Gxiba-1
take pictures of Mexican active volcanoes
98531 https://upaep.mx/gxiba IARU Sat Coordinator
9k6 GFSK downlink using AX100 mode 5. Planning a JAXA deployment from the ISS in June 2025. 437.300 MHz has been coordinated
CoRAL
401.14 (max BW = 20 kHz)
Testing Distributed Telemetry Networks and Inter-Satellite Links (ISL) through
Internet of Things technologies
For anyone who would like to test their RX & decode setup for KNACKSAT-2, the Team has kindly shared a sample I/Q file (32-bit float, samp-rate 1250000) as well as an even easier file to test with, demodulated 48k audio.
That URL is:
… and if you have obtained an API Key for use w/ the ‘KnackSat Packet Forwarder’, you can confirm that it is working correctly for you as well.
Here’s an example of the sample frames decoded in GNU Radio:
… and now that we know the source host name being used (or destination if you prefer), an AX.25 check block can be used to not send false/trash decodes to neither the Team nor SatNogs:
… Thanks very much to the KnackSat-2 Team for providing all the info, tools, & sample files so that we can know that we are setup properly to receive their satellite!
Regarding the KnackSat-2 Telemetry Forwarder, please be sure to download the latest version from
… and as of v4.0.7, the Team has confirmed that our decodes are being uploaded correctly. However, there is a lingering “Bad request: Invalid AX.25 frame format” error message in the log that can be ignored.
The 1525utc pass over the Eastern U.S. was nothing heard from KNACKSAT-2 on 400.630 nor 145.825 and nothing heard from CoRAL on 401.14.
There was a VERY weak signal about where CoRAL should have been, but it looked to be much too narrow for 9k6. Will keep an eye on that.
P.S. - just noticed that an earlier decode from some other object in the 401 MHz satellite band got uploaded as a decode for CoRAL. Sorry about that. SO much nicer when we have payloads w/ AX.25 addresses so that all the false hits can be filtered out.
