Hey all,
as a lot of you already noticed I am working on telemetry dashboards for some days now.
As a feedback to the whole community and to start some discussions and maybe get some useful hints on doing this and that I wanted to summarize my work in this thread.
The start of interpreting telemetry frames already stored in the data tab of an observation has been requested already some time ago. In these days there was a decision to use kaitai struct for the telemetry decoding. @cshields Corey already did some experiments with it on CAS-4A/B and I started very optimistically with the telemetry format of one of the AMSAT FOX satellites. Corey’s approach went very well where mine turned out to be a bit too advanced to start with (no worries, it is still work in progress
). Corey also did “some” work on “Closing the loop” between satnogs-network and satnogs-db to get frames from SatNOGS stations into the db (not only SiDS frames from other frontends). He also added grafana to visualize the data inside that frames into satnogs-db. As a proof of concept there were some dashboards made available to see if there are some showstoppers with the concept that was chosen (kaitai, influxdb, grafana, etc.).
To get back to my efforts I decided to dig deeper into that kaitai stuff by going one (or even more) steps back and tried to decode the AX.25 header in the dataframes oduced in satnogs-network. I started with a simple kaitai struct, following the AX.25 documentation on TAPR. The first one looked liek the following:
meta:
endian: be
seq:
- id: ax25_header
doc-ref: 'https://www.tapr.org/pub_ax25.html'
type: hdr
- id: ax25_info
type: str
encoding: ASCII
size-eos: true
types:
hdr:
seq:
- id: dest_address
type: str
encoding: ASCII
- id: dest_ssid
type: u1
- id: src_address
type: str
encoding: ASCII
- id: src_ssid
type: u1
- id: ctrl
type: u1
Which gave pretty good results if you keep reading on the AX.25 docs: source and destination callsign are 7-bit ASCII charcters and are enhanced by a so called extension bit. This is why you won’t ever get readable callsigns without converting the raw binary data in this fields. It took a while to get behind that and in a first step I was satisfied to convert these values by hand, masking the single charcacters and shift them one to the right
c = (c & 0xFE) >> 1
Some time later I got a really good hint from one of the kaitai-guys to use a built-in process called “ror” (rotate right) but I just didn’t know how to use this and startet poking around. As one of the last things I did these days, and with the story being told much further, I finally got the point how to use it. To decode the AX.25 header’s callsigns one can do (in kaitai struct):
meta:
endian: be
seq:
- id: ax25_header
type: hdr
- id: ax25_info
type: str
encoding: ASCII
size-eos: true
types:
my_str:
seq:
- id: callsign_str
type: str
encoding: ASCII
hdr:
seq:
- id: dest_address
type: my_str
process: ror(1)
- id: dest_ssid
type: u1
- id: src_address
type: my_str
process: ror(1)
- id: src_ssid
type: u1
- id: ctrl
type: u1
Using this kaitai struct I could get what I wanted: read callsigns of the AX.25 header in human readable ASCII inside the kaitai web IDE. But it was more than that! I suddenly got a tool on my hands to process raw telemetry data and I wanted more!
Time came and fortunately one of the team members of the UCLA ELFIN STAR team joined the IRC chat where lots of the SatNOGS team and contributors are around to talk. He was very interested in seeing observation data from their satellites first orbits. He was very cooperative and gave informations essential for further decoding of the satellites telemetry data.
Thanks for that man
I went off to the awesome #oscw18 to meet the core SatNOGS and Libre Space members and even some of the contributors beside me made it to Madrid. It was a great experience to meet all that people and it was really fun.
One evening I started poking around with the telemetry frames of the ELFIN satellites. I had great talks about that with all the guys staying with me. So I decided to go for a complete dashboard of these two satellites: complete the already started kaitai struct, get behind the secret of compiling them
and have a start in grafana for the visualization. But you want to validate that structs with some data and it was nearly impossible to get valid frames from these satellites. I decided to write a message to their twitter account and see what happens. I also had that guy in the IRC chat in mind, but he was busy and not very much around to talk (what is absolutely understandable in such times). But guess what? I got answer on twitter. He told me about the complete frame structure (and that there are some very special specialities) and gave a link to the conversion rules for the telemetry values. What a great conversation! I was trying to figure out how I could put all that information into the kaitai struct, so I went back to the guys on the kaitai chat. One told me: 'this is the reason we have implemented ‘user-processes’ and I was remembering the “ror”-built-in. Poking around a bit and reading a lots of docs finally gave me the idea behind that. I made an implementation of a so called “ELFIN-preprocessor” in python and that worked just out of the box! Great!
Need to make a break here now, to be continued asap!
P.S.: for the current results, but still WIP, visit: dashboard-dev.satnogs.org and watch the graphs
