TLE update for KOYO satellite, is not fully accurate as it is difficult to find the center of the wide signals, but it is definitely better than the current we use:
Status for the the IARU non-coordinated satellites (except the german ones):
Satellite
Reception
KOYO
received
SCION-X
received
SUCHAI-4
not-received
SCION-X signals are very faint. Also the current TLE used is good for now.
SUCHAI-4 hasn’t been received, we are going to use the current TLE for now, may be we are going to change it using as reference TLE from another satellite in a couple of days. Note here that the transmitter is unconfirmed, so the satellite may not transmit at this frequency or frequency band.
For now the TLE for the IARU non-coordinated german satellites look good, so we keep them as they are. As the Unknown 1 T17 satellite is probably one of them, I’ll keep present it here too and I’ll note that also the TLE set used is pretty accurate.
Satellite
Reception
Unknown 1 T17
received
TOM-[1-3]
received
CUBY-[1-5]
received
CLOUDCT-PRECURSOR
received
It is not clear as we don’t have clear decodings, but it seems that we have received if not all at least some of them.
What we have managed to decode, it is CloudCT-Precursor with callsign DP2CTP and we have in its observations 3 other satellites DP2TOA, DP2TOB and DP2TOC. These belong respectively to TOM-1, TOM-2 and TOM-3 according to Rufzeichen (thanks @dl7ndr for linking it previously).
So, with the above, it looks like that all the TOM satellites transmit at least at 435.600 MHz with the same modulation with CloudCT-Precursor and they are the wide ones.
Thus we remain with the narrow long transmissions which expected to be one or more CUBY satellites. As we haven’t decode these narrow signals we are not say for sure more.
Another note is that these narrow signals seem to be transmitted around 435.595 MHz instead 435.600 MHz, so I’m going for now to change this in DB. Another change is the modulation and baudrate of TOM satellites.
cc @db2os that’s probably is interested in this analysis
EDIT:
PS There isn’t any signal received at the other expected frequency at 437.800 MHz
Discussing with @PE0SAT in the satnogs chat, I’ve realized the narrow signal is the default music transmission from endurosat comms. Thus probably don’t belong to CUBY satellites, a similar one at 435.5470 MHz for the “Unknown 1 T17”.
So, probably we are looking for the 5 CUBY sats and to find out which one are the satellites with endurosat transmissions at 435.595 MHz and 435.5470 MHz.
Great work by everybody working on decode parameters, TLEs, and everything else around this deployment.
I certainly don’t mind copy/pasting as improvements are made to individual TLEs when we have these mass deployments… but out of curiosity, is there a list anywhere that’s updated & could be re-downloaded once or twice per day? If not, no problem - just wanted to ask.
If you need specific satellites you can filter with the sat_id parameter using comma separator of the satellite IDs (comma “,” becomes %2C in the request), for example for T17 launch satellites:
PS The TLE I post usually are updated 1-2 minutes after the post, for the other ones they are updated when I have “liked” the post.
PS 2 Hopefully in the future there will be a way for users/teams update the orbital data directly in DB without my intervention.
