Upgrade from stretch to buster on Rpi3 rtlsdr system
My station (no rotator) was running fine using stretch and client v1.0, but I wanted to get the latest software running on my system and buster is recommended. So I follow the wiki, burn a new image and install satnogs client, but I pick up problems. I look at troubleshooting as described on wiki, but no luck so far. Also searched the forum and no luck.
I don’t get any waterfalls and I think it has to do with the sample rate setting. I tried 2.048e6 and 2048000. The values below recommended for sample rates are soundcard settings?
This is the my “support information”
“versions”: {
“satnogs-client”: “1.2”,
“satnogs-client-ansible”: “202003221112”,
“satnogs-flowgraphs”: “1.0.1-1”,
“gr-satnogs”: “2.0.1-1”,
“gr-soapy”: “2.1.1-1”,
“gnuradio”: “3.8.1.0~rc1-2”,
“satnogs-config”: “0.9”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “4.19.97-v7+”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 971055104,
“available”: 796377088,
“percent”: 18.0,
“used”: 102318080,
“free”: 585818112,
“active”: 206610432,
“inactive”: 106070016,
“buffers”: 26345472,
“cached”: 256573440,
“shared”: 12562432,
“slab”: 52289536
“disk”: {
“total”: 15351623680,
“used”: 3723116544,
“free”: 10957373440,
“percent”: 25.4
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_rf_gain”: “49.6”,
“satnogs_soapy_rx_device”: “rtlsdr”,
“satnogs_station_elev”: “612”,
“satnogs_station_id”: “146”,
“satnogs_station_lat”: “24.771”,
“satnogs_station_lon”: “46.708”
and this is my " journalctl -f -u satnogs-client.service" output
– Logs begin at Sat 2020-03-28 16:25:54 UTC. –
Mar 28 16:25:57 raspberrypi systemd[1]: Started SatNOGS client.
Mar 28 16:39:16 raspberrypi satnogs-client[315]: rot_init called
Mar 28 16:39:16 raspberrypi satnogs-client[315]: dummy: init called
Mar 28 16:39:16 raspberrypi satnogs-client[315]: rot_register (1)
Mar 28 16:39:16 raspberrypi satnogs-client[315]: rot_register (2)
Mar 28 16:39:16 raspberrypi satnogs-client[315]: dummy_rot_init called
Mar 28 16:39:16 raspberrypi satnogs-client[315]: rot_open called
Mar 28 16:39:16 raspberrypi satnogs-client[315]: dummy_rot_open called
Mar 28 16:39:16 raspberrypi satnogs-client[315]: rot_get_position called
Mar 28 16:39:16 raspberrypi satnogs-client[315]: dummy_rot_get_position called
Mar 28 16:39:16 raspberrypi satnogs-client[315]: rot_set_position called
Mar 28 16:39:22 raspberrypi satnogs-client[315]: [INFO] [UHD] linux; GNU C++ ver sion 8.3.0; Boost_106700; UHD_3.15.0.0-2
Mar 28 16:39:22 raspberrypi satnogs-client[315]: Found Rafael Micro R820T tuner
Mar 28 16:39:22 raspberrypi satnogs-client[315]: Traceback (most recent call las t):
Mar 28 16:39:22 raspberrypi satnogs-client[315]: File “/usr/bin/satnogs_fsk_ax 25.py”, line 490, in
Mar 28 16:39:22 raspberrypi satnogs-client[315]: main()
Mar 28 16:39:22 raspberrypi satnogs-client[315]: File “/usr/bin/satnogs_fsk_ax 25.py”, line 475, in main
Mar 28 16:39:22 raspberrypi satnogs-client[315]: tb = top_block_cls(antenna= options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options. bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_f ile_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler
correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.fil e_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_ file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, p pm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_r ate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_arg s=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_p ort=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Mar 28 16:39:22 raspberrypi satnogs-client[315]: File “/usr/bin/satnogs_fsk_ax 25.py”, line 92, in init
Mar 28 16:39:22 raspberrypi satnogs-client[315]: tune_args, settings, samp_r ate_rx, “fc32”)
Mar 28 16:39:22 raspberrypi satnogs-client[315]: File “/usr/lib/python3/dist-p ackages/soapy/soapy_swig.py”, line 166, in make
Mar 28 16:39:22 raspberrypi satnogs-client[315]: return _soapy_swig.source_m ake(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_ra te, type)
Mar 28 16:39:22 raspberrypi satnogs-client[315]: RuntimeError: soapy::source: Un supported sample rate. Rate must be in the range [8000.000000, 8000.000000] [16 000.000000, 16000.000000] [22050.000000, 22050.000000] [32000.000000, 32000.0000 00] [44100.000000, 44100.000000] [48000.000000, 48000.000000] [96000.000000, 960 00.000000]
Mar 28 16:39:25 raspberrypi satnogs-client[315]: satnogsclient.observer.observer - ERROR - No waterfall data file found
This was the metadata from the observation
Have you tried any of the recommended sample rates?
Also it should be driver=rtlsdr and not just rtlsdr there …
Check the documentation more closely https://wiki.satnogs.org/SatNOGS_Client_Setup
Under basic configuration SATNOGS_SOAPY_RX_DEVICE
Yep, but I think the devil is in detail as @pierros explained below. Will let you know how it goes! Thanks guys. Awesome platform :wink: and great work. PS give @csete the difficult tasks :sweat_smile: he is enjoying this way too much
Its working so it was the driver=rtlsdr. Thanks
