SpaceX F9 Transporter-9 - Vandenberg - 2023-11-11 18:47 UTC
It looks like that NINJASAT has limited transmissions. From two of them I’ve generated the TLE set bellow, hopefully is accurate enough to keep it in the field of view of the stations when it transmit again:
NINJASAT
1 99006U          23325.40000000  .00000000  00000-0  84388-4 0    01
2 99006  97.4829  39.2992 0009399 342.8375  12.7149 15.15574275    07
ninja_325.dat (1.4 KB)
sites.txt (4.3 KB)
In observation SatNOGS Network - Observation 8548670 there is a similar signal that @PE0SAT managed to demodulate and find similar frames with the one of @N6RFM post.
This makes a little stronger the possibility of this being NINJASAT.
Hi @fredy,
Currently, we only track UHF data on SatNOGS. Since we will open S-Band in the future, we deleted the existing S-Band transmitters in order not to occupy the stations.
No need to delete, we can set them as inactive for now :wink:
It seems that the previous TLE for PEARL 1C was off, I’ve recalculated one, not very very accurate but much better that the previous we used:
PEARL 1C
1 99009U          23325.40000000  .00000000  00000-0  16011-2 0    00
2 99009  97.4857  36.4196 0010615  27.9614 335.3182 15.15656154    04
On this pass, the TLE is quite suitable
99025 ION SCV-013 ULTIMATE HUG strf observations over last 24 hours and resulting TLE
1 99025U          23325.95555556  .00000000  00000-0  71105-4 0    06
2 99025  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    07
99025_20231121_2256UTC_combined.dat (1.6 KB)
site.txt (51 Bytes)
NinjaSat
Riken, Japan
https://wakky.asablo.jp/blog/2023/11/22/9636371
402.000MHz, 2k4_GMSK mode-U (LightSat-1 framing)
USA pass at 0332utc (22-Nov-2023) produced 5 (!!) 2k4 decodes from DJIBOUTI-1A.
Strongest I’ve seen those little 2k4 packets and it’s pouring down rain here at the moment. I hope the Team is getting their data from SatNogs - they should be very proud of how this sat is performing, especially for a 1st effort!
DJIBOUTI-1A
Centre Spatial Universitaire de Montpellier, Djibouti
401.800MHz, 2k4_FSK, callsign:DJIB1A
Hi @fredy ,
Can we change the currently used CONNECTA T3.1 and CONNECTA T3.2 TLEs created by SatNOGS to following TLEs ?
CONNECTA T3.1
1 88301U          23325.74282862 +.00013944 +00000+0 +77822-3 0  0017
2 88301  97.4790  38.5016 0010071 246.2128 113.8048 15.13617615002110
CONNECTA T3.2
1 88313U          23325.74340014 +.00009383 +00000+0 +52680-3 0  0011
2 88313  97.4809  38.5034 0010547 247.2210 112.7907 15.13499738002111
Thanks @satcolintel5 @je9pel @K4KDR and @ps_observer for the info!
Some comments:
About NINJASAT while it is probably the one we received and we’ve seen on other obs, the limited transmissions (receptions in SatNOGS) and the not confirmed frequency make hard to be 100% sure. I’ve tried to contact the team but I didn’t get any response, maybe too busy or my email went on spam folder. So, the only solution keep watching and waiting to see if these signals belong to the T9 launch.
About DJIBUTI 1A, indeed very good performance!
About the TLE sets, I’m checking them and adding them to DB in the next hour.
According to AMSAT-EA announcement (Nov’21):
HADES-D will be deployed on November 24 or 27 (11/21/2023)
D-Orbit has concluded the testing operations of the ION SCV-013 orbital transfer vehicle (OTV), so the deployment phase of the satellites contained therein will begin shortly. Telemetry data confirms that the orbiter is healthy and working properly.
There is still no confirmation of the exact deployment times, but it is considered Friday the 24th or Monday the 27th. As soon as we know, including the time, this news will be updated.
About other passangers, probably ROM-3 (thanks given to Felix, EA4GQS)
73, Rafael
The TLE of the KAFASAT satellite is old and is not correct.
Please also update the TLE of the KAFASAT satellite.
TLE for CONNECTA satellites and ION SCV-013 has been updated. Bellow are the same TLE for CONNECTA using the temporary NORAD ID we use in DB:
CONNECTA T3.1
1 99031U          23325.74282862 +.00013944 +00000+0 +77822-3 0  0019
2 99031  97.4790  38.5016 0010071 246.2128 113.8048 15.13617615002112
CONNECTA T3.2
1 99030U          23325.74340014 +.00009383 +00000+0 +52680-3 0  0019
2 99030  97.4809  38.5034 0010547 247.2210 112.7907 15.13499738002119
I’ll try to produce a new TLE set later today.
@ea4bpn I’ll make sure that we will have some observations scheduled on Friday for HADES-D and ROM-3. If you get any updates, let us know!
From tinygs telegram there is the info that Apogeo satellites have been deployed today from ION deployer.
Bellow are the TLE sets that will be used for them in DB, the TLE are based on @satcolintel5 latest TLE set for the ION deployer with their NORAD ID changed to fit the temporary one that is used in DB:
PICO-1A-1
1 99024U          23325.95555556  .00000000  00000-0  71105-4 0    05
2 99024  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    06
PICO-1A-2
1 99023U          23325.95555556  .00000000  00000-0  71105-4 0    04
2 99023  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    05
PICO-1A-3
1 99022U          23325.95555556  .00000000  00000-0  71105-4 0    03
2 99022  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    04
PICO-1A-4
1 99021U          23325.95555556  .00000000  00000-0  71105-4 0    02
2 99021  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    03
PICO-1A-5
1 99020U          23325.95555556  .00000000  00000-0  71105-4 0    01
2 99020  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    02
PICO-1A-6
1 99019U          23325.95555556  .00000000  00000-0  71105-4 0    09
2 99019  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    00
PICO-1A-7
1 99018U          23325.95555556  .00000000  00000-0  71105-4 0    08
2 99018  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    09
PICO-1A-8
1 99017U          23325.95555556  .00000000  00000-0  71105-4 0    07
2 99017  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    08
PICO-1A-9
1 99016U          23325.95555556  .00000000  00000-0  71105-4 0    06
2 99016  97.4837  38.7502 0015373 231.5222 237.3442 15.14398988    07
EDIT:
Due to the size difference between ION deployer and the PICO satellites, these TLE sets are expected to be non-accurate soon.
New TLE for KAFASAT:
KAFASAT
1 99028U          23326.60000000  .00000000  00000-0  37742-2 0    08
2 99028  97.4830  39.4137 0001962  83.4484 311.9728 15.15394418    09
kafasat_326.dat (2.6 KB)
sites.txt (4.4 KB)
99027 DJIBUTI 1A strf observations over last 24 hours and resulting TLE
 DJIBUTI 1A
1 99027U          23326.34930556  .00000000  00000-0  16330-2 0    06
2 99027  97.4926  38.9259 0012683 242.9791 178.1799 15.13638940    08
99027_20231122_0823UTC.dat (1.3 KB)
site.txt (51 Bytes)
@fredy, just got an account and set up a listening station here in Alamogordo NM. Thanks to you and the SatNOGS community for helping us track our satellite Barry-1!
Possibly 99007 Lemur 2 - Mango 2B best-fit strf observations (between 2A and 2B)_over last 24 hours and resulting TLE. Grain of salt with this one but since were still using Celestrak (supplemental) TLEs of 70343 from Nov 11th … and there’s a lot signal flying in formation around this one … it’s worth a shot. Nothing seen via Alaska #2051 so these are from 2134 here in Colorado (updated in site.txt)
Lemur 2 - Mango 2B
1 99007U          23326.20138889  .00000000  00000-0  79212-3 0    07
2 99007  97.4866  38.2659 0012353 224.7783 176.4186 15.17087233    07
site.txt (103 Bytes)
