TLE update
TUSUR-GO
1 98788U 24340.13931713 .00000000 00000-0 32782-3 0 09
2 98788 97.3813 204.4954 0012526 58.9524 59.3270 15.23929250 04
TLE update
TUSUR-GO
48 hours of strf, 150 MHz center, 400 kHz wide, no show of doppler signals.
Thanks for checking, there are still not TLEs even on space-track, as far as I can tell also no acknowledgement from Roscosmos about the status of these satellites, basically no information anywhere
RTU MIREA1
1 98894U 24340.25594996 .00000000 00000-0 50000-4 0 02
2 98894 97.4000 203.8010 0017651 29.1303 5.8702 15.24714497 08
VIZARD-ion
1 98789U 24340.83209490 .00000000 00000-0 50000-4 0 01
2 98789 97.4000 205.2810 0002766 41.5644 59.8381 15.25288381 03
The SamSat-Ionosphere beacon packet structure is published on the site.
For example the beacon was successfully received in this observation.
Thanks for the link! If anyone interested, you can add a decoder as it is described in librespacefoundation / SatNOGS / satnogs-decoders ยท GitLab. When the decoder is ready we can use it, decode data in DB and create a dashboard in https://dashboard.satnogs.org.
Hi Leonid,
Thank you for this information.
However, the published structure only describes 12 bytes (5 values).
These values are spread over the entire beacon leaving 99 bytes without any details.
Could you provide us with full details of the telemetry format?
73
Daniel
TUSUR-GO
1 98788U 24341.84196759 .00000000 00000-0 32782-3 0 01
2 98788 97.3813 205.8121 0013751 274.9081 181.0921 15.23902575 01
Horizon
1 98793U 24341.88049769 .00000000 00000-0 50000-4 0 03
2 98793 97.4000 205.4811 0004119 16.4394 91.3903 15.25506950 04
Colibri-S
1 98794U 24341.77046296 .00000000 00000-0 50000-4 0 04
2 98794 97.4000 206.3054 0017786 87.1082 99.9799 15.25495076 00
RTU MIREA1
1 98894U 24341.99180555 .00000000 00000-0 50000-4 0 06
2 98894 97.4000 205.5159 0017802 22.3145 172.1492 15.24719143 05
VIZARD-ion
1 98789U 24341.88457175 .00000000 00000-0 50000-4 0 02
2 98789 97.4000 206.3217 0002512 27.4791 89.4050 15.25291284 09
We have 56 TBA (To Be Assigned) TLE sets from space-track.org:
0 TBA - TO BE ASSIGNED
1 61735U 24199A 24341.76632087 .00000369 00000-0 18443-3 0 9991
2 61735 98.7910 207.3885 0000882 19.2817 340.8394 14.22771451 48442
1 61736U 24199B 24341.71516690 .00000206 00000-0 11530-3 0 9998
2 61736 98.7919 207.2923 0000912 88.6345 271.4936 14.21114944 51569
1 61737U 24199C 24341.74278354 .00005652 00000-0 55078-3 0 9999
2 61737 97.3794 204.5994 0008055 135.1159 225.0714 14.92819396 48501
1 61738U 24199D 24341.67404051 .00005468 00000-0 53200-3 0 9997
2 61738 97.3793 204.5387 0007802 135.3727 224.8122 14.92898773 48493
1 61739U 24199E 24341.70587457 .00006311 00000-0 63596-3 0 9991
2 61739 97.3792 204.4980 0014793 130.7549 229.4957 14.91381459 48538
1 61740U 24199F 24341.77279701 .00006439 00000-0 64849-3 0 9993
2 61740 97.3794 204.5625 0014850 131.7097 228.5396 14.91394330 48698
1 61741U 24199G 24341.77193448 .00006251 00000-0 62912-3 0 9998
2 61741 97.3797 204.5639 0014742 133.0604 227.1853 14.91431723 48664
1 61742U 24199H 24341.50330403 .00006494 00000-0 65319-3 0 9997
2 61742 97.3794 204.3125 0014627 133.4873 226.7565 14.91443621 48502
1 61743U 24199J 24341.73898879 .00005581 00000-0 54143-3 0 9998
2 61743 97.3796 204.6045 0007584 135.6064 224.5765 14.93004857 48660
1 61744U 24199K 24341.73406872 .00020141 00000-0 79516-3 0 9997
2 61744 97.3820 206.1093 0015987 113.5799 246.7120 15.25441581 48706
1 61745U 24199L 24341.73260093 .00022891 00000-0 90002-3 0 9998
2 61745 97.3791 206.0991 0013378 119.7963 240.4608 15.25589427 51846
1 61746U 24199M 24341.73647584 .00018111 00000-0 71971-3 0 9997
2 61746 97.3817 206.1043 0015852 114.5327 245.7565 15.25247855 51847
1 61747U 24199N 24341.73535996 .00016809 00000-0 66818-3 0 9997
2 61747 97.3817 206.1050 0015813 113.0649 247.2258 15.25252844 51844
1 61748U 24199P 24341.73052211 .00024393 00000-0 95453-3 0 9996
2 61748 97.3792 206.1019 0013206 118.8805 241.3760 15.25735964 51845
1 61749U 24199Q 24341.73207308 .00021206 00000-0 83433-3 0 9991
2 61749 97.3820 206.1105 0015618 112.5887 247.7005 15.25551441 51842
1 61750U 24199R 24341.74485372 .00020327 00000-0 81515-3 0 9995
2 61750 97.3792 206.0831 0015826 123.1827 237.0931 15.24917973 51845
1 61751U 24199S 24341.74562981 .00012338 00000-0 50147-3 0 9998
2 61751 97.3793 206.0823 0014288 122.6280 237.6339 15.24601287 51853
1 61752U 24199T 24341.67288792 .00005486 00000-0 53295-3 0 9999
2 61752 97.3795 204.5401 0007666 135.6218 224.5618 14.92952839 51792
1 61753U 24199U 24341.73866353 .00020584 00000-0 81908-3 0 9990
2 61753 97.3789 206.0914 0014113 120.6671 239.5960 15.25200556 51845
1 61754U 24199V 24341.73648185 .00023061 00000-0 91197-3 0 9996
2 61754 97.3791 206.0940 0014218 120.4547 239.8098 15.25382515 51845
1 61755U 24199W 24341.72973608 .00024291 00000-0 94945-3 0 9997
2 61755 97.3791 206.1028 0013143 118.8612 241.3947 15.25775831 51842
1 61756U 24199X 24341.72943755 .00024322 00000-0 95017-3 0 9994
2 61756 97.3790 206.1030 0013117 119.2837 240.9714 15.25793727 51841
1 61757U 24199Y 24341.72968056 .00023880 00000-0 93267-3 0 9999
2 61757 97.3815 206.1125 0015728 111.9361 248.3551 15.25770122 51841
1 61758U 24199Z 24341.73751882 .00005655 00000-0 54762-3 0 9995
2 61758 97.3793 204.6048 0007355 136.9304 223.2493 14.93074191 51805
1 61759U 24199AA 24341.73672943 .00005438 00000-0 52629-3 0 9995
2 61759 97.3794 204.6061 0007268 138.2888 221.8888 14.93108342 51805
1 61760U 24199AB 24341.72930986 .00023382 00000-0 91480-3 0 9996
2 61760 97.3791 206.1033 0012968 119.9831 240.2697 15.25754456 51843
1 61761U 24199AC 24341.72942161 .00021505 00000-0 84339-3 0 9995
2 61761 97.3791 206.1029 0012744 120.4050 239.8449 15.25693189 51845
1 61762U 24199AD 24341.72597557 .00027278 00000-0 10558-2 0 9995
2 61762 97.3814 206.1168 0015588 110.5970 249.6942 15.26046097 51844
1 61763U 24199AE 24341.72763188 .00025664 00000-0 10001-2 0 9991
2 61763 97.3791 206.1058 0012766 119.7249 240.5261 15.25869821 51843
1 61764U 24199AF 24341.72569088 .00024654 00000-0 95837-3 0 9994
2 61764 97.3792 206.1089 0012444 120.2438 240.0034 15.25964746 48682
1 61765U 24199AG 24340.86776268 .00034893 00000-0 13309-2 0 9998
2 61765 97.3815 205.2835 0015555 111.4947 248.7952 15.26480735 48564
1 61766U 24199AH 24341.58902043 .00031241 00000-0 11937-2 0 9990
2 61766 97.3814 205.9940 0015404 108.7576 251.5335 15.26449248 48671
1 61767U 24199AJ 24341.77999920 .00035954 00000-0 13537-2 0 9995
2 61767 97.3810 206.1943 0015211 106.2864 254.0050 15.26909236 48707
1 61768U 24199AK 24341.72093735 .00019040 00000-0 74116-3 0 9999
2 61768 97.3799 206.1183 0010598 124.0582 236.1664 15.25991462 48699
1 61769U 24199AL 24341.71813675 .00019854 00000-0 76833-3 0 9993
2 61769 97.3794 206.1208 0010495 123.7541 236.4699 15.26180300 48693
1 61770U 24199AM 24341.73550851 .00109331 00000-0 35402-2 0 9997
2 61770 97.3634 206.1727 0019356 117.8441 242.4765 15.31408106 48708
1 61771U 24199AN 24341.75352661 .00021955 00000-0 88884-3 0 9997
2 61771 97.3765 206.0610 0016428 131.2184 229.0473 15.24574688 48691
1 61772U 24199AP 24341.75199417 .00025596 00000-0 10290-2 0 9996
2 61772 97.3789 206.0733 0018319 124.8536 235.4428 15.24748270 48695
1 61773U 24199AQ 24341.68848603 .00022187 00000-0 89918-3 0 9994
2 61773 97.3767 205.9968 0016473 131.5933 228.6719 15.24535997 48681
1 61774U 24199AR 24341.75437078 .00022711 00000-0 91989-3 0 9997
2 61774 97.3767 206.0607 0016638 131.0394 229.2285 15.24547840 48699
1 61775U 24199AS 24341.69385079 .00014717 00000-0 60709-3 0 9997
2 61775 97.3796 205.9997 0018312 126.1753 234.1182 15.23998275 48688
1 61776U 24199AT 24341.75519675 .00022801 00000-0 92448-3 0 9994
2 61776 97.3767 206.0606 0016795 131.5365 228.7316 15.24510992 51845
1 61777U 24199AU 24341.76004448 .00014971 00000-0 61789-3 0 9996
2 61777 97.3796 206.0635 0018357 125.9228 234.3716 15.23975482 48695
1 61778U 24199AV 24341.75700463 .00022100 00000-0 89946-3 0 9994
2 61778 97.3768 206.0575 0016821 131.9635 228.3039 15.24389583 48694
1 61779U 24199AW 24341.76123431 .00014570 00000-0 60253-3 0 9992
2 61779 97.3796 206.0624 0018629 126.3491 233.9469 15.23910355 51843
1 61780U 24199AX 24341.69223029 .00022603 00000-0 92070-3 0 9998
2 61780 97.3775 205.9958 0017173 132.2072 228.0626 15.24351109 48689
1 61781U 24199AY 24341.76449851 .00013801 00000-0 57468-3 0 9992
2 61781 97.3797 206.0582 0018772 126.4008 233.8964 15.23688170 48699
1 61782U 24199AZ 24341.75886360 .00023678 00000-0 96219-3 0 9992
2 61782 97.3793 206.0650 0019589 124.4687 235.8405 15.24380074 48695
1 61783U 24199BA 24341.75625052 .00032544 00000-0 13027-2 0 9999
2 61783 97.3790 206.0665 0020076 123.8043 236.5110 15.24809631 51848
1 61784U 24199BB 24341.75996031 .00022192 00000-0 90575-3 0 9990
2 61784 97.3793 206.0631 0019316 125.2970 235.0077 15.24251155 51843
1 61785U 24199BC 24341.75952437 .00022840 00000-0 93098-3 0 9996
2 61785 97.3792 206.0640 0019252 124.5696 235.7362 15.24290429 48699
1 61786U 24199BD 24341.75864772 .00022584 00000-0 92078-3 0 9993
2 61786 97.3769 206.0571 0017098 132.8554 227.4123 15.24321874 48690
1 61787U 24199BE 24341.76441759 .00013247 00000-0 55154-3 0 9991
2 61787 97.3795 206.0579 0018956 126.2754 234.0238 15.23698477 51848
1 61788U 24199BF 24341.75544458 .00021758 00000-0 88359-3 0 9990
2 61788 97.3762 206.0577 0016746 131.7115 228.5558 15.24468556 48672
1 61789U 24199BG 24341.73622668 .00005551 00000-0 53683-3 0 9994
2 61789 97.3798 204.6089 0007352 142.0762 218.0978 14.93133177 48707
1 61790U 24199BH 24341.73642519 .00005448 00000-0 52716-3 0 9994
2 61790 97.3795 204.6067 0007256 139.8251 220.3507 14.93120822 48709
Thanks for the TLE update!
Well, if these are from our deployment, then it looks like โAYโ and โBEโ are the two closest to the calculated TLE for ASRTU-1โฆ time will tell!
VIZARD-ion
RTU MIREA1
Colibri-S
Horizon
TUSUR GO
ArcticSat-1
HyperView-1
ZIMSAT-2
ZIMSAT-2 โ also possible 61783
RUZAEVKA-390
