SpaceX F9: Transporter-11 Rideshare : VSFB SLC-4E - 2024-08-16 18:56 UTC
And 60543 Arctic Weather Satellite on 2230 MHz
I’m back, after almost one month, and I went through the list of the T11 satellites in order to update the status.
Some notes:
  • It looks like that finally we have 113 objects for this launch
  • About LUR-1, it looks like we have tracked the wrong transmission. The transmission that we observed in LUR-1 observations was YAM-7. I’ve made all the necessary changes in DB and Network to fix it, more specificaly a new satellite entry for LUR-1 is added by @pe2bz, as well as a new transmitter by @pe2bz and updated with more details by @pe0sat, for the old LUR-1 entry I’ve merged it with the YAM-7 entry and moved all the observations to YAM-7 entry.
  • Identification below is based mostly on Network observations and confirmed in space-track.org. However some of them are only based on space-track.org, so there is a small possibility not to be accurate. In the last update column is described how we identified the satellites.
  • Usually I’m uploading results from ikhnos on archive.org about the identification based on Network observations, but due to the recent issues with the archive.org I’ve kept the results locally. Anyone can replicate easily the results by running ikhnos on any of the satellite’s good observations. If someone needs any help or extra evidence, let me know here or with pm.
  • We have two remaining unknown satellites, the one is received (Unknown_3_T11) and identified as object but we don’t have any hints which one is it, the other (Unknown_2_T11) is probably received and it is probably LEMU-NGE but we need more observations with the updated TLE (based on space-track.org identification) to confirm it.
  • I haven’t checked all the space-track.org identified objects, so many satellites not in DB or not received remain unidentified in SatNOGS DB, I’m going to check them the next days
Temporary NORAD ID Satellite NORAD ID to follow Other NORAD IDs Identified Deployed Reception Last Update
RECEIVED AND DEMODULATED
BRO-14 60551 - YES YES Received (03 F6 in demodulated data) Identified, by Network observations and verified by space-track.org
BRO-15 60553 - YES YES Received (03 F7 in demodulated data) Identified, by Network observations and verified by space-track.org
PTD-R 60523 - YES YES Received Identified, by Network observations and verified by space-track.org
PTD-4 60565 - YES YES Received Identified, by Network observations and verified by space-track.org
IPERDRONE.0 60520 - YES YES Received Identified, by Network observations and verified by space-track.org
ION SCV-012 60573 - YES YES Received Identified, by Network observations and verified by space-track.org
QUBE 60476 - YES YES Received Identified, by Network observations. Not identified in space-track.org
WARATAH SEED-1 60469 - YES YES Received Identified, by Network observations and verified by space-track.org
CUAVA-2 60527 - YES YES Received Identified, by Network observations and verified by space-track.org
NIGHTJAR 60535 - YES YES Received Identified, by Network observations. Not identified in space-track.org
TORO 60530 - YES YES Received Identified, by Network observations. Not identified in space-track.org
ORESAT0.5 60525 - YES YES Received Identified, by Network observations. Not identified in space-track.org
CONNECTAIOT-1 60472 - YES YES Received Identified, by Network observations and verified by space-track.org
CONNECTAIOT-2 60522 - YES YES Received Identified, by Network observations and verified by space-track.org
CONNECTAIOT-3 60475 - YES YES Received Identified, by Network observations and verified by space-track.org
CONNECTAIOT-4 60524 - YES YES Received Identified, by Network observations and verified by space-track.org
KANYINI 60556 - YES YES Received Identified, by Network observations. Not identified in space-track.org
ERNST 60528 - YES YES Received Identified, by Network observations and verified by space-track.org
SATORO-T2 60477 - YES YES Received Identified, by Network observations and verified by space-track.org
GAINDESAT-1A 60529 - YES YES Received Identified, by Network observations. Not identified in space-track.org
98818 PICO-1B-1 60572 all the non-identified - YES Received by tinygs Change to follow 60572 based on tinygs.com
98819 PICO-1B-2 60571 all the non-identified - YES Received by tinygs Change to follow 60571 based on tinygs.com
98820 PICO-1B-3 60564 all the non-identified - YES Received by tinygs Change to follow 60564 based on tinygs.com
98821 PICO-1B-4 60568 all the non-identified - YES Received by tinygs Change to follow 60568 based on tinygs.com
98822 PICO-1B-5 60572 all the non-identified - YES Received by tinygs Change to follow 60572 based on tinygs.com
98823 PICO-1B-6 60538 all the non-identified - YES Received by tinygs Change to follow 60538 based on tinygs.com
98824 PICO-1B-7 60567 all the non-identified - YES Received by tinygs Change to follow 60567 based on tinygs.com
98825 PICO-1B-8 60566 all the non-identified - YES Received by tinygs Change to follow 60566 based on tinygs.com
98826 PICO-1B-9 60570 all the non-identified - YES Received by tinygs Change to follow 60570 based on tinygs.com
RECEIVED
UM5-EOSAT 60555 - YES YES Received Identified, by Network observations and verified by space-track.org
UM5SAT-RIBAT 60554 - YES YES Received Identified, by Network observations and verified by space-track.org
LEMUR-2-TOMATOKECHUP 60471 - YES YES Received Identified, by space-track.org and verified by Network observations
LEMUR-2-STELLA 60533 - YES YES Received Identified, by space-track.org and verified by Network observations
WREN-1 60478 - YES YES Received Identified, by Network observations and verified by space-track.org
QPS-SAR-8 60542 - YES YES Received Identified, by space-track.org
LUR-1 60506 - YES YES Received Identified, by space-track.org and verified by strf and Network observations
YAM-7 60504 - YES YES Received Identified, by space-track.org and verified by Network observations
LEMUR-2-MARHISYAM 60536 - YES YES Received Identified, by space-track.org and verified by Network observations
DEIMOS 60526 - YES YES Received Identified, by Network observations and verified by space-track.org
Arctic Weather Satellite 60543 - YES YES Received Identified, by space-track.org and verified by strf observations
ICEYE X40 60549 - YES YES Received Identified, by space-track.org and verified by strf observations
Unknown_3_T11 60468 - YES(as transmission, not as satellite) YES Received Identified (as transmission not as satellite), by Network observations
CLAIMED RECEIVED WITHOUT PUBLIC EVIDENCE
TYCHE 60496 - YES YES Received Identified, by space-track.org
TANAGER-1 60507 - YES YES Received Identified, by space-track.org
EAGLEEYE 60508 - YES YES Received Identified, by space-track.org
NOT RECEIVED
Sedna-1 60580 - YES YES Identified, by space-track.org
LEMU NGE 60506 - YES YES Identified, by space-track.org
98814 Unknown_2_T11 60532 - - YES Changed to follow 60532
98852 HYPSO-2 - - - YES
98828 GNA-3 - - - YES
98832 UMBRA 09 - - - YES
98833 UMBRA 10 - - - YES
98835 TOMORROW-S2 - - - YES
98836 TOMORROW-S1 - - - YES
98841 GYESMES-5 - - - YES
98848 HYPERFIELD-1 - - - YES
98861 CAKRA-1 - - - YES
98863 ACADIA-5 - - - YES
99012 SATELIOT 4 - - - YES
99013 SATELIOT 3 - - - YES
99014 SATELIOT 2 - - - YES
99015 SATELIOT 1 - - - YES
NOT IN DB
- FLOCK 4BE 10 - - - YES
- FLOCK 4BE 11 - - - YES
- FLOCK 4BE 12 - - - YES
- FLOCK 4BE 13 - - - YES
- FLOCK 4BE 14 - - - YES
- FLOCK 4BE 15 - - - YES
- FLOCK 4BE 16 - - - YES
- FLOCK 4BE 17 - - - YES
- FLOCK 4BE 18 - - - YES
- FLOCK 4BE 19 - - - YES
- FLOCK 4BE 1 - - - YES
- FLOCK 4BE 20 - - - YES
- FLOCK 4BE 21 - - - YES
- FLOCK 4BE 22 - - - YES
- FLOCK 4BE 23 - - - YES
- FLOCK 4BE 24 - - - YES
- FLOCK 4BE 25 - - - YES
- FLOCK 4BE 26 - - - YES
- FLOCK 4BE 27 - - - YES
- FLOCK 4BE 28 - - - YES
- FLOCK 4BE 29 - - - YES
- FLOCK 4BE 2 - - - YES
- FLOCK 4BE 30 - - - YES
- FLOCK 4BE 31 - - - YES
- FLOCK 4BE 32 - - - YES
- FLOCK 4BE 33 - - - YES
- FLOCK 4BE 34 - - - YES
- FLOCK 4BE 35 - - - YES
- FLOCK 4BE 36 - - - YES
- FLOCK 4BE 3 - - - YES
- FLOCK 4BE 4 - - - YES
- FLOCK 4BE 5 - - - YES
- FLOCK 4BE 6 - - - YES
- FLOCK 4BE 7 - - - YES
- FLOCK 4BE 8 - - - YES
- FLOCK 4BE 9 - - - YES
- HAWK-10A - - - YES Received
- HAWK-10B - - - YES Received
- HAWK-10C - - - YES Received
- ICEYE 33 - - - YES Received
- ICEYE 39 - - - YES Received
- ICEYE 43 - - - YES Received
- NUSAT-48 - - - YES Received
- NUSAT-49 - - - YES Received
- NUSAT-50 - - - YES Received
- PHISAT-2 - - - YES Received
- ROCK LOPEN - - - YES
- TROOP - F2 - - - YES
Looks like 60521 Object BF is at 2219 MHz
Confirmed :slight_smile: added as suggestion to DB
60548 ICEYE-X33
Need one more to confirm but usally these fit right in the first observation
Edit: Found one obs from a day before, so suggested satellite and added transmitter for it.
60472 CONNECTA IOT-1 on 2240 MHz ?
LUR-1 on S-band 2217 MHz
@K4KDR Scott, can you give this one a checkup ? From the waterfall it looks like 125 kHz wide which could be a match with a LoRa mode ?
Sure will!
While I wait for the next pass here, do you have any audio or I/Q recordings?
I have strf only :smiling_face_with_sunglasses:
I see on SatNogs that LUR-1 does list 2217 MHz as a downlink freq.
Finally after a long wait, I have a decent pass later tonight.
Have you seen any additional instances of that wide-band downlink?
LUR-1 was super strong on 400 MHz 15-Oct @ 0345utc over the Eastern U.S., but nothing seen on 2217 MHz. I wonder if you might be near a ground station that Spain is using? Perhaps S-Band is only used when in-range of a ground station?
Here is a single burst of 9k6 AX.100 packets at exactly the right time - decoded 12 frames.
… if anyone manages to capture an I/Q recording of these wide-band signals from LUR-1, I sure would like to analyze. Sample rate of 625k or greater would be extremely helpful. Thanks!
Yes, I noticed another pass of that signal. Let me try and record an s-band pass the upcoming weekend. Now which SDR is attached to which antenna again… In the middle of reorganazation of the mess :slight_smile:
Edit: Wired the strf hackrf to windows PC running sdrconsole. Scheduled recording for the 12:21 and 13:55 local time passes , 32 and 25 degrees elevation.
I think I might do this again but with 2217 MHz not in the center ?
30 seconds from the pass before
32 bit iq created with datafile editor from sdr console, 675 kHz bandwidth, 2217 center, 32 bits iq
trying to receord another 2 passes tonight away from the dc spike
Yes - that’s why I prefer Airspy products… no center spike!
Thanks for the I/Q file, but we’ll need a higher pass (i.e., more SNR) to tell much. In inspectrum, it’s just a smudge.
And no S- band :sweat_smile:
This friday 13:03 local time I expect a 73 degrees elevation pass. and 23:50 another 79 degrees pass. I will record tonight’s passes to check, if signal is not clearly improved I will skip the upload till friday
3 passes with 45+ degrees elevation but no trace of the “lora like” signal, only a much wider transmission ( 1MHz or more) in all 3 passes.
