IO-86 SSDV Experiment
For the past month, PRTeksat and AMSAT-ID have been running SSDV (Slow-Scan Digital Video) experiments via the IO-86 FM repeater. I’m creating this topic to document the event and preserve all the image transmissions and receptions so nothing gets lost. The main software used was ssdv2sat by @bali:
However, some participants also used other Android-based apps. To keep things organized, this thread will focus specifically on the IO-86 SSDV experiments. Feel free to share your received images, decode results, setups, or any tips :slightly_smiling_face:
7th February 2026
Sender: YB0OSU
Sender: YC0AVJ
Sender: YB0OSU
8th February 2026
Sender:
YD0NXX
16 February 2026
Sender: YG4SLJ
from satno 7-8 february observations
from 16 february:
waterfall pattern:
17 February 2026
Sender YD0BSK:
Sender YD0NXX:
*nb: both sent the image multiple times, YD0BSK has some QRM issues, YD0NXX’s image is complemented from each transmission with 93% decode.
Waited for a long time did not receive anything :frowning:
Hi, where are you located at? Currently the FM transponder only turned on at near midnight once a day for SSDV experiment in South East Asia region.
Anyone on the footprint activation area are welcome to join :slight_smile:
Schedule can be seen here:
Live decoding using SDR:
or replay from satnogs obs :slight_smile:
LAPAN-A2/IO86 observation on 2026-02-19 15:10 - 15:25 UTC
decode with this tool
Not able to play. Kindly upload on someother server.
download here and here
some video can’t play on firefox browser, but can play on another browser like chrome.
Got it thanks. Need to get direwolf running on Arch linux. Any help?
source
Installed direwolf. What are the configuration settings?
just use direwolf.conf and follow the instruction in ssdv2sat github page
this obs, ssdv send by amateur in indonesia reach india. good time
2026-02-24 - 13:17 - 13:38 UTC
from YD3ADN:
some logs:
Summary
 β†’ YG4SLJ  | IMG 0              | Pkt       33 |      28 frags
 β†’ YG4SLJ  | IMG 0              | Pkt       34 |      29 frags
 β†’ YG4SLJ  | IMG 0              | Pkt        2 |      29 frags (Recovered FEC 3)
 β†’ YG4SLJ  | IMG 0              | Pkt        4 |      29 frags
 β†’ YG4SLJ  | IMG 0              | Pkt        5 |      29 frags
 β†’ YG4SLJ  | IMG 0              | Pkt        6 |      29 frags
 β†’ D_2     | M7UovL             | OTHER #  311 | |6cX2Dxl&!Bm:u
 β†’ YG4SLJ  | IMG 0              | Pkt        8 |      29 frags (Recovered FEC 3)
 β†’ YG4SLJ  | IMG 0              | Pkt        9 |      29 frags (Recovered FEC 3)
 ✱ New from: YD3ADN, image: 0 (256 bytes/frag) (NON FEC)
 β†’ YD3ADN  | IMG 0              | Pkt        0 |    1/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        1 |    2/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        3 |    3/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        4 |    4/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        5 |    5/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        6 |    6/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        7 |    7/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        1 |    7/ 8 frags
 β†’ YD3ADN  | IMG 0              | Pkt        2 |    8/ 8 frags
Nitin (SatNOGS Network - Observation 13469123) is at a higher elevation.His satnogs station will pick IO 86. I am sorrounded by buildings.
maybe if your elevation is possible, and you’re luck enough, you can try yourself send ssdv over io86. just use tx.py script that include in ssdv2sat.
btw tommorow until weekend, maybe you can try ssdv event. check time here
Is this from the observation that you shared??
No image file is created. Only .bin and .txt
