@K4KDR Maybe I have missed some posts, but can you please give some info about your TX equipment for Veronika?
Gladly!
Using -5- memory channels for up/down doppler correction in a TM-V71A set to 9600-baud mode. Originally I was transmitting w/ 50w from the radio but on the most recent passes, used an external RF amp for something closer to 80w. Antenna is a 70cm Wimo X-Quad AZ/EL tracked with RHCP connections.
From the computer, I’m using UZ7HO High-Speed SoundModem set to ‘FSK G3RUH 9600bd’ to relay messages from the UISS application w/ a variety of TO: & VIA: combinations including:
TO: CQ, VIA: {nothing}
TO: CQ, VIA: OM9VER
TO: OM9VER, VIA: {nothing}
… and thanks to in-house, over-the-air testing, have confirmed that my transmitted 9600 packets decode cleanly on an SDR + Direwolf (9600 baud).
Absent a single indication that my uplinks were being received & repeated, for the moment I’ve shifted attention to the dozens of other objects from this deployment pending any updates regarding the digipeater on Veronika!
Thank you for info. It is sad that the Icom IC-9700 do not have 9k6 TX possibility.
Hi friends, sharing with you this information from Alba Orbital:
AlbaPod 2 will be deployed first tomorrow. Please find details below of the deployment schedule.
- Date: 28.11.2023
- Time: 07:53 UTC
Backup:
- Date 28.11.2023
- Time: 12:40 UTC
Confirmation of deployment will happen after the first passage after deployment, meaning 8:55 for the nominal, or 13:46 for the backup.
The satellites in each Pod are as follows:
Albapod 1: Unicorn 2J, SpaceAnt-D, Unicorn 2TA2
Albapod 2: Unicorn 2K, HADES-D, ROM-3
Kind regards,
Félix EA4GQS
With another round of deployments about to take place, does anyone have an updated TLE for ION SCV-013? The existing numbers are about a week old now. Thanks!
I’ve just checked the last observations in Network and the TLE seems to describe pretty well the current orbit of ION SCV-013.
So, for the deployed satellite we will go with these TLE sets:
ROM-3
1 98996U 23325.95555556 .00000000 00000-0 71105-4 0 02
2 98996 97.4837 38.7502 0015373 231.5222 237.3442 15.14398988 03
HADES-D
1 98981U 23325.95555556 .00000000 00000-0 71105-4 0 06
2 98981 97.4837 38.7502 0015373 231.5222 237.3442 15.14398988 07
SPACEANT-D
1 98995U 23325.95555556 .00000000 00000-0 71105-4 0 01
2 98995 97.4837 38.7502 0015373 231.5222 237.3442 15.14398988 02
New TLE sets:
DJIBUTI 1A
1 99027U 23332.10000000 .00000000 00000-0 16330-2 0 09
2 99027 97.4926 44.7988 0015922 223.7457 195.3387 15.13932702 04
djib_332.dat (1.3 KB)
sites.txt (4.7 KB)
BARRY-1
1 99010U 23332.10000000 .00000000 00000-0 -17495-3 0 06
2 99010 97.4835 44.3942 0010765 305.0952 221.0525 15.18601583 01
barry_332.dat (1.1 KB)
sites.txt (4.7 KB)
OUTPOST MISSION 2
1 99005U 23332.10000000 .00000000 00000-0 -60206-3 0 08
2 99005 97.4898 45.0506 0002127 222.4079 290.5209 15.15451273 09
outpost2_332.dat (2.6 KB)
sites.txt (4.7 KB)
PLATFORM 5
1 98979U 23332.10000000 .00000000 00000-0 99195-3 0 05
2 98979 97.4895 45.3096 0012643 357.4665 166.6271 15.15541581 00
plat5_332.dat (1.5 KB)
sites.txt (4.7 KB)
IRIS C2
1 98978U 23332.10000000 .00000000 00000-0 -76831-3 0 07
2 98978 97.4897 56.5920 0012422 249.6202 179.1432 15.14187254 05
Note: Not very accurate, they will need an update soon
irisc2_332.dat (1.6 KB)
sites.txt (4.7 KB)
PEARL-1H
1 98980U 23332.10000000 .00000000 00000-0 20275-2 0 09
2 98980 97.4782 40.5559 0009612 238.8065 173.9809 15.14554333 02
pearl1h_332.dat (2.1 KB)
sites.txt (4.7 KB)
KAFASAT
1 99028U 23332.10000000 .00000000 00000-0 37742-2 0 00
2 99028 97.4830 44.9427 0001317 17.9661 115.9617 15.15146077 00
kafasat_332.dat (1.4 KB)
sites.txt (4.7 KB)
Thanks.
Good morning,
Confirmed HADES-D signal here:
https://network.satnogs.org/observations/8608500/
Kind regards,
Félix EA4GQS
These are great news! There are additional observations, even some low pass that have gotten HADES-D signals.
For ROM-3 there are some forms of signals but I’m not sure if they belong to ROM-3, maybe other satellites or terrestrial. For Spaceant nothing for now. Let’s keep watching!
Got digipeated by Veronika after 30 tries.
https://dashboard.satnogs.org/d/abEVHMIIk/veronika?orgId=1&kiosk=tv&from=1701168110000&to=1701168201000
Equipment:
(Antenna is in the attic, FT-847 on 50 watts output.)
I’ve used DL7NDR to CQ via OM9VER.
SpaceANT-D yet to deploy. Will confirm the new date later.
@norilmi thanks for the info, I’m going to remove the future observations and change the status in DB.
EDIT please let us know as far as possible in advance when the new date will be.
Hi all, Got this info from Alba Orbital.
Deployment has been confirmed for SpaceANT -D tomorrow:
"Here the information you need,
Nominal:
Date: 29.11.2023
Time: 09:14 UTC
Backup:
Date 29.11.2023
Time: 17:09 UTC
Confirmation of deployment will happen after the first passage after deployment, meaning 10:08 for the nominal, or 17:31 for the backup."
We have the first “TO BE ASSIGNED” TLE sets by space-track.org:
0 TBA - TO BE ASSIGNED
1 58256U 23174A 23332.68378867 .00017835 00000-0 98753-3 0 9998
2 58256 97.4785 45.3156 0010439 220.2900 139.7559 15.13840594 3163
1 58257U 23174B 23332.68702173 .00021135 00000-0 11751-2 0 9990
2 58257 97.4800 45.3152 0012293 226.2527 133.7688 15.13638534 3165
1 58258U 23174C 23332.68733016 .00011482 00000-0 64432-3 0 9990
2 58258 97.4772 45.3098 0011700 224.8498 135.1789 15.13452775 3165
1 58259U 23174D 23332.68615305 .00011085 00000-0 62050-3 0 9994
2 58259 97.4780 45.3122 0011851 222.0694 137.9628 15.13549739 3167
1 58260U 23174E 23332.68564281 .00018275 00000-0 10154-2 0 9997
2 58260 97.4847 45.3258 0012045 222.5039 137.5261 15.13697345 3163
1 58261U 23174F 23332.68603795 .00017935 00000-0 99697-3 0 9994
2 58261 97.4860 45.3274 0013087 220.5483 139.4774 15.13671852 3160
1 58262U 23174G 23332.68696866 .00018485 00000-0 10308-2 0 9998
2 58262 97.4835 45.3217 0012664 221.9366 138.0897 15.13558249 3160
1 58263U 23174H 23332.68587282 .00018516 00000-0 10293-2 0 9998
2 58263 97.4791 45.3145 0011084 225.1073 134.9259 15.13686214 3169
1 58264U 23174J 23332.68605112 .00014630 00000-0 81581-3 0 9994
2 58264 97.4878 45.3322 0012388 222.3378 137.6899 15.13614172 3162
1 58265U 23174K 23332.68576639 .00008893 00000-0 49883-3 0 9999
2 58265 97.4746 45.3046 0009887 222.9033 137.1428 15.13555164 3162
1 58266U 23174L 23332.68406669 .00018591 00000-0 10281-2 0 9990
2 58266 97.4883 45.3340 0013142 216.6882 143.3451 15.13850338 3169
1 58267U 23174M 23332.68442603 .00017856 00000-0 98959-3 0 9991
2 58267 97.4769 45.3120 0010552 222.7454 137.2958 15.13807933 3161
1 58268U 23174N 23332.15608753 .00013209 00000-0 73602-3 0 9990
2 58268 97.4808 44.7993 0010876 223.4361 136.6015 15.13679018 3080
1 58269U 23174P 23332.68238141 .00018062 00000-0 99518-3 0 9995
2 58269 97.4857 45.3320 0012169 215.2771 144.7656 15.13996963 3168
1 58270U 23174Q 23332.68134975 .00009922 00000-0 54955-3 0 9998
2 58270 97.4844 45.3322 0010721 213.2428 146.8131 15.13969166 3163
1 58271U 23174R 23332.68184973 .00008785 00000-0 48788-3 0 9995
2 58271 97.4810 45.3234 0010710 214.0362 146.0183 15.13908435 3164
1 58272U 23174S 23332.68139278 .00015064 00000-0 83091-3 0 9998
2 58272 97.4813 45.3232 0008692 206.0066 154.0730 15.14029799 3169
1 58273U 23174T 23332.68147412 .00009426 00000-0 52257-3 0 9993
2 58273 97.4836 45.3297 0010515 213.3533 146.7037 15.13952618 3165
1 58274U 23174U 23332.67860434 .00009291 00000-0 51142-3 0 9991
2 58274 97.4843 45.3387 0010174 207.6296 152.4396 15.14215476 3164
1 58275U 23174V 23332.61499549 .00010062 00000-0 55687-3 0 9997
2 58275 97.4803 45.2576 0009880 211.7429 148.3208 15.14002527 3152
1 58276U 23174W 23332.61538509 .00007203 00000-0 40084-3 0 9996
2 58276 97.4753 45.2460 0009473 211.7476 148.3185 15.13911317 3158
1 58277U 23174X 23332.68068794 .00015194 00000-0 83637-3 0 9997
2 58277 97.4805 45.3218 0008833 203.3870 156.6961 15.14098272 3165
1 58278U 23174Y 23332.68030095 .00009236 00000-0 51062-3 0 9998
2 58278 97.4790 45.3192 0009322 207.5353 152.5386 15.14067139 3160
1 58279U 23174Z 23332.68006919 .00008444 00000-0 46695-3 0 9993
2 58279 97.4861 45.3377 0011160 210.8829 149.1747 15.14069087 3160
1 58280U 23174AA 23332.67993368 .00009443 00000-0 52160-3 0 9991
2 58280 97.4845 45.3364 0010013 209.8127 150.2536 15.14088775 3169
1 58281U 23174AB 23332.67824233 .00015362 00000-0 83908-3 0 9997
2 58281 97.4829 45.3340 0009744 206.4503 153.6233 15.14366463 3160
1 58282U 23174AC 23332.67899913 .00009316 00000-0 51335-3 0 9996
2 58282 97.4795 45.3208 0009354 202.1637 157.9192 15.14183129 3161
1 58283U 23174AD 23332.67811361 .00012109 00000-0 66350-3 0 9995
2 58283 97.4786 45.3207 0009535 203.4608 156.6190 15.14311034 3166
1 58284U 23174AE 23332.67837841 .00010159 00000-0 55825-3 0 9995
2 58284 97.4850 45.3399 0010521 208.0496 152.0170 15.14246191 3163
1 58285U 23174AF 23332.67820940 .00010012 00000-0 55007-3 0 9998
2 58285 97.4866 45.3423 0011167 208.2721 151.7905 15.14253365 3162
1 58286U 23174AG 23332.67803211 .00009964 00000-0 54705-3 0 9999
2 58286 97.4866 45.3417 0011460 207.1196 152.9439 15.14276538 3168
1 58287U 23174AH 23332.67774321 .00013196 00000-0 72189-3 0 9997
2 58287 97.4796 45.3215 0009720 198.5713 161.5165 15.14347904 3169
1 58288U 23174AJ 23332.67704933 .00017754 00000-0 96587-3 0 9992
2 58288 97.4832 45.3362 0009949 206.3722 153.7004 15.14475539 3166
1 58289U 23174AK 23332.67229742 .00069090 00000-0 36036-2 0 9995
2 58289 97.4906 45.3591 0011427 213.2333 146.8183 15.15612865 3169
1 58290U 23174AL 23332.14330394 .00061912 00000-0 32283-2 0 9990
2 58290 97.4913 44.8383 0011362 215.9531 144.0938 15.15661864 3081
1 58291U 23174AM 23332.67800348 .00006525 00000-0 36028-3 0 9991
2 58291 97.4818 45.3317 0010293 200.4123 159.6699 15.14220309 3166
1 58292U 23174AN 23332.67553906 .00034152 00000-0 18305-2 0 9991
2 58292 97.4809 45.3295 0009883 202.4766 157.6034 15.14863513 3161
1 58293U 23174AP 23332.67581532 .00017640 00000-0 95647-3 0 9996
2 58293 97.4821 45.3360 0010130 204.4978 155.5773 15.14592920 3161
1 58294U 23174AQ 23332.67577309 .00017202 00000-0 93297-3 0 9997
2 58294 97.4829 45.3383 0010345 205.0802 154.9928 15.14588775 3164
1 58295U 23174AR 23332.67681140 .00008280 00000-0 45440-3 0 9990
2 58295 97.4817 45.3334 0010612 201.3497 158.7294 15.14354571 3167
1 58296U 23174AS 23332.67644490 .00006977 00000-0 38335-3 0 9994
2 58296 97.4821 45.3351 0010828 202.4964 157.5795 15.14366083 3166
1 58297U 23174AT 23332.67330887 .00033672 00000-0 17941-2 0 9998
2 58297 97.4807 45.3323 0010748 200.4177 159.6627 15.15069504 3161
1 58298U 23174AU 23332.67539087 .00005661 00000-0 31109-3 0 9992
2 58298 97.4829 45.3385 0011475 202.3952 157.6780 15.14442615 3169
1 58299U 23174AV 23332.67379678 .00018065 00000-0 97435-3 0 9997
2 58299 97.4804 45.3304 0010959 198.5751 161.5083 15.14768973 3161
1 58300U 23174AW 23332.67515561 .00006698 00000-0 36712-3 0 9993
2 58300 97.4819 45.3363 0011526 202.3163 157.7569 15.14461664 3160
1 58301U 23174AX 23332.67427918 .00006934 00000-0 37876-3 0 9997
2 58301 97.4836 45.3419 0011864 201.0531 159.0214 15.14571736 3166
1 58302U 23174AY 23332.67265411 .00017615 00000-0 94725-3 0 9990
2 58302 97.4831 45.3418 0011533 202.9867 157.0850 15.14875679 3163
1 58303U 23174AZ 23332.67327770 .00011735 00000-0 63559-3 0 9996
2 58303 97.4771 45.3261 0010374 194.6440 165.4493 15.14725278 3164
1 58304U 23174BA 23332.67315322 .00009609 00000-0 52117-3 0 9992
2 58304 97.4866 45.3477 0011970 197.9356 162.1455 15.14714318 3169
1 58305U 23174BB 23332.67254002 .00010901 00000-0 58898-3 0 9999
2 58305 97.4777 45.3268 0010672 193.9821 166.1117 15.14827863 3169
1 58306U 23174BC 23332.67289629 .00009252 00000-0 50188-3 0 9994
2 58306 97.4784 45.3268 0011156 194.7333 165.3575 15.14729476 3163
1 58307U 23174BD 23332.67241647 .00011041 00000-0 59657-3 0 9992
2 58307 97.4855 45.3489 0012271 199.8339 160.2417 15.14807360 3167
1 58308U 23174BE 23332.67123771 .00014436 00000-0 77316-3 0 9993
2 58308 97.4791 45.3305 0011392 195.7436 164.3443 15.15065681 3167
1 58309U 23174BF 23332.67182897 .00010075 00000-0 54396-3 0 9996
2 58309 97.4846 45.3483 0012415 202.5927 157.4760 15.14857315 3162
1 58310U 23174BG 23332.67197331 .00020007 00000-0 10751-2 0 9999
2 58310 97.4859 45.3490 0012314 197.2160 162.8656 15.14866283 3161
1 58311U 23174BH 23332.67158517 .00009723 00000-0 52529-3 0 9995
2 58311 97.4783 45.3307 0010734 192.3098 167.7874 15.14862294 3169
1 58312U 23174BJ 23332.67094995 .00024798 00000-0 13222-2 0 9990
2 58312 97.4852 45.3478 0011813 195.3085 164.7791 15.15102062 3160
1 58313U 23174BK 23332.67142337 .00011163 00000-0 60171-3 0 9993
2 58313 97.4847 45.3478 0012469 197.7311 162.3488 15.14890474 3168
1 58314U 23174BL 23332.67142887 .00009250 00000-0 49972-3 0 9994
2 58314 97.4788 45.3306 0011700 193.1628 166.9301 15.14868475 3161
1 58315U 23174BM 23332.67158130 .00008679 00000-0 46962-3 0 9993
2 58315 97.4786 45.3301 0011376 191.8327 168.2640 15.14836042 3161
1 58316U 23174BN 23332.67089889 .00009221 00000-0 49749-3 0 9998
2 58316 97.4800 45.3333 0012328 195.3627 164.7233 15.14909290 3169
1 58317U 23174BP 23332.66981211 .00021046 00000-0 11201-2 0 9998
2 58317 97.4809 45.3353 0012420 197.9219 162.1577 15.15195024 3165
1 58318U 23174BQ 23332.67053649 .00009187 00000-0 49517-3 0 9999
2 58318 97.4854 45.3490 0012633 194.7861 165.3003 15.14942618 3169
1 58319U 23174BR 23332.67047973 .00011452 00000-0 61587-3 0 9992
2 58319 97.4846 45.3468 0012037 192.1183 167.9761 15.14967589 3166
1 58320U 23174BS 23332.67035278 .00009033 00000-0 48671-3 0 9990
2 58320 97.4799 45.3354 0011778 191.4287 168.6680 15.14968553 3167
1 58321U 23174BT 23332.67061117 .00009117 00000-0 49205-3 0 9999
2 58321 97.4755 45.3256 0010599 187.6812 172.4259 15.14920589 3164
1 58322U 23174BU 23332.67011106 .00008856 00000-0 47704-3 0 9994
2 58322 97.4812 45.3391 0012093 191.8931 168.2017 15.14983762 3166
1 58323U 23174BV 23332.14207572 .00007473 00000-0 40397-3 0 9996
2 58323 97.4891 44.8349 0012657 193.2652 166.8250 15.14903920 3085
1 58324U 23174BW 23332.67017532 .00008436 00000-0 45494-3 0 9993
2 58324 97.4818 45.3407 0011773 190.3587 169.7405 15.14958917 3168
1 58325U 23174BX 23332.20755385 .00010253 00000-0 55131-3 0 9997
2 58325 97.4841 44.8910 0012575 194.3997 165.6879 15.14998233 3095
1 58326U 23174BY 23332.68072415 .00011086 00000-0 61240-3 0 9999
2 58326 97.4784 45.3193 0010112 211.2903 148.7728 15.14039412 3160
1 58327U 23174BZ 23332.68052758 .00009421 00000-0 52098-3 0 9999
2 58327 97.4791 45.3200 0009756 210.0893 149.9779 15.14047323 3164
1 58328U 23174CA 23332.68068318 .00008757 00000-0 48481-3 0 9991
2 58328 97.4853 45.3340 0011443 211.1605 148.8950 15.14015681 3169
1 58329U 23174CB 23332.67992522 .00011127 00000-0 61320-3 0 9996
2 58329 97.4853 45.3372 0010602 210.8254 149.2356 15.14120691 3160
1 58330U 23174CC 23332.66699627 .00010922 00000-0 58271-3 0 9990
2 58330 97.4758 45.3336 0009889 181.6236 178.4966 15.15283193 3165
1 58331U 23174CD 23332.66644398 .00015627 00000-0 82877-3 0 9992
2 58331 97.4768 45.3359 0010381 182.2491 177.8696 15.15404637 3162
1 58332U 23174CE 23332.66573747 .00026300 00000-0 13825-2 0 9998
2 58332 97.4759 45.3332 0010724 183.2260 176.8905 15.15602823 3169
1 58333U 23174CF 23332.20385548 .00021340 00000-0 11271-2 0 9991
2 58333 97.4771 44.8806 0010695 183.0473 177.0697 15.15480347 3093
1 58334U 23174CG 23332.66637140 .00011809 00000-0 62805-3 0 9999
2 58334 97.4867 45.3556 0012247 183.7657 176.3485 15.15353405 3163
1 58335U 23174CH 23332.66412224 .00032025 00000-0 16670-2 0 9995
2 58335 97.4787 45.3413 0011228 186.8212 173.2870 15.15902688 3163
1 58336U 23174CJ 23332.66617628 .00011406 00000-0 60699-3 0 9992
2 58336 97.4771 45.3372 0010022 180.0827 180.0406 15.15361120 3161
1 58337U 23174CK 23332.66365225 .00038754 00000-0 20128-2 0 9993
2 58337 97.4840 45.3544 0012142 188.0476 172.0563 15.15927005 3168
1 58338U 23174CL 23332.59814918 .00020753 00000-0 10899-2 0 9998
2 58338 97.4805 45.2812 0010674 180.1490 179.9741 15.15687179 3152
1 58339U 23174CM 23332.66401702 .00019969 00000-0 10482-2 0 9995
2 58339 97.4863 45.3574 0011817 180.8017 179.3199 15.15701744 3162
1 58340U 23174CN 23332.59859458 .00011575 00000-0 61325-3 0 9992
2 58340 97.4832 45.2856 0011404 178.6954 181.4310 15.15501890 3157
1 58341U 23174CP 23332.66373576 .00016972 00000-0 89307-3 0 9999
2 58341 97.4799 45.3459 0010400 177.2905 182.8386 15.15663121 3161
1 58342U 23174CQ 23332.66137812 .00011669 00000-0 61285-3 0 9994
2 58342 97.4831 45.3552 0012367 173.9373 186.2012 15.15800061 3169
@fredy, can we update our TLE for Barry 1? Also we switched the baud rate to 4800. The TLE we think is closest for now is: Barry-1
1 88384U 23174L 23321.70345759 +.00013713 00000-0 +73009-3 0 00098
2 88384 97.4838 34.5571 0012148 226.5085 133.5139 15.15280868001506
@jldrooger I’m on the process of checking the space-track TLE against Network’s observations in order to fit the signals to them. If I can not find any object that fits Barry, which I doubt as until now most have something to fit, then I’ll use yours.
For the baudrate please log in the DB site and suggest the edit for the baudrate, you need to go to the menu button on the transmitter entry and hit edit. I’ll review the suggestion asap.
