Hello everyone. It’s time to upgrade the rotors!
A few days ago I contacted the Engineer Francesco Bandini, (IK5XWA) representing the problem of the meridian flip treated in this post https://community.libre.space/t/the-meridian-flip-fix-for-arduino-software- repositioning-rotator/2702
the problem is present on all the rotors’ firmware, both Stepper Motor and DC motor. It 's a big problem because in many cases during the satellite tracking, the rotor relocating loses for a few tens of seconds tracking.
Thanks to Francesco, who had already solved the problem with the firmware of his rotor https://www.youtube.com/watch?v=MNwRFbsHNNY&t=282s, after having sent the firmware for stepper motor Satnogs, analyzing it has implemented the code that solves the MERIDIAN FLIP. I tested it and it seems to work perfectly, the rotor does not reposition itself and continues tracking until the satellite is lost on the horizon.
He added some code in the cmd_proc routine, from line 206 onwards.
// detect any 360-0 or 0-360 crossing to avoid Meridian Flip
double eps; // differenza in gradi tra posiz. voluta e attuale
double az_val = angleAz; // posizione voluta in gradi
double az_att = step2deg(AZstepper.currentPosition()); // posizione attuale in gradi
// da qui si presuppone che le posizioni siano sempre tra 0 e 360, quindi per sicurezza le riporta nel range 0-360
int n_giri=( int ) (az_att / 360.0); // esempio con az_att=357 -> ngiri = 0
az_att = az_att - ((double) n_giri)*360.; // azimuth attuale, riportato tra 0 e 360 gradi
n_giri=( int ) (az_val / 360.0);
az_val = az_val - ((double) n_giri)*360.; // azimuth voluto, riportato tra 0 e 360 gradi
eps = az_val - az_att; // calcola errore di posizione
if (fabs(eps) > 180.) // deve fare piu' di mezzo giro (quindi deve attraversare il nord)
if (az_att < 180) // lo attraversa girando in senso antiorario
// esempio: deve andare da +10 a +350, eps diventa (350 - 360) -10 = -20 e gira al contrario
eps = (az_val - 360) - az_att;
else // az_att > 180
// ha passato il nord girando in senso orario (esempio az_att = 350 e az_val = 10)
eps = az_val -(az_att - 360); // 10 - (350 - 360) = +20 e continua in senso orario
} // end if az_att > 180
} // end if fabs(eps) > 180
// ridefinisce la posizione voluta in step
stepAz = AZstepper.currentPosition() + deg2step(eps);
// end of meridian flip detection code
HERE IS THE ENTIRE CODE FOR STEPPER MOTOR ARDUINO PRO MICRO AND 54 GEAR RATIO
#include <string.h>
#include <stdlib.h>
#include <math.h>
#include <AccelStepper.h>
#define DIR_AZ 18 //PIN for Azimuth Direction
#define STEP_AZ 10 //PIN for Azimuth Steps
#define DIR_EL 6 //PIN for Elevation Direction
#define STEP_EL 7 //PIN for Elevation Steps
#define MS1 9 //PIN for step size
#define EN 8 //PIN for Enable or Disable Stepper Motors
#define SPR 200 //Step Per Revolution
#define RATIO 54 //Gear ratio
#define T_DELAY 60000 //Time to disable the motors in millisecond
#define HOME_AZ 4 //Homing switch for Azimuth
#define HOME_EL 5 //Homing switch for Elevation
/*The MAX_ANGLE depends of ANGLE_SCANNING_MULT and maybe misbehave for large values*/
#define ANGLE_SCANNING_MULT 180 //Angle scanning multiplier
#define MAX_AZ_ANGLE 360 //Maximum Angle of Azimuth for homing scanning
#define MAX_EL_ANGLE 360 //Maximum Angle of Elevation for homing scanning
#define HOME_DELAY 6000 //Time for homing Decceleration in millisecond
/*Global Variables*/
unsigned long t_DIS = 0; //time to disable the Motors
/*Define a stepper and the pins it will use*/
AccelStepper AZstepper(1, STEP_AZ, DIR_AZ);
AccelStepper ELstepper(1, STEP_EL, DIR_EL);
void setup()
/*Change these to suit your stepper if you want*/
AZstepper.setMaxSpeed(150);
AZstepper.setAcceleration(50);
ELstepper.setMaxSpeed(150);
ELstepper.setAcceleration(50);
/*Enable Motors*/
pinMode(EN, OUTPUT);
digitalWrite(EN, LOW);
/*Step size*/
pinMode(MS1, OUTPUT);
digitalWrite(MS1, LOW); //Full step
/*Homing switch*/
pinMode(HOME_AZ, INPUT);
pinMode(HOME_EL, INPUT);
/*Serial Communication*/
Serial.begin(19200);
/*Initial Homing*/
Homing(deg2step(-ANGLE_SCANNING_MULT), deg2step(-ANGLE_SCANNING_MULT));
void loop()
/*Define the steps*/
static int AZstep = 0;
static int ELstep = 0;
/*Time Check*/
if (t_DIS == 0)
t_DIS = millis();
/*Disable Motors*/
if (AZstep == AZstepper.currentPosition() && ELstep == ELstepper.currentPosition() && millis()-t_DIS > T_DELAY)
digitalWrite(EN, HIGH);
/*Enable Motors*/
else
/*Read the steps from serial*/
cmd_proc(AZstep, ELstep);
/*Move the Azimuth & Elevation Motor*/
stepper_move(AZstep, ELstep);
/*Homing Function*/
void Homing(int AZsteps, int ELsteps)
int value_Home_AZ = HIGH;
int value_Home_EL = HIGH;
int n_AZ = 1; //Times that AZ angle has changed
int n_EL = 1; //Times that EL angle has changed
boolean isHome_AZ = false;
boolean isHome_EL = false;
AZstepper.moveTo(AZsteps);
ELstepper.moveTo(ELsteps);
while(isHome_AZ == false || isHome_EL == false)
value_Home_AZ = digitalRead(HOME_AZ);
value_Home_EL = digitalRead(HOME_EL);
/* Change to LOW according to Home sensor */
if (value_Home_AZ == HIGH)
AZstepper.moveTo(AZstepper.currentPosition());
isHome_AZ = true;
if (value_Home_EL == HIGH)
ELstepper.moveTo(ELstepper.currentPosition());
isHome_EL = true;
if (AZstepper.distanceToGo() == 0 && !isHome_AZ)
n_AZ++;
AZsteps = deg2step(pow(-1,n_AZ)*n_AZ*ANGLE_SCANNING_MULT);
if (abs(n_AZ*ANGLE_SCANNING_MULT) > MAX_AZ_ANGLE)
error(0);
break;
if (ELstepper.distanceToGo() == 0 && !isHome_EL)
n_EL++;
ELsteps = deg2step(pow(-1,n_EL)*n_EL*ANGLE_SCANNING_MULT);
if (abs(n_EL*ANGLE_SCANNING_MULT) > MAX_EL_ANGLE)
error(1);
break;
AZstepper.run();
ELstepper.run();
/*Delay to Deccelerate*/
long time = millis();
while(millis() - time < HOME_DELAY)
AZstepper.run();
ELstepper.run();
/*Reset the steps*/
AZstepper.setCurrentPosition(0);
ELstepper.setCurrentPosition(0);
/*EasyComm 2 Protocol & Calculate the steps*/
void cmd_proc(int &stepAz, int &stepEl)
/*Serial*/
char buffer[256];
char incomingByte;
char *p=buffer;
char *str;
static int counter=0;
char data[100];
double angleAz,angleEl;
/*Read from serial*/
while (Serial.available() > 0)
incomingByte = Serial.read();
/* XXX: Get position using custom and test code */
if (incomingByte == '!')
/* Get position */
Serial.print("TM");
Serial.print(1);
Serial.print(" ");
Serial.print("AZ");
Serial.print(10*step2deg(AZstepper.currentPosition()), 1);
Serial.print(" ");
Serial.print("EL");
Serial.println(10*step2deg(ELstepper.currentPosition()), 1);
/*new data*/
else if (incomingByte == '\n')
p = buffer;
buffer[counter] = 0;
if (buffer[0] == 'A' && buffer[1] == 'Z')
if (buffer[2] == ' ' && buffer[3] == 'E' && buffer[4] == 'L')
/* Get position */
Serial.print("AZ");
Serial.print(step2deg(AZstepper.currentPosition()), 1);
Serial.print(" ");
Serial.print("EL");
Serial.print(step2deg(ELstepper.currentPosition()), 1);
Serial.println(" ");
else
/*Get the absolute value of angle*/
str = strtok_r(p, " " , &p);
strncpy(data, str+2, 10);
angleAz = atof(data);
/*Calculate the steps*/
stepAz = deg2step(angleAz);
if (str[0] == 'E' && str[1] == 'L')
angleEl = atof(data);
stepEl = deg2step(angleEl);
/* Stop Moving */
else if (buffer[0] == 'S' && buffer[1] == 'A' && buffer[2] == ' ' && buffer[3] == 'S' && buffer[4] == 'E')
/* Get position */
Serial.print("AZ");
Serial.print(" ");
Serial.print("EL");
Serial.println(step2deg(ELstepper.currentPosition()), 1);
stepAz = AZstepper.currentPosition();
stepEl = ELstepper.currentPosition();
/* Reset the rotator */
else if (buffer[0] == 'R' && buffer[1] == 'E' && buffer[2] == 'S' && buffer[3] == 'E' && buffer[4] == 'T')
/* Get position */
Serial.print("AZ");
Serial.print(" ");
Serial.print("EL");
/*Move the steppers to initial position*/
Homing(0,0);
/*Zero the steps*/
stepAz = 0;
stepEl = 0;
counter = 0;
/*Reset the disable motor time*/
t_DIS = 0;
/*Fill the buffer with incoming data*/
else {
buffer[counter] = incomingByte;
counter++;
/*Error Handling*/
void error(int num_error)
switch (num_error)
/*Azimuth error*/
case (0):
while(1)
Serial.println("AL001");
delay(100);
/*Elevation error*/
case (1):
while(1)
Serial.println("AL002");
delay(100);
default:
while(1)
Serial.println("AL000");
delay(100);
/*Send pulses to stepper motor drivers*/
void stepper_move(int stepAz, int stepEl)
AZstepper.moveTo(stepAz);
ELstepper.moveTo(stepEl);
AZstepper.run();
ELstepper.run();
/*Convert degrees to steps*/
int deg2step(double deg)
return(RATIO*SPR*deg/360);
/*Convert steps to degrees*/
double step2deg(int Step)
return(360.00*Step/(SPR*RATIO));
