pu4elt
August 15, 2025, 12:44pm
609
August 16 at 07:07 UTC , activation of image transmission in SSTV format from the UmKA-1 satellite is planned.
Mode - Robot36
Interval - 120 sec
Frequency - 437.625 MHz
Conclusion - August 17 at 16:16 UTC
Message sent on the Telegram channel : ON AIR (See the message HERE )
HS318
August 16, 2025, 8:51am
610
Low passes with and omnidirectional antenna just don’t work with these low passes. This was at 19elv
HS318
August 16, 2025, 6:10pm
612
These were better this morning with just over 40 degrees elevation
pu4elt
August 17, 2025, 1:55am
613
2025-08-16 12:18UTC
2025-08-16 23:56UTC
2025-08-16 23:58UTC
2025-08-17 00:01UTC
2025-08-17 01:33UTC
So far I have been able to receive all the images transmitted by UmKA-1 during this event .
I still need to try to improve some images
dl7ndr
August 17, 2025, 9:19am
614
I’m always getting the same images 4 images. I’m missing the pink planet.
10:04 UTC
10:06 UTC
It did send some data right after the first SSTV transmission that was not the usual telemetry. Did anyone catch what that was?
Jomjom79
dl7ndr
August 17, 2025, 10:52am
617
My recording shows usual telemetry 20 seconds after the first image, which is 10:05:03.
pu4elt
August 18, 2025, 2:32pm
619
In honor of the 70th anniversary of the OKB “Fakel”, an image transmission in SSTV format from the UmKA-1 RS40S satellite is planned
Format - Robot36
Intervals - 120 sec
Transmission start - August 19 at 00:01 UTC
Transmission end - August 19 at 17:15 UTC
2e0gkw
August 19, 2025, 10:47am
621
Thanks to @pu4elt for the heads-up I managed to grab this on the 093xZ pass over UK; actually same image a couple of times but this best of them. I think this was the only viable pass over UK during the activation period so glad to catch it.
UmKa-1 (RS40S) 0939UTC 19-Aug-25
dl7ndr
August 19, 2025, 4:22pm
622
best quality of 10 transmissions.
dl7ndr
August 21, 2025, 8:16am
623
2025-08-21 07:33 Robot72
2025-08-21 07:34 BW 8
2025-08-21 07:35 BW12
2025-08-21 07:36 Robot24
With only a few degrees over the horizon.
https://t.me/onthe_air/1424
pu4elt
August 29, 2025, 3:38pm
624
A new SSTV event from the UmKA-1 RS40S satellite is planned. The transmission is timed to coincide with Knowledge Day. The broadcast will include some student drawings from previous broadcasts, as well as a special themed drawing.
Format - Robot36
Intervals - 120 sec
Transmission start - August 30 at 00:35UTC
Transmission end - August 30 at 21:00UTC
30/08/25 10:06 UTC
Very strong signal
10:09 UTC
Not so strong signal
Jomjom79
