2025-08-30_10.11.45 UTC
Greetings, friends.
As part of the “Umka from Space” program, a transmission of children’s drawings in SSTV format from the UmKA-1 (RS40S) school CubeSat telescope is planned.
Broadcast start: September 20, 2025, 20:20 UTC
Broadcast end: September 21, 2025, 22:11 UTC
Frequency: 437.625 MHz
Mode: Robot36
Interval: Every 94 seconds
Image transmission is possible while passing over the MСС.
Transmission may be interrupted without prior notice if necessary (increased temperature, low battery, etc.)
thank you for information. very interesting ![]()
- 2025-09-21 00:57UTC
- 2025-09-21 01:00 (VERY VERY strong ionospheric scintillation)
UmKA-1 over Brazil
No images on pass 09:3x.
Good to know. I thought it was just me. Nothing but tlm heard here on same pass.
Same here 11:00 UTC.
Jomjom79
I will resume broadcasting as soon as I can contact the satellite. I may also repeat the broadcast on Monday.
Thank you for your observation.
same. very faint tlm.
21.09.25
20:22 UTC
Started only 6° above the horizon. Considering all the mountains around here i am amazed it came out that good
20:24 UTC
20:26 UTC
Jomjom79
very good. what type antenna you used?
I’m using a HB9CV with 3+3 elements (9.5 dBd) with preamp on a rotator in the attic.
This pass was done with something as basic as my Diamond MR77 mag mount.
Jomjom79
incredible, with only 6 degree max ? wow
