I’ve cleaned up the QR code a little bit, then the reader showed:
Some TLE updates, more will follow:
Vizard-ion
1 98789U 24311.10000000 .00000000 00000-0 50000-4 0 05
2 98789 97.4000 176.8087 0010388 45.9938 28.2118 15.20343518 02
Horizon
1 98793U 24311.10000000 .00000000 00000-0 50000-4 0 00
2 98793 97.4000 179.3227 0009285 261.8013 182.7277 15.19529351 09
RTU MIREA1
1 98894U 24311.30000000 .00000000 00000-0 50000-4 0 04
2 98894 97.4000 176.2640 0012212 66.9248 24.4610 15.22293824 04
ASRTU-1
1 99130U 24310.60000000 .00000000 00000-0 50000-4 0 00
2 99130 97.3998 177.1234 0017757 130.4118 84.8746 15.24622913 01
Colibri-S
1 98794U 24311.30000000 .00000000 00000-0 50000-4 0 03
2 98794 97.4000 172.2709 0007877 181.6187 274.4517 15.25669108 01
I have been able to play back a recording from this morning and have telemetry from ArcticSat-1
Original observation https://network.satnogs.org/observations/10525124/
À.¤d‚œŒ@`¤¦nh¦@c.ð>…ÿ.ë.+…À
2024-11-06 13:35:46.650
Packet number 2
0000: C0 00 A4 64 82 9C 8C 40 60 A4 A6 6E 68 A6 40 63
0010: 00 F0 18 01 1C 00 01 00 02 00 41 00 C0
À.¤d‚œŒ@`¤¦nh¦@c.ð…A.À
2024-11-06 13:35:49.400
Packet number 3
0010: 00 F0 24 DE 04 00 01 00 00 00 C0
À.¤d‚œŒ@`¤¦nh¦@c.ð$Þ…À
2024-11-06 13:36:00.500
Packet number 4
0010: 00 F0 18 01 02 00 01 00 02 00 33 42 C0
À.¤d‚œŒ@`¤¦nh¦@c.ð…3BÀ
2024-11-06 13:36:07.960
Packet number 5
2024-11-06 13:36:13.190
Packet number 6
I’ve also decoded RS74S and additionally RS66S (Hyperview-1G).
Both are at 2k4 currently.
One of the 10 decoded frames:
A4 64 82 9C 8C 40 60 A4 A6 6C 6C A6 40 63 00 F0 46 42 02 00 01 00 19 00 09 00 74 7C 21 0F B2 1E 03 7E 2A 67 B6 00 00 00 60 09 00 00 29 00 20 1F 00 25 DF 04 00 01 00 2B 00 1A 00 10 00 1B 00 00 00 06 00 1B 00 7C FD FB 1E 00 00 00 00 32 FE DA FD 4B 00 01 40 00 00 00 00 00 80 15 00 00 90 12 95 5A AA 14
RS66S-1 to R2ANF
… and already applied for QSL cards as PU4ELT informed us earlier.
There are more passes tonight so I plan to capture more data then so the time stamp is correct and not the time when I replayed the data.
If you have problems to decode RS44S (RUZAEVKA-390) or RS50S (Mordovia-IOT) using UZ7HO’s SoundModem for AFSK 1200bd, try Direwolf with the following line in the configuration file.
Modem 1143 1142:2285
It tells Direwolf to use 1143 Baud and the tones 1142 and 2285 Hertz (instead of 1200 Baud and tones 1200 and 2200 as of the standard Bell 202).
Try it on observation 10519815 at second 25. The other beacons in this observation are not totally clear enough to be decoded.
Direwolf outputs:
RS44S audio level = 26(4/4) |||__
[0.3 17:56:11] RS44S>ALL:RS44S S=122 U1=4.33 U2=4.30 T1=27.72 Mx=29.378645 My=68.849190 Mz=37.900692 Vx=28.778625 Vy=-18.824427 Vz=-4.732824 Time=7648107U frame UI: p/f=0, No layer 3 protocol implemented., length = 144
dest ALL 0 c/r=1 res=3 last=0
source RS44S 0 c/r=0 res=3 last=1
000: 82 98 98 40 40 40 e0 a4 a6 68 68 a6 40 61 03 f0 …@@@…hh.@a…
010: 52 53 34 34 53 20 53 3d 31 32 32 20 55 31 3d 34 RS44S S=122 U1=4
020: 2e 33 33 20 55 32 3d 34 2e 33 30 20 54 31 3d 32 .33 U2=4.30 T1=2
030: 37 2e 37 32 20 4d 78 3d 32 39 2e 33 37 38 36 34 7.72 Mx=29.37864
040: 35 20 4d 79 3d 36 38 2e 38 34 39 31 39 30 20 4d 5 My=68.849190 M
050: 7a 3d 33 37 2e 39 30 30 36 39 32 20 56 78 3d 32 z=37.900692 Vx=2
060: 38 2e 37 37 38 36 32 35 20 56 79 3d 2d 31 38 2e 8.778625 Vy=-18.
070: 38 32 34 34 32 37 20 56 7a 3d 2d 34 2e 37 33 32 824427 Vz=-4.732
080: 38 32 34 20 54 69 6d 65 3d 37 36 34 38 31 30 37 824 Time=7648107
For RUZAEVKA-390 (RS44S), SWSU-60 (RS6S), ZIMSAT-2 (Z2AS), MORDOVIA-IOT (RS50S), AHMAT-2 (RS79S)
AFSK 1143
Hi Fredy.
I made an IQ recording (4 MHz width) this morning 08:30UTC (Orbit 11) and I did a quick replay as I had to leave the QTH. So I didnt process it deeply. Just some SSTV decodes. I will replay the saving IQ later trying to get more decodes and I will let you know in which freq the SSTV was.
73
David
Vlad thanks for sharing this information, I updated the yaml files and gr-satellites is decoding the AFSK with this information.
alternative_names:
- Z2AS
norad: 98777
&tlm AX25 telemetry:
telemetry: ax25
1k135 AX25 AFSK downlink:
frequency: 437.050e+6
modulation: AFSK
baudrate: 1143
af_carrier: 1810
deviation: 565
framing: AX.25
- *tlm
2k4 AX25 FSK downlink:
frequency: 435.750e+6
modulation: FSK
baudrate: 2400
framing: AX.25
- *tlm
-> Packet from 1k135 AX25 AFSK downlink
Container:
header = Container:
addresses = ListContainer:
Container:
callsign = u'ALL' (total 3)
ssid = Container:
ch = True
ssid = 0
extension = False
Container:
callsign = u'RS44S' (total 5)
ssid = Container:
ch = False
ssid = 0
extension = True
control = 0x03
pid = 0xF0
info = b'RS44S S=1456 U1=3.86 U2=3.83 T1=18.82 Mx=-5.606611 My=-5.606611 Mz=76.025650 Vx=28.419847 Vy=-7.862596 Vz=21.229008 Time=93140075' (total 129)
Slightly better TLE
Colibri-S
1 98794U 24311.76000000 .00000000 00000-0 50000-4 0 03
2 98794 97.4000 172.2709 0007877 187.6187 260.4517 15.25669108 02
Yes. Those 2 images were received in 437.050 at 08:27UTC, 6th-11-24. The first one was received just 1 second before of the flag of Zimbabwe, so I asumme that was not transmitted by Zimsat-2 but by one of the others sats SWSU-60 or Ruzaevka-390
Hi Vlad,
Thank you for this great hint.
You wrote that these settings are for … RS6S, ZIMSAT-2 and RS79S.
@geoscan put 1135 Baud into the transmitters for these three satellites.
Do you or Kirill have sources for this value or is it actually 1143 Baud?
Daniel
Hi Daniel,
So Dmitry R4UAB told me.
On 437.050
2024-11-06 21:29:24 UTC
RS44S>ALL:RS44S S=2496 U1=3.79 U2=3.80 T1=19.71 Mx=-20.632330 My=-4.036760 Mz=30.948496 Vx=28.412214 Vy=-5.610687 Vz=23.679390 Time=161369230
2024-11-06 21:31:05 UTC from RS44S
I have tried to receive signals from ArticSat-1 7 HyperView-1G but not been able to decode so will try again later, I may just have to set the ground station up to record passes as and see what I get as im not going to be near the computer and only on Ipad for some time.
This was from last nights Zimsat-2 pass over the UK.
Updated TLE for SamSat-Ionosphere:
SamSat-Ionosphere
1 98786U 24312.21716968 .00000000 00000-0 00000-0 0 00003
2 98786 097.3918 176.8695 0038216 216.7386 218.3261 15.22636349000006
