ISS Deployment (JAXA) J-SSOD#35 - 2026-02-03 08:20 UTC
On behalf of the KKNACKSAT-2 team, thank you very much for your help and support.
We really appreciate everyone who tracks satellites and shares observations of J-SSOD#35.
We would like to share an update about KNACKSAT-2. On 11 Feb 2026, we believe we observed the first signal across Europe, approximately 8 days after deployment. On the waterfall, we can see a repeating beacon pattern, with an interval of about 30 seconds.
However, we still need to confirm if the packet data shows callsign HS0K from KNACKSAT-2.
We will keep tracking and work on decoding the frames.
The observation below shows the beacon transmission every 30 seconds:
Apiwat HS4SCI
Hi Apiwat,
It’s not 9k6.
Daniel
Unfortunately the signal you see in these observations doesn’t fit any of the objects of the JSSOD#35 deployment.
Checking further I found that it is CUAVA-2 satellite.
Dear Apiwat @Pao
Those beacon observations show the frequency upper shift around 10KHz-20KHz,
Is this your specification? FSK 9K6 derivation should be 2.4kHz from the center 400.63MHz?
BR
Anol
Hi Apiwat @Pao
FYI
BR
Anol
Thank you for send us the observation.
Unfortunately, it is not from KNACKSAT-2.
Apiwat
Status update:
Temporary NORAD ID Satellite NORAD ID to follow Other candidate NORAD IDs Identified Deployed Reception Last Update
RECEIVED & DEMODULATED/DECODED
- GXIBA-1 67684 - YES YES Received Identified, here are the ikhnos results
- LEOPARD 67687 - YES YES Received Identified, here are the ikhnos results
- CoRAL 67685 - YES YES Received Identified, here are the ikhnos results
UNKNOWN STATUS
98532 KNACKSAT-2 67683 67686, 67688 NO YES - Randomly chosen to follow 67683 , other possible 67686, 67688
98398 UiTMSAT-2 67686 67683, 67688 NO YES - Randomly chosen to follow 67686, other possible 67683, 67688
IN DB WITHOUT FREQUENCIES
98403 HMU-SAT2 67688 67683, 67686 NO YES - Randomly chosen to follow 67688, other possible 67683, 67686
It’s seem that during 21Feb 18:03 - 18:08 UTC, TSC-NARIT Made first contact with KNACKSAT-2 (first picture) and second contact following by @fredy new schedule at 4044 - South Australia - UHF at this observation SatNOGS Network - Observation 13452879. I have decoded using provided decoder second succession after TSC Station decoded
The data decoded from SatNOGS Network - Observation 13452879 matches the KNACKSAT-2 packet format.
We confirmed the packet data shows callsign HS0K from KNACKSAT-2.
On behalf of the KKNACKSAT-2 team, thank you very much for support from Satnogs.
Apiwat HS4SCI
Decodes confirmed over Eastern U.S. also. Congratulations to the Team!
https://x.com/scott23192/status/2025586783044419867
KNACKSAT-2 Decodes Comfirmed
@emone I have forwarded the packet. You can check dashboard.
Thanks for the help, @siravijbb. I’m a 3rd-party volunteer for validation, I won’t push any packet to their network.
Thanks Daniel @dl7ndr for schema correction.
Resolved satnogs-decoders merge request for KNACKSAT-2 decoder → KNACKSAT-2 decoder (!501) · Merge requests · librespacefoundation / SatNOGS / satnogs-decoders · GitLab
Awesome! With this observations we are now able to identify the 4th of the 6 satellites of this deployment, here is the latest status update:
- KNACKSAT-2 67683 - YES YES Received Identified, here are the ikhnos results
UNKNOWN STATUS
98398 UiTMSAT-2 67686 67688 NO YES - Randomly chosen to follow 67686, other possible 67688
98403 HMU-SAT2 67688 67686 NO YES - Randomly chosen to follow 67688, other possible 67686
Amazing and wonderful to see KnackSat-2 put on such a SHOW after being silent for so long! Should we also be listening for the 9k6 APRS on 145.825 or will that only be switched on later? Thanks!
(0632utc, 24-Feb, USA-East)
May this observation be the 9k6 APRS on 145.825 KNACKSAT-2 TT/C receipt or their customer D/L payload only Thailand region?
Here is an update from the KnackSat-2 Team ref. the 145.825 transmitter!
Date: Tue, Feb 24, 2026 at 11:54 AM
Regarding APRS on 145.825 MHz (9k6) — the APRS digipeater is not enabled by default at the moment. It will be activated later according to our planned schedule.
The satellite remained in standby on the ISS much longer than we originally expected — about 175 days instead of the planned ~90 days. After deployment, it needed time for the solar panels to recharge the battery and allow the system to return to stable operation.
We’ll announce it here and through our usual channels once the APRS digipeater is enabled so everyone will know when to start monitoring 145.825 MHz.
At the moment, I’m unable to reply on the SatNOGS forum as my account appears to be pending review, so please feel free to share this information there if needed.
Best regards,
KNACKSAT-2 Team
Typical of the signals you see waiting on a KnackSat-2 pass. There are some SERIOUS transmitters in that 400 MHz satellite band!
It’s strong, like a tropical depression is coming close to your house.
We have some updates regarding the KNACKSAT-2 decoder, and request a schema validator.
