CroCube: QSL cards!
The CroCube team has provided a Google form to request eQSL cards for reception of data and CW.
CroCube also has a digipeater and it seems that until now, I’m the only one who has made use of it.
And they answer really fast: My QSL cards for 9k6 FSK (DATA) and CW.
I sure wish i could…
Jomjom79
Understood.
CroCube has an inclination of 45° which brings it only about 3° above your horizon.
By the way same for LASARSat.
I filled last night the google form, let see when they’ll send the QSL card.
YO4DFT - Cristian
dl7ndr, I tried the digipeat today but no luck. How much power were you using. Do you have an Satgate which heard the digipeated packets and also by EA5WA.
I am yet to recieve my QSL card :slight_smile:
73, Nitin
Hi Nitin,
Thanks for trying the digipeater of CroCube.
I’m usually putting 50 watts into a 9.5 dBd UHF antenna.
Satgate is a different thing.
I’m guessing you are referring to the digipeater dashboard.
EA5WA, me and others just upload received data (telemetry and also digipeated packets) to SatNOGS.
In my case, I’m using gnuradio and blocks from gr-satellites as described for the GR-satellites uploader.
You may also simply use GetKISS+ instead.
By the way, if you have no luck with CroCube, feel free to try LASARSat.
73
Daniel
Hi Daniel,
ok ,noted. Will try. I am using a Kenwood TS2000 with X quad stacked . Now I understand how APRS data is geeting uploaded to the dashboard you have created in SatNogs. I will use GetKISS+ as still need to learn about GR-Satellites. Will try LASARSat as well. Thanks again for the response.
73, Nitin, VU2JEK (Ex VU3TYG)
received a QSL today for reception of CW back in December last year
CroCube Over Brazil :brazil: at 2025-04-09 ~20:09UTC
In one of the packets received :
From eTwinning schools to stars knowledge knows no limits! Spread kindness and never stop exploring !
Received that line on March 22nd.
Hello to all,
could anybody please share the correct Soundmodem (Ver 0.31 FSK 9600 G3RUH) here?
Thank you very much
Olaf
DH1OK
http://uz7.ho.ua/hs_soundmodem31.zip
So great Thank you very much!!!
