I’m building the v3 rotator and notice that there’s some ambiguity. Are the instructions intended to match the contents of satnogs-rotator-v3_1.zip?
(I’ve not encountered a 3.0 zip so assume that all is well, but thought it best to double-check before getting the 3d-printing and laser-cutting done.)
A question on mast connection: do I understand correctly from the pictures in the wiki and the assembly instructions that the rotator design ends at a piece of 40mm aluminium tube poking out the bottom, to be mounted as appropriate?
(My use will all be portable, so I’ll be using a speaker stand (tripod that DJs use); am working through what I’ll need for integration while I wait for ordered parts to arrive.)
Nothing terribly exciting to report yet, although I do have a pile of laser-cut and 3D-printed parts and neatly cut aluminium profile sitting on my table at HackerspaceSG awaiting my attention. As ever, priorities shifted and I ended up running my JSConf.Asia 2019 workshop with existing WRAPS rotator, despite its various limitations.
