62500 sounds like a LoRa bandwidth, if so, can you share the parameters ?
Thanks,
Ben
Thanks,
Ben
Hi from the Apolink team again!
Please don’t mind that S band Frequency
2222MHz
Thank you!
Using the temp SatNogs Object ID, proper spacing & checksum, that works out to:
IPoS-TDsM
1 98287U 00000A 26188.34024854 .00000000 00000-0 18614-3 0 9992
2 98287 97.8255 89.2617 0020625 306.4921 036.2639 14.90153634 11
Thank you very much and good luck with the mission.
I updated the TLE with the temporary SatNOGS NoradID.
IPOS-TDSM
1 98287U 26188.34024854 .00000000 00000-0 18614-3 0 9992
2 98287 97.8255 89.2617 0020625 306.4921 36.2639 14.90153634 11
Howdy from the Apolink team again!
For IPoS, the TLE that we will be using for the AOS of the mission, we’ll be using:
1 99900U 26045OUT 26188.33738904 .00000000 00000-0 42263-3 0 9996
2 99900 97.7549 88.3329 0000516 30.6441 312.5509 14.90922007 13
Apologies for the sudden changes.
Best,
The Apolink Team
Then we get:
IPOS-TDSM AOS
1 98287U 26188.33738904 .00000000 00000-0 42263-3 0 9996
2 98287 97.7549 88.3329 0000516 30.6441 312.5509 14.90922007 10
We have orbital data in OMM format from celestrak.org:
"OBJECT_NAME": "OSIRIS-A",
"OBJECT_ID": "2026-156A",
"EPOCH": "2026-07-07T08:04:42.112992",
"MEAN_MOTION": 14.90659552,
"ECCENTRICITY": 0.0001361,
"INCLINATION": 97.7556,
"RA_OF_ASC_NODE": 88.3326,
"ARG_OF_PERICENTER": 348.3326,
"MEAN_ANOMALY": 350.6181,
"EPHEMERIS_TYPE": 0,
"CLASSIFICATION_TYPE": "C",
"NORAD_CAT_ID": 799501928,
"ELEMENT_SET_NO": 0,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028101,
"MEAN_MOTION_DOT": -0.00027473,
"MEAN_MOTION_DDOT": 0,
"RMS": "0.139",
"DATA_SOURCE": "Transporter-SV"
"OBJECT_NAME": "LEMUR-2-ELEONORE",
"OBJECT_ID": "2026-156B",
"EPOCH": "2026-07-07T08:04:44.913043",
"MEAN_MOTION": 14.92743488,
"ECCENTRICITY": 0.0008006,
"INCLINATION": 97.7532,
"RA_OF_ASC_NODE": 88.3336,
"ARG_OF_PERICENTER": 153.2897,
"MEAN_ANOMALY": 185.8419,
"NORAD_CAT_ID": 799501955,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025626,
"MEAN_MOTION_DOT": -0.0002641,
"RMS": "0.139",
"OBJECT_NAME": "SUCHAI-4",
"OBJECT_ID": "2026-156C",
"EPOCH": "2026-07-07T08:04:54.712963",
"MEAN_MOTION": 14.90694328,
"ECCENTRICITY": 0.000155,
"INCLINATION": 97.752,
"RA_OF_ASC_NODE": 88.3341,
"ARG_OF_PERICENTER": 18.9519,
"MEAN_ANOMALY": 320.7898,
"NORAD_CAT_ID": 799501929,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027405,
"MEAN_MOTION_DOT": -0.00026815,
"RMS": "0.139",
"OBJECT_NAME": "KOYO",
"OBJECT_ID": "2026-156D",
"EPOCH": "2026-07-07T08:05:10.213037",
"MEAN_MOTION": 14.90654813,
"ECCENTRICITY": 0.0002099,
"INCLINATION": 97.7491,
"RA_OF_ASC_NODE": 88.3353,
"ARG_OF_PERICENTER": 28.8632,
"MEAN_ANOMALY": 311.8475,
"NORAD_CAT_ID": 799501931,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027955,
"MEAN_MOTION_DOT": -0.00027327,
"RMS": "0.139",
"OBJECT_NAME": "CYBERCUBE",
"OBJECT_ID": "2026-156E",
"EPOCH": "2026-07-07T08:05:12.513005",
"MEAN_MOTION": 14.92755752,
"ECCENTRICITY": 0.0008283,
"INCLINATION": 97.7461,
"RA_OF_ASC_NODE": 88.3364,
"ARG_OF_PERICENTER": 145.4114,
"MEAN_ANOMALY": 195.4497,
"NORAD_CAT_ID": 799501938,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0024976,
"MEAN_MOTION_DOT": -0.0002575,
"RMS": "0.139",
"OBJECT_NAME": "LEMUR-2-CRIMBOREALIS",
"OBJECT_ID": "2026-156F",
"EPOCH": "2026-07-07T08:05:13.512998",
"MEAN_MOTION": 14.92514201,
"ECCENTRICITY": 0.0006966,
"INCLINATION": 97.7528,
"ARG_OF_PERICENTER": 153.1593,
"MEAN_ANOMALY": 187.749,
"NORAD_CAT_ID": 799501946,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025339,
"MEAN_MOTION_DOT": -0.00025961,
"RMS": "0.139",
"OBJECT_NAME": "LEONAV-1",
"OBJECT_ID": "2026-156G",
"EPOCH": "2026-07-07T08:05:27.913027",
"MEAN_MOTION": 14.9279635,
"ECCENTRICITY": 0.0008328,
"INCLINATION": 97.7488,
"RA_OF_ASC_NODE": 88.3356,
"ARG_OF_PERICENTER": 149.7955,
"MEAN_ANOMALY": 192.0159,
"NORAD_CAT_ID": 799501934,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025507,
"MEAN_MOTION_DOT": -0.00026324,
"RMS": "0.139",
"OBJECT_NAME": "LEMUR-2-ALYX",
"OBJECT_ID": "2026-156H",
"EPOCH": "2026-07-07T08:05:28.913021",
"MEAN_MOTION": 14.92362871,
"ECCENTRICITY": 0.0006236,
"INCLINATION": 97.7553,
"RA_OF_ASC_NODE": 88.3334,
"ARG_OF_PERICENTER": 156.7462,
"MEAN_ANOMALY": 185.1135,
"NORAD_CAT_ID": 799501948,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025573,
"MEAN_MOTION_DOT": -0.00026098,
"RMS": "0.139",
"OBJECT_NAME": "IPOS-TDSM",
"OBJECT_ID": "2026-156J",
"EPOCH": "2026-07-07T08:05:50.412970",
"MEAN_MOTION": 14.90938278,
"ECCENTRICITY": 4.75e-5,
"INCLINATION": 97.7565,
"ARG_OF_PERICENTER": 49.2988,
"MEAN_ANOMALY": 293.894,
"NORAD_CAT_ID": 799501924,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029151,
"MEAN_MOTION_DOT": -0.00028697,
"RMS": "0.138",
"OBJECT_NAME": "MARMOTSAT",
"OBJECT_ID": "2026-156K",
"EPOCH": "2026-07-07T08:06:02.013034",
"MEAN_MOTION": 14.90890677,
"ECCENTRICITY": 0.000113,
"INCLINATION": 97.7535,
"RA_OF_ASC_NODE": 88.3345,
"ARG_OF_PERICENTER": 51.7582,
"MEAN_ANOMALY": 292.1617,
"NORAD_CAT_ID": 799501923,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029148,
"MEAN_MOTION_DOT": -0.0002866,
"RMS": "0.138",
"OBJECT_NAME": "GRITSS",
"OBJECT_ID": "2026-156L",
"EPOCH": "2026-07-07T08:06:03.813005",
"MEAN_MOTION": 14.92446208,
"ECCENTRICITY": 0.0006762,
"INCLINATION": 97.7493,
"RA_OF_ASC_NODE": 88.3357,
"ARG_OF_PERICENTER": 148.6625,
"MEAN_ANOMALY": 195.378,
"NORAD_CAT_ID": 799501950,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027036,
"MEAN_MOTION_DOT": -0.0002765,
"RMS": "0.139",
"OBJECT_NAME": "CUBY-4",
"OBJECT_ID": "2026-156M",
"EPOCH": "2026-07-07T08:06:13.313030",
"MEAN_MOTION": 14.90914177,
"ECCENTRICITY": 0.0001786,
"INCLINATION": 97.7497,
"ARG_OF_PERICENTER": 63.5996,
"MEAN_ANOMALY": 281.03,
"NORAD_CAT_ID": 799501921,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029328,
"MEAN_MOTION_DOT": -0.00028854,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-5",
"OBJECT_ID": "2026-156N",
"EPOCH": "2026-07-07T08:06:24.212995",
"MEAN_MOTION": 14.9097297,
"ECCENTRICITY": 0.0002156,
"INCLINATION": 97.7477,
"RA_OF_ASC_NODE": 88.3363,
"ARG_OF_PERICENTER": 72.8399,
"MEAN_ANOMALY": 272.471,
"NORAD_CAT_ID": 799501920,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029272,
"MEAN_MOTION_DOT": -0.00028842,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-DELOITTE-6",
"OBJECT_ID": "2026-156P",
"EPOCH": "2026-07-07T08:06:25.512970",
"MEAN_MOTION": 14.91113155,
"ECCENTRICITY": 0.0001089,
"INCLINATION": 97.7545,
"ARG_OF_PERICENTER": 104.9094,
"MEAN_ANOMALY": 240.4681,
"NORAD_CAT_ID": 799501939,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027061,
"MEAN_MOTION_DOT": -0.00026757,
"RMS": "0.138",
"OBJECT_NAME": "ET-001A & ET-001B & ET-001C & ET-001D",
"OBJECT_ID": "2026-156Q",
"EPOCH": "2026-07-07T08:06:26.512963",
"MEAN_MOTION": 14.92399957,
"ECCENTRICITY": 0.0006672,
"INCLINATION": 97.7471,
"RA_OF_ASC_NODE": 88.3365,
"ARG_OF_PERICENTER": 145.7726,
"MEAN_ANOMALY": 199.6821,
"NORAD_CAT_ID": 799501933,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027791,
"MEAN_MOTION_DOT": -0.0002839,
"RMS": "0.139",
"OBJECT_NAME": "LEMUR-2-DELOITTE-5",
"OBJECT_ID": "2026-156R",
"EPOCH": "2026-07-07T08:06:37.012982",
"MEAN_MOTION": 14.91000096,
"ECCENTRICITY": 0.0001347,
"INCLINATION": 97.7525,
"RA_OF_ASC_NODE": 88.3352,
"ARG_OF_PERICENTER": 76.3976,
"MEAN_ANOMALY": 269.6984,
"NORAD_CAT_ID": 799501941,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027499,
"MEAN_MOTION_DOT": -0.00027113,
"RMS": "0.138",
"OBJECT_NAME": "TOM-3",
"OBJECT_ID": "2026-156S",
"EPOCH": "2026-07-07T08:06:44.213040",
"MEAN_MOTION": 14.91020171,
"ECCENTRICITY": 0.000269,
"INCLINATION": 97.745,
"RA_OF_ASC_NODE": 88.3371,
"ARG_OF_PERICENTER": 78.3124,
"MEAN_ANOMALY": 268.2462,
"NORAD_CAT_ID": 799501918,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028338,
"MEAN_MOTION_DOT": -0.00027956,
"RMS": "0.138",
"OBJECT_NAME": "N2-P-BODY",
"OBJECT_ID": "2026-156T",
"EPOCH": "2026-07-07T08:06:53.613014",
"MEAN_MOTION": 14.9246987,
"ECCENTRICITY": 0.000669,
"RA_OF_ASC_NODE": 88.3355,
"ARG_OF_PERICENTER": 155.0449,
"MEAN_ANOMALY": 192.0822,
"NORAD_CAT_ID": 799501932,
"REV_AT_EPOCH": 1,
"BSTAR": -0.002748,
"MEAN_MOTION_DOT": -0.00028122,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-3",
"OBJECT_ID": "2026-156U",
"EPOCH": "2026-07-07T08:07:03.213005",
"MEAN_MOTION": 14.90951928,
"ECCENTRICITY": 0.0002199,
"INCLINATION": 97.7485,
"ARG_OF_PERICENTER": 71.2438,
"MEAN_ANOMALY": 276.4883,
"NORAD_CAT_ID": 799501943,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029607,
"MEAN_MOTION_DOT": -0.00029157,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-2",
"OBJECT_ID": "2026-156V",
"EPOCH": "2026-07-07T08:07:13.913040",
"MEAN_MOTION": 14.91072886,
"ECCENTRICITY": 0.0002627,
"INCLINATION": 97.7464,
"RA_OF_ASC_NODE": 88.3369,
"ARG_OF_PERICENTER": 84.2848,
"MEAN_ANOMALY": 264.1165,
"NORAD_CAT_ID": 799501944,
"REV_AT_EPOCH": 1,
"BSTAR": -0.002946,
"MEAN_MOTION_DOT": -0.000291,
"RMS": "0.138",
"OBJECT_NAME": "CENTAURI-9",
"OBJECT_ID": "2026-156W",
"EPOCH": "2026-07-07T08:07:17.113037",
"MEAN_MOTION": 14.92275912,
"ECCENTRICITY": 0.0006004,
"INCLINATION": 97.7492,
"ARG_OF_PERICENTER": 148.5212,
"MEAN_ANOMALY": 200.0723,
"NORAD_CAT_ID": 799501925,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028063,
"MEAN_MOTION_DOT": -0.00028576,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-1",
"OBJECT_ID": "2026-156X",
"EPOCH": "2026-07-07T08:07:44.512982",
"MEAN_MOTION": 14.91041023,
"ECCENTRICITY": 0.0002626,
"INCLINATION": 97.7467,
"RA_OF_ASC_NODE": 88.337,
"ARG_OF_PERICENTER": 81.794,
"MEAN_ANOMALY": 268.5068,
"NORAD_CAT_ID": 799501937,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029752,
"MEAN_MOTION_DOT": -0.00029365,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-NURAY",
"OBJECT_ID": "2026-156Y",
"EPOCH": "2026-07-07T08:08:00.512966",
"MEAN_MOTION": 14.92442177,
"ECCENTRICITY": 0.000706,
"INCLINATION": 97.7444,
"RA_OF_ASC_NODE": 88.3375,
"ARG_OF_PERICENTER": 144.4848,
"MEAN_ANOMALY": 206.8158,
"NORAD_CAT_ID": 799501958,
"REV_AT_EPOCH": 1,
"BSTAR": -0.002717,
"MEAN_MOTION_DOT": -0.00027786,
"RMS": "0.138",
"OBJECT_NAME": "SCION-X",
"OBJECT_ID": "2026-156Z",
"EPOCH": "2026-07-07T08:08:06.713030",
"MEAN_MOTION": 14.91080738,
"ECCENTRICITY": 0.0003427,
"INCLINATION": 97.7428,
"RA_OF_ASC_NODE": 88.3377,
"ARG_OF_PERICENTER": 85.2165,
"MEAN_ANOMALY": 266.4716,
"NORAD_CAT_ID": 799501935,
"REV_AT_EPOCH": 1,
"BSTAR": -0.00298,
"MEAN_MOTION_DOT": -0.00029444,
"RMS": "0.138",
"OBJECT_NAME": "BOHR & CLOUDCT-PRECURSOR",
"OBJECT_ID": "2026-156AA",
"EPOCH": "2026-07-07T08:08:28.313030",
"MEAN_MOTION": 14.92600845,
"ECCENTRICITY": 0.000709,
"INCLINATION": 97.7549,
"RA_OF_ASC_NODE": 88.3362,
"ARG_OF_PERICENTER": 161.6835,
"MEAN_ANOMALY": 191.3221,
"NORAD_CAT_ID": 799501917,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027741,
"MEAN_MOTION_DOT": -0.00028483,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-DELOITTE-4",
"OBJECT_ID": "2026-156AB",
"EPOCH": "2026-07-07T08:08:42.412992",
"MEAN_MOTION": 14.92542287,
"ECCENTRICITY": 0.0006951,
"INCLINATION": 97.7518,
"RA_OF_ASC_NODE": 88.3368,
"ARG_OF_PERICENTER": 157.0719,
"MEAN_ANOMALY": 196.8161,
"NORAD_CAT_ID": 799501940,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0026801,
"MEAN_MOTION_DOT": -0.00027477,
"RMS": "0.138",
"OBJECT_NAME": "KOSTKA & OASIS ALPHA",
"OBJECT_ID": "2026-156AC",
"EPOCH": "2026-07-07T08:08:52.613030",
"MEAN_MOTION": 14.92533875,
"ECCENTRICITY": 0.0007318,
"INCLINATION": 97.7451,
"RA_OF_ASC_NODE": 88.3376,
"ARG_OF_PERICENTER": 148.7649,
"MEAN_ANOMALY": 205.7698,
"NORAD_CAT_ID": 799501936,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028254,
"MEAN_MOTION_DOT": -0.00028962,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-SOPHILUNA-X1",
"OBJECT_ID": "2026-156AD",
"EPOCH": "2026-07-07T08:08:54.413002",
"MEAN_MOTION": 14.92449201,
"ECCENTRICITY": 0.0006435,
"INCLINATION": 97.7537,
"ARG_OF_PERICENTER": 159.4173,
"MEAN_ANOMALY": 195.212,
"NORAD_CAT_ID": 799501942,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0026976,
"MEAN_MOTION_DOT": -0.0002759,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-JESS-R",
"OBJECT_ID": "2026-156AE",
"EPOCH": "2026-07-07T08:09:14.913043",
"MEAN_MOTION": 14.92325853,
"ECCENTRICITY": 0.0005784,
"INCLINATION": 97.7555,
"ARG_OF_PERICENTER": 161.4127,
"MEAN_ANOMALY": 194.4864,
"NORAD_CAT_ID": 799501945,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027239,
"MEAN_MOTION_DOT": -0.00027771,
"RMS": "0.137",
"OBJECT_NAME": "BALKAN-3",
"OBJECT_ID": "2026-156AF",
"EPOCH": "2026-07-07T08:09:36.412992",
"MEAN_MOTION": 14.9106442,
"ECCENTRICITY": 0.000161,
"INCLINATION": 97.7554,
"RA_OF_ASC_NODE": 88.3373,
"ARG_OF_PERICENTER": 84.3638,
"MEAN_ANOMALY": 272.8717,
"NORAD_CAT_ID": 799501922,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029049,
"MEAN_MOTION_DOT": -0.00028687,
"RMS": "0.137",
"OBJECT_NAME": "TOM-2",
"OBJECT_ID": "2026-156AG",
"EPOCH": "2026-07-07T08:09:52.013030",
"MEAN_MOTION": 14.90626373,
"ECCENTRICITY": 0.0002761,
"INCLINATION": 97.7546,
"ARG_OF_PERICENTER": 39.3805,
"MEAN_ANOMALY": 318.8259,
"NORAD_CAT_ID": 799501916,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030506,
"MEAN_MOTION_DOT": -0.000298,
"RMS": "0.137",
"OBJECT_NAME": "TOM-1",
"OBJECT_ID": "2026-156AH",
"EPOCH": "2026-07-07T08:10:09.812986",
"MEAN_MOTION": 14.90574335,
"ECCENTRICITY": 0.0003692,
"RA_OF_ASC_NODE": 88.3379,
"ARG_OF_PERICENTER": 49.637,
"MEAN_ANOMALY": 309.6861,
"NORAD_CAT_ID": 799501919,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030633,
"MEAN_MOTION_DOT": -0.00029887,
"RMS": "0.137",
"OBJECT_NAME": "LEMUR-2-ALEX-FULTON",
"OBJECT_ID": "2026-156AJ",
"EPOCH": "2026-07-07T08:10:20.912966",
"MEAN_MOTION": 14.9110281,
"ECCENTRICITY": 0.0001887,
"RA_OF_ASC_NODE": 88.338,
"ARG_OF_PERICENTER": 89.258,
"MEAN_ANOMALY": 270.7433,
"NORAD_CAT_ID": 799501947,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029098,
"MEAN_MOTION_DOT": -0.00028763,
"RMS": "0.137",
"OBJECT_NAME": "MAVERIC",
"OBJECT_ID": "2026-156AK",
"EPOCH": "2026-07-07T08:10:24.413030",
"MEAN_MOTION": 14.9227692,
"ECCENTRICITY": 0.0005583,
"RA_OF_ASC_NODE": 88.3381,
"ARG_OF_PERICENTER": 159.1871,
"MEAN_ANOMALY": 201.0329,
"NORAD_CAT_ID": 799501952,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029547,
"MEAN_MOTION_DOT": -0.00030086,
"RMS": "0.137",
"OBJECT_NAME": "MARINA",
"OBJECT_ID": "2026-156AL",
"EPOCH": "2026-07-07T08:10:26.512982",
"MEAN_MOTION": 14.92201586,
"ECCENTRICITY": 0.0005629,
"ARG_OF_PERICENTER": 150.25,
"MEAN_ANOMALY": 210.1097,
"NORAD_CAT_ID": 799501930,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028026,
"MEAN_MOTION_DOT": -0.00028484,
"RMS": "0.137",
"OBJECT_NAME": "HYPERION GR 1",
"OBJECT_ID": "2026-156AM",
"EPOCH": "2026-07-07T08:10:32.912976",
"MEAN_MOTION": 14.91422264,
"ECCENTRICITY": 0.0002763,
"RA_OF_ASC_NODE": 88.3382,
"ARG_OF_PERICENTER": 120.4824,
"MEAN_ANOMALY": 240.2698,
"NORAD_CAT_ID": 799501963,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030036,
"MEAN_MOTION_DOT": -0.00029929,
"RMS": "0.137",
"OBJECT_NAME": "RAFS CUBESAT",
"OBJECT_ID": "2026-156AN",
"EPOCH": "2026-07-07T08:10:44.613005",
"MEAN_MOTION": 14.92184492,
"ECCENTRICITY": 0.0005664,
"INCLINATION": 97.7479,
"ARG_OF_PERICENTER": 148.3231,
"MEAN_ANOMALY": 213.1635,
"NORAD_CAT_ID": 799501926,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029909,
"MEAN_MOTION_DOT": -0.00030384,
"RMS": "0.137",
"OBJECT_NAME": "REPLICATOR-2",
"OBJECT_ID": "2026-156AP",
"EPOCH": "2026-07-07T08:11:12.113002",
"MEAN_MOTION": 14.92266081,
"ECCENTRICITY": 0.0005666,
"INCLINATION": 97.7512,
"RA_OF_ASC_NODE": 88.3386,
"ARG_OF_PERICENTER": 155.7143,
"MEAN_ANOMALY": 207.4739,
"NORAD_CAT_ID": 799501927,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029622,
"MEAN_MOTION_DOT": -0.00030154,
"RMS": "0.137",
"OBJECT_NAME": "SPEAR-1A & SPEAR-1B & SPEAR-1C",
"OBJECT_ID": "2026-156AQ",
"EPOCH": "2026-07-07T08:11:24.813024",
"MEAN_MOTION": 14.91327793,
"ECCENTRICITY": 0.0002419,
"RA_OF_ASC_NODE": 88.3389,
"ARG_OF_PERICENTER": 113.2629,
"MEAN_ANOMALY": 250.71,
"NORAD_CAT_ID": 799501949,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028432,
"MEAN_MOTION_DOT": -0.00028265,
"RMS": "0.136",
"OBJECT_NAME": "R5 SPACECRAFT 9 (R5-S9)",
"OBJECT_ID": "2026-156AR",
"EPOCH": "2026-07-07T08:11:59.312976",
"MEAN_MOTION": 14.91285612,
"ECCENTRICITY": 0.000298,
"INCLINATION": 97.7501,
"RA_OF_ASC_NODE": 88.3391,
"ARG_OF_PERICENTER": 105.8597,
"MEAN_ANOMALY": 260.2626,
"NORAD_CAT_ID": 799501953,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031441,
"MEAN_MOTION_DOT": -0.00031222,
"RMS": "0.136",
"OBJECT_NAME": "FOSSASAT-2E",
"OBJECT_ID": "2026-156AS",
"EPOCH": "2026-07-07T08:12:11.413037",
"MEAN_MOTION": 14.91376672,
"ECCENTRICITY": 0.0003295,
"INCLINATION": 97.7489,
"ARG_OF_PERICENTER": 112.2586,
"MEAN_ANOMALY": 254.6176,
"NORAD_CAT_ID": 799501951,
"REV_AT_EPOCH": 1,
"BSTAR": -0.002832,
"MEAN_MOTION_DOT": -0.00028189,
"RMS": "0.136",
"OBJECT_NAME": "BRO-31",
"OBJECT_ID": "2026-156AT",
"EPOCH": "2026-07-07T08:12:13.512989",
"MEAN_MOTION": 14.92112681,
"ECCENTRICITY": 0.0005112,
"INCLINATION": 97.7503,
"RA_OF_ASC_NODE": 88.3392,
"ARG_OF_PERICENTER": 151.3751,
"MEAN_ANOMALY": 215.6293,
"NORAD_CAT_ID": 799501965,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029747,
"MEAN_MOTION_DOT": -0.00030164,
"RMS": "0.136",
"OBJECT_NAME": "POSIDONIA",
"OBJECT_ID": "2026-156AU",
"EPOCH": "2026-07-07T08:12:18.212976",
"MEAN_MOTION": 14.92098049,
"ECCENTRICITY": 0.0005189,
"INCLINATION": 97.749,
"ARG_OF_PERICENTER": 149.034,
"MEAN_ANOMALY": 218.2648,
"NORAD_CAT_ID": 799501964,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030358,
"MEAN_MOTION_DOT": -0.00030772,
"RMS": "0.136",
"OBJECT_NAME": "ION SCV-023",
"OBJECT_ID": "2026-156AV",
"EPOCH": "2026-07-07T08:12:27.213005",
"MEAN_MOTION": 14.92057654,
"ECCENTRICITY": 0.0004709,
"INCLINATION": 97.7522,
"RA_OF_ASC_NODE": 88.3396,
"ARG_OF_PERICENTER": 153.0359,
"MEAN_ANOMALY": 214.8158,
"NORAD_CAT_ID": 799501912,
"REV_AT_EPOCH": 1,
"BSTAR": -0.003013,
"MEAN_MOTION_DOT": -0.00030509,
"RMS": "0.136",
"OBJECT_NAME": "ICEYE-X80",
"OBJECT_ID": "2026-156AW",
"EPOCH": "2026-07-07T08:12:52.213018",
"MEAN_MOTION": 14.9148775,
"ECCENTRICITY": 0.0003113,
"INCLINATION": 97.7515,
"RA_OF_ASC_NODE": 88.3399,
"ARG_OF_PERICENTER": 122.8776,
"MEAN_ANOMALY": 246.5281,
"NORAD_CAT_ID": 799501968,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027857,
"MEAN_MOTION_DOT": -0.00027804,
"RMS": "0.136",
"OBJECT_NAME": "ICEYE-X77",
"OBJECT_ID": "2026-156AX",
"EPOCH": "2026-07-07T08:12:57.512966",
"MEAN_MOTION": 14.92028842,
"ECCENTRICITY": 0.0004782,
"INCLINATION": 97.7502,
"RA_OF_ASC_NODE": 88.3397,
"ARG_OF_PERICENTER": 149.2727,
"MEAN_ANOMALY": 220.4649,
"NORAD_CAT_ID": 799501967,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030642,
"MEAN_MOTION_DOT": -0.00031005,
"RMS": "0.136",
"OBJECT_NAME": "KITA-36",
"OBJECT_ID": "2026-156AY",
"EPOCH": "2026-07-07T08:13:06.612960",
"MEAN_MOTION": 14.91496894,
"ECCENTRICITY": 0.0003215,
"INCLINATION": 97.7511,
"RA_OF_ASC_NODE": 88.34,
"ARG_OF_PERICENTER": 122.8443,
"MEAN_ANOMALY": 247.4567,
"NORAD_CAT_ID": 799501914,
"REV_AT_EPOCH": 1,
"MEAN_MOTION_DOT": -0.00029859,
"RMS": "0.136",
"OBJECT_NAME": "FIRESAT3",
"OBJECT_ID": "2026-156AZ",
"EPOCH": "2026-07-07T08:13:08.812963",
"MEAN_MOTION": 14.9201168,
"ECCENTRICITY": 0.0004567,
"RA_OF_ASC_NODE": 88.3401,
"ARG_OF_PERICENTER": 150.9566,
"MEAN_ANOMALY": 219.4803,
"NORAD_CAT_ID": 799501909,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029693,
"MEAN_MOTION_DOT": -0.00030031,
"RMS": "0.136",
"OBJECT_NAME": "ICEYE-X81",
"OBJECT_ID": "2026-156BA",
"EPOCH": "2026-07-07T08:13:28.712957",
"MEAN_MOTION": 14.91534042,
"ECCENTRICITY": 0.0003122,
"RA_OF_ASC_NODE": 88.3405,
"ARG_OF_PERICENTER": 126.7831,
"MEAN_ANOMALY": 244.8884,
"NORAD_CAT_ID": 799501956,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028124,
"MEAN_MOTION_DOT": -0.00028104,
"RMS": "0.136",
"OBJECT_NAME": "GRUS-3D",
"OBJECT_ID": "2026-156BB",
"EPOCH": "2026-07-07T08:13:29.813002",
"MEAN_MOTION": 14.91984305,
"ECCENTRICITY": 0.0004726,
"ARG_OF_PERICENTER": 146.5603,
"MEAN_ANOMALY": 225.1855,
"NORAD_CAT_ID": 799501903,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031334,
"MEAN_MOTION_DOT": -0.00031669,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3A",
"OBJECT_ID": "2026-156BC",
"EPOCH": "2026-07-07T08:13:35.613034",
"MEAN_MOTION": 14.91551354,
"ECCENTRICITY": 0.0003641,
"ARG_OF_PERICENTER": 124.3294,
"MEAN_ANOMALY": 247.7767,
"NORAD_CAT_ID": 799501907,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031838,
"MEAN_MOTION_DOT": -0.00031828,
"RMS": "0.135",
"OBJECT_NAME": "FIRESAT1",
"OBJECT_ID": "2026-156BD",
"EPOCH": "2026-07-07T08:13:40.412986",
"MEAN_MOTION": 14.91971803,
"ECCENTRICITY": 0.0004309,
"RA_OF_ASC_NODE": 88.3406,
"ARG_OF_PERICENTER": 151.1423,
"MEAN_ANOMALY": 221.2558,
"NORAD_CAT_ID": 799501961,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030008,
"MEAN_MOTION_DOT": -0.00030319,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3E",
"OBJECT_ID": "2026-156BE",
"EPOCH": "2026-07-07T08:13:42.713040",
"MEAN_MOTION": 14.91575701,
"ECCENTRICITY": 0.0003216,
"ARG_OF_PERICENTER": 129.5776,
"MEAN_ANOMALY": 242.9636,
"NORAD_CAT_ID": 799501904,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031854,
"MEAN_MOTION_DOT": -0.00031863,
"RMS": "0.135",
"OBJECT_NAME": "YAM-17",
"OBJECT_ID": "2026-156BF",
"EPOCH": "2026-07-07T08:13:43.812998",
"MEAN_MOTION": 14.91942832,
"ECCENTRICITY": 0.000459,
"ARG_OF_PERICENTER": 145.063,
"MEAN_ANOMALY": 227.5524,
"NORAD_CAT_ID": 799501910,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030838,
"MEAN_MOTION_DOT": -0.00031135,
"RMS": "0.135",
"OBJECT_NAME": "MISR-D-1",
"OBJECT_ID": "2026-156BG",
"EPOCH": "2026-07-07T08:14:07.013040",
"MEAN_MOTION": 14.9159133,
"ECCENTRICITY": 0.0003743,
"RA_OF_ASC_NODE": 88.3402,
"ARG_OF_PERICENTER": 126.799,
"MEAN_ANOMALY": 247.2576,
"NORAD_CAT_ID": 799501962,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031804,
"MEAN_MOTION_DOT": -0.00031827,
"RMS": "0.135",
"OBJECT_NAME": "NAVIGATOR",
"OBJECT_ID": "2026-156BH",
"EPOCH": "2026-07-07T08:14:08.813011",
"MEAN_MOTION": 14.91917062,
"ECCENTRICITY": 0.0004154,
"INCLINATION": 97.7519,
"RA_OF_ASC_NODE": 88.3409,
"ARG_OF_PERICENTER": 148.3667,
"MEAN_ANOMALY": 225.7964,
"NORAD_CAT_ID": 799501969,
"REV_AT_EPOCH": 1,
"BSTAR": -0.003074,
"MEAN_MOTION_DOT": -0.00031015,
"RMS": "0.135",
"OBJECT_NAME": "ANDURIL-216",
"OBJECT_ID": "2026-156BJ",
"EPOCH": "2026-07-07T08:14:25.312992",
"MEAN_MOTION": 14.91617977,
"ECCENTRICITY": 0.0003335,
"INCLINATION": 97.7521,
"RA_OF_ASC_NODE": 88.3412,
"ARG_OF_PERICENTER": 131.9564,
"MEAN_ANOMALY": 243.2312,
"NORAD_CAT_ID": 799501915,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030775,
"MEAN_MOTION_DOT": -0.00030817,
"RMS": "0.135",
"OBJECT_NAME": "NOVA 1",
"OBJECT_ID": "2026-156BK",
"EPOCH": "2026-07-07T08:14:26.913034",
"MEAN_MOTION": 14.91896653,
"ECCENTRICITY": 0.0004141,
"RA_OF_ASC_NODE": 88.341,
"ARG_OF_PERICENTER": 146.735,
"MEAN_ANOMALY": 228.5533,
"NORAD_CAT_ID": 799501954,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030833,
"MEAN_MOTION_DOT": -0.00031092,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3C",
"OBJECT_ID": "2026-156BL",
"EPOCH": "2026-07-07T08:14:29.312966",
"MEAN_MOTION": 14.9163878,
"ECCENTRICITY": 0.0003973,
"INCLINATION": 97.7484,
"ARG_OF_PERICENTER": 128.8694,
"MEAN_ANOMALY": 246.574,
"NORAD_CAT_ID": 799501905,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032235,
"MEAN_MOTION_DOT": -0.00032297,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3B",
"OBJECT_ID": "2026-156BM",
"EPOCH": "2026-07-07T08:14:51.812995",
"MEAN_MOTION": 14.91873367,
"ECCENTRICITY": 0.000389,
"INCLINATION": 97.7527,
"RA_OF_ASC_NODE": 88.3417,
"ARG_OF_PERICENTER": 147.7305,
"MEAN_ANOMALY": 229.1021,
"NORAD_CAT_ID": 799501902,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032178,
"MEAN_MOTION_DOT": -0.00032429,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3F",
"OBJECT_ID": "2026-156BN",
"EPOCH": "2026-07-07T08:15:58.013021",
"MEAN_MOTION": 14.91660773,
"ECCENTRICITY": 0.0003378,
"INCLINATION": 97.7524,
"RA_OF_ASC_NODE": 88.3425,
"ARG_OF_PERICENTER": 134.51,
"MEAN_ANOMALY": 246.4349,
"NORAD_CAT_ID": 799501906,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0033045,
"MEAN_MOTION_DOT": -0.00033125,
"RMS": "0.134",
"OBJECT_NAME": "GRUS-3G",
"OBJECT_ID": "2026-156BP",
"EPOCH": "2026-07-07T08:16:13.312992",
"MEAN_MOTION": 14.91846008,
"ECCENTRICITY": 0.0004455,
"INCLINATION": 97.7482,
"RA_OF_ASC_NODE": 88.3411,
"ARG_OF_PERICENTER": 140.301,
"MEAN_ANOMALY": 241.6031,
"NORAD_CAT_ID": 799501908,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032997,
"MEAN_MOTION_DOT": -0.00033233,
"RMS": "0.134",
"OBJECT_NAME": "MIKROGLOB-1",
"OBJECT_ID": "2026-156BQ",
"EPOCH": "2026-07-07T08:16:24.912970",
"MEAN_MOTION": 14.91682015,
"ECCENTRICITY": 0.0004058,
"RA_OF_ASC_NODE": 88.3414,
"ARG_OF_PERICENTER": 131.9314,
"MEAN_ANOMALY": 250.692,
"NORAD_CAT_ID": 799501911,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032383,
"MEAN_MOTION_DOT": -0.0003248,
"RMS": "0.134",
"OBJECT_NAME": "MISR-D-2",
"OBJECT_ID": "2026-156BR",
"EPOCH": "2026-07-07T08:17:15.912989",
"MEAN_MOTION": 14.91818436,
"ECCENTRICITY": 0.0004334,
"INCLINATION": 97.7487,
"RA_OF_ASC_NODE": 88.3418,
"ARG_OF_PERICENTER": 139.6282,
"MEAN_ANOMALY": 246.1637,
"NORAD_CAT_ID": 799501966,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0033366,
"MEAN_MOTION_DOT": -0.00033581,
"RMS": "0.133",
"OBJECT_NAME": "FIRESAT2",
"OBJECT_ID": "2026-156BS",
"EPOCH": "2026-07-07T08:17:44.212963",
"MEAN_MOTION": 14.91710647,
"ECCENTRICITY": 0.0003452,
"RA_OF_ASC_NODE": 88.3441,
"ARG_OF_PERICENTER": 137.1506,
"MEAN_ANOMALY": 250.3908,
"NORAD_CAT_ID": 799501960,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032605,
"MEAN_MOTION_DOT": -0.00032725,
"RMS": "0.133",
"OBJECT_NAME": "KITA-53",
"OBJECT_ID": "2026-156BT",
"EPOCH": "2026-07-07T08:17:50.312976",
"MEAN_MOTION": 14.9173786,
"ECCENTRICITY": 0.0004287,
"RA_OF_ASC_NODE": 88.3419,
"ARG_OF_PERICENTER": 134.9515,
"MEAN_ANOMALY": 252.9781,
"NORAD_CAT_ID": 799501913,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032357,
"MEAN_MOTION_DOT": -0.000325,
"RMS": "0.133",
"OBJECT_NAME": "PELICAN-11 3012",
"OBJECT_ID": "2026-156BU",
"EPOCH": "2026-07-07T08:19:31.313021",
"MEAN_MOTION": 14.91804198,
"ECCENTRICITY": 0.0003655,
"RA_OF_ASC_NODE": 88.3452,
"ARG_OF_PERICENTER": 142.3397,
"MEAN_ANOMALY": 251.8553,
"NORAD_CAT_ID": 799501959,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0035048,
"MEAN_MOTION_DOT": -0.00035259,
"RMS": "0.132",
"OBJECT_NAME": "ICEYE-X79",
"OBJECT_ID": "2026-156BV",
"EPOCH": "2026-07-07T08:22:35.213002",
"MEAN_MOTION": 14.91757176,
"ECCENTRICITY": 0.0004382,
"RA_OF_ASC_NODE": 88.3442,
"ARG_OF_PERICENTER": 137.5869,
"MEAN_ANOMALY": 268.0401,
"NORAD_CAT_ID": 799501957,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0033443,
"MEAN_MOTION_DOT": -0.00033607,
"RMS": "0.130",
"OBJECT_NAME": "CAS500-4",
"OBJECT_ID": "2026-156BW",
"EPOCH": "2026-07-07T09:40:22.913040",
"MEAN_MOTION": 14.00951053,
"ECCENTRICITY": 0.00086,
"INCLINATION": 98.9901,
"RA_OF_ASC_NODE": 88.1472,
"ARG_OF_PERICENTER": 269.6151,
"MEAN_ANOMALY": 61.508,
"NORAD_CAT_ID": 799501901,
"REV_AT_EPOCH": 1,
"BSTAR": -0.041486,
"MEAN_MOTION_DOT": -0.00061954,
"RMS": "0.096",
Here are the same orbital data converted to TLE:
OSIRIS-A
1 71928C 26156A 26188.33659853 -.00013736 00000-0 -28101-2 0 9990
2 71928 97.7556 88.3326 0001361 348.3326 350.6181 14.90659552 19
LEMUR-2-ELEONORE
1 71955C 26156B 26188.33663094 -.00013205 00000-0 -25626-2 0 9992
2 71955 97.7532 88.3336 0008006 153.2897 185.8419 14.92743488 19
SUCHAI-4
1 71929C 26156C 26188.33674436 -.00013407 00000-0 -27405-2 0 9996
2 71929 97.7520 88.3341 0001550 18.9519 320.7898 14.90694328 15
KOYO
1 71931C 26156D 26188.33692376 -.00013663 00000-0 -27955-2 0 9996
2 71931 97.7491 88.3353 0002099 28.8632 311.8475 14.90654813 10
CYBERCUBE
1 71938C 26156E 26188.33695038 -.00012875 00000-0 -24976-2 0 9995
2 71938 97.7461 88.3364 0008283 145.4114 195.4497 14.92755752 14
1 71946C 26156F 26188.33696196 -.00012981 00000-0 -25339-2 0 9992
2 71946 97.7528 88.3341 0006966 153.1593 187.7490 14.92514201 14
LEONAV-1
1 71934C 26156G 26188.33712862 -.00013162 00000-0 -25507-2 0 9997
2 71934 97.7488 88.3356 0008328 149.7955 192.0159 14.92796350 17
LEMUR-2-ALYX
1 71948C 26156H 26188.33714020 -.00013049 00000-0 -25573-2 0 9997
2 71948 97.7553 88.3334 0006236 156.7462 185.1135 14.92362871 12
IPOS-TDSM
1 71924C 26156J 26188.33738904 -.00014348 00000-0 -29151-2 0 9997
2 71924 97.7565 88.3334 0000475 49.2988 293.8940 14.90938278 16
MARMOTSAT
1 71923C 26156K 26188.33752330 -.00014330 00000-0 -29148-2 0 9992
2 71923 97.7535 88.3345 0001130 51.7582 292.1617 14.90890677 14
GRITSS
1 71950C 26156L 26188.33754413 -.00013825 00000-0 -27036-2 0 9998
2 71950 97.7493 88.3357 0006762 148.6625 195.3780 14.92446208 14
CUBY-4
1 71921C 26156M 26188.33765409 -.00014427 00000-0 -29328-2 0 9998
2 71921 97.7497 88.3357 0001786 63.5996 281.0300 14.90914177 17
CUBY-5
1 71920C 26156N 26188.33778024 -.00014421 00000-0 -29272-2 0 9996
2 71920 97.7477 88.3363 0002156 72.8399 272.4710 14.90972970 17
LEMUR-2-DELOITTE-6
1 71939C 26156P 26188.33779529 -.00013379 00000-0 -27061-2 0 9992
2 71939 97.7545 88.3345 0001089 104.9094 240.4681 14.91113155 11
1 71933C 26156Q 26188.33780686 -.00014195 00000-0 -27791-2 0 9999
2 71933 97.7471 88.3365 0006672 145.7726 199.6821 14.92399957 11
LEMUR-2-DELOITTE-5
1 71941C 26156R 26188.33792839 -.00013557 00000-0 -27499-2 0 9997
2 71941 97.7525 88.3352 0001347 76.3976 269.6984 14.91000096 16
TOM-3
1 71918C 26156S 26188.33801173 -.00013978 00000-0 -28338-2 0 9993
2 71918 97.7450 88.3371 0002690 78.3124 268.2462 14.91020171 19
N2-P-BODY
1 71932C 26156T 26188.33812052 -.00014061 00000-0 -27480-2 0 9998
2 71932 97.7520 88.3355 0006690 155.0449 192.0822 14.92469870 10
CUBY-3
1 71943C 26156U 26188.33823163 -.00014579 00000-0 -29607-2 0 9992
2 71943 97.7485 88.3363 0002199 71.2438 276.4883 14.90951928 10
CUBY-2
1 71944C 26156V 26188.33835547 -.00014550 00000-0 -29460-2 0 9998
2 71944 97.7464 88.3369 0002627 84.2848 264.1165 14.91072886 14
CENTAURI-9
1 71925C 26156W 26188.33839251 -.00014288 00000-0 -28063-2 0 9999
2 71925 97.7492 88.3363 0006004 148.5212 200.0723 14.92275912 15
CUBY-1
1 71937C 26156X 26188.33870964 -.00014683 00000-0 -29752-2 0 9993
2 71937 97.7467 88.3370 0002626 81.7940 268.5068 14.91041023 14
LEMUR-2-NURAY
1 71958C 26156Y 26188.33889483 -.00013893 00000-0 -27170-2 0 9996
2 71958 97.7444 88.3375 0007060 144.4848 206.8158 14.92442177 19
SCION-X
1 71935C 26156Z 26188.33896659 -.00014722 00000-0 -29800-2 0 9998
2 71935 97.7428 88.3377 0003427 85.2165 266.4716 14.91080738 17
1 71917C 26156AA 26188.33921659 -.00014242 00000-0 -27741-2 0 9996
2 71917 97.7549 88.3362 0007090 161.6835 191.3221 14.92600845 13
LEMUR-2-DELOITTE-4
1 71940C 26156AB 26188.33937978 -.00013738 00000-0 -26801-2 0 9998
2 71940 97.7518 88.3368 0006951 157.0719 196.8161 14.92542287 14
1 71936C 26156AC 26188.33949784 -.00014481 00000-0 -28254-2 0 9991
2 71936 97.7451 88.3376 0007318 148.7649 205.7698 14.92533875 19
1 71942C 26156AD 26188.33951867 -.00013795 00000-0 -26976-2 0 9999
2 71942 97.7537 88.3368 0006435 159.4173 195.2120 14.92449201 14
LEMUR-2-JESS-R
1 71945C 26156AE 26188.33975594 -.00013886 00000-0 -27239-2 0 9999
2 71945 97.7555 88.3369 0005784 161.4127 194.4864 14.92325853 18
BALKAN-3
1 71922C 26156AF 26188.34000478 -.00014343 00000-0 -29049-2 0 9995
2 71922 97.7554 88.3373 0001610 84.3638 272.8717 14.91064420 18
TOM-2
1 71916C 26156AG 26188.34018534 -.00014900 00000-0 -30506-2 0 9999
2 71916 97.7546 88.3376 0002761 39.3805 318.8259 14.90626373 11
TOM-1
1 71919C 26156AH 26188.34039135 -.00014944 00000-0 -30633-2 0 9991
2 71919 97.7491 88.3379 0003692 49.6370 309.6861 14.90574335 18
LEMUR-2-ALEX-FULTON
1 71947C 26156AJ 26188.34051983 -.00014381 00000-0 -29098-2 0 9995
2 71947 97.7546 88.3380 0001887 89.2580 270.7433 14.91102810 18
MAVERIC
1 71952C 26156AK 26188.34056034 -.00015043 00000-0 -29547-2 0 9998
2 71952 97.7537 88.3381 0005583 159.1871 201.0329 14.92276920 18
MARINA
1 71930C 26156AL 26188.34058464 -.00014242 00000-0 -28026-2 0 9994
2 71930 97.7491 88.3381 0005629 150.2500 210.1097 14.92201586 14
HYPERION GR 1
1 71963C 26156AM 26188.34065871 -.00014965 00000-0 -30036-2 0 9996
2 71963 97.7518 88.3382 0002763 120.4824 240.2698 14.91422264 13
RAFS CUBESAT
1 71926C 26156AN 26188.34079413 -.00015192 00000-0 -29909-2 0 9992
2 71926 97.7479 88.3382 0005664 148.3231 213.1635 14.92184492 11
REPLICATOR-2
1 71927C 26156AP 26188.34111242 -.00015077 00000-0 -29622-2 0 9994
2 71927 97.7512 88.3386 0005666 155.7143 207.4739 14.92266081 16
1 71949C 26156AQ 26188.34125941 -.00014133 00000-0 -28432-2 0 9999
2 71949 97.7532 88.3389 0002419 113.2629 250.7100 14.91327793 16
1 71953C 26156AR 26188.34165871 -.00015611 00000-0 -31441-2 0 9996
2 71953 97.7501 88.3391 0002980 105.8597 260.2626 14.91285612 16
FOSSASAT-2E
1 71951C 26156AS 26188.34179876 -.00014095 00000-0 -28320-2 0 9991
2 71951 97.7489 88.3391 0003295 112.2586 254.6176 14.91376672 13
BRO-31
1 71965C 26156AT 26188.34182307 -.00015082 00000-0 -29747-2 0 9990
2 71965 97.7503 88.3392 0005112 151.3751 215.6293 14.92112681 10
POSIDONIA
1 71964C 26156AU 26188.34187747 -.00015386 00000-0 -30358-2 0 9999
2 71964 97.7490 88.3391 0005189 149.0340 218.2648 14.92098049 19
ION SCV-023
1 71912C 26156AV 26188.34198163 -.00015254 00000-0 -30130-2 0 9998
2 71912 97.7522 88.3396 0004709 153.0359 214.8158 14.92057654 10
ICEYE-X80
1 71968C 26156AW 26188.34227098 -.00013902 00000-0 -27857-2 0 9999
2 71968 97.7515 88.3399 0003113 122.8776 246.5281 14.91487750 13
ICEYE-X77
1 71967C 26156AX 26188.34233233 -.00015502 00000-0 -30642-2 0 9990
2 71967 97.7502 88.3397 0004782 149.2727 220.4649 14.92028842 11
KITA-36
1 71914C 26156AY 26188.34243765 -.00014929 00000-0 -29909-2 0 9999
2 71914 97.7511 88.3400 0003215 122.8443 247.4567 14.91496894 13
FIRESAT3
1 71909C 26156AZ 26188.34246311 -.00015015 00000-0 -29693-2 0 9990
2 71909 97.7515 88.3401 0004567 150.9566 219.4803 14.92011680 10
ICEYE-X81
1 71956C 26156BA 26188.34269344 -.00014052 00000-0 -28124-2 0 9991
2 71956 97.7522 88.3405 0003122 126.7831 244.8884 14.91534042 18
GRUS-3D
1 71903C 26156BB 26188.34270617 -.00015835 00000-0 -31334-2 0 9995
2 71903 97.7493 88.3399 0004726 146.5603 225.1855 14.91984305 18
GRUS-3A
1 71907C 26156BC 26188.34277330 -.00015914 00000-0 -31838-2 0 9995
2 71907 97.7493 88.3399 0003641 124.3294 247.7767 14.91551354 13
FIRESAT1
1 71961C 26156BD 26188.34282885 -.00015160 00000-0 -30008-2 0 9997
2 71961 97.7522 88.3406 0004309 151.1423 221.2558 14.91971803 19
GRUS-3E
1 71904C 26156BE 26188.34285547 -.00015931 00000-0 -31854-2 0 9998
2 71904 97.7522 88.3406 0003216 129.5776 242.9636 14.91575701 16
YAM-17
1 71910C 26156BF 26188.34286821 -.00015568 00000-0 -30838-2 0 9998
2 71910 97.7493 88.3400 0004590 145.0630 227.5524 14.91942832 10
MISR-D-1
1 71962C 26156BG 26188.34313672 -.00015914 00000-0 -31804-2 0 9999
2 71962 97.7493 88.3402 0003743 126.7990 247.2576 14.91591330 12
NAVIGATOR
1 71969C 26156BH 26188.34315756 -.00015507 00000-0 -30740-2 0 9997
2 71969 97.7519 88.3409 0004154 148.3667 225.7964 14.91917062 19
ANDURIL-216
1 71915C 26156BJ 26188.34334853 -.00015409 00000-0 -30775-2 0 9996
2 71915 97.7521 88.3412 0003335 131.9564 243.2312 14.91617977 15
NOVA 1
1 71954C 26156BK 26188.34336705 -.00015546 00000-0 -30833-2 0 9994
2 71954 97.7515 88.3410 0004141 146.7350 228.5533 14.91896653 13
GRUS-3C
1 71905C 26156BL 26188.34339483 -.00016149 00000-0 -32235-2 0 9994
2 71905 97.7484 88.3402 0003973 128.8694 246.5740 14.91638780 14
GRUS-3B
1 71902C 26156BM 26188.34365524 -.00016214 00000-0 -32178-2 0 9995
2 71902 97.7527 88.3417 0003890 147.7305 229.1021 14.91873367 13
GRUS-3F
1 71906C 26156BN 26188.34442145 -.00016563 00000-0 -33045-2 0 9995
2 71906 97.7524 88.3425 0003378 134.5100 246.4349 14.91660773 11
GRUS-3G
1 71908C 26156BP 26188.34459853 -.00016616 00000-0 -32997-2 0 9995
2 71908 97.7482 88.3411 0004455 140.3010 241.6031 14.91846008 15
MIKROGLOB-1
1 71911C 26156BQ 26188.34473279 -.00016240 00000-0 -32383-2 0 9999
2 71911 97.7489 88.3414 0004058 131.9314 250.6920 14.91682015 14
MISR-D-2
1 71966C 26156BR 26188.34532307 -.00016791 00000-0 -33366-2 0 9990
2 71966 97.7487 88.3418 0004334 139.6282 246.1637 14.91818436 15
FIRESAT2
1 71960C 26156BS 26188.34565061 -.00016363 00000-0 -32605-2 0 9997
2 71960 97.7525 88.3441 0003452 137.1506 250.3908 14.91710647 13
KITA-53
1 71913C 26156BT 26188.34572121 -.00016250 00000-0 -32357-2 0 9999
2 71913 97.7482 88.3419 0004287 134.9515 252.9781 14.91737860 13
PELICAN-11 3012
1 71959C 26156BU 26188.34689020 -.00017630 00000-0 -35048-2 0 9999
2 71959 97.7519 88.3452 0003655 142.3397 251.8553 14.91804198 14
ICEYE-X79
1 71957C 26156BV 26188.34901867 -.00016803 00000-0 -33443-2 0 9991
2 71957 97.7484 88.3442 0004382 137.5869 268.0401 14.91757176 15
CAS500-4
1 71901C 26156BW 26188.40304298 -.00030977 00000-0 -41486-1 0 9995
2 71901 98.9901 88.1472 0008600 269.6151 61.5080 14.00951053 19
And here are the above TLE using the temporary NORAD IDs from SatNOGS DB:
OSIRIS-A
1 98261C 26156A 26188.33659853 -.00013736 00000-0 -28101-2 0 9999
2 98261 97.7556 88.3326 0001361 348.3326 350.6181 14.90659552 18
SUCHAI-4
1 98265C 26156C 26188.33674436 -.00013407 00000-0 -27405-2 0 9998
2 98265 97.7520 88.3341 0001550 18.9519 320.7898 14.90694328 17
KOYO
1 98273C 26156D 26188.33692376 -.00013663 00000-0 -27955-2 0 9994
2 98273 97.7491 88.3353 0002099 28.8632 311.8475 14.90654813 18
CYBERCUBE
1 98277C 26156E 26188.33695038 -.00012875 00000-0 -24976-2 0 9990
2 98277 97.7461 88.3364 0008283 145.4114 195.4497 14.92755752 19
IPOS-TDSM
1 98287C 26156J 26188.33738904 -.00014348 00000-0 -29151-2 0 9998
2 98287 97.7565 88.3334 0000475 49.2988 293.8940 14.90938278 17
MARMOTSAT
1 98272C 26156K 26188.33752330 -.00014330 00000-0 -29148-2 0 9998
2 98272 97.7535 88.3345 0001130 51.7582 292.1617 14.90890677 10
CUBY-4
1 98281C 26156M 26188.33765409 -.00014427 00000-0 -29328-2 0 9996
2 98281 97.7497 88.3357 0001786 63.5996 281.0300 14.90914177 15
CUBY-5
1 98280C 26156N 26188.33778024 -.00014421 00000-0 -29272-2 0 9994
2 98280 97.7477 88.3363 0002156 72.8399 272.4710 14.90972970 15
TOM-3
1 98262C 26156S 26188.33801173 -.00013978 00000-0 -28338-2 0 9994
2 98262 97.7450 88.3371 0002690 78.3124 268.2462 14.91020171 10
CUBY-3
1 98282C 26156U 26188.33823163 -.00014579 00000-0 -29607-2 0 9997
2 98282 97.7485 88.3363 0002199 71.2438 276.4883 14.90951928 15
CUBY-2
1 98283C 26156V 26188.33835547 -.00014550 00000-0 -29460-2 0 9993
2 98283 97.7464 88.3369 0002627 84.2848 264.1165 14.91072886 19
CENTAURI-9
1 98279C 26156W 26188.33839251 -.00014288 00000-0 -28063-2 0 9990
2 98279 97.7492 88.3363 0006004 148.5212 200.0723 14.92275912 16
CUBY-1
1 98284C 26156X 26188.33870964 -.00014683 00000-0 -29752-2 0 9997
2 98284 97.7467 88.3370 0002626 81.7940 268.5068 14.91041023 18
SCION-X
1 98266C 26156Z 26188.33896659 -.00014722 00000-0 -29800-2 0 9994
2 98266 97.7428 88.3377 0003427 85.2165 266.4716 14.91080738 13
1 98278C 26156AA 26188.33921659 -.00014242 00000-0 -27741-2 0 9995
2 98278 97.7549 88.3362 0007090 161.6835 191.3221 14.92600845 12
KOSTKA
1 98395C 26156AC 26188.33949784 -.00014481 00000-0 -28254-2 0 9999
2 98395 97.7451 88.3376 0007318 148.7649 205.7698 14.92533875 17
OASIS ALPHA
1 98269C 26156AC 26188.33949784 -.00014481 00000-0 -28254-2 0 9999
2 98269 97.7451 88.3376 0007318 148.7649 205.7698 14.92533875 17
TOM-2
1 98263C 26156AG 26188.34018534 -.00014900 00000-0 -30506-2 0 9993
2 98263 97.7546 88.3376 0002761 39.3805 318.8259 14.90626373 15
TOM-1
1 98264C 26156AH 26188.34039135 -.00014944 00000-0 -30633-2 0 9993
2 98264 97.7491 88.3379 0003692 49.6370 309.6861 14.90574335 10
MAVERIC
1 98271C 26156AK 26188.34056034 -.00015043 00000-0 -29547-2 0 9991
2 98271 97.7537 88.3381 0005583 159.1871 201.0329 14.92276920 11
MARINA
1 98293C 26156AL 26188.34058464 -.00014242 00000-0 -28026-2 0 9995
2 98293 97.7491 88.3381 0005629 150.2500 210.1097 14.92201586 15
RAFS CUBESAT
1 98268C 26156AN 26188.34079413 -.00015192 00000-0 -29909-2 0 9990
2 98268 97.7479 88.3382 0005664 148.3231 213.1635 14.92184492 19
REPLICATOR-2
1 98267C 26156AP 26188.34111242 -.00015077 00000-0 -29622-2 0 9990
2 98267 97.7512 88.3386 0005666 155.7143 207.4739 14.92266081 12
FOSSASAT-2E
1 98285C 26156AS 26188.34179876 -.00014095 00000-0 -28320-2 0 9990
2 98285 97.7489 88.3391 0003295 112.2586 254.6176 14.91376672 12
BRO-31
1 98286C 26156AT 26188.34182307 -.00015082 00000-0 -29747-2 0 9995
2 98286 97.7503 88.3392 0005112 151.3751 215.6293 14.92112681 15
ION SCV-023
1 98276C 26156AV 26188.34198163 -.00015254 00000-0 -30130-2 0 9990
2 98276 97.7522 88.3396 0004709 153.0359 214.8158 14.92057654 12
KITA-36
1 98275C 26156AY 26188.34243765 -.00014929 00000-0 -29909-2 0 9998
2 98275 97.7511 88.3400 0003215 122.8443 247.4567 14.91496894 12
NAVIGATOR
1 98270C 26156BH 26188.34315756 -.00015507 00000-0 -30740-2 0 9991
2 98270 97.7519 88.3409 0004154 148.3667 225.7964 14.91917062 13
KITA-53
1 98274C 26156BT 26188.34572121 -.00016250 00000-0 -32357-2 0 9998
2 98274 97.7482 88.3419 0004287 134.9515 252.9781 14.91737860 12
Given that the time of the live-stream start has changed, we may have a slight change in the launch time. Thus I’m going to perform scheduling after launch with, if necessary (launch time difference is more than 2m), new TLE sets.
Got my HF station up and running to receive CW telemetry and DVB-S2. Probably will only get CW if I’m lucky because I’m using a Random Wire antenna. My new HF station is here: SatNOGS Network - Ground Station PISTATION-HF
Launch time is scheduled to be 07:12 UTC according to the live-stream. So, it is exactly 2min difference from the announced one (07:10 UTC). This is on the limit of changing or not the TLE, I’m going for now to keep the same ones and will see if there is any other delay.
In total 2089 observations have been scheduled for the first 48h after deployment of the satellites. We have used the TLE sets of the previous post.
| Temp NORAD ID | Satellite | Scheduled Observations |
| 98395 | KOSTKA | 114 |
| 98287 | IPoS-TDsM | 111 |
| 98293 | Marina | 292 |
| 98272 | MARMOTSat | 321 |
| 98266 | SCION-X | 55 |
| 98274 | Kita-53 | 94 |
| 98275 | Kita-36 | 95 |
| 98264 | TOM-1 | 10 |
| 98268 | RAFS | 116 |
| 98281 | CUBY-4 | 11 |
| 98285 | FOSSASAT-2E26 | 102 |
| 98267 | Replicator-2 | 95 |
| 98279 | Centauri-9 | 94 |
| 98271 | Maveric | 64 |
| 98278 | CloudCT-Precursor | 19 |
| 98286 | BRO-31 | 103 |
| 98265 | SUCHAI-4 | 55 |
| 98269 | Oasis Alpha | 94 |
| 98273 | Koyo | 55 |
| 98270 | Navigator | 10 |
| 98276 | ION SCV Joyful Julia | 99 |
| 98263 | TOM-2 | 9 |
| 98280 | CUBY-5 | 11 |
| 98284 | CUBY-1 | 11 |
| 98277 | CyberCUBE | 10 |
| 98283 | CUBY-2 | 9 |
| 98282 | CUBY-3 | 11 |
| 98261 | SENTINEL-1 | 10 |
| 98262 | TOM-3 | 9 |
| Total: | 2089 |
due to a small shift in launch time from 7:10 to 7:12 UTC
I have recalculated the TLEs for Marina
MARINA
1 98293U 26001A 26188.34197353 .00000000 00000-0 20931-6 0 9991
2 98293 97.7424 88.8387 0013355 90.3955 269.9665 14.90887088 02
Postlaunch TLE
MARINA
1 98293U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9996
2 98293 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 09
Vetting just has started… any help more than appreciated as always!
Until now we have:
Marina satellite alive and received
IPoS-TDsM satellite alive and received
More updates to come, as vetting continues…
I’m going to use the Marina TLE for IPoS-TDsM, until we have more observations to generate a best fit:
IPoS-TDsM
1 98287U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9999
2 98287 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 02
KOSTKA also alive and received
Also we are going to use for now MARINA TLE:
KOSTKA
1 98395U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9999
2 98395 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 02
SCION-X also alive and received
We are using again MARINA TLE set for SCION-X:
SCION-X
1 98266U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9996
2 98266 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 09
