Soyuz-2.1b / Fregat - Vostochny Launch - 2024-11-04 23:18 UTC
Just to mention that the satellites will be available for scheduling in Network around 1 hour before deployment. I’m going to schedule massively observations for the satellites for the next couple of days and generate TLE if necessary.
More updates in the next hours, stay tuned!
PS Thanks everyone who helps organizing the tracking of this launch!
Can you please check the TLE, it seems there is a checksum error on line 1
Yes, thank you very much! Your version of TLE has the correct checksum.
Information from R4UAB
Corrected frequencies:
RUZAEVKA-390 (RS44S) - 435.750 FSK, 437.050 AFSK 1143
MORDOVIA-IOT (RS50S) - 435.750 FSK, 437.100 AFSK
AHMAT-2 (RS79S) - 435.750 FSK, 437.550 AFSK
ZIMSAT-2 (Z2AS) - 435.750 FSK, 437.050 AFSK
SWSU-60 (RS6S) - 437.050 AFSK
HYPERVIEW-1G (RS66S) - 436.540, 436.600 USP GMSK
ARCTICSAT-1 (RS74S) - 435.890 USP
Updated frequencies for RUZAEVKA-390 and MORDOVIA-IOT
Please corrected:
98783 YUZGU-60 (RS41S) to SWSU-60 (RS6S) / FRANK-1
YUZGU-60 is right transliterated name. Callsign is taken from this source. All info is official and provided by satellite teams. I’ll add aka’s in DB
AHMAT-1 (57206) is RS41S
https://db.satnogs.org/satellite/ULWR-5929-7873-9279-5662
RS6S is from YuZGU-55 12. It has decayed.
Ahmat-1 have a malfunction status. So it might be taken from both.
But i agree that rs6s looks like most suitable one
So it might be false information from satellite team…
Russian GKRCH (State Commission of Radio Frequencies) has long been issuing the CallSign of re-entered satellites again.
Has anyone download this program yet? opportunity for QSL
https://x.com/bg2bhc/status/1852389886197899644
https://x.com/bg2bhc/status/1853470726092951841
I’ve updated the first post with the satellite sorted by its frequency, the initial table is expandable at the top of the post. More updates as we move forward the launch.
No idea if these will actually work at launch time, but a couple of possible LiveStream links:
-and-
Although I don’t understand much about GNU Radio, I apparently managed to install everything correctly.
We also have QSL card opportunities with “HyperView-1G” and “ArcticSat-1” as mentioned in the R4UAB post that can be seen HERE
Support for the new GEOSCAN satellite platform in SatDump
https://x.com/HRPTEgor/status/1853561834126921728
Some scheduling stats for the next 48h:
Satellite Observations
99194 RUZAEVKA-390 86
98786 SamSat-Ionosphere 168
98788 TUSUR GO 69
98772 Kosar 70
98778 Hors 4 67
98894 RTU MIREA1 144
98785 MORDOVIA-IOT 98
98794 Colibri-S 150
98789 Vizard-ion 71
98793 Horizon 155
98787 ArcticSat-1 150
98782 Nokhcho 73
98774 SIT-HSE 75
98771 HOD-HOD 171
98783 SWSU-60 73
98777 ZIMSAT-2 80
98773 SIT-2086 78
98779 Hors 3 64
99130 ASRTU-1 150
98795 Altair 66
98781 HyperView-1G 68
Total 2108
First observations with signal should be around 4:10 UTC
A first status update:
Temporary NORAD ID Satellite NORAD ID to follow Other NORAD IDs Identified Deployed Reception Last Update
RECEIVED
98779 Hors 3 - - - YES RECEIVED RECEIVED
98778 Hors 4 - - - YES RECEIVED [1] [2] Reception visible on Altair observations
98787 ArcticSat-1 - - - YES RECEIVED RECEIVED
98773 SIT-2086 - - - YES RECEIVED RECEIVED
98774 SIT-HSE - - - YES RECEIVED RECEIVED
98781 HyperView-1G - - - YES RECEIVED RECEIVED
PROBABLY RECEIVED
98785 MORDOVIA-IOT - - - YES Probably RECEIVED Probably RECEIVED, there is signal but it is at least 15kHz off than the expected
98793 Horizon - - - YES Probably RECEIVED Probably RECEIVED, we need more observations
98783 SWSU-60 - - - YES Probably RECEIVED Probably RECEIVED, we need more observations as it shares frequency with other satellites
99194 RUZAEVKA-390 - - - YES Probably RECEIVED Probably RECEIVED, we need more observations as it shares frequency with other satellites
NOT RECEIVED
98771 HOD-HOD - - - YES - -
98772 Kosar - - - YES - -
98775 Polytech Universe-5 - - - YES - -
98776 Polytech Universe-4 - - - YES - -
98777 ZIMSAT-2 - - - YES - -
98782 Nokhcho - - - YES - -
98786 SamSat-Ionosphere - - - YES - -
98788 TUSUR GO - - - YES - -
98789 Vizard-ion - - - YES - -
98794 Colibri-S - - - YES - -
98795 Altair - - - YES - -
98894 RTU MIREA1 - - - YES - -
99130 ASRTU-1 - - - YES - -
IN DB WITHOUT FREQUENCY
98767 CSTP-2.11 - - - YES - -
98768 CSTP-2.2 - - - YES - -
98769 CSTP-2.1 - - - YES - -
98770 Norby-3 - - - YES - -
98780 MTUSI-1 - - - YES - -
98784 Vladivostok-1 - - - YES - -
98790 Ionosfera-M №2 - - - YES - -
98792 Ionosfera-M №1 - - - YES - -
NOT IN DB
- SITRO-AIS-17 - - - YES - -
- SITRO-AIS-18 - - - YES - -
- SITRO-AIS-19 - - - YES - -
- SITRO-AIS-20 - - - YES - -
- SITRO-AIS-21 - - - YES - -
- SITRO-AIS-22 - - - YES - -
- SITRO-AIS-23 - - - YES - -
- SITRO-AIS-24 - - - YES - -
- SITRO-AIS-13 - - - YES - -
- SITRO-AIS-14 - - - YES - -
- SITRO-AIS-15 - - - YES - -
- SITRO-AIS-16 - - - YES - -
- SITRO-AIS-41 - - - YES - -
- SITRO-AIS-42 - - - YES - -
- SITRO-AIS-43 - - - YES - -
- SITRO-AIS-44 - - - YES - -
- SITRO-AIS-37 - - - YES - -
- SITRO-AIS-38 - - - YES - -
- SITRO-AIS-39 - - - YES - -
- SITRO-AIS-40 - - - YES - -
- SITRO-AIS-45 - - - YES - -
- SITRO-AIS-46 - - - YES - -
- SITRO-AIS-47 - - - YES - -
- SITRO-AIS-48 - - - YES - -
One more status update gathering info from Telegram posts and SONIK Network:
RECEIVED AND DEMODULATED
99130 ASRTU-1 - - - YES RECEIVED RECEIVED and Demodulated [1]
99194 RUZAEVKA-390 - - - YES RECEIVED RECEIVED and Demodulated [1]
98781 HyperView-1G - - - YES RECEIVED RECEIVED and Demodulated(Telegram post by @EU1SAT)
98787 ArcticSat-1 - - - YES RECEIVED RECEIVED and Demodulated(Telegram post by @EU1SAT)
98785 MORDOVIA-IOT - - - YES RECEIVED RECEIVED, confirmed also by SONIK and Demodulated(Telegram post by @EU1SAT)
98782 Nokhcho - - - YES RECEIVED RECEIVED and Demodulated(Telegram post by @EU1SAT)
RECEIVED
98786 SamSat-Ionosphere - - - YES RECEIVED RECEIVED
PROBABLY RECEIVED
NOT RECEIVED
NOT IN DB
IVED](SatNOGS Network - Observations) RECEIVED
PROBABLY RECEIVED
NOT RECEIVED
NOT IN DB
There are two new unknown satellites added in DB (and in the first post) found by @PE0SAT at 435.215 MHz and 435.315 MHz:
98766 S2.1b Unknown 1
98765 S2.1b Unknown 2
Below is the initial list of the preliminary TLE fixed on the temporary NORAD IDs we use in SatNOGS DB, thanks for @geoscan and @R4HHZ for sharing them:
Hod-Hod
1 98771U          24310.14375000  .00000000  00000-0  50000-4 0    04
2 98771  97.4000 174.6627 0005600  73.9500 162.9000 15.23116778    01
Kosar
1 98772U          24310.14432870  .00000000  00000-0  50000-4 0    04
2 98772  97.4000 174.6627 0005600  73.9500 162.9000 15.23116778    02
SIT-2086
1 98773U          24310.14664352  .00000000  00000-0  50000-4 0    07
2 98773  97.4000 174.6627 0016235  86.9300 165.7900 15.25312984    00
ZIMSAT-2
1 98777U          24310.14664352  .00000000  00000-0  50000-4 0    01
2 98777  97.4000 174.6627 0016235  86.9300 165.7900 15.25312984    04
TUSURGO
1 98788U          24310.14780093  .00000000  00000-0  50000-4 0    04
2 98788  97.4000 174.6627 0012369 113.2800 145.7900 15.23898165    05
RTUMIREA1
1 98894U          24310.14785880  .00000000  00000-0  50000-4 0    01
2 98894  97.4000 174.6627 0012369 112.8000 146.5700 15.23898165    07
YUZGU-60
1 98783U          24310.14791667  .00000000  00000-0  50000-4 0    08
2 98783  97.4000 174.6627 0012369 112.8000 146.5700 15.23898165    04
SIT-HSE
1 98774U          24310.14895833  .00000000  00000-0  50000-4 0    08
2 98774  97.4000 174.6627 0019879 103.6200 161.7900 15.25712769    05
SamSat-Ionosphere
1 98786U          24310.14895833  .00000000  00000-0  50000-4 0    01
2 98786  97.4000 174.6627 0019879 103.6200 161.7900 15.25712769    08
NORBY-3
1 98770U          24310.15011574  .00000000  00000-0  50000-4 0    07
2 98770  97.4000 174.6627 0019879 103.6200 161.7900 15.25712769    01
ASRTU-1
1 99130U          24310.15069444  .00000000  00000-0  00000-0 0 00019
2 99130 097.3998 174.6627 0017604 130.9343 144.0104 15.26720093000013
Altair
1 98795U          24310.15127315  .00000000  00000-0  50000-4 0    05
2 98795  97.4000 174.6627 0018265 134.5300 143.5600 15.24314031    04
Polytech Universe-5
1 98775U          24310.15243056  .00000000  00000-0  50000-4 0    04
2 98775  97.4000 174.6627 0021329 129.9700 154.4700 15.25113157    08
HORS-3
1 98779U          24310.15300926  .00000000  00000-0  50000-4 0    08
2 98779  97.4000 174.6627 0021329 129.9700 154.4700 15.25113157    02
HyperView-1G
1 98781U          24310.15300926  .00000000  00000-0  50000-4 0    01
2 98781  97.4000 174.6627 0019354 147.3300 140.2700 15.23964681    07
MTUSI-1
1 98780U          24310.15300926  .00000000  00000-0  50000-4 0    00
2 98780  97.4000 174.6627 0019354 147.3300 140.2700 15.23964681    06
HORS-4
1 98778U          24310.15416667  .00000000  00000-0  50000-4 0    07
2 98778  97.4000 174.6627 0019354 147.3300 140.2700 15.23964681    03
Vladivostok-1
1 98784U          24310.15474537  .00000000  00000-0  50000-4 0    04
2 98784  97.4000 174.6627 0019354 147.3300 140.2700 15.23964681    00
Nokhcho
1 98782U          24310.15821759  .00000000  00000-0  50000-4 0    04
2 98782  97.4000 174.6627 0018543 171.5100 144.6200 15.22685039    03
Ruzaevka-390
1 99194U          24310.15937500  .00000000  00000-0  50000-4 0    04
2 99194  97.4000 174.6627 0016065 180.3500 142.1200 15.21854976    00
MORDOVIA-IOT
1 98785U          24310.16053241  .00000000  00000-0  50000-4 0    01
2 98785  97.4000 174.6627 0013880 187.6700 141.1400 15.21158033    01
ArcticSat-1
1 98787U          24310.16168982  .00000000  00000-0  50000-4 0    02
2 98787  97.4000 174.6627 0011478 194.3000 140.8400 15.20511763    00
Vizard-ion
1 98789U          24310.16226852  .00000000  00000-0  50000-4 0    05
2 98789  97.4000 174.6627 0010388 196.8000 141.5100 15.20230108    04
Horizon
1 98793U          24310.16284722  .00000000  00000-0  50000-4 0    00
2 98793  97.4000 174.6627 0009297 199.3000 142.1700 15.19948540    01
Polytech Universe-4
1 98776U          24310.16342593  .00000000  00000-0  50000-4 0    02
2 98776  97.4000 174.6627 0008279 200.6600 143.9800 15.19716651    09
Colibri-S
1 98794U          24310.16400463  .00000000  00000-0  50000-4 0    03
2 98794  97.4000 174.6627 0007262 200.7400 147.0700 15.19518044    09
SAMSAT-IONOSPHERE
2 98786  97.3798 174.9600 0018460 238.8292  26.4749 15.22447084    02
S2.1b Unknown 1
1 98766U          24310.16053241  .00000000  00000-0  50000-4 0    00
2 98766  97.4000 174.6627 0013880 187.6700 141.1400 15.21158033    00
S2.1b Unknown 2
1 98765U          24310.14791667  .00000000  00000-0  50000-4 0    08
2 98765  97.4000 174.6627 0012369 112.8000 146.5700 15.23898165    04
More TLE updates will follow in the next hours as we receive signals from the satellites
