SatNOGS Client v2.1 release
In the meantime I had a look at the setup and indeed it seems that "satnogs_rig_ip": "127.0.0.1", was changed and shouldn’t have this 127.0.0.1 value when using the containerized solution.
support output:
Generating support report. Please wait...
    "versions": {
        "satnogs-client": "unknown",
        "satnogs-ansible": "unknown",
        "satnogs-flowgraphs": "unknown",
        "gr-satnogs": "unknown",
        "gr-soapy": "unknown",
        "gnuradio": "unknown",
        "satnogs-config": "1.1"
    "state": {
        "is-applied": false,
        "pending-tags": null
    "system": {
        "date": "2025-12-07T10:02:32.380785+00:00",
        "platform": {
            "system": "Linux",
            "node": "satnogs-config",
            "release": "6.12.47+rpt-rpi-v8",
            "version": "#1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16)",
            "machine": "aarch64",
            "processor": ""
        "memory": {
            "total": 1935421440,
            "available": 1522917376,
            "percent": 21.3,
            "used": 289304576,
            "free": 419397632,
            "active": 654266368,
            "inactive": 624427008,
            "buffers": 60502016,
            "cached": 1166217216,
            "shared": 18268160,
            "slab": 173449216
        "disk": {
            "total": 14878285824,
            "used": 7516573696,
            "free": 6585774080,
            "percent": 53.3
    "configuration": {
        "satnogs_antenna": "RX",
        "satnogs_post_observation_script": "satnogs-post {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}",
        "satnogs_ppm_error": "0",
        "satnogs_pre_observation_script": "satnogs-pre {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}",
        "satnogs_rf_gain": "40.2",
        "satnogs_station_elev": "50",
        "satnogs_station_id": "342",
        "satnogs_station_lat": "39.104",
        "satnogs_station_lon": "-0.458"
Checking the running containers:
sudo docker container list
CONTAINER ID   IMAGE                           COMMAND                  CREATED          STATUS          PORTS     NAMES
ec4419641c10   librespace/satnogs-client:2.1   "satnogs-client"         21 minutes ago   Up 21 minutes             satnogs_satnogs-client
d57481eb3d33   librespace/hamlib:4.5.4         "/docker-entrypoint.…"   21 minutes ago   Up 21 minutes             satnogs_rigctld
The rigctl container is called satnogs_rigctld and this should be used as "satnogs_rig_ip": value.
After correcting this value we have a good observation SatNOGS Network - Observation 12892826
Many thanks Jan….
It was my fault during the initial setup
Now it’s working
73 de EA5WA
Just to be clear, you manually changed the "satnogs_rig_ip": value?
No blaming just so others will also learn when moving towards the container solution.
Yes, exactly, it was my fault, because is confusing when looking for information not updated on internet.
Many thanks
Thank you SatNOGS developer team,
We now have the first SatNOGS-client 2.1 docker based HydraSDR RFOne SDR observation.
The integration needs some polishing to make it to 2.1 stable, but the first steps are set.
SatNOGS Client 2.1 docker container updated with gr-satellites 5.8 and RFOne SDR support.
Good evening,
There where some important SatNOGS client updates and I ran the update this evening.
This to keep the system on the latest and greatest :wink:
me too. my station setup base on this tutorial. and update is fast just run:
sudo docker-compose pull
and to free up space
sudo docker image prune
(read first this trick from @PE0SAT)
I run prune command above, and reclaimed space: 8.832GB.
WARNING! This will remove all dangling images.
How can I update the client?
73 de EA5WA Juan Carlos
depending on how your station when firstly setup.
if your station setup with official setup: sudo satnogs-setup then follow this step:
or if you install with alternative setup, just run this command:
Thanks
Too much “conditionals”…. I think I will remain in 2.1, I dont have good experience with updates
I would suggest in the directory where the compose file is located.
sudo docker-compose down && sudo docker-compose pull && sudo docker-compose up -d
I am a bit confused here. I use a Raspbery Pi 4. Should i wait?
dpkg --print-architecture
gives me back arm64
no. it same. my station also raspbery 4
My docker station 3442 fails after the pull of client v 2.1
satnogs_client_1 | [INFO] Opening PlutoSDR #0 192.168.2.1…
satnogs_client_1 | WARNING: Unknown parameter ‘0’ in
satnogs_client_1 | WARNING: Unknown parameter ‘25’ in
satnogs_client_1 | WARNING: Unknown parameter ‘v0.25’ in
satnogs_client_1 | [INFO] Using format CF32.
satnogs_client_1 | [INFO] Auto setting Buffer Size: 131072
satnogs_client_1 | [INFO] Set MTU Size: 131072
satnogs_client_1 | [INFO] Has direct RX copy: 1
satnogs_client_1 | netrigctl_close: done status=Command completed successfully
satnogs_client_1 | ERROR satnogsclient.scheduler.tasks Upload of waterfall_13277255_2026-01-25T10-13-44.png for observation 13277255 is forbidden, “Watefall has already been uploaded”
satnogs_client_1 | URL: SatNOGS Network API
satnogs_client_1 | ERROR satnogsclient.scheduler.tasks Upload of satnogs_13277255_2026-01-25T10-13-44.ogg for observation 13277255 is forbidden, “Audio has already been uploaded”
satnogs_client_1 | grsat - WARNING - UDP_DUMP_HOST not set, no data will be sent to the demod
satnogs_client_1 | network_open: hoststr=192.168.0.186, portstr=4533
satnogs_client_1 | connect to 192.168.0.186:4533 failed, (trying next interface): Network error 110: Connection timed out
satnogs_client_1 | network_open: failed to connect to 192.168.0.186:4533
satnogs_client_1 | rig_init: rig does not have rx_range!!
I am forbidden to upload because it allready had been uploaded ?
SATNOGS_PRE_OBSERVATION_SCRIPT=“satnogs-pre {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}”
SATNOGS_STATION_ID=“3442”
SATNOGS_STATION_LAT=“52”
SATNOGS_STATION_LON=“4.2”
SATNOGS_STATION_ELEV=“13”
SATNOGS_ROT_ENABLED=“True”
SATNOGS_ROT_BAUD=“0”
SATNOGS_ROT_PORT=“192.168.0.186:4533”
SATNOGS_SOAPY_RX_DEVICE=“driver=plutosdr,hostname=192.168.2.1”
SATNOGS_RX_SAMP_RATE=“4e6”
SATNOGS_RX_BANDWIDTH=“3e6”
SATNOGS_LO_OFFSET=“0”
SATNOGS_PPM_ERROR=“0”
SATNOGS_RF_GAIN=“69”
SATNOGS_ANTENNA=“A_BALANCED”
SATNOGS_BB_FREQ=“0”
ENABLE_IQ_DUMP=“TRUE”
IQ_DUMP_FILENAME=“/data/iq3442.raw”
Any clues ?
Thanks,
Ben
How was the client installed ?
Did you use the new satnogs docker satnogs-setup method or you own created docker compose file ?
We need some details.
if installed with satnog-setup
sudo docker exec -ti satnogs_satnogs-client bash
if installed with manual docker setup
cd your_station_dir
sudo docker-compose exec satnogs_client bash
inside station shell:
cd /tmp/.satnogs/data
ls
remove suspected waterfall (.png) or audio (.ogg) with rm command
My station 3442 is now up and running again.
Long story short: Before you update confirm your station being operational to prevent blaming others for your mistakes, also, don’t start the docker station from a windows PC by ssh to the linux PC AND start the docker station from that linux PC , 2 instances and one pluto, it makes sense one of them says “allready uploaded” and it makes sense 2 instances accessing the pluto leads to corrupt contents.
Finally, after cleaning up my own mess, and replugging the PlutoSDR, I noticed even sdrpp showed the device and allowed to start it but no waterfall output. So I went to dfu mode, flashed 0.35 firmware and now I am up and running again.
:sweat_smile:
I did become happy to fast. After one successfull observation the next one did this:
satnogs_client_1 | ERROR: READ LINE: -32
satnogs_client_1 | [ERROR] Unable to set BB rate.
satnogs_client_1 | ERROR satnogsclient.observer.observer Waterfall data array is invalid
satnogs_client_1 | rig_check_rig_caps: p1=0x71e56d834c40, p2=0x71e56d83b1c0, rig_model=0x71e56d834c40, macro_name=0x71e56d83b1c0
satnogs_client_1 | initrigs4_dummy: _init called
satnogs_client_1 | rig_init: rig_model=Hamlib NET rigctl
satnogs_client_1 | rig_init: rx_range_list1 is empty, using rx_range_list2
satnogs_client_1 | rig_init: rig does not have tx_range!!
satnogs_client_1 | netrigctl_init version 20230106.0
satnogs_client_1 | ERROR: Unable to create Avahi DNS-SD client :Daemon not running
satnogs_client_1 | [WARNING] Unable to scan ip: -26
and all next observations
satnogs_client_1 | ERROR satnogsclient.observer.observer Waterfall data array is empty
Now let me restart the pluto and attach a separate USB power cable to it.
Pluto is in a “state of crash”
