Wanted to mention some updates on the sonik.space page… several more objects on that list are now showing as “ACTIVE”.
Also, at the bottom of the image below, note the -4- Grifon sats… I have received LoRa decodes from #1 and #3 (listed on tinyGS as using SF=9). However, I got zero decodes listening for either of the others using SF=10. So, I don’t know if only two are communicating currently or if that SF=10 parameter is an error.
Anybody knows the status of the Galapagos and its SSTV transmissions ???
I got a couple on 29-Dec, but with my attention being spent on so many of the other sats, have not monitored any passes since then.
I listened out for it a few days back but did not here it.
20260104.41-20260107.82, 81 measurements, 0.052 kHz rms
LOBACHEVSKY
1 98423U 25313X   26007.81780737  .00000000  00000-0  13724-3 0    09
2 98423  97.4100  85.0434 0016070 187.5291 221.3397 15.20937522    03
Which fit this TLE better
OBJECT AN
1 67284U 25313AN  26006.95361696  .00004494  00000+0  20591-3 0  9990
2 67284  97.4106  84.2589 0010487 198.4327 161.6530 15.20934831  1432
The full list of objects by NORAD (https://celestrak.org/NORAD/elements/gp.php?INTDES=2025-313&FORMAT=tle)
OBJECT A
1 67248U 25313A   26006.95413144  .00002178  00000+0  22149-3 0  9994
2 67248  97.5641  83.7477 0280314 134.4591 227.9917 14.66765523  1386
OBJECT B
1 67249U 25313B   26006.91471311  .00005330  00000+0  40926-3 0  9997
2 67249  97.5328  83.7499 0297656 139.1132 223.2825 14.73121151  1381
OBJECT C
1 67250U 25313C   26006.91293020  .00019875  00000+0  18625-2 0  9997
2 67250  97.6370  84.0467 0163639 149.4877 211.5985 14.84390876  1395
OBJECT D
1 67251U 25313D   26006.95233771  .00004700  00000+0  41066-3 0  9996
2 67251  97.5882  84.0724 0152177 142.1153 219.0891 14.88686704  1404
OBJECT E
1 67252U 25313E   26006.95057061  .00009715  00000+0  43394-3 0  9990
2 67252  97.4122  84.2717 0010417 184.6271 175.4870 15.21504695  1438
OBJECT F
1 67253U 25313F   26006.95455570  .00047629  00000+0  49747-3 0  9992
2 67253  97.1039  84.2234 0010067 205.4372 154.6394 15.64293194  1450
OBJECT G
1 67254U 25313G   26006.95484365  .00044656  00000+0  46787-3 0  9995
2 67254  97.1037  84.2228 0010255 206.3873 153.6866 15.64225039  1442
OBJECT H
1 67255U 25313H   26006.73610101  .00002281  00000+0  16313-3 0  9991
2 67255  97.3117  83.6918 0090294 164.1192 196.2899 15.02134996  1384
OBJECT J
1 67256U 25313J   26006.96152778  .00011494  00000+0  53888-3 0  9992
2 67256  97.4109  84.2529 0016323 204.0376 156.0099 15.19722541  1430
OBJECT K
1 67257U 25313K   26006.76373291  .00010350  00000+0  48534-3 0  9998
2 67257  97.4119  84.0599 0016008 207.0067 153.0337 15.19749387  1403
OBJECT L
1 67258U 25313L   26006.96112769  .00011194  00000+0  52400-3 0  9996
2 67258  97.4113  84.2528 0016011 205.6730 154.3712 15.19788464  1430
OBJECT M
1 67259U 25313M   26006.95988140  .00014270  00000+0  66230-3 0  9994
2 67259  97.4156  84.2716 0015159 203.6003 156.4538 15.20034916  1437
OBJECT N
1 67260U 25313N   26006.76270795  .00009140  00000+0  42722-3 0  9995
2 67260  97.4125  84.0617 0015317 206.8377 153.2068 15.19906542  1409
OBJECT P
1 67261U 25313P   26006.95945761  .00018992  00000+0  87664-3 0  9998
2 67261  97.4157  84.2725 0015104 204.2068 155.8459 15.20161524  1430
OBJECT Q
1 67262U 25313Q   26006.95972019  .00012726  00000+0  59111-3 0  9990
2 67262  97.4124  84.2566 0015086 206.1997 153.8476 15.20036933  1431
OBJECT R
1 67263U 25313R   26006.95976897  .00011036  00000+0  51356-3 0  9995
2 67263  97.4136  84.2697 0015006 205.1371 154.9135 15.20010346  1431
OBJECT S
1 67264U 25313S   26006.82831412  .00008225  00000+0  38458-3 0  9999
2 67264  97.4206  84.1306 0014935 211.0002 149.0353 15.19932381  1418
OBJECT T
1 67265U 25313T   26006.95957023  .00010515  00000+0  48902-3 0  9991
2 67265  97.4116  84.2669 0014907 206.0750 153.9736 15.20044292  1433
OBJECT U
1 67266U 25313U   26006.95955220  .00011455  00000+0  53241-3 0  9995
2 67266  97.4144  84.2699 0014870 204.5636 155.4892 15.20044424  1430
OBJECT V
1 67267U 25313V   26006.95940160  .00012879  00000+0  59750-3 0  9995
2 67267  97.4126  84.2592 0014076 210.5830 149.4585 15.20088106  1431
OBJECT W
1 67268U 25313W   26006.95959301  .00010148  00000+0  47240-3 0  9991
2 67268  97.4125  84.2574 0014995 205.5027 154.5470 15.20020395  1439
OBJECT X
1 67269U 25313X   26006.95936354  .00015207  00000+0  70371-3 0  9997
2 67269  97.4152  84.2706 0014886 203.8910 156.1636 15.20127115  1438
OBJECT Y
1 67270U 25313Y   26006.95973517  .00011653  00000+0  54192-3 0  9995
2 67270  97.4127  84.2676 0014947 205.8221 154.2270 15.20017795  1438
OBJECT Z
1 67271U 25313Z   26006.95981433  .00006106  00000+0  28638-3 0  9995
2 67271  97.4122  84.2586 0014892 201.3795 158.6820 15.19936454  1439
OBJECT AA
1 67272U 25313AA  26006.95908818  .00014846  00000+0  68626-3 0  9993
2 67272  97.4124  84.2575 0014708 206.1286 153.9209 15.20170958  1434
OBJECT AB
1 67273U 25313AB  26006.69631881  .00004667  00000+0  21974-3 0  9993
2 67273  97.4141  84.0013 0013752 211.4127 148.6288 15.19940621  1393
OBJECT AC
1 67274U 25313AC  26006.95928763  .00008688  00000+0  40466-3 0  9995
2 67274  97.4115  84.2663 0014583 205.2480 154.8044 15.20052905  1439
OBJECT AD
1 67275U 25313AD  26006.82731512  .00009060  00000+0  42130-3 0  9991
2 67275  97.4089  84.1347 0013840 208.5857 151.4620 15.20105301  1417
OBJECT AE
1 67276U 25313AE  26006.95894458  .00008562  00000+0  39830-3 0  9994
2 67276  97.4093  84.2639 0013784 208.0475 152.0019 15.20110412  1436
OBJECT AF
1 67277U 25313AF  26006.95900504  .00008047  00000+0  37482-3 0  9994
2 67277  97.4096  84.2645 0013752 207.9362 152.1137 15.20086813  1434
OBJECT AG
1 67278U 25313AG  26006.95892595  .00007910  00000+0  36833-3 0  9992
2 67278  97.4098  84.2652 0013727 207.7161 152.3344 15.20101162  1440
OBJECT AH
1 67279U 25313AH  26006.89285982  .00009336  00000+0  43325-3 0  9990
2 67279  97.4109  84.2019 0014300 205.0970 154.9572 15.20160083  1424
OBJECT AJ
1 67280U 25313AJ  26006.95643210  .00005610  00000+0  25936-3 0  9990
2 67280  97.4180  84.2655 0013182 201.0598 159.0096 15.20487006  1435
OBJECT AK
1 67281U 25313AK  26006.95587744  .00005659  00000+0  26103-3 0  9990
2 67281  97.4064  84.2627 0011898 199.7513 160.3263 15.20578136  1434
OBJECT AL
1 67282U 25313AL  26006.95369905  .00007244  00000+0  32970-3 0  9999
2 67282  97.4112  84.2597 0010667 198.6554 161.4292 15.20952964  1430
OBJECT AM
1 67283U 25313AM  26006.95346492  .00010219  00000+0  46259-3 0  9997
2 67283  97.4120  84.2611 0010629 198.6401 161.4447 15.21032239  1433
OBJECT AN
OBJECT AP
1 67285U 25313AP  26006.95301009  .00009995  00000+0  45161-3 0  9994
2 67285  97.4098  84.2585 0010207 200.1097 159.9738 15.21103659  1431
OBJECT AQ
1 67286U 25313AQ  26006.82109325  .00009164  00000+0  41394-3 0  9990
2 67286  97.4118  84.1403 0009850 196.6126 163.4788 15.21144998  1411
OBJECT AR
1 67287U 25313AR  26006.75512462  .00011800  00000+0  53101-3 0  9992
2 67287  97.4120  84.0763 0009815 197.3119 162.7783 15.21203014  1405
OBJECT AS
1 67288U 25313AS  26006.88687582  .00007218  00000+0  32682-3 0  9992
2 67288  97.4107  84.2032 0011589 189.4159 170.6862 15.21122454  1425
OBJECT AT
1 67289U 25313AT  26006.95212781  .00014611  00000+0  65454-3 0  9994
2 67289  97.4120  84.2717 0009792 196.9750 163.1159 15.21307251  1431
OBJECT AU
1 67290U 25313AU  26006.95203761  .00011823  00000+0  53079-3 0  9996
2 67290  97.4119  84.2715 0009577 195.9225 164.1711 15.21286088  1435
OBJECT AV
1 67291U 25313AV  26006.95187254  .00013002  00000+0  58264-3 0  9997
2 67291  97.4117  84.2717 0009489 195.9969 164.0968 15.21328411  1433
OBJECT AW
1 67292U 25313AW  26006.95147393  .00011857  00000+0  53096-3 0  9992
2 67292  97.4123  84.2730 0009208 195.8667 164.2282 15.21377094  1431
OBJECT AX
1 67293U 25313AX  26006.95174662  .00005333  00000+0  24142-3 0  9994
2 67293  97.4119  84.2698 0011100 186.4208 173.6887 15.21255995  1431
OBJECT AY
1 67294U 25313AY  26006.75390468  .00013225  00000+0  59101-3 0  9999
2 67294  97.4125  84.0789 0009100 197.0953 162.9977 15.21420180  1408
OBJECT AZ
1 67295U 25313AZ  26006.75382721  .00010707  00000+0  47915-3 0  9995
2 67295  97.4117  84.0765 0010600 187.0967 173.0120 15.21411200  1401
OBJECT BA
1 67296U 25313BA  26006.95091199  .00012126  00000+0  54141-3 0  9990
2 67296  97.4130  84.2746 0008874 196.4880 163.6069 15.21473934  1438
OBJECT BB
1 67297U 25313BB  26006.95057713  .00012100  00000+0  53943-3 0  9996
2 67297  97.4133  84.2748 0008593 198.2591 161.8337 15.21528135  1433
For now, the following ID’s
Updated 09-01-2026 12:50 UTC
67291 2025-313AV 435.240 SCORPION
67282 2025-313AL 436.320 LOBACHEVSKY
67255 2025-313H  436.740 ?
67293 2025-313AX 436.951 QMR-KWT-2
67287 2025-313AR 437.180 LUCA
67279 2025-313AU 437.050 GALAPAGOS-UTE-SWSU
67271 2025-313Z  437.200 ?
67290 2025-313AU 437.350 SAKHACUBE-CHOLBON
Let’s TLE lottery begin!
There is our attempt to identify some satellites:
Satellite         |  NORAD ID |RMS [Hz]| Next candidate |RMS [Hz]
Luca-1		      |   67287   |  134   |      67286     | 296
QMR-KWT-2         |   67291   |  141   |      67293     | 189
SAKHACUBE-CHOLBON |   67289   |  76    |      67290     | 127
This one is another unknown at 436.740 with a very wide signal.
Again an update and other unknown satellites
67283 2025-313AM 435.550 ?
67254 2025-313G  435.850 ?
67253 2025-313F  436.090 ?
An example:
Whatever this unk. LoRa downlink is on 436.550 (Object #98423), it tracks very closely each day with passes of KOSAR-1.5. I guess eventually these objects will spread out enough that the source can be narrowed down.
IQ recording from object 67271. Details: Center 437.200, sample rate 1.25e6 PCM 16
It seems to be some kind of RTTY but with a very wide shift.
Maybe if you have more experience with RTTY you can try to decode it.
Another TLE Lottery update
67279 2025-313AH 435.750 GALAPAGOS-UTE-SWSU
437200000Hz_10-01-2026T12:18:19_1250000_IQ.wav
time in UTC+0 ?
Please correct:
67279 - obj. 2025-313AH
It’s the same signal PU4ELT observed.
IQ is UTC+1 CET
What would you suggest Vlad ?
Removed duplicate
67279 2025-313AH 437.050, 435.750 GALAPAGOS-UTE-SWSU
