@ea5wa Thanks you for allowing me to connect remotely and I wish I had better news.
After many hours, this is the outcome.
Some info on the system:
lscpu
Architecture: aarch64
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Vendor ID: ARM
Model: 3
Model name: Cortex-A72
Stepping: r0p3
CPU max MHz: 1500,0000
CPU min MHz: 600,0000
BogoMIPS: 108.00
L1d cache: 128 KiB
L1i cache: 192 KiB
L2 cache: 1 MiB
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Retbleed: Not affected
Vulnerability Spec store bypass: Vulnerable
Vulnerability Spectre v1: Mitigation; __user pointer sanitization
Vulnerability Spectre v2: Vulnerable
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Flags: fp asimd evtstrm crc32 cpuid
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
docker -v
Docker version 29.1.0, build 360952c
free
total used free shared buff/cache available
Mem: 1,8Gi 152Mi 55Mi 1,0Mi 1,6Gi 1,6Gi
Swap: 924Mi 0B 924Mi
df -h
df -h
S.ficheros Tama�o Usados Disp Uso% Montado en
/dev/root 7,1G 6,7G 89M 99% /
devtmpfs 667M 0 667M 0% /dev
tmpfs 925M 0 925M 0% /dev/shm
tmpfs 370M 1,1M 369M 1% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
/dev/mmcblk0p1 253M 51M 202M 20% /boot
tmpfs 185M 0 185M 0% /run/user/1000
sudo hdparm --direct -t /dev/mmcblk0
/dev/mmcblk0:
Timing O_DIRECT disk reads: 6 MB in 3.83 seconds = 1.57 MB/sec
Container install:
docker-compose -f satnogs-342.yml up -d
cat satnogs-342.yml
services:
rigctld:
container_name: satnogs-342-rigctld
image: 'librespace/hamlib:4.5.4'
user: '999'
read_only: true
environment:
MODEL: '1'
restart: 'unless-stopped'
command: 'rigctld'
satnogs_client:
hostname: 'satnogs-342'
image: 'librespace/satnogs-client:2.1'
# image: 'librespace/satnogs-client:master-unstable'
user: '500:500'
read_only: true
environment:
SATNOGS_API_TOKEN: 'secret'
SATNOGS_LOG_LEVEL: 'INFO'
SATNOGS_SOAPY_RX_DEVICE: 'driver=rtlsdr,biastee=false'
SATNOGS_PPM_ERROR: '0'
SATNOGS_RF_GAIN: '43.9'
SATNOGS_ANTENNA: 'RX'
SATNOGS_RX_SAMP_RATE: '2.048e6'
SATNOGS_STATION_ELEV: '50'
SATNOGS_STATION_ID: '342'
SATNOGS_STATION_LAT: '39.104'
SATNOGS_STATION_LON: '-0.458'
SATNOGS_RIG_IP: 'satnogs-342-rigctld'
SATNOGS_RIG_PORT: '4532'
GR_SATELLITES_ENABLED: 'true'
GR_SATELLITES_APP: 'gr_satellites'
GR_SATELLITES_KEEPLOGS: 'false'
# GR_SATELLITES_ZMQ_PORT: '5555'
UDP_DUMP_HOST: '127.0.0.1'
UDP_DUMP_PORT: '50342'
command: 'satnogs-client'
device_cgroup_rules:
- 'c 189:* rwm'
devices:
- '/dev/bus/usb'
volumes:
- type: 'tmpfs'
target: '/tmp'
- type: 'volume'
source: 'satnogs-client'
target: '/var/lib/satnogs-client'
- type: 'volume'
source: 'satyaml'
target: '/usr/lib/python3/dist-packages/satellites/satyaml'
- '/dev/bus/usb:/dev/bus/usb'
volumes:
satnogs-client:
satyaml:
Looking at this command and output you would think the docker containers are active
docker container list
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ffcc589e4791 librespace/satnogs-client:2.1 "satnogs-client" 5 hours ago Restarting (1) 6 seconds ago satnogs-342
0ed48b21a12b librespace/hamlib:4.5.4 "/docker-entrypoint.…" 5 hours ago Up 5 hours satnogs-342-rigctld
But when I for example want to look at the SatNOGS-client logs, we get the following.
docker logs -f satnogs-342
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.11 from "/usr/bin/python3"
* The NumPy version is: "1.26.4"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory
The above exception was the direct cause of the following exception:
File "/usr/local/bin/satnogs-client", line 5, in <module>
from satnogsclient import main
File "/usr/local/lib/python3.11/dist-packages/satnogsclient/__init__.py", line 11, in <module>
from satnogsclient.scheduler.tasks import status_listener
File "/usr/local/lib/python3.11/dist-packages/satnogsclient/scheduler/tasks.py", line 15, in <module>
from satnogsclient.observer.observer import Observer
File "/usr/local/lib/python3.11/dist-packages/satnogsclient/observer/observer.py", line 17, in <module>
from satnogsclient.artifacts import Artifacts
File "/usr/local/lib/python3.11/dist-packages/satnogsclient/artifacts.py", line 5, in <module>
import h5py
File "/usr/local/lib/python3.11/dist-packages/h5py/__init__.py", line 33, in <module>
from . import version
File "/usr/local/lib/python3.11/dist-packages/h5py/version.py", line 17, in <module>
import numpy
File "/usr/local/lib/python3.11/dist-packages/numpy/__init__.py", line 135, in <module>
raise ImportError(msg) from e
ImportError: Error importing numpy: you should not try to import numpy from
its source directory; please exit the numpy source tree, and relaunch
your python interpreter from there.
File "/usr/local/lib/python3.11/dist-packages/numpy/core/__init__.py", line 24, in <module>
from . import multiarray
File "/usr/local/lib/python3.11/dist-packages/numpy/core/multiarray.py", line 10, in <module>
from . import overrides
File "/usr/local/lib/python3.11/dist-packages/numpy/core/overrides.py", line 8, in <module>
from numpy.core._multiarray_umath import (
ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.11/dist-packages/numpy/__init__.py", line 130, in <module>
from numpy.__config__ import show as show_config
File "/usr/local/lib/python3.11/dist-packages/numpy/__config__.py", line 4, in <module>
File "/usr/local/lib/python3.11/dist-packages/numpy/core/__init__.py", line 50, in <module>
ImportError:
installed.
import h5py
import numpy
Apart from limited hardware resources, 8Gb sd-card, 2G internal memory and very slow SD-card I have no explanation for the fact the container doesn’t seem to work.
Maybe one of the developers can tell us what this error means.
Upfront, this system doesn’t seem capable of running the SatNOGS-client 2.1, very unresponsive, small SD-card, little memory
I am out of options.
Tag @fredy @kerel
