Now that I have done some testing on the last couple days and it’s running great so far software wise, the rest should be on the hardware (gear, motor driver and antenna). Also, I might need to try to change the setting from max_el=90 to max_el=180 so the rotator wouldn’t have meridian flip issues (I used that setting on GPredict).
I might continue the next update on my other thread about the rotator as the station is mainly focused on that (it should be station 4205 under testing mode), I will continue update station 3852 here.
Thanks for the info. That’s a bit unfortunate, is there I can do for the rotator not doing flip when it crossed the meridian or this is only an issue on SatNogs rotator?
