Transmission of children’s drawings via SSTV from RS27S, RS38S, RS40S and RS49S.
2024-05-09 18:30utc RS40S - Sofia - Saturn
2024-05-09 18:45utc RS49S - Alisa - deleted
2024-05-09 18:54utc RS38S - Anna - deleted
I’ve decided to stop posting SSTV images containing soldiers, tanks and red stars linked to May 9th as a national holiday in some countries. This looks like war propaganda to me and is therefore not compatible with amateur service according to ITU RR 1.56.
Hi, is SSTV event always Robot36…?
My station didn’t synchronize with valid lines start. VE2DSK
What SSTV software did you use? If you use Blackcat, then you can select different modes during reception until you find one that works. I usually record the audio of the signal in SDR#, then play it back into Blackcat and select the announced SSTV mode to force the software into trying to decode that mode, especially if I miss the initial synchronisation signals.
I’m using RX-SSTV. It auto detects the mode.
Sometimes the satellites send in Robot 36 but mostly in Robot 72.
ISS also uses PD120.
Hi…
I’m using the build in satnogs decoder. That’s why.
Working for ISS SSTV. VE2DSK
Hi. There is no diploma program this SSTV broadcast. A diploma program is planned for the summer. On May 10, RS40S UMKA -1 stopped transmitting due to a series of solar flares. The transfer of children’s drawings with astronomical objects has been postponed to May 25-26.
Replay on MMSSTV look better.
VE2DSK
On Saturday and Sunday (May 25-26), the UMKA satellite will begin broadcasting children’s drawings depicting astronomical objects as part of the educational experiment “UMKA from Space.”
UMKA-1 RS40S
SSTV format Robot72
The transmission of each pattern begins after 250 seconds.
Frequency: 437.625 MHz
Broadcast start time May 25, 06:05 UTC
me too, but signal was most of the time too low and with fading.
I was super lucky with the second one. I see your Stratosat-TK1 image in the other thread, I got that one as well. I got 4 transmissions, but only one image came out of it… I had two jpg headers, but for the same picture.
Got now also on a zenith pass “the moon” (Голованковой Арины (9 лет) – “Луна”) in full quality as you did before and additionally near LOS “Ursa Major and Ursa Minor” (Дуровой Варвары (8 лет) – “Большая и Малая медведицы”).
UmKA-1 over Brazil with 11 degrees of elevation!!! The hills to the west bother me a lot
73 from PU4ELT !
In North America…
2024-05-25 20:04 utc
Платон (2″В” класс) – “Сатурн”
Saturn
2024-05-25 20:08 utc
Егор (2″В” класс) – “Солнечная Система”
Solar System
Hi Robert,
Welcome to the community.
If you are using RX-SSTV and want to get rid of the green nebula at the beginning of the images, just switch off AFC.
