last update: 2026-07-06 17:00 UTC
Temporary NORAD ID Satellite Frequency Modes Notes Deployment
AMATEUR HF
98272 MARMOTSat 29.410 MHz FM, DVB-S2,CW IARU Coordinated Directly
AMATEUR VHF
98272 MARMOTSat 145.875 MHz AFSK 1200.0, CW IARU Coordinated Directly
98293 Marina 145.925 MHz GFSK 9600.0 IARU Coordinated Directly
COMMERCIAL UHF
98279 Centauri-9 400.220 MHz FSK 9600.0 - Directly
98267 Replicator-2 400.500 MHz GFSK 9600.0 - Directly
98275 Kita-36 400.500 MHz GFSK 30000.0 - Directly
98274 Kita-53 400.500 MHz GFSK 30000.0 - Directly
98269 Oasis Alpha 400.575 MHz Unknown Mode - Directly
98276 ION SCV Joyful Julia 401.415 MHz FSK AX.100 Mode 5 1200.0 - Directly
98287 IPoS-TDsM 401.500 MHz GFSK 9600.0 - Directly
98285 FOSSASAT-2E26 401.700 MHz LoRa - Directly
98268 RAFS 401.700 MHz Unknown Mode - Directly
98286 BRO-31 401.735 MHz FSK AX.100 Mode 5 4800.0 - Directly
98268 RAFS 401.850 MHz Unknown Mode - Directly
98268 RAFS 401.950 MHz Unknown Mode - Directly
AMATEUR UHF
98273 Koyo 435.400 MHz FSK 9600.0 Unconfirmed transmitter Directly
98264 TOM-1 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98263 TOM-2 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98262 TOM-3 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98283 CUBY-2 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98282 CUBY-3 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98281 CUBY-4 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98280 CUBY-5 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98284 CUBY-1 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98278 CloudCT-Precursor 435.600 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98272 MARMOTSat 436.125 MHz Unknown Mode IARU Coordinated Directly
98293 Marina 436.680 MHz GFSK 9600.0, CW,SSDV IARU Coordinated Directly
98395 KOSTKA 436.870 MHz CW, GFSK 9600.0 IARU Coordinated Directly
98265 SUCHAI-4 437.230 MHz FSK AX.100 Mode 5 4800.0 Unconfirmed transmitter Directly
98266 SCION-X 437.500 MHz GFSK 9600.0 IARU coordination in progress Directly
98271 Maveric 437.575 MHz GMSK 9600.0 IARU Coordinated Directly
98264 TOM-1 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98263 TOM-2 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98262 TOM-3 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98283 CUBY-2 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98282 CUBY-3 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98281 CUBY-4 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98280 CUBY-5 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98284 CUBY-1 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
98278 CloudCT-Precursor 437.800 MHz Unknown Mode AMATEURIARU uncoordinated, range from ITU entry 400 KHz, probably not the right center frequency Directly
OTHER UHF,L-Band, S-Band
98277 CyberCUBE 2206.500 MHz Unknown Mode - Directly
98287 IPoS-TDsM 2222.000 MHz Unknown Mode 62500.0 - Directly
98270 Navigator 2250.000 MHz Unknown Mode - Directly
98261 SENTINEL-1 2254.100 MHz Unknown Mode - Directly
98268 RAFS 2267.000 MHz Unknown Mode - Directly
98264 TOM-1 2275.500 MHz Unknown Mode - Directly
98263 TOM-2 2275.500 MHz Unknown Mode - Directly
98262 TOM-3 2275.500 MHz Unknown Mode - Directly
98264 TOM-1 2285.500 MHz Unknown Mode - Directly
98263 TOM-2 2285.500 MHz Unknown Mode - Directly
98262 TOM-3 2285.500 MHz Unknown Mode - Directly
98277 CyberCUBE 2285.500 MHz Unknown Mode - Directly
NOT IN DB
- BOHR (City Labs) - - iridium 1618.725-1626.5 MHz FCC grant Directly
- CAS500-4 - - - Directly
- Balkan-3 - - Ku and Ka bands ITU entry Directly
- ET-01 (EarthTraq) - - iridium 1618.725-1626.5 MHz FCC grant Directly
- FireSat1 - - - Directly
- FireSat2 - - - Directly
- FireSat3 - - - Directly
- Flashpoint 1 - - - Directly
- Flashpoint 2 - - - Directly
- GRITSS - - S-band 3.2GHz, X-band 10.2GHz Directly
- GRUS-3A - - 467.720 MHz and 2278.25 MHz ITU entry Directly
- GRUS-3B - - 467.720 MHz and 2278.25 MHz ITU entry Directly
- GRUS-3C - - 467.720 MHz and 2278.25 MHz ITU entry Directly
- GRUS-3D - - 467.720 MHz and 2278.25 MHz ITU entry Directly
- GRUS-3E - - 467.720 MHz and 2278.25 MHz ITU entry Directly
- GRUS-3F - - 467.720 MHz and 2278.25 MHz ITU entry Directly
- GRUS-3G - - 467.720 MHz and 2278.25 MHz ITU entry Directly
- Hyperion GR 1 - - - Directly
- ICEYE 1 - - - Directly
- ICEYE 2 - - - Directly
- ICEYE 3 - - - Directly
- ICEYE 4 - - - Directly
- LA3 - - - Directly
- LEMUR-2-ALEX-FULTON - - - Directly
- LEMUR-2-ALYX - - - Directly
- LEMUR-2-CRIMBOREALIS - - - Directly
- LEMUR-2-DELOITTE-4 - - - Directly
- LEMUR-2-DELOITTE-5 - - - Directly
- LEMUR-2-DELOITTE-6 - - - Directly
- LEMUR-2-ELEONORE - - - Directly
- LEMUR-2-JESS-R - - - Directly
- LEMUR-2-NURAY - - - Directly
- LEMUR-2-SOPHILUNA-X1 - - - Directly
- LEONAV-1 - - - Directly
- Loft-EarthDaily-8 - - - Directly
- N2-P-BODY - - iridium 1618.725-1626.5 MHz FCC grant Directly
- Nova 1 - - - Directly
- POSIDONIA - - - Directly
- Pelican-11 - - - Directly
- Pirx-1 - - - Directly
- R5-S9 - - iridium ITU entry Directly
- SPEAR-1A - - iridium 1618.725-1626.5 MHz FCC grant Directly
- SPEAR-1B - - iridium 1618.725-1626.5 MHz FCC grant Directly
- SPEAR-1C - - iridium 1618.725-1626.5 MHz FCC grant Directly
Sources:
https://forum.nasaspaceflight.com/index.php?topic=61462.0;all
ORIGINAL POST:
The pace of announcements from individual cubesat teams as well as from deployment providers with payloads on Transporter-17 is really picking up now, so we should start organizing.
Exolaunch alone has announced that it will deploy -49- sats from T-17, so this is going to be a big one.
Some individual sats that have public info available are:
Maveric (USC) -
https://today.usc.edu/usc-satellite-heading-to-orbit-on-spacex-mission/
https://iaru.amsat-uk.org/finished_detail.php?serialnum=1097
MARMOTSat (University of Victoria) -
https://www.marmotsat.ca/updates/transporter-17-launch-commitment
https://www.propagationlab.ca/satellite/
LABSAT IoT (Argentina) -
https://www.palermo.edu/ingenieria/satelite-labsat-iot/en/
… I’ll stop there since the list is going to get VERY long. Anyway, let’s hope for a successful launch and that most (if not all) of the payloads are heard after deployment!
Thanks for the update. Indeed we should start gathering information.
Given that my current focus is on the SatNOGS Development, any help with suggestions in DB for this launch is more than welcome. You can find information on how to suggest satellites and transmitters can be found in these wiki pages:
Priority satellite for getting them in DB are the ones that we know their transmission frequencies and they are in VHF, UHF and S-band. For transmission frequencies, a good generic source is the ITU explorer site and for the amateur radio ones the IARU coordination site.
Maybe there are already some satellites suggested already, you can take a quick look in https://db.satnogs.org/suggestions before making a new one.
Finally I’ll be able to check most of the suggestions during the weekend (unfortunately I’m still the bottleneck on satellites suggestions review).
2 posts were split to a new topic: About Satellite and Transmitter Suggestions
Firesat-1/2/3 will also be on this launch, based on a Twitter message by ExoLaunch.
Another Sat just confirmed being on this deployment.
Kostka: (436.870, 9k6 AX25 G3RUH GFSK, AX.25 messages and telemetry, a digipeater service, CW beacon, SatNOGS integration, and SSDV image transmission)
https://www.idnes.cz/technet/vesmir/vesmir-druzice-cubesat-kostka-1u-vut-yspace.A260701_121627_tec_vesmir_vse
-and-
https://iaru.amsat-uk.org/finished_detail.php?serialnum=1089
-and-
https://db.satnogs.org/satellite/PCVZ-1444-3446-1456-5852
We can add FossaSat-26 to this launch. I assume that it’ll use LoRa as all their previous missions did, but hopefully we can get all the details and find out whether there are any other transmitters on-board.
Add to the list LEONAV-1
Unfortunately I’ve not been able to locate any downlink frequency info on that one.
https://x.com/Exolaunch/status/2073384937558868387
Regarding the 10-meter downlink planned for MARMOTSat, today I used my newly-acquired ‘Ham-It-Up’ converter from NooElec to successfully receive the downlink from AO-7. Today’s test was not ideal… just using a non-resonant SkyLoop. Will experiment with other antenna options & report if anything works well.
https://www.amazon.com/Ham-Up-Plus-Upconverter-Enclosure/dp/B076CYK8XZ
COMMERCIAL UHF
xxx LEMUR-2-ELEONORE - - Directly
xxx CyberCUBE - - Directly
xxx LEMUR-2-CRIMBOREALIS - - Directly
xxx LEONAV-1 - - Directly
xxx LEMUR-2-ALYX - - Directly
98287 Apolink IPoS 401.500 MHz - Directly
xxx GRITSS - - Directly
xxx LEMUR-2-DELOITTE-6 - - Directly
xxx EarthTraq’s ET-01 - - Directly
xxx LEMUR-2-DELOITTE-5 - - Directly
xxx N2-P-BOD - - Directly
98279 Centauri-9 400.220 MHz - Directly
xxx LEMUR-2-NURAY - - Directly
xxx BOHR (City Labs) - - Directly
xxx LEMUR-2-DELOITTE-4 - - Directly
98269 Oasis Alpha 400.575 MHz - Directly
xxx LEMUR-2-SOPHILUNA-X1 - - Directly
xxx LEMUR-2-JESS-R - - Directly
xxx Balkan-3 - - Directly
xxx TOM-1 - - Directly
xxx TOM-2 - - Directly
xxx TOM-3 - - Directly
xxx LEMUR-2-ALEX-FULTON - - Directly
xxx Hyperion GR1 - - Directly
98268 RAFS Cubesat 401.700 MHz, 401.850 MHz, 401.950 MHz - Directly
98267 Replicator-2 400.500 MHz - Directly
xxx SPEAR-1A - - Directly
xxx SPEAR-1B - - Directly
xxx SPEAR-1C - - Directly
xxx R5-S9 - - Directly
98285 FOSSASAT-2E26 401.700 MHz - Directly
98286 BRO-31 401.735 MHz - Directly
xxx POSIDONIA - - Directly
98276 ION SCV Joyful Julia 401.415 MHz - Directly
xxx ICEYE3 - - Directly
xxx ICEYE1 - - Directly
98275 KITA-36 400.500 MHz - Directly
xxx FireSat3 - - Directly
xxx ICEYE4 - - Directly
xxx GRUS-3D - - Directly
xxx GRUS-3A - - Directly
xxx FireSat1 - - Directly
xxx GRUS-3E - - Directly
xxx Loft-EarthDaily-8 - - Directly
xxx Flashpoint1 - - Directly
xxx LA3 - - Directly
xxx Nova1 - - Directly
xxx GRUS-3C - - Directly
xxx GRUS-3B - - Directly
xxx GRUS-3F - - Directly
xxx GRUS-3G - - Directly
xxx Pirx-1 - - Directly
xxx Flashpoint2 - - Directly
xxx FireSat2 - - Directly
98274 KITA-35 400.500 MHz - Directly
xxx Pelican-11 - - Directly
xxx ICEYE2 - - Directly
xxx CAS500-4 - - Directly
AMATEUR UHF
98273 KOYO 435.400 Mhz - Directly
98272 MARMOTSat 436.125 MHz IARU Coordinated Directly
98395 KOSTKA 436.870 MHz - Directly
98265 SUCHAI-4 / SPEL / UCHILE 437.230 MHz - Directly
98284 CUBY-1 435.600 Mhz, 437.800 Mhz IARU Uncoordinated Directly
98283 CUBY-2 435.600 Mhz, 437.800 Mhz IARU Uncoordinated Directly
98282 CUBY-3 435.600 Mhz, 437.800 Mhz IARU Uncoordinated Directly
98281 CUBY-4 435.600 Mhz, 437.800 Mhz IARU Uncoordinated Directly
98280 CUBY-5 435.600 Mhz, 437.800 Mhz IARU Uncoordinated Directly
98278 CloudCT-Precursor 435.600 Mhz, 437.800 Mhz IARU Uncoordinated Directly
98271 MAVERIC 437.575 MHz IARU Coordinated Directly
98293 Marina 436.680 MHz IARU Coordinated Directly
98266 SCION-X 437.500 MHz - Directly
AMATEUR VHF
98293 Marina 145.925 MHz IARU Coordinated Directly
98272 MARMOTSat 145.875 MHz IARU Coordinated Directly
98270 Navigator 2250.000 MHz - Directly
98261 OSIRIS-A 2254.100 MHz - Directly
last update: 2026-07-06 16:43 UTC
spaceX page screenshot - 2026-07-06 04:12 UTC 2026
Great list!
Here is info ref. KOYO
https://github.com/daniestevez/gr-satellites/pull/841#discussion_r3525446272
Hi, I’m a member of the YSpace team, which is responsible for the KOSTKA (temp. NORAD ID 98395, callsign OK0KST) CubeSat. As mentioned earlier, we are also launching on this mission. KOSTKA uses the frequency 436.870 MHz with 9k6 G3RUH GFSK modulation. It will transmit 4 types of AX.25 beacons and one CW beacon. A decoder for the AX.25 beacons is already available in the satnogs-decoders repository on GitLab. KOSTKA also contains a digipeater, and in a few months it will transmit images from the onboard camera using SSDV. One of its objectives is to test our custom in-house antenna and UHF receiver. More info can be found on the website https://cubesat.cz/.
I would also like to ask one question. I noticed that for previous launches, you scheduled observations for the satellites integrated into SatNOGS for the first 24 hours after launch. Are you planning to do the same for this launch, or should we schedule the observations ourselves? Thank for the answer!
Yes there will be a systematic scheduling until a couple of days/weeks after TLE for this launch are published in space-track.org and we have performed any possible identifications.
Scheduling usually starts ~1h before launch. For the satellite missions, keep us updated if you have any updates, like changes in launch time, any preliminary or post launch TLE sets etc.
I’m hoping i can get a HF station up and running so i can track MARMOTSat on HF. I would like to get signal from its CW transmitter and maybe its DVB-S2 signal on the same frequency. I also have submitted a suggestion here: SatNOGS DB - MARMOTSat that should have all of the transmitters and modulations of the transmitters. Some of the data might be inaccurate
I went through all the satellites from the SpaceX page and reviewed and suggested satellites and transmitters.
I’ve continue later today by creating the table for the first post and prepare for the launch.
Hi everyone,
I am a member of the SCION-X team, responsible for the SCION-X CubeSat (temporary NORAD ID: 98266, callsign: BV0SCX).
Here are our transmission specifications:
  • Frequency: 437.500 MHz
  • Data Rate: 9600 bps
  • Modulation: GFSK
  • Protocol: HDLC/AX.25 (Note: NRZI encoding and scrambling are NOT used)
only on UHF? no VHF?
source: SCION-X Spacecraft - Nanosats Database
source
First post updated with the satellites and frequency details. There are some suggestions pending some answers before checked.
Unfortunately until now we don’t have any TLE from celestrak, if we don’t have any, later we are going to produce our own.
There are a 9 satellites from Germany that will transmit in the range from 435.400 Mhz to 435.800 MHz and in the range from 437.600 MHz to 438.000 MHz, in DB have been added with the center frequencies of these ranges, so we will may need help to check these whole ranges to find the real center frequencies.
btw based on above data, inclination of transporter 17 around 97.41 degree
LIVE
I have looking at the expected places but can’t find any preliminary TLE, has somebody else found any orbit information ?
Hi I’m from the Apolink Team!
For IPoS-TDsM
-We have two transmitter frequencies
AX.25
401.5MHz
GFSK
9600 bps baud rate
The other frequency is
2222.000 MHz
62500 bps baud rate
As for our current TLE:
1 99999U 00000A 26188.34024854 .00000000 00000-0 18614-3 0 9993
2 99999 97.8255 89.2617 0020625 306.4921 36.2639 14.90153634 12
See you in Space!
