Many thanks I think I will start from new as multiple errors, this is just some of the issues.
ImportError: Error importing numpy: you should not try to import numpy from
its source directory; please exit the numpy source tree, and relaunch
your python interpreter from there.
File “/usr/local/lib/python3.11/dist-packages/numpy/core/**init**.py”, line 24, in
from . import multiarray
File “/usr/local/lib/python3.11/dist-packages/numpy/core/multiarray.py”, line 10, in
from . import overrides
File “/usr/local/lib/python3.11/dist-packages/numpy/core/overrides.py”, line 8, in
from numpy.core.\_multiarray_umath import (
ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.11/dist-packages/numpy/**init**.py”, line 130, in
from numpy.**config** import show as show_config
File “/usr/local/lib/python3.11/dist-packages/numpy/**config**.py”, line 4, in
File “/usr/local/lib/python3.11/dist-packages/numpy/core/**init**.py”, line 50, in
raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.11 from “/usr/bin/python3”
* The NumPy version is: “1.26.4”
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory
The above exception was the direct cause of the following exception:
File “/usr/local/bin/satnogs-client”, line 5, in
from satnogsclient import main
File “/usr/local/lib/python3.11/dist-packages/satnogsclient/**init**.py”, line 11, in
from satnogsclient.scheduler.tasks import status_listener
File “/usr/local/lib/python3.11/dist-packages/satnogsclient/scheduler/tasks.py”, line 15, in
from satnogsclient.observer.observer import Observer
File “/usr/local/lib/python3.11/dist-packages/satnogsclient/observer/observer.py”, line 17, in
from satnogsclient.artifacts import Artifacts
File “/usr/local/lib/python3.11/dist-packages/satnogsclient/artifacts.py”, line 5, in
import h5py
File “/usr/local/lib/python3.11/dist-packages/h5py/**init**.py”, line 33, in
from . import version
File “/usr/local/lib/python3.11/dist-packages/h5py/version.py”, line 17, in
import numpy
File “/usr/local/lib/python3.11/dist-packages/numpy/**init**.py”, line 135, in
raise ImportError(msg) from e
ImportError:
installed.
import h5py
import numpy
ImportError:
installed.
import h5py
import numpy
