SamSat-Ionosphere RS75S 07:19:37 UTC, Replay IQ wav
TLE for Nokhcho:
Nokhcho
1 98782U 24310.30000000 .00000000 00000-0 50000-4 0 09
2 98782 97.4000 174.9953 0018543 175.5537 198.1021 15.22683429 02
sites.txt (9.5 KB)
nok_310_v1.dat (560 Bytes)
HORS-3 updated TLE
HORS-3
1 98779U 24310.30000000 .00000000 00000-0 50000-4 0 05
2 98779 97.4000 175.1058 0021275 129.6972 241.7582 15.23112758 06
hors3_310_v1.dat (945 Bytes)
sites.txt (9.5 KB)
TLE for Horizon, not very accurate as we don’t have many points per observation:
Horizon
1 98793U 24310.30000000 .00000000 00000-0 50000-4 0 01
2 98793 97.4000 174.3871 0009297 264.8826 107.6196 15.19952844 00
sites.txt (9.5 KB)
horiz_310_v1.dat (140 Bytes)
New TLE set for ArcticSat-1:
ArcticSat-1
1 98787U 24310.40000000 .00000000 00000-0 50000-4 0 05
2 98787 97.4000 175.2386 0012483 194.3385 7.4978 15.24199641 01
arct_310_v1.dat (1.9 KB)
sites.txt (9.5 KB)
Glad to see our SamSat beacon was successfully decoded. It is strange that SatNogs don’t decode it automatically, may be we should change some parameters in SatNogs transmitter description page?
TLE for SWSU-60, at 437.050 MHz that it was received, there is also at least one more singal, so the TLE set is not very accurate and may fit the wrong signal, we will be able to tell after more separation:
SWSU-60
1 98783U 24310.50000000 .00000000 00000-0 50000-4 0 02
2 98783 97.4000 175.1102 0012345 110.9719 278.8168 15.23899120 07
sites.txt (9.5 KB)
swsu_310_v1.dat (595 Bytes)
TLE set for SIT-2086:
SIT-2086
1 98773U 24310.50000000 .00000000 00000-0 50000-4 0 01
2 98773 97.4000 175.5119 0016203 86.1079 303.9712 15.25560133 04
sit2086_310_v1.dat (1.2 KB)
sites.txt (9.5 KB)
Is the preliminary TLE file in the first post updated regularly as new TLE data comes in?
Jomjom79
No, you can use https://db.satnogs.org/api/tle/?format=3le for the updated TLE sets.
TLE for HORS-4:
HORS-4
1 98778U 24310.60000000 .00000000 00000-0 50000-4 0 07
2 98778 97.4000 174.6081 0019723 146.3177 69.0339 15.23966233 09
It is probably the low SNR, btw the preliminary TLE are pretty accurate for now.
TLE updated for RTU MIREA1:
RTU MIREA1
1 98894U 24310.60000000 .00000000 00000-0 50000-4 0 06
2 98894 97.4000 175.1948 0012212 111.1769 105.5779 15.23899975 01
sites.txt (9.5 KB)
rtum_310_v1.dat (140 Bytes)
It is successfully decoded playing raw IQ samples from artifacts with direwolf or soundmodem, but not automatically for same observation. This was tested on observation #10518936 as it only have raw samples, thanks to @EU1SAT
TLE for Vizard-ion, not very accurate due to the few points we have for it:
Vizard-ion
1 98789U 24310.60000000 .00000000 00000-0 50000-4 0 09
2 98789 97.4000 175.2746 0010388 14.1509 199.7959 15.20235191 03
viz_310_v1.dat (140 Bytes)
sites.txt (9.5 KB)
TLE for ASRTU-1, not very good fit:
ASRTU-1
1 99130U 24310.60000000 .00000000 00000-0 50000-4 0 00
2 99130 97.3998 173.7266 0017757 130.4118 88.4782 15.24622913 08
sites.txt (9.5 KB)
asrtu_301_v1.dat (2.1 KB)
Updated TLE for SamSat-Ionosphere:
SamSat-Ionosphere
1 98786U 24310.78309028 .00000000 00000-0 00000-0 0 00008
2 98786 097.3791 175.6757 0025052 253.7053 245.2116 15.22685276000008
ZIMSAT-2 on 437.050
2024-11-06 06:59:18 UTC - National Anthem of Zimbabwe.mp3.zip (698.2 KB)
[After 11 seconds a noise overlays it completely.]
2024-11-06 07:02:25 UTC - SSTV - Flag of Zimbabwe
@EA4SG can you mention also the frequency you got these images?
Is it 437.050?
