TUBIN/TUBSAT-27 Re-Entry
Hi Bob,
Yes, similar to the last test two weeks ago the satellite will transmit on UHF regularly. For example see SatNOGS Network - Observation 12705580 for what to expect. The only difference will be that the interval will be reduced from a frame every 30 seconds to one every 10 seconds.
The term “Auto Send” is used by us to state that the satellite is transmitting telemetry independently from from a ground station contact and at a regular interval. For now the feature is only active during certain tests, but it will run consistently in last days before re-entry. This will help us to generate fresh TLEs from Doppler shift measurements, but also the telemetry is relevant, see the BEESAT-9 Re-Entry thread.
Best Julian / DH4RJU
