[Announcement] SatNOGS station software upgrades are available
This topic will be used to announce that new SatNOGS station software upgrades are available. Set the notification level to Watching at the bottom of the thread to receive notifications for each new release.
This topic will be closed to replies. If you have any questions for a release, please create a new topic under SatNOGS - Software category.
Manifest
Component Version
SatNOGS Client Ansible 202105092144
SatNOGS Config 0.12
SatNOGS Client 1.5
SatNOGS Flowgraphs package 1.3.1-1
gr-satnogs package 2.2.1.0-1
gr-soapy package 2.1.3.1-1
Changelog
  • 202105092144
    • Bump versions of ‘satnogs-client’, ‘satnogs-flowgraphs’, and ‘satnogs-config’
    • satnogs-setup: Fix overriding of Ansible URL and branch experimental defaults
    • Add UDP_DUMP_* variables to satnogs-config
    • gitlab-ci: Run syntax check on footloose inventory as well
    • README: Fix footloose instructions
    • README: Update footloose installation guide
    • footloose: Remove SSH inventory configuration
    • footloose: Autodetect Python interpreter
    • production.dist: Add defaults to example host variables
    • footlose: Bind mount ‘/dev/usb’ to access USB devices
    • footloose: Do not run the container with privileges
    • README: Fix instructions on how to run playbook
    • Rename footloose SSH key to be hidden
    • satnogs-config: Write api interval to client
SatNOGS Client
  • 1.5
    • docs: Add missing description on settings
    • docs: Fix type of some settings
    • docs: Fix a few spelling errors
    • Disable legacy feature for selecting dependency resolver
    • Remove unused functions
    • isort: Fix line length parameter
    • Default port settings updated
    • Removed audio and changed default port
    • Add control for UDP audio and I/Q sinks
    • Immediate run of get_jobs on client start
    • docs: Pin versions of dependencies
    • docs: Add Read the Docs configuration
    • Refresh requirements
    • refresh-requirements: Use new dependency resolver
    • tox: Make system packages available when checking for dependencies
    • gitlab-ci: Install SatNOGS APT repository for ‘python3-gps’
    • gitlab-ci: Do not install system packages available as wheels
    • Downgrade ‘numpy’
SatNOGS Config
  • 0.12
    • UDP sink short description corrected
    • Added variables for UDP_DUMP_*
    • apt: Catch and ignore fetch failure exception
    • refresh-requirements: Add ‘setuptools’ to requirements file
  • 1.3.1-1
    • UDP sink, doppler corrected
Update instructions
Instructions on how to update can be found under wiki section Updating SatNOGS Client Software.
Manifest
Component Version
SatNOGS Client Ansible 202105301943
SatNOGS Config 0.12
SatNOGS Client 1.5.1
Changelog
  • 202105301943
    • satnogs-client: Bump version
SatNOGS Client
  • 1.5.1
    • Fix observer thread deadlock when there are no waterfall data
    • Fix logging when handling HTTP exceptions
Update instructions
Manifest
Component Version
SatNOGS Client Ansible 202109022142
SatNOGS Config 0.12
SatNOGS Client 1.6
SatNOGS Flowgraphs package 1.4-1
gr-satnogs package 2.3.1.0-1
Changelog
  • 202109022142
    • Bump ‘satnogs-client’, ‘satnogs-flowgraphs’ and ‘gr-satnogs’ versions
SatNOGS Client
  • 1.6
    • Fix GFSK/BPSK flowgraph parameters
    • Add support for satnogs_qubik_telem flowgraph
    • Worker{|Freq|Track}: Refactor class and instance variables
    • gitlab-ci: Fix Security Scanning
    • Bump versions of dependencies
    • Handle exception when trying to get jobs (fixes #390)
  • 1.4-1
    • Add flowgraph for the QUBIK 1 & 2
    • Example flowgraph: Remove obsolete variables
gr-satnogs package
  • 2.3.1.0-1
    • Bump up version to v2.3.1.0
    • IEEE 802.15.4 variant decoder: Fix RS frame size and CRC
  • 2.3.0.0-1
    • Bump up to v2.3.0.0
    • Add hint for Tumbleweed users
    • Add ITPP (IT++) dependency
    • IEEE 802.15.4-like decoder: Add support for RS(255,223)
    • debian: Remove implicit package dependency
    • BER Calculator: Fix CRC and perfromance issue
    • CRC: Fix CRC16-AUG and improve usability
    • Improve QA tests of the whitening class
    • Unified SPUTNIX protocol (USP) encoder
    • Add convolutional encoder and decoder
    • Implement packed_to_unpacked and unpacked_to_packed utilities.
    • Change of libfec based on the changes that exist in gr-ccsds
    • Reed-Muller RM(1, 6) code
    • Mode 6 Encoder for the AX100 modem of GomSpace.
    • Mode 5 Encoder for the AX100 modem of GomSpace.
Update instructions
Manifest
Component Version
SatNOGS Client Ansible 202205101826
SatNOGS Config 0.12
SatNOGS Client 1.6
gr-satnogs package 2.3.1.1-1
Changelog
  • 202205101826
    • Update APT cache with a handler
    • common: Add retries to apt key download
    • common: Add workaround for renamed Raspbian repositories (buster/bullseye)
    • common: Add workaround for missing repo signing key
    • add file type upload options in satnogs-client-ansible
gr-satnogs package
  • 2.3.1.1-1
    • libfec: Remove unsupported SIMD enabled viterbi functions
Update instructions
Manifest
Component Version
SatNOGS Client Ansible 202209101535
SatNOGS Config 0.13.2
SatNOGS Client 1.8.1
Changelog
  • 202209101535
    • satnogs-setup: Fix missing variable holding distribution codename
    • satnogs-setup: Bump SatNOGS Config version
    • satnogs-radio: Blacklist all RTL-SDR modules
    • satnogs-client: Clean-up package dependencies
    • Revert “Use Ansible to detect release information”
    • satnogs-client: Bump SatNOGS Client version
    • Declare compatibility with Raspbian Bullseye
    • satnogs-setup: Add missing dependency of ‘satnogs-config’
    • zram: Use package facts to detect if package is installed
    • Use Ansible to detect release information
    • Install packages in one shot
    • packages: Install all packages in one shot
    • apt: Keep repository and key URLs in distinct variables
    • satnogs-client: Retire transitional package
    • satnogs-client: Update system package dependencies
    • satnogs-client: Refresh client settings
    • satnogs-setup: Install PyPI dependencies from requirements file
    • README: Mention Debian Bullseye support
    • README Mention Ansible version dependency
    • satnogs-client: Install PyPI packages from requirements file
    • satnogs_client: Add libatlas3-base dependency
    • satnogs-client: Bump to version ‘1.8’
    • satnogs_client: Update Python dependencies
    • satnogs-client: Fix mount module FQDN
    • gitlab-ci: Lint both playbook and roles
    • gitlab-ci: Check for signed-off commits
    • ansible: Bump minimum version of core to ‘2.12’
    • Update role names in Vagrant and local playbook
    • gitlab-ci: Bump Ansible version, remove ‘yamllint’ checking
    • Rename roles to remove hyphens
    • Fix missing FQCN
    • Replace module names with FQCN (closes #111)
    • Override system Python packages
    • Remove futile retries
    • gpsd: Optimize installation of packages
    • common: Move package and APT retries into variables
    • satnogs-setup: Remove workarounds for bullseye
    • satnogs-upgrade: Check for current release
    • satnogs-setup: Use ‘focal’ Ansible repository on Debian Bullseye
    • vagrant: Support pre- and post-provisioning scripts
    • satnogs-upgrade: Fix Debian security archive source line
    • Drop support for footloose Docker container for now (fixes #107)
    • Declare compatibility with Debian Bullseye
    • satnogs-setup: Create Ansible system-wide configuration directory
    • satnogs-client: Install ‘libhdf5-dev’ to allow building of Python ‘h5py’ when no wheel is available
    • Replace ‘python-apt’ with ‘python3-apt’ for ‘bullseye’
    • Make ‘satnogs-setup’ role depend on ‘common’ role
    • satnogs-setup: Update upgrade utility to support ‘buster’ to ‘bullseye’ upgrades
    • vagrant: Add ‘debian_bullseye’ VM
SatNOGS Config
  • 0.13.2
    • Initialize configuration to empty when YAML loading fails
  • 0.13.1
    • docs: Add missing tox environment for checking for broken dependencies
    • docs: Install development extras
    • docs: Mention release of Debian
    • Install ‘lsb-release’ dependency
    • Remove ‘python3-psutil’ from system dependencies
    • Update ReadTheDocs Ubuntu image
    • docs: Update ReadTheDocs theme
    • Fix default value of SATNOGS_KEEP_ARTIFACTS
    • Fixup d67f1ed: Bracketing on ‘if’ scoped variable assignements
  • 0.13
    • Fix variable inconsistency
    • apt: Handle lock failure exception
    • Redact ‘satnogs_artifacts_api_token’
    • Add new menu entries
    • pylint: Enable all plugins
    • pylint: Remove useless suppresions
    • tox: Check quoting consistency with ‘flake8-quotes’
    • gitlab-ci: Install runtime dependencies for completeness
    • Use f-strings where applicable
    • Remove futile import aliases
    • Set encoding while opening files
    • Return ‘None’ when no menu definition could be loaded
    • Use ‘with’ syntax to empty config file
    • Remove newlines from docstrings
    • Use consistent quoting
    • Use ‘if’ scoped variable assignments
    • Fix exception when there is no configuration yet to show
    • docs: Auto-update copyright notice date
    • docs: Modernize Readthedocs configuration
    • gitlab-ci: Check for sign-offs in commit messages
    • gitlab-ci: Update Alpine Docker image
    • Use ternary expression to improve readability
    • Remove futile variable assignements
    • foo
    • Replace ‘else’…‘if’ with ‘elif’ to improve readability
    • Use set instead of list
    • Update dependencies
    • Move to Debian Bullseye
    • Introduce script for refreshing requirements using a Docker container
    • refresh-requirements: Fix sorting of packages
    • tox: Move environment dependencies in ‘dev’ extras, refresh requirements
    • refresh-requirements: Generate dependency constraints file
    • Bump ‘versioneer’ version
    • docs: Show source editing links
    • add file type upload options in satnogs-setup menu
    • refresh-requirements: Verify that script requirements are installed
    • refresh-requirements: Exclude both hyphen and underscore on ‘pkg-resources’
SatNOGS Client
  • 1.8.1
    • README: Remove outdated information, fix contact channels
    • readthedocs: Update to newer Ubuntu image
    • gitlab-ci: Retire ‘python3-libhamlib2’ transitional package
    • docs: Add missing ‘tox’ environments
    • docs: Remove instruction on how to install ‘tox’
    • docs: Update system package dependencies
    • docs: Remove empty lines from end of file
    • docs: Add empty line after EOL colon
    • docs: Fix name of environment variable
    • docs: Fix order of variables in user guide
    • docs: Move environment variables section into a seperate file
    • docs/userguide.rst: Normalize markup usage
    • docs/userguide.rst: Unify newline handling
  • 1.8
    • docs: Add description for SATNOGS_ROT_ENABLED
    • observer: Run rotator thread only when SATNOGS_ROT_ENABLED is True
    • Add settings SATNOGS_ROT_ENABLED
    • Bump sign-off excluded commit
    • Allow specifying multiple RX devices
    • Do not set negative values on lock timeout
    • Don’t assign value to variable when used only once
    • Replace ‘else’…‘if’ with ‘elif’ to increase readability
    • Don’t reuse loop variable
    • Fix true/false comparisons
    • Convert lists to tuple on ‘for’ loops
    • Follow PEP257 conventions on docstrings
    • pylint: Enable ‘docparams’ extension
    • Fix docstrings
    • refresh-requirements: Sort before adding comments
    • refresh-requirements: Fix sorting consistency of ‘requirements.txt’
    • refresh-requirements: Use consistent sorting
    • tox: Make sure that virtualenv ‘pytest’ is used
    • tox: Fix inadvertently committed dependency constaints filename
    • Increase development environment reproducibility
    • refresh-requirements: Generate constraints file
    • Open decoded data with ‘utf-8’ encoding
    • Fix data frame filetype detection
    • artifacts: Set labels on dataset object as they are created
    • Add setting for keeping artifacts after upload
    • gitlab-ci: Replace deprecated dependency scanning variable
    • tox: Fix robot linting and tidying
    • docs: Bump Readthedocs theme version
    • docs: Mock system site package imports
    • docs: Give virtualenv access to system packages
    • Fix rotator module docstrings
    • Use system Python bindings for ‘gps’
    • Handle the case when artifacts api token is not set but artifacts upload is
    • gitlab-ci: Install system library dependencies (fixes #440)
    • Fix exception handling when in get_jobs tasks when max retries exceeded
    • gitlab-ci: Check commits for valid sign-offs
    • gitlab-ci: Bump Alpine image version
    • gitlab-ci: Test against Debian Bullseye
    • Update dependencies, refresh requirements
    • docs: Modernize readthedocs configuration
    • Fix ‘UnboundLocalError’ when trying to access GET response (fixes #441)
    • tox: Fix package name of dependency
    • tox: docs: Treat warnings as errors
    • docs: Fix warnings
    • docs: Fix title underline length
    • docs: Don’t try to build documentation for removed module
    • refresh-requirements: Verify that script dependencies are installed
  • 1.7
    • Move metadata in artifacts file from waterfall group to root
    • add file type upload options in satnogs-client settings
    • refresh-requirements: Exclude both underscore and hyphen on ‘pkg-resources’ package
    • Remove accidentally added ‘pkg-resources’ from requirements file
    • Add pytest to tox and gitlab-ci
    • Add pytest dependency
    • tests: Add test_artifacts
    • Artifacts: Introduce more metadata
Update instructions
CAUTION!!! THIS UPDATE IS ONLY AVAILABLE WITH A REFLASH AS IT REQUIRES A DISTRIBUTION UPGRADE (Buster → Bullseye)!
Do not attempt to Update through satnogs-setup; it will render it useless!!!
Manifest
Component Version
Raspbian SatNOGS Image 2023111400
Changelog
SatNOGS pi-gen
This update only provides a new SatNOGS Image for new stations. For existing stations nothing was changed.
Manifest
Docker image Version
SatNOGS Ansible 202601141228
SatNOGS Config 1.1
SatNOGS Client 2.1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202601141228
    • Add support for enabling automatic updates without a prompt
    • Disable warning about discovered Python interpreter
    • Install ‘gnupg’ package
    • satnogs-setup: Reload Docker engine after configuration changes
    • Add Docker configuration file
    • Do not restart Docker when running Ansible through it
    • Create keyring file before writing
    • Add ‘gpg’ in the requirements
    • Fix writing to repository list file
    • satnogs-setup: Install Docker CE instead of ‘docker.io’ package
    • Replace ‘docker.io’ with ‘docker-ce’ package
    • Add support for checking and prompting for updates before provisioning
    • Increase verbosity of Ansible run
Update instructions
Note: During the update (from versions <202601141228), the initial run of satnogs-setup will fail with an error. This is expected due to limitations in the previous version of the script. If you encounter this error, simply re-run satnogs-setup and it should then proceed normally.
Manifest
SatNOGS Ansible 202601141317
SatNOGS Config 1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202601141317
    • Allow replacement of ‘satnogs-setup’ by itself
Update instructions
Manifest
SatNOGS Ansible 202601152103
SatNOGS Config 1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202601152103
    • Match either space or tabs when parsing list of installed packages
    • satnogs-setup: Add support for Debian trixie
Update instructions
Manifest
SatNOGS Ansible 202601232106
SatNOGS Config 1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202601232106
    • Add missing compatibility with Debian trixie
Update instructions
Manifest
SatNOGS Ansible 202602080833
SatNOGS Config 1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202602080833
    • satnogs-setup: Fix getting Debian version when distro ID is ‘raspbian’
    • satnogs-setup: Improve prevention of running multiple instances
    • satnogs-setup: Do not show error when image archives directory does not exist
    • Introduce offline mode
    • Replace ‘ansible-pull’ with ‘ansible-playbook’
    • Remove unused option to provision only when branch has changed
    • Prevent Ansible container to modify itself
    • Print message on successful installation
    • satnogs-setup: Prevent pulling new images when re-configuring
    • Fix Docker configuration discrepancy
    • Introduce tag to mark tasks that should be executed only during re-configuration
    • satnogs-setup: Remove unused configuration option
    • compose-ansible: Fix permissions of Ansible host variables directory
    • satnogs-setup: Fix image loading
    • satnogs-setup: Fix syntax error in loop
    • Add support for loading Docker images from archives
    • Rename deprecated Ansible module
    • Mark all tasks that install packages or change repositories with the ‘packages’ tag
    • Add support for overriding pull policy
    • Fix Hamlib utilities running user
    • gitlab-ci: Enable merge request pipelines
    • Fix satnogs-config container running user
    • Introduce persistent ‘satnogs-config’ container
    • Migrate Ansible configuration to new path
    • Replace named bind volumes with anonymous bind volumes
    • gitlab-ci: Create release notes, use template for sign-off check
    • Do not always pull new images
    • Introduce persistent Ansible container
    • satnogs-setup: Add ‘curl’ to list of requirements
    • docker-engine: Let compose decide when a container needs to be recreated
    • Remove unused file
    • Change order of role execution to install required packages
    • Tune host UDP socket network performance
    • Add support for manipulating sysctl entries
    • Replace ‘apt-key’ with curl to download Docker CE repository key1
    • Install ‘gnupg’
    • Vagrant: Add support for Debian trixie
Update instructions
Note: During an update from versions <202601141228, the initial run of satnogs-setup will fail with an error. This is expected due to limitations in the previous version of the script. If you encounter this error, simply re-run satnogs-setup and it should then proceed normally.
Manifest
SatNOGS Ansible 202604201049
SatNOGS Config 1.1
SatNOGS Client 2.1.2
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202604201049
    • Bump ‘satnogs-client’ version
    • Wait for build container to complete before starting compose
    • Use host IPC mode to share memory between containers
    • Make SatNOGS Client container join SDRplay IPC namespace
    • Set environment variables to extend library and SoapySDR plugin lookup paths
    • Introduce ‘sdrplay’ service in SatNOGS compose
    • Run non-free build container when enabled and not already installed
    • Add SatNOGS non-free build container definition
    • Add tasks to install ‘satnogs-non-free’ script and check for install status
    • Introduce SatNOGS non-free bind mount directory
    • Add SDRplay udev rules
    • docker-engine: Add task to manage containers
SatNOGS Client
  • 2.1.2
    • Remove stale files from docker implementation
Update instructions
2026-06-29
Manifest
SatNOGS Ansible 202606292136
SatNOGS Config 1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202606292136
    • Fix base URL for Docker CE APT repository
    • common: Remove ‘zram’ management tasks
Update instructions
2026-07-06
Manifest
SatNOGS Ansible 202607061801
SatNOGS Config 1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202607061801
    • Move sysctl configuration to sysctl.d configuration directory
Update instructions
2026-07-09
Manifest
SatNOGS Ansible 202607090923
SatNOGS Config 1.1
Hamlib 4.5.4
Changelog
SatNOGS Ansible
  • 202607090923
    • Fix path to sysctl file
Update instructions
2026-07-17
Manifest
Software component Version
SatNOGS Ansible 202607171639
SatNOGS Config 1.2-284
SatNOGS Flowgraphs 2.5.2-1
gr-satnogs 3.1.0.1-1
GNU Radio 3.10.5.1-satnogs
Hamlib 4.5.4-39
Ansible 9.13.0
Changelog
SatNOGS Ansible
  • 202607171639
    • Bump Docker images
    • Fix configuration of rotator parameters on SatNOGS Client container
    • Do not force group on running containers that need additional group access
    • Fix default values on undefined parameter
    • Conditionally provide access to serial devices for Hamlib and SatNOGS client containers when defined
    • Allow Hamlib containers to access USB device
    • Set default pull policy to always
    • Update Hamlib container environment variables
Update instructions
Manifest
SatNOGS Ansible 202607181148
Hamlib 4.5.4-39
Ansible 9.13.0
Changelog
SatNOGS Ansible
  • 202607181148
    • Fix invalid default value of rotator port
Update instructions
