Soyuz-2.1b/Fregat launch planned at 28 December 2025 with two AIST-2T as main payload.
Satellites we know about on this launch:
Initial post
Temporary NORAD ID Satellite Frequency Callsign Notes
COMMERCIAL UHF
98446 Sitro-AIS-57 401,0025 SC2371
98445 Sitro-AIS-58 401,0325 SC2359
98444 Sitro-AIS-59 401,0475 SC2356
98443 Sitro-AIS-60 401,0625 SC2348
98442 Sitro-AIS-61 401,0775 SC2349
98441 Sitro-AIS-62 401,0925 SC2372
98440 Sitro-AIS-63 401,1075 SC2351
98439 Sitro-AIS-64 401,1225 SC2352
98438 Sitro-AIS-65 401,1375 SC2353
98437 Sitro-TD-3 401,1725 SC2345
98436 Sitro-TD-4 401,1975 SC2354
98435 Zorkiy-2M VPE 401.2125, 401.18 A0X8A, A0X8B
98434 Zorkiy-2M 5 401.23, 401.165 A0X9A, A0X9B
98433 Zorkiy-2M 7 401.0175, 401.245 A0XAA, A0XAB
98432 DCS-1 401.15 SCA0KR
98431 NasbSat-1 401.5, 401.6 S3809A, S3809B
98430 NasbSat-2 401.7, 401.8 A2S5A, A2S5B
AMATEUR UHF
98450 SAKHACUBE-CHOLBON 437,350 RS18S IARU Coordinated
98449 Luca-1 437,180 RS90S IARU Coordination in progress
98448 QMR-KWT-2 436,950 RS95S IARU Coordinated
OTHER
AIST-2T N1
AIST-2T N2
QMR-KWT-2 carries amateur repeater with 2m-band uplink.
Last update: 2025-12-29 18:15 UTC
Temporary NORAD ID Satellite Frequency Modulation Notes Deployment
AMATEUR VHF
98429 Lobachevsky 145.910 MHz AFSK 1200.0 - Directly
98429 Lobachevsky 145.910 MHz FM - Directly
COMMERCIAL UHF
98446 Sitro-AIS-57 401.002 MHz GMSK USP 2400.0 - Directly
98433 Zorkiy-2M 7 401.017 MHz GMSK USP 2400.0 - Directly
98445 Sitro-AIS-58 401.033 MHz GMSK USP 2400.0 - Directly
98444 Sitro-AIS-59 401.048 MHz GMSK USP 2400.0 - Directly
98443 Sitro-AIS-60 401.062 MHz GMSK USP 2400.0 - Directly
98442 Sitro-AIS-61 401.077 MHz GMSK USP 2400.0 - Directly
98441 Sitro-AIS-62 401.092 MHz GMSK USP 2400.0 - Directly
98440 Sitro-AIS-63 401.108 MHz GMSK USP 2400.0 - Directly
98439 Sitro-AIS-64 401.123 MHz GMSK USP 2400.0 - Directly
98438 Sitro-AIS-65 401.137 MHz GMSK USP 2400.0 - Directly
98432 DCS-1 401.150 MHz GMSK USP 2400.0 - Directly
98434 Zorkiy-2M 5 401.165 MHz GMSK USP 2400.0 - Directly
98437 Sitro-TD-3 401.173 MHz GMSK USP 2400.0 - Directly
98435 Zorkiy-2M VPE 401.180 MHz GMSK USP 2400.0 - Directly
98436 Sitro-TD-4 401.197 MHz GMSK USP 2400.0 - Directly
98435 Zorkiy-2M VPE 401.212 MHz GMSK USP 2400.0 - Directly
98434 Zorkiy-2M 5 401.230 MHz GMSK USP 2400.0 - Directly
98433 Zorkiy-2M 7 401.245 MHz GMSK USP 2400.0 - Directly
98402 Grifon-1 401.315 MHz LoRa 125000.0 - Directly
98401 Grifon-2 401.315 MHz LoRa 125000.0 - Directly
98400 Grifon-3 401.400 MHz LoRa 125000.0 - Directly
98399 Grifon-4 401.400 MHz LoRa 125000.0 - Directly
98431 NasbSat-1 401.500 MHz GMSK USP 2400.0 - Directly
98431 NasbSat-1 401.600 MHz GMSK USP 2400.0 - Directly
98430 NasbSat-2 401.700 MHz GMSK USP 2400.0 - Directly
98430 NasbSat-2 401.800 MHz GMSK USP 2400.0 - Directly
AMATEUR UHF
98427 SCORPION 435.240 MHz AFSK 1143.0 - Directly
98427 SCORPION 435.240 MHz DOKA 9600.0 - Directly
98426 KOSAR-1.5 436.100 MHz LoRa - Directly
98429 Lobachevsky 436.320 MHz GFSK 9600.0 - Directly
98429 Lobachevsky 436.320 MHz SSDV - Directly
98429 Lobachevsky 436.320 MHz SSTV - Directly
98425 Mule 4T 436.700 MHz LoRa - Directly
98448 QMR-KWT 2 436.950 MHz FM - Directly
98448 QMR-KWT 2 436.950 MHz SSTV - Directly
98448 QMR-KWT 2 436.950 MHz GMSK 4800.0 - Directly
98428 GALAPAGOS-UTE-SWSU 437.050 MHz SSTV - Directly
98428 GALAPAGOS-UTE-SWSU 437.050 MHz AFSK 1143.0 - Directly
98449 Luca 437.180 MHz GMSK 4800.0 - Directly
98450 SAKHACUBE-CHOLBON 437.350 MHz SSTV - Directly
98450 SAKHACUBE-CHOLBON 437.350 MHz GMSK USP 2400.0 - Directly
98450 SAKHACUBE-CHOLBON 437.350 MHz GMSK 9600.0 - Directly
OTHER Frequency Bands
98429 Lobachevsky 10470.000 MHz DVB-S2 - Directly
There are expected orbital parameters:
25-12-2025_Launch_TLE.txt (3.0 KB)
SatNOGS DB entries:
SAKHACUBE-CHOLBON
Luca
QMR-KWT 2
More info about the launch:
For a couple of weeks now I am unable to open the https://en.sonik.space/ website
I tried Firefox and Brave, it looks that some css style sheets can’t be loaded.
Here a screenshot
There seems to be a content security policy that stops loading.
It’s displayed to me correctly using Waterfox.
Hey, Jan!
I’ll take a look what I can do about it. Thanks for sharing an issue.
Same issue here. It seemed like the problem was resolved a few days ago, but it’s here again.
works fine here as https://sonik.space/ under Chrome. Then I allow Google translate to go from Russian to English.
There is also a translated page https://en.soniks.space/ and there seems to be the issue.
agree, same problem here. Thus my use of the untranslated page, then let google translate do the work. Not perfect, but workable.
Based on previous satellites and launches I created a list of gr-satellites Yaml files that are part of this launch.
If there are errors or updates, then please let me know.
superb. yaml master. :dizzy:
Satellites added in DB, in the next hour transmitters will be also added.
I’ve updated the first post with the temporary NORAD IDs.
Satellites will be ready for scheduling in Network near the launch time.
Transmitters are in DB too, please take a look and let me know if something isn’t right.
TLE provided above changed to use temporary NORAD IDs of DB entries:
SITRO-AIS-57
1 98446U 14087A   25362.65607639  .00000000  00000-0  00000-0 0  9991
2 98446  97.5494  74.7763 0008345 198.4892  48.5477 15.20742974000013
SITRO-AIS-61
1 98442U 14087A   25362.65642361  .00000000  00000-0  00000-0 0  9998
2 98442  97.5515  74.7821 0006193 138.2731 110.6700 15.22458020000019
NASBSat-2
1 98430U 14087A   25362.65642361  .00000000  00000-0  00000-0 0  9995
2 98430  97.5482  74.7733 0005950 152.5108  96.4298 15.22110850000017
SITRO-AIS-65
1 98438U 14087A   25362.65723380  .00000000  00000-0  00000-0 0  9994
2 98438  97.5527  74.7878 0007527 193.472   59.8969 15.20986783000013
SITRO-AIS-58
1 98445U 14087A   25362.65758102  .00000000  00000-0  00000-0 0  9992
2 98445  97.5497  74.7776 0008104 199.1872  56.0778 15.20768726000019
SITRO-AIS-62
1 98441U 14087A   25362.65792824  .00000000  00000-0  00000-0 0  9997
2 98441  97.5511  74.7836 0006430 139.6959 117.4814 15.22431762000016
DCS-1
1 98432U 14087A   25362.65850694  .00000000  00000-0  00000-0 0  9997
2 98432  97.5518  74.7892 0007371 193.5482  66.7837 15.21010713000019
SITRO-AIS-59
1 98444U 14087A   25362.65885417  .00000000  00000-0  00000-0 0  9991
2 98444  97.55    74.7787 0007890 199.3829  62.8443 15.20804039000012
SITRO-AIS-63
1 98440U 14087A   25362.65920139  .00000000  00000-0  00000-0 0  9998
2 98440  97.5507  74.7848 0006598 141.2768 122.8677 15.22396034000014
SITRO-TD-3
1 98437U 14087A   25362.65978009  .00000000  00000-0  00000-0 0  9993
2 98437  97.5508  74.7904 0007212 193.1938  74.1011 15.21047451000019
SITRO-AIS-60
1 98443U 14087A   25362.66012731  .00000000  00000-0  00000-0 0  9992
2 98443  97.5504  74.7798 0007681 199.2246  69.9650 15.20849973000011
SITRO-AIS-64
1 98439U 14087A   25362.66047454  .00000000  00000-0  00000-0 0  9997
2 98439  97.5504  74.7860 0006722 143.1496 127.9619 15.22347261000011
SITRO-TD-4
1 98436U 14087A   25362.66105324  .00000000  00000-0  00000-0 0  9995
2 98436  97.5498  74.7915 0007079 192.7628  81.4952 15.21085385000013
NASBSat-1
1 98431U 14087A   25362.66122685  .00000000  00000-0  00000-0 0  9999
2 98431  97.5502  74.7865 0006723 145.4221 129.8058 15.22283419000010
Luca-1
1 98449U 14087A   25362.66174769  .00000000  00000-0  00000-0 0  9998
2 98449  97.55    74.7869 0006729 146.6344 131.4433 15.22247693000016
Zorkiy-2M 7
1 98433U 14087A   25362.66174769  .00000000  00000-0  00000-0 0  9991
2 98433  97.5508  74.7818 0007115 194.1003  83.9534 15.21059869000019
Zorkiy-2M VPE
1 98435U 14087A   25362.66348380  .00000000  00000-0  00000-0 0  9995
2 98435  97.5502  74.7864 0007980 152.1305 135.4342 15.22303434000016
Zorkiy-2M 5
1 98434U 14087A   25362.66521991  .00000000  00000-0  00000-0 0  9995
2 98434  97.5502  74.7879 0008090 153.8669 143.1983 15.22274995000011
QMR-KWT-2
1 98448U 14087A   25362.66174769  .00000000  00000-0  00000-0 0  9997
2 98448  97.55    74.7869 0006729 146.6344 131.4433 15.22247693000015
SAKHACUBE-CHOLBON
1 98450U 14087A   25362.66174769  .00000000  00000-0  00000-0 0  9990
2 98450  97.55    74.7869 0006729 146.6344 131.4433 15.22247693000018
In total 1411 observations have been scheduled for the first ~48h after deployment of the satellites. We have used the TLE sets in the previous post.
  • Frequency of transmission of the satellite
Temp NORAD ID Satellite Scheduled Observations
98449 Luca 155
98436 Sitro-TD-4 45
98444 Sitro-AIS-59 44
98443 Sitro-AIS-60 44
98435 Zorkiy-2M VPE 61
98448 QMR-KWT 2 190
98433 Zorkiy-2M 7 65
98450 SAKHACUBE-CHOLBON 226
98438 Sitro-AIS-65 44
98445 Sitro-AIS-58 44
98437 Sitro-TD-3 44
98432 DCS-1 44
98430 NasbSat-2 63
98431 NasbSat-1 63
98441 Sitro-AIS-62 43
98442 Sitro-AIS-61 43
98440 Sitro-AIS-63 43
98434 Zorkiy-2M 5 63
98446 Sitro-AIS-57 44
98439 Sitro-AIS-64 43
Total 1411
Lobachevsky is also on the rocket. 436.320 MHz GFSK 9600
Added in DB with the temporary NORAD ID 98429 and I’m going to use the TLE of SAKHACUBE-CHOLBON from above, changed to use this temporary NORAD ID:
Lobachevsky
1 98429U 14087A   25362.66174769  .00000000  00000-0  00000-0 0  9996
2 98429  97.5500  74.7869 0006729 146.6344 131.4433 15.22247693000014
I’ll remove some the scheduled observations to share this time with Lobachevsky satellite.
It looks empty from first observation of Sitro-AIS-59 but there is something on the middle left side of the waterfall.
From another satellite?
