Welcome in the community @jldrooger and congratulation to you and your team for your successful launch! From its signal, It looks like that Barry-1 is pretty active and in a good health.
PS Nice music touch on the downlink! ![]()
99010 BARRY-1 strf observations over last 24 hours and resulting TLE
BARRY-1
1 99010U 23326.40347222 .00000000 00000-0 -17495-3 0 02
2 99010 97.4835 39.2875 0010765 282.5799 141.5255 15.15439447 08
+1 for the music, it also was the only reason I has able to see any signal on one of the included observations ![]()
Thanks! We’ve learned a lot in a short amount of time. I’m proud of what our little team has pulled off.
We are still deciding what the music will be on our next satellite.
This is really helpful, thanks @satcolintel5!
Thanks @satcolintel5 all the TLE are in DB and in Network.
For the Lemur one, let’s keep watching, it is indeed difficult to separate them, however in some Network observations we can see them separate at the middle of the waterfall, with the 2B be at the left side and 2A at the right one.
Also added a newer for KAFASAT by @PE0SAT
KAFASAT
1 99028U 23326.85416667 .00000000 00000-0 37742-2 0 05
2 99028 97.4830 39.8028 0001962 10.0086 330.4973 15.15393799 05
@fredy Could you please add ION TLE to Intuition-1 as it will be deployed very soon SatNOGS DB - Intuition-1
@begreen will be deployed today? Maybe tomorrow or on Monday with the alba pocketqubes? I’m asking in order to include it in the scheduling as we occupy almost all the available passes.
The TLE will be added in the next minutes.
EDIT:
Bellow is the TLE set for Intuition-1 that is added in DB, the TLE are based on @satcolintel5 latest TLE set for the ION deployer with the NORAD ID changed to fit the temporary one that is used in DB:
Intuition-1
1 98993U 23325.95555556 .00000000 00000-0 71105-4 0 09
2 98993 97.4837 38.7502 0015373 231.5222 237.3442 15.14398988 00
I’ve also update the entry in DB to show its status as future, as it hasn’t been deployed.
@begreen when it is deployed please suggest a change in DB, status from future to alive and add the deployment date.
First Intuition-1 decode MAUSyagi 1675
These TLE for the possible deployment of the satellites from alba orbital deployer on ION SCV-013.
The TLE sets are based on @satcolintel5 latest TLE set for the ION deployer with the NORAD ID changed to fit the temporary one that is used in DB:
ROM-3
1 98996U 23325.95555556 .00000000 00000-0 71105-4 0 02
2 98996 97.4837 38.7502 0015373 231.5222 237.3442 15.14398988 03
HADES-D
1 98981U 23325.95555556 .00000000 00000-0 71105-4 0 06
2 98981 97.4837 38.7502 0015373 231.5222 237.3442 15.14398988 07
SPACEANT-D
1 98995U 23325.95555556 .00000000 00000-0 71105-4 0 01
2 98995 97.4837 38.7502 0015373 231.5222 237.3442 15.14398988 02
New TLE for VERONIKA by Samuel:
VERONIKA
1 99052U 23327.83333333 .00000000 00000-0 31268-3 0 07
2 99052 97.4757 40.6682 0000019 356.0112 218.9010 15.13408825 08
Intuition-1
http://wakky.asablo.jp/blog/2023/11/23/9636870
New TLE set for Intuition-1:
INTUITION-1
1 98993U 23328.20000000 .00000000 00000-0 71105-4 0 09
2 98993 97.4837 40.6485 0014938 223.4194 232.9130 15.16159612 02
intui_328.dat (1015 Bytes)
sites.txt (4.5 KB)
It seems will be delayed ![]()
Update 11/24: HADES-D deployment delayed another additional week
Thanks of the update, I’m going to remove any scheduled observation for HADES-D, ROM-3 and SPACEANT-D and mark them as future in DB.
I had stopped trying, but it appears that the 9k6 digipeater is functional on Veronika! Will have to try again when there are good passes over the Eastern U.S. I don’t have confirmation of the settings that resulted in these messages getting through, but if I have any luck first-hand, I’ll certainly post all the particulars.
Well, 88° Veronika pass this morning (25-Nov-2023, ~1600utc) with an 80w RF amp on the 70cm uplink (doppler-corrected up/down) and still no digipeat. (using a variety of TO: & VIA: options)
Will have to put this one back at the bottom of the list in favor of some of the other objects deployed from Transporter-9.
On the positive side, -4- more 2k4 decodes from DJIBOUTI-1A, so more data into SatNogs for that Team.
We’ve generated new set of TLE for Intuition-1. @fredy would you be so kind to update it on Satnogs as previous TLE already drifted. Thanks!
INTUITION-1
1 99999U 23327.43194444 .00000000 00000-0 -30975-4 0 07
2 99999 97.5093 40.1170 0005573 236.9398 355.1922 15.13936510 04
EDIT: I’ve changed Temporary NORAD ID to the number used on Satnogs:
INTUITION-1
1 98993U 23327.43194444 .00000000 00000-0 -30975-4 0 00
2 98993 97.5093 40.1170 0005573 236.9398 355.1922 15.13936510 07
Added in DB and Network thank you @begreen!
Also we have by @somecheese a new TLE for Veronika:
VERONIKA
1 99052U 23330.25000000 .00000000 00000-0 70949-3 0 08
2 99052 97.4646 43.0171 0000019 151.4468 262.7195 15.13527144 03
