This is really a puzzle, I am running the same version on a Debian x86 system without a rotor and I will share my support output, maybe that will help.
"versions": {
"satnogs-client": "1.7+1.g07f6c80",
"satnogs-client-ansible": "202206091629",
"gr-satnogs": "2.3.1.1+3+gb02af152-1",
"gr-soapy": "2.1.3.1+2+gf2c6097a-1",
"gnuradio": "3.8.2.0-14satnogs2",
"satnogs-config": "0.12+3.g014a15d"
"state": {
"is-applied": true,
"pending-tags": null
"system": {
"date": "2022-06-17T20:51:47.758938+00:00",
"distribution": {
"DESCRIPTION": "Debian GNU/Linux 10 (buster)",
"RELEASE": "10",
"CODENAME": "buster",
"ID": "Debian"
"pending-updates": false,
"platform": {
"system": "Linux",
"node": "exomars",
"release": "4.19.0-20-686-pae",
"version": "#1 SMP Debian 4.19.235-1 (2022-03-17)",
"machine": "i686",
"processor": ""
"memory": {
"total": 2113404928,
"available": 1410666496,
"percent": 33.3,
"used": 438915072,
"free": 290680832,
"active": 348909568,
"inactive": 1294356480,
"buffers": 61870080,
"cached": 1321938944,
"shared": 16261120,
"slab": 108654592
"disk": {
"total": 4194500608,
"used": 1396928512,
"free": 2589708288,
"percent": 35.0
"configuration": {
"experimental": true,
"satnogs_antenna": "RX",
"satnogs_artifacts_enabled": true,
"satnogs_artifacts_api_token": "[redacted]",
"satnogs_dev_args": "biastee=true",
"satnogs_post_observation_script": "/usr/local/bin/satnogs-post {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}",
"satnogs_ppm_error": "-1",
"satnogs_pre_observation_script": "/usr/local/bin/satnogs-pre {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}",
"satnogs_rf_gain": "29.7",
"satnogs_soapy_rx_device": "driver=rtlsdr,serial=00001220",
"satnogs_station_elev": "5",
"satnogs_station_id": "[redacted]",
"satnogs_station_lat": "[redacted]",
"satnogs_station_lon": "[redacted]",
"snmpd_enabled": true,
"udp_dump_host": "127.0.0.1",
"udp_dump_port": "57356"
