Tutorial: How to install satnogs groundstation for Newbie & PRO (for STATIC and ROTATOR)
I’d recommend changing the docker-compose file from using the device forwarding to using a full bind mount. It makes it resilient against cases where the USB port disconnects and then reconnects later.
By mounting/binding the whole USB tree, the SatNOGS client can auto-discover the USB device again. With the devices: bind, docker only passes through the devices present on container startup.
Remove this:
    devices:
      - '/dev/bus/usb'
Replace with this (in the volumes: section):
      - type: 'bind'
        source: '/dev/bus/usb'
        target: '/dev/bus/usb'
