One more update a little more accurate:
ENSO
1 58470U 23185J 25307.66367680 .00000000 00000-0 13644-2 0 05
2 58470 97.3446 30.2368 0007750 264.0936 63.8040 16.06561675 04
enso_307_v2.dat (2.6 KB)
sites.txt (11.6 KB)
ENSO
sites.txt (11.6 KB)
Looks like the issue have something to do with the TLE. Previously I added satellite TLEs to the amateur.txt file just fine (IO-86, BOTAN, etc.) but somehow some satellites just wont be added to the TLE list on that file. I copied a working TLE and swapped only the name, satellite number and international designator and I am able to be connected to getkiss and uploaded to the network ( but first I’m making sure the data uploaded was the correct NORAD ID).
But thank you for pointing out the “sat_app.ini” file. After adding the path, when I run getkiss and choose the satellite, it now automatically open the soundmodem program.
One more updated TLE:
ENSO
1 58470U 23185J 25308.50056687 .00000000 00000-0 13644-2 0 01
2 58470 97.3446 31.0703 0007750 264.0936 224.1901 16.08641039 09
enso_308_v1.dat (4.4 KB)
sites.txt (11.7 KB)
If you have scheduled Network observations make sure that they have updated to the TLE set above, if not I suggest you remove and re-schedule it.
TLE update for ENSO:
ENSO
1 58470U 23185J 25309.29302767 .00000000 00000-0 13644-2 0 01
2 58470 97.3446 31.9261 0007750 264.0936 133.6775 16.10884178 06
sites.txt (11.7 KB)
enso_309_v1.dat (1.9 KB)
TLE update based on the latest passes and the latest TLE from space-track.org:
ENSO
1 58470U 23185J 25311.17651581 .00000000 00000-0 16177-2 0 06
2 58470 97.3393 34.1923 0008707 312.5225 226.1416 16.18527232 03
enso_311_v1.dat (1.6 KB)
sites.txt (11.7 KB)
One more update:
ENSO
1 58470U 23185J 25311.27548044 .00000000 00000-0 17218-2 0 03
2 58470 97.3393 34.5482 0008707 312.5225 82.8843 16.19988456 08
3 posts were split to a new topic: Error in submitted frames
One small correction:
ENSO
1 58470U 23185J 25311.47641362 .00000000 00000-0 16970-2 0 06
2 58470 97.3393 34.3929 0008707 312.5225 174.1856 16.21252103 07
sites.txt (11.7 KB)
enso_311_v3.dat (3.4 KB)
One TLE update which was produced earlier:
ENSO
1 58470U 23185J 25311.84885737 .00000000 00000-0 15361-2 0 06
2 58470 97.3374 34.7981 0008943 272.9419 227.7210 16.23989981 06
Updated TLE from observations over Australia and Europe:
ENSO
1 58470U 23185J 25312.04660606 .00000000 00000-0 15324-2 0 04
2 58470 97.3374 35.1136 0008943 272.9419 303.5465 16.25491153 09
enso_312_v1.dat (2.3 KB)
sites.txt (11.7 KB)
One more TLE:
ENSO
1 58470U 23185J 25312.18007021 .00000000 00000-0 15663-2 0 01
2 58470 97.3374 35.2637 0008943 272.9419 4.3953 16.27391656 03
sites.txt (11.7 KB)
enso_312_v2.dat (1.8 KB)
One more TLE:
ENSO
1 58470U 23185J 25312.42170203 .00000000 00000-0 15666-2 0 04
2 58470 97.3374 35.4318 0008943 272.9419 339.5213 16.29528473 04
enso_312_v5.dat (2.9 KB)
sites.txt (11.7 KB)
Probably one of the last TLE:
ENSO
1 58470U 23185J 25312.88048863 .00000000 00000-0 12613-2 0 09
2 58470 97.3330 35.9867 0009766 273.4712 154.0828 16.37277084 06
A small fix from pass over Antarctica:
ENSO
1 58470U 23185J 25312.97993368 .00000000 00000-0 96914-3 0 05
2 58470 97.3304 36.1084 0010794 270.9690 22.7082 16.39542341 07
Probably the last one:
ENSO
1 58470U 23185J 25313.04020590 .00000000 00000-0 96914-3 0 02
2 58470 97.3304 36.3669 0010794 270.9690 18.3880 16.42726675 03
in one hour will pass my station. max elev 68.0° . hope get the beacon
TLE update after passing over Japan:
ENSO
1 58470U 23185J 25313.07667494 .00000000 00000-0 96914-3 0 05
2 58470 97.3304 36.0323 0010794 270.9690 234.1311 16.46372525 09
A small adjustment after the passes over Australia and Antarctica:
ENSO
1 58470U 23185J 25313.10039455 .00000000 00000-0 96914-3 0 09
2 58470 97.3304 36.4152 0010794 270.9690 14.1192 16.44997100 06
got the beacon
decode manual, got 2 message:
gr_satellites 58470 --wavfile satnogs_12707491_2025-11-09T03-25-38.ogg
-> Packet from 9k6 FSK downlink
Container:
header = Container:
addresses = ListContainer:
Container:
callsign = u'F4KJX' (total 5)
ssid = Container:
ch = True
ssid = 0
extension = False
Container:
callsign = u'FX6FRC' (total 6)
ssid = Container:
ch = True
ssid = 0
extension = True
control = 0x03
pid = 0xF0
info = b'\x8c\x10\x9d\n\x10i\x9a\n\x10i\x17\x01\x04U\xa0\x92\x02\x00d\x01C\xd0U\xc6\x10\xc5\xc6\xc6\x16b/\x0e\x0e:\x00\x81(\x15\x1b\x18\x1a\x1a\x1a\xcbd\xcaD\x9faW\t\x11\x12\xc9\x11\xc7\x03w\x00\x00\xfc\x06\x9c\xbe\x00F\x11\x00\x00\n\x02\x01D\x01F\xc3\x007\x00 \x01\r\x00:\x00:\x00\x00\x00\x02\x02\x01\x07\x00,\xfe\xe4\xfe\xb8\xfc\xab\x00\x0e\xff\xd5\xfb\xe0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Last game! @CSUM_F4KJX ' (total 142)
Container:
header = Container:
Container:
ssid = Container:
ch = True
ssid = 0
extension = False
Container:
ssid = Container:
ch = True
ssid = 0
extension = True
control = 0x03
pid = 0xF0
info = b'\x8c\x10\xd0\n\x10i\xcc\n\x10i\x17\x01\x04U\xa0\x92\x02\x00d\x01C\xd0U\xc8\x11\xc5\xca\xc8-b.\x0e\x0e:\x00\x81(*\x1c\x19\x1a\x1b\x19\xcbd\xcaA\x9faX\t\x12\x12\xc9\x11\xc7\x03w\x00\x00\x01\x07\x9c\xbe\x00F\x12\x00\x00\n\x02\x01K\x01N\xc3\x007\x00&\x01\r\x00:\x00:\x00\x00\x00\x02\x02\x01\x07\x00\x08\xfe\xf0\xfe\xd4\xfd?\x001\x00\x11\xfb\xdd\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Last game! @CSUM_F4KJX ' (total 142)
Got that too at only 3°. I’m sure this will be the last time I captured ENSO’s beacon ![]()
