Effects of Hyacinth Bean Vine on Moxon Takeoff Angles.
Hello,
how to extract data from satnogs-network for a station to create the diagram itself ?
I added a LNA and modified the configuration for station 972 and thus improved the number of decoded frames.
This will allow me to correlate the theoretical radiation pattern of the antenna with the decoded frame diagram
Great work Fredy, will look to elevate my antenna at the weekend given the plot the garage is obviously in the way
cheers
Max
Unfortunately extract this kind of data currently is not easy for a user, I’ll try by the end of the week to extract and calculate the needed data for your station. :wink:
Thank you, I will look at the code satnogs-db and satnogs-network to better understand the data structure and perhaps bring new possibilities for users …
Just to be clear, there are ways to create these plots on yourself but it would take several requests on the API, what I’m doing is to use temporarily one of the backups of the database and run the script for generating the extra needed data (the ones attached on the first post) locally, the I run an extra script to draw the plots.
The plan is to create that kind of stats and others either in the site or maybe in https://dashboard.satnogs.org but unfortunately it’s not the number one priority, as we need to move forward with some more critical issues.
This is definitely not an appropriate way of estimating the radiation pattern of your antenna, for various reasons (including satellite passes at different azimuths and elevations, different effective radiated power (ERP) by on-board transmitters, different downlink frequencies etc.).
A much better idea would be to try and center the main lobe of the antenna to an azimuth and elevation the sun drifts through (let me know if you need help figuring that out). The sun is a continuum (broadband) source which will allow you to map the radiation pattern of your antenna, without any tracking involved.
The antenna is also omnidirectional (the gain is a function of just one parameter (θ, or φ)), so that makes things even easier for you if you take that assumption into account (fewer measurements are necessary).
The gain will be normalized (it’s possible but a bit more work to calibrate/convert to dBi), but I think that’s what you’re looking for anyway.
Sort of relevant to something I started working on until classes got in the way. Using SatNOGS to study the antenna patterns of antennas on the network
This thread was also mentioned in my thread. :slight_smile:
I might work on that threads topic over winter break.
