Koyo also alive and received
Again TLE of Marina changed to be used for Koyo:
KOYO
1 98273U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9994
2 98273 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 07
KOYO
There are a couple of signals watching the German satellites at 435.600 MHz, not sure if coming from the satellites or other already in orbit, will keep watching. If someone has IQ and can demodulate/decode any signals would be very useful.
In order to get better results we are going to use the Marina TLE here too:
TOM-1
1 98264U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9994
2 98264 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 07
TOM-2
1 98263U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9993
2 98263 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 06
TOM-3
1 98262U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9992
2 98262 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 05
CUBY-1
1 98284U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9996
2 98284 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 09
CUBY-2
1 98283U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9995
2 98283 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 08
CUBY-3
1 98282U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9994
2 98282 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 07
CUBY-4
1 98281U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9993
2 98281 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 06
CUBY-5
1 98280U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9992
2 98280 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 05
CloudCT-Precursor
1 98278U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9999
2 98278 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 02
Replicator-2 seems to be also alive and received
One more time we use Marina TLE for using them for Replicator-2 satellite:
Replicator-2
1 98267U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9997
2 98267 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 00
Not clear reception of BRO-31, so we will need to wait until have more observations, until then let’s update the TLE we use for BRO-31 with Marina’s ones:
BRO-31
1 98286U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9998
2 98286 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 01
Several wide signals on 400.500 MHz probably from Kita satellites, unfortunately without demodulation/decoding not easy to say if they are both alive or one of them, we will see in the next observations while they are going to get separated more.
Also ION deployer is also alive and transmitting. Here are updated TLEs for all of them, based on Marina’s ones:
ION SCV Joyful Julia
1 98276U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9997
2 98276 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 00
Kita-36
1 98275U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9996
2 98275 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 09
Kita-53
1 98274U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9995
2 98274 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 08
For Navigator, there is something that looks like a signal, but we will need more observations to verify it, until then here is an updated TLE set:
Navigator
1 98270U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9991
2 98270 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 04
I’m updating also the TLE for RAFS, Centauri and OASIS Alpha. For RAGS also for now only 401.700 MHz expected to be active transmitting GMSK4k8 signals:
RAFS
1 98268U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9998
2 98268 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 01
OASIS Alpha
1 98269U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9999
2 98269 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 02
Centauri-9
1 98279U 26001A 26188.34186184 .00000000 00000-0 20819-6 0 9990
2 98279 97.7473 88.7946 0015982 99.5762 260.7915 14.90763950 03
Hello, I have a question: where did you get the TLE data for your satellites? We (KOSTKA) have data from the launch provider that doesn’t match; it seems they have one orbit offset. As some people have already mentioned here, we also use the TLE data for the MARINA, so thank you.
Thank you, we will try it!
What software did you use, is it public?
The software used is the STRF toolkit that can be found on github.
We use real received data and use the Doppler to create/update the orbital elements.
Here some information on how to use the toolkit.
Here is TLE calculated by RAFS team, changed to use the temporary NORAD ID in DB:
RAFS
1 98268U 26188.34218302 .00000001 00000-0 10630-6 0 00001
2 98268 097.8005 088.9913 0007775 072.6974 288.8205 14.89096002000016
MARINA TLE Update:
MARINA
1 98293U 26188.48552270 .00000000 00000-0 32990-3 0 08
2 98293 97.7424 89.0422 0013355 90.3955 320.8560 14.89755318 04
# 20260707.42-20260707.49, 9 measurements, 0.083 kHz rms
@PE0SAT have reception of one satellite from T17 launch at 435.547 MHz through strf.
We’ve created an unknown object to track it. I suspect that this is probably one of TOM 1-3, Cuby 1-5 or CloudCT-Precursor.
Here is a TLE set to track it:
Unknown 1 T17
1 98259U 26156AC 26188.48555653 .00000000 00000-0 30030-3 0 01
2 98259 97.7451 90.1526 0007318 148.7649 262.2128 14.89467368 08
Thanks that’s very useful.
I guess this is the wide one, probably one of the German satellite, please keep checking the other observations too, maybe we can find a way to identify these satellites.
We have post launch orbital data from celestrak.org
"OBJECT_NAME": "OSIRIS-A",
"OBJECT_ID": "2026-156A",
"EPOCH": "2026-07-07T08:06:32.462986",
"MEAN_MOTION": 14.90521421,
"ECCENTRICITY": 0.0002486,
"INCLINATION": 97.7602,
"RA_OF_ASC_NODE": 88.7897,
"ARG_OF_PERICENTER": 119.086,
"MEAN_ANOMALY": 219.8729,
"EPHEMERIS_TYPE": 0,
"CLASSIFICATION_TYPE": "C",
"NORAD_CAT_ID": 799501928,
"ELEMENT_SET_NO": 0,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027695,
"MEAN_MOTION_DOT": -0.00026984,
"MEAN_MOTION_DDOT": 0,
"RMS": "0.139",
"DATA_SOURCE": "Transporter-SV"
"OBJECT_NAME": "LEMUR-2-ELEONORE",
"OBJECT_ID": "2026-156B",
"EPOCH": "2026-07-07T08:06:35.263037",
"MEAN_MOTION": 14.92615016,
"ECCENTRICITY": 0.0011472,
"INCLINATION": 97.7577,
"RA_OF_ASC_NODE": 88.7907,
"ARG_OF_PERICENTER": 147.9592,
"MEAN_ANOMALY": 191.1808,
"NORAD_CAT_ID": 799501955,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025853,
"MEAN_MOTION_DOT": -0.00026576,
"RMS": "0.139",
"OBJECT_NAME": "SUCHAI-4",
"OBJECT_ID": "2026-156C",
"EPOCH": "2026-07-07T08:06:45.063043",
"MEAN_MOTION": 14.90569754,
"ECCENTRICITY": 0.0003239,
"INCLINATION": 97.7563,
"RA_OF_ASC_NODE": 88.7914,
"ARG_OF_PERICENTER": 109.855,
"MEAN_ANOMALY": 229.8959,
"NORAD_CAT_ID": 799501929,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027022,
"MEAN_MOTION_DOT": -0.00026361,
"RMS": "0.139",
"OBJECT_NAME": "KOYO",
"OBJECT_ID": "2026-156D",
"EPOCH": "2026-07-07T08:07:00.563030",
"MEAN_MOTION": 14.90541647,
"ECCENTRICITY": 0.0003659,
"INCLINATION": 97.7534,
"RA_OF_ASC_NODE": 88.7926,
"ARG_OF_PERICENTER": 102.2687,
"MEAN_ANOMALY": 238.451,
"NORAD_CAT_ID": 799501931,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027618,
"MEAN_MOTION_DOT": -0.00026924,
"RMS": "0.139",
"OBJECT_NAME": "CYBERCUBE",
"OBJECT_ID": "2026-156E",
"EPOCH": "2026-07-07T08:07:02.862998",
"MEAN_MOTION": 14.92649585,
"ECCENTRICITY": 0.0011928,
"INCLINATION": 97.7504,
"RA_OF_ASC_NODE": 88.7937,
"ARG_OF_PERICENTER": 142.6529,
"MEAN_ANOMALY": 198.2166,
"NORAD_CAT_ID": 799501938,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025226,
"MEAN_MOTION_DOT": -0.00025956,
"RMS": "0.139",
"OBJECT_NAME": "LEMUR-2-CRIMBOREALIS",
"OBJECT_ID": "2026-156F",
"EPOCH": "2026-07-07T08:07:03.862992",
"MEAN_MOTION": 14.92414423,
"ECCENTRICITY": 0.0010575,
"INCLINATION": 97.7573,
"RA_OF_ASC_NODE": 88.7912,
"ARG_OF_PERICENTER": 147.3856,
"MEAN_ANOMALY": 193.5313,
"NORAD_CAT_ID": 799501946,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025575,
"MEAN_MOTION_DOT": -0.00026153,
"RMS": "0.139",
"OBJECT_NAME": "LEONAV-1",
"OBJECT_ID": "2026-156G",
"EPOCH": "2026-07-07T08:07:18.263021",
"MEAN_MOTION": 14.92702059,
"ECCENTRICITY": 0.0011979,
"RA_OF_ASC_NODE": 88.7927,
"ARG_OF_PERICENTER": 145.8166,
"MEAN_ANOMALY": 196.0032,
"NORAD_CAT_ID": 799501934,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025728,
"MEAN_MOTION_DOT": -0.00026508,
"RMS": "0.139",
"OBJECT_NAME": "LEMUR-2-ALYX",
"OBJECT_ID": "2026-156H",
"EPOCH": "2026-07-07T08:07:19.263014",
"MEAN_MOTION": 14.92266596,
"ECCENTRICITY": 0.0009798,
"INCLINATION": 97.7601,
"RA_OF_ASC_NODE": 88.7905,
"ARG_OF_PERICENTER": 149.4052,
"MEAN_ANOMALY": 192.4627,
"NORAD_CAT_ID": 799501948,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0025803,
"MEAN_MOTION_DOT": -0.00026285,
"RMS": "0.139",
"OBJECT_NAME": "IPOS-TDSM",
"OBJECT_ID": "2026-156J",
"EPOCH": "2026-07-07T08:07:40.762963",
"MEAN_MOTION": 14.90866242,
"ECCENTRICITY": 0.0003829,
"INCLINATION": 97.7614,
"ARG_OF_PERICENTER": 130.9056,
"MEAN_ANOMALY": 212.295,
"NORAD_CAT_ID": 799501924,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028836,
"MEAN_MOTION_DOT": -0.0002834,
"RMS": "0.139",
"OBJECT_NAME": "MARMOTSAT",
"OBJECT_ID": "2026-156K",
"EPOCH": "2026-07-07T08:07:52.363027",
"MEAN_MOTION": 14.90814289,
"ECCENTRICITY": 0.0003994,
"INCLINATION": 97.7584,
"RA_OF_ASC_NODE": 88.7916,
"ARG_OF_PERICENTER": 121.8469,
"MEAN_ANOMALY": 222.0806,
"NORAD_CAT_ID": 799501923,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028711,
"MEAN_MOTION_DOT": -0.00028181,
"RMS": "0.139",
"OBJECT_NAME": "GRITSS",
"OBJECT_ID": "2026-156L",
"EPOCH": "2026-07-07T08:07:54.162998",
"MEAN_MOTION": 14.9237129,
"ECCENTRICITY": 0.0010476,
"INCLINATION": 97.7542,
"RA_OF_ASC_NODE": 88.7928,
"ARG_OF_PERICENTER": 145.2203,
"MEAN_ANOMALY": 198.8271,
"NORAD_CAT_ID": 799501950,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027206,
"MEAN_MOTION_DOT": -0.0002779,
"RMS": "0.139",
"OBJECT_NAME": "CUBY-4",
"OBJECT_ID": "2026-156M",
"EPOCH": "2026-07-07T08:08:03.663024",
"MEAN_MOTION": 14.90823096,
"ECCENTRICITY": 0.0004526,
"INCLINATION": 97.7547,
"ARG_OF_PERICENTER": 115.5433,
"MEAN_ANOMALY": 229.0938,
"NORAD_CAT_ID": 799501921,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029024,
"MEAN_MOTION_DOT": -0.00028496,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-5",
"OBJECT_ID": "2026-156N",
"EPOCH": "2026-07-07T08:08:14.562989",
"MEAN_MOTION": 14.90879188,
"ECCENTRICITY": 0.0005002,
"INCLINATION": 97.7526,
"RA_OF_ASC_NODE": 88.7934,
"ARG_OF_PERICENTER": 114.7262,
"MEAN_ANOMALY": 230.5922,
"NORAD_CAT_ID": 799501920,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029062,
"MEAN_MOTION_DOT": -0.00028574,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-DELOITTE-6",
"OBJECT_ID": "2026-156P",
"EPOCH": "2026-07-07T08:08:15.862963",
"MEAN_MOTION": 14.9100993,
"ECCENTRICITY": 0.0004599,
"INCLINATION": 97.7595,
"ARG_OF_PERICENTER": 130.1668,
"MEAN_ANOMALY": 215.2181,
"NORAD_CAT_ID": 799501939,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027171,
"MEAN_MOTION_DOT": -0.00026801,
"RMS": "0.138",
"OBJECT_NAME": "ET-001A & ET-001B & ET-001C & ET-001D",
"OBJECT_ID": "2026-156Q",
"EPOCH": "2026-07-07T08:08:16.863043",
"MEAN_MOTION": 14.92299057,
"ECCENTRICITY": 0.001029,
"INCLINATION": 97.752,
"RA_OF_ASC_NODE": 88.7936,
"ARG_OF_PERICENTER": 143.0413,
"MEAN_ANOMALY": 202.4205,
"NORAD_CAT_ID": 799501933,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027959,
"MEAN_MOTION_DOT": -0.00028506,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-DELOITTE-5",
"OBJECT_ID": "2026-156R",
"EPOCH": "2026-07-07T08:08:27.362976",
"MEAN_MOTION": 14.9088961,
"ECCENTRICITY": 0.0004451,
"RA_OF_ASC_NODE": 88.7924,
"ARG_OF_PERICENTER": 121.6355,
"MEAN_ANOMALY": 224.4682,
"NORAD_CAT_ID": 799501941,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027376,
"MEAN_MOTION_DOT": -0.00026922,
"RMS": "0.138",
"OBJECT_NAME": "TOM-3",
"OBJECT_ID": "2026-156S",
"EPOCH": "2026-07-07T08:08:34.563034",
"MEAN_MOTION": 14.90907974,
"ECCENTRICITY": 0.0005573,
"INCLINATION": 97.7499,
"RA_OF_ASC_NODE": 88.7943,
"ARG_OF_PERICENTER": 111.9697,
"MEAN_ANOMALY": 234.5972,
"NORAD_CAT_ID": 799501918,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028258,
"MEAN_MOTION_DOT": -0.00027805,
"RMS": "0.138",
"OBJECT_NAME": "N2-P-BODY",
"OBJECT_ID": "2026-156T",
"EPOCH": "2026-07-07T08:08:43.963008",
"MEAN_MOTION": 14.92374329,
"ECCENTRICITY": 0.0010288,
"INCLINATION": 97.7568,
"ARG_OF_PERICENTER": 148.4479,
"MEAN_ANOMALY": 198.6875,
"NORAD_CAT_ID": 799501932,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027653,
"MEAN_MOTION_DOT": -0.00028248,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-3",
"OBJECT_ID": "2026-156U",
"EPOCH": "2026-07-07T08:08:53.562998",
"MEAN_MOTION": 14.90858835,
"ECCENTRICITY": 0.0005043,
"INCLINATION": 97.7531,
"ARG_OF_PERICENTER": 113.3266,
"MEAN_ANOMALY": 234.4137,
"NORAD_CAT_ID": 799501943,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029385,
"MEAN_MOTION_DOT": -0.00028877,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-2",
"OBJECT_ID": "2026-156V",
"EPOCH": "2026-07-07T08:09:04.263034",
"MEAN_MOTION": 14.90986392,
"ECCENTRICITY": 0.0005715,
"INCLINATION": 97.7512,
"RA_OF_ASC_NODE": 88.7942,
"ARG_OF_PERICENTER": 115.6779,
"MEAN_ANOMALY": 232.7312,
"NORAD_CAT_ID": 799501944,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029348,
"MEAN_MOTION_DOT": -0.00028935,
"RMS": "0.138",
"OBJECT_NAME": "CENTAURI-9",
"OBJECT_ID": "2026-156W",
"EPOCH": "2026-07-07T08:09:07.463030",
"MEAN_MOTION": 14.921997,
"ECCENTRICITY": 0.0009734,
"RA_OF_ASC_NODE": 88.7935,
"ARG_OF_PERICENTER": 144.2824,
"MEAN_ANOMALY": 204.3191,
"NORAD_CAT_ID": 799501925,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028221,
"MEAN_MOTION_DOT": -0.00028698,
"RMS": "0.138",
"OBJECT_NAME": "CUBY-1",
"OBJECT_ID": "2026-156X",
"EPOCH": "2026-07-07T08:09:34.862976",
"MEAN_MOTION": 14.9096604,
"ECCENTRICITY": 0.000567,
"INCLINATION": 97.7517,
"ARG_OF_PERICENTER": 115.1834,
"MEAN_ANOMALY": 235.1252,
"NORAD_CAT_ID": 799501937,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029606,
"MEAN_MOTION_DOT": -0.00029174,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-NURAY",
"OBJECT_ID": "2026-156Y",
"EPOCH": "2026-07-07T08:09:50.862960",
"MEAN_MOTION": 14.92353786,
"ECCENTRICITY": 0.0010718,
"INCLINATION": 97.7493,
"RA_OF_ASC_NODE": 88.7947,
"ARG_OF_PERICENTER": 142.3121,
"MEAN_ANOMALY": 208.9953,
"NORAD_CAT_ID": 799501958,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027377,
"MEAN_MOTION_DOT": -0.00027953,
"RMS": "0.138",
"OBJECT_NAME": "SCION-X",
"OBJECT_ID": "2026-156Z",
"EPOCH": "2026-07-07T08:09:57.063024",
"MEAN_MOTION": 14.90966055,
"ECCENTRICITY": 0.0006232,
"INCLINATION": 97.7479,
"RA_OF_ASC_NODE": 88.795,
"ARG_OF_PERICENTER": 112.0609,
"MEAN_ANOMALY": 239.6332,
"NORAD_CAT_ID": 799501935,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029743,
"MEAN_MOTION_DOT": -0.0002931,
"RMS": "0.138",
"OBJECT_NAME": "BOHR & CLOUDCT-PRECURSOR",
"OBJECT_ID": "2026-156AA",
"EPOCH": "2026-07-07T08:10:18.663024",
"MEAN_MOTION": 14.92485527,
"ECCENTRICITY": 0.001045,
"INCLINATION": 97.7597,
"ARG_OF_PERICENTER": 153.3517,
"MEAN_ANOMALY": 199.6609,
"NORAD_CAT_ID": 799501917,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027934,
"MEAN_MOTION_DOT": -0.00028615,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-DELOITTE-4",
"OBJECT_ID": "2026-156AB",
"EPOCH": "2026-07-07T08:10:32.762986",
"MEAN_MOTION": 14.92423465,
"ECCENTRICITY": 0.0010409,
"RA_OF_ASC_NODE": 88.7941,
"ARG_OF_PERICENTER": 149.7197,
"MEAN_ANOMALY": 204.1762,
"NORAD_CAT_ID": 799501940,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027048,
"MEAN_MOTION_DOT": -0.00027664,
"RMS": "0.138",
"OBJECT_NAME": "KOSTKA & OASIS ALPHA",
"OBJECT_ID": "2026-156AC",
"EPOCH": "2026-07-07T08:10:42.963024",
"MEAN_MOTION": 14.92452439,
"ECCENTRICITY": 0.0010998,
"INCLINATION": 97.7498,
"RA_OF_ASC_NODE": 88.7949,
"ARG_OF_PERICENTER": 145.0777,
"MEAN_ANOMALY": 209.4642,
"NORAD_CAT_ID": 799501936,
"REV_AT_EPOCH": 1,
"BSTAR": -0.002842,
"MEAN_MOTION_DOT": -0.00029091,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-SOPHILUNA-X1",
"OBJECT_ID": "2026-156AD",
"EPOCH": "2026-07-07T08:10:44.762995",
"MEAN_MOTION": 14.92369126,
"ECCENTRICITY": 0.0009998,
"INCLINATION": 97.7585,
"ARG_OF_PERICENTER": 151.5398,
"MEAN_ANOMALY": 203.0966,
"NORAD_CAT_ID": 799501942,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027191,
"MEAN_MOTION_DOT": -0.0002777,
"RMS": "0.138",
"OBJECT_NAME": "LEMUR-2-JESS-R",
"OBJECT_ID": "2026-156AE",
"EPOCH": "2026-07-07T08:11:05.263037",
"MEAN_MOTION": 14.9227032,
"ECCENTRICITY": 0.000943,
"INCLINATION": 97.7605,
"ARG_OF_PERICENTER": 152.5195,
"MEAN_ANOMALY": 203.3866,
"NORAD_CAT_ID": 799501945,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0027434,
"MEAN_MOTION_DOT": -0.00027946,
"RMS": "0.137",
"OBJECT_NAME": "BALKAN-3",
"OBJECT_ID": "2026-156AF",
"EPOCH": "2026-07-07T08:11:26.762986",
"MEAN_MOTION": 14.90973932,
"ECCENTRICITY": 0.0004779,
"INCLINATION": 97.7604,
"RA_OF_ASC_NODE": 88.7946,
"ARG_OF_PERICENTER": 122.468,
"MEAN_ANOMALY": 234.7738,
"NORAD_CAT_ID": 799501922,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028951,
"MEAN_MOTION_DOT": -0.00028532,
"RMS": "0.137",
"OBJECT_NAME": "TOM-2",
"OBJECT_ID": "2026-156AG",
"EPOCH": "2026-07-07T08:11:42.363024",
"MEAN_MOTION": 14.90529192,
"ECCENTRICITY": 0.0004157,
"INCLINATION": 97.7598,
"ARG_OF_PERICENTER": 97.7063,
"MEAN_ANOMALY": 260.5057,
"NORAD_CAT_ID": 799501916,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030222,
"MEAN_MOTION_DOT": -0.00029454,
"RMS": "0.137",
"OBJECT_NAME": "TOM-1",
"OBJECT_ID": "2026-156AH",
"EPOCH": "2026-07-07T08:12:00.162979",
"MEAN_MOTION": 14.90459953,
"ECCENTRICITY": 0.000517,
"INCLINATION": 97.754,
"RA_OF_ASC_NODE": 88.7952,
"ARG_OF_PERICENTER": 92.5007,
"MEAN_ANOMALY": 266.8278,
"NORAD_CAT_ID": 799501919,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030469,
"MEAN_MOTION_DOT": -0.00029646,
"RMS": "0.137",
"OBJECT_NAME": "LEMUR-2-ALEX-FULTON",
"OBJECT_ID": "2026-156AJ",
"EPOCH": "2026-07-07T08:12:11.262960",
"MEAN_MOTION": 14.90977076,
"ECCENTRICITY": 0.0004969,
"INCLINATION": 97.7596,
"RA_OF_ASC_NODE": 88.7953,
"ARG_OF_PERICENTER": 120.7121,
"MEAN_ANOMALY": 239.2949,
"NORAD_CAT_ID": 799501947,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029096,
"MEAN_MOTION_DOT": -0.00028677,
"RMS": "0.137",
"OBJECT_NAME": "MAVERIC",
"OBJECT_ID": "2026-156AK",
"EPOCH": "2026-07-07T08:12:14.763024",
"MEAN_MOTION": 14.92155297,
"ECCENTRICITY": 0.0008957,
"RA_OF_ASC_NODE": 88.7954,
"ARG_OF_PERICENTER": 150.5475,
"MEAN_ANOMALY": 209.6785,
"NORAD_CAT_ID": 799501952,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029727,
"MEAN_MOTION_DOT": -0.00030192,
"RMS": "0.137",
"OBJECT_NAME": "MARINA",
"OBJECT_ID": "2026-156AL",
"EPOCH": "2026-07-07T08:12:16.862976",
"MEAN_MOTION": 14.92075453,
"ECCENTRICITY": 0.0009083,
"ARG_OF_PERICENTER": 145.0736,
"MEAN_ANOMALY": 215.2919,
"NORAD_CAT_ID": 799501930,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028288,
"MEAN_MOTION_DOT": -0.00028673,
"RMS": "0.137",
"OBJECT_NAME": "HYPERION GR 1",
"OBJECT_ID": "2026-156AM",
"EPOCH": "2026-07-07T08:12:23.262970",
"MEAN_MOTION": 14.91296495,
"ECCENTRICITY": 0.000622,
"INCLINATION": 97.7566,
"RA_OF_ASC_NODE": 88.7955,
"ARG_OF_PERICENTER": 129.5741,
"MEAN_ANOMALY": 231.184,
"NORAD_CAT_ID": 799501963,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030201,
"MEAN_MOTION_DOT": -0.00030009,
"RMS": "0.137",
"OBJECT_NAME": "RAFS CUBESAT",
"OBJECT_ID": "2026-156AN",
"EPOCH": "2026-07-07T08:12:34.962998",
"MEAN_MOTION": 14.92083176,
"ECCENTRICITY": 0.0009244,
"INCLINATION": 97.7529,
"RA_OF_ASC_NODE": 88.7956,
"ARG_OF_PERICENTER": 144.1326,
"MEAN_ANOMALY": 217.3601,
"NORAD_CAT_ID": 799501926,
"REV_AT_EPOCH": 1,
"BSTAR": -0.003008,
"MEAN_MOTION_DOT": -0.00030496,
"RMS": "0.137",
"OBJECT_NAME": "REPLICATOR-2",
"OBJECT_ID": "2026-156AP",
"EPOCH": "2026-07-07T08:13:02.462995",
"MEAN_MOTION": 14.92183436,
"ECCENTRICITY": 0.000925,
"RA_OF_ASC_NODE": 88.796,
"ARG_OF_PERICENTER": 148.8823,
"MEAN_ANOMALY": 214.3122,
"NORAD_CAT_ID": 799501927,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029788,
"MEAN_MOTION_DOT": -0.00030276,
"RMS": "0.136",
"OBJECT_NAME": "SPEAR-1A & SPEAR-1B & SPEAR-1C",
"OBJECT_ID": "2026-156AQ",
"EPOCH": "2026-07-07T08:13:15.163018",
"MEAN_MOTION": 14.91251195,
"ECCENTRICITY": 0.0005915,
"RA_OF_ASC_NODE": 88.7963,
"ARG_OF_PERICENTER": 129.0948,
"MEAN_ANOMALY": 234.8834,
"NORAD_CAT_ID": 799501949,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028597,
"MEAN_MOTION_DOT": -0.00028382,
"RMS": "0.136",
"OBJECT_NAME": "R5 SPACECRAFT 9 (R5-S9)",
"OBJECT_ID": "2026-156AR",
"EPOCH": "2026-07-07T08:13:49.662970",
"MEAN_MOTION": 14.91163577,
"ECCENTRICITY": 0.000621,
"INCLINATION": 97.7554,
"RA_OF_ASC_NODE": 88.7964,
"ARG_OF_PERICENTER": 123.0113,
"MEAN_ANOMALY": 243.1155,
"NORAD_CAT_ID": 799501953,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031498,
"MEAN_MOTION_DOT": -0.00031193,
"RMS": "0.136",
"OBJECT_NAME": "FOSSASAT-2E26",
"OBJECT_ID": "2026-156AS",
"EPOCH": "2026-07-07T08:14:01.763030",
"MEAN_MOTION": 14.91251691,
"ECCENTRICITY": 0.0006643,
"ARG_OF_PERICENTER": 125.0034,
"MEAN_ANOMALY": 241.8779,
"NORAD_CAT_ID": 799501951,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028555,
"MEAN_MOTION_DOT": -0.00028343,
"RMS": "0.136",
"OBJECT_NAME": "BRO-31",
"OBJECT_ID": "2026-156AT",
"EPOCH": "2026-07-07T08:14:03.862982",
"MEAN_MOTION": 14.91985986,
"ECCENTRICITY": 0.0008537,
"INCLINATION": 97.7556,
"RA_OF_ASC_NODE": 88.7966,
"ARG_OF_PERICENTER": 145.5626,
"MEAN_ANOMALY": 221.4467,
"NORAD_CAT_ID": 799501965,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029981,
"MEAN_MOTION_DOT": -0.00030318,
"RMS": "0.136",
"OBJECT_NAME": "POSIDONIA",
"OBJECT_ID": "2026-156AU",
"EPOCH": "2026-07-07T08:14:08.562970",
"MEAN_MOTION": 14.91978158,
"ECCENTRICITY": 0.0008675,
"RA_OF_ASC_NODE": 88.7965,
"ARG_OF_PERICENTER": 144.2454,
"MEAN_ANOMALY": 223.0586,
"NORAD_CAT_ID": 799501964,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030564,
"MEAN_MOTION_DOT": -0.00030902,
"RMS": "0.136",
"OBJECT_NAME": "ION SCV-023",
"OBJECT_ID": "2026-156AV",
"EPOCH": "2026-07-07T08:14:17.562998",
"MEAN_MOTION": 14.91934636,
"ECCENTRICITY": 0.0008176,
"INCLINATION": 97.7571,
"RA_OF_ASC_NODE": 88.797,
"ARG_OF_PERICENTER": 145.9616,
"MEAN_ANOMALY": 221.8956,
"NORAD_CAT_ID": 799501912,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030352,
"MEAN_MOTION_DOT": -0.00030652,
"RMS": "0.136",
"OBJECT_NAME": "ICEYE-X80",
"OBJECT_ID": "2026-156AW",
"EPOCH": "2026-07-07T08:14:42.563011",
"MEAN_MOTION": 14.91388383,
"ECCENTRICITY": 0.0006695,
"INCLINATION": 97.7567,
"RA_OF_ASC_NODE": 88.7972,
"ARG_OF_PERICENTER": 130.8064,
"MEAN_ANOMALY": 238.6051,
"NORAD_CAT_ID": 799501968,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028142,
"MEAN_MOTION_DOT": -0.00028029,
"RMS": "0.136",
"OBJECT_NAME": "ICEYE-X77",
"OBJECT_ID": "2026-156AX",
"EPOCH": "2026-07-07T08:14:47.862960",
"MEAN_MOTION": 14.91932589,
"ECCENTRICITY": 0.0008385,
"INCLINATION": 97.7553,
"RA_OF_ASC_NODE": 88.7971,
"ARG_OF_PERICENTER": 144.3196,
"MEAN_ANOMALY": 225.4236,
"NORAD_CAT_ID": 799501967,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030834,
"MEAN_MOTION_DOT": -0.00031138,
"RMS": "0.136",
"OBJECT_NAME": "KITA-36",
"OBJECT_ID": "2026-156AY",
"EPOCH": "2026-07-07T08:14:56.963040",
"MEAN_MOTION": 14.91402994,
"ECCENTRICITY": 0.00068,
"RA_OF_ASC_NODE": 88.7973,
"ARG_OF_PERICENTER": 130.8877,
"MEAN_ANOMALY": 239.419,
"NORAD_CAT_ID": 799501914,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030107,
"MEAN_MOTION_DOT": -0.00029997,
"RMS": "0.136",
"OBJECT_NAME": "FIRESAT3",
"OBJECT_ID": "2026-156AZ",
"EPOCH": "2026-07-07T08:14:59.162957",
"MEAN_MOTION": 14.91915856,
"ECCENTRICITY": 0.0008132,
"RA_OF_ASC_NODE": 88.7974,
"ARG_OF_PERICENTER": 145.3025,
"MEAN_ANOMALY": 225.1396,
"NORAD_CAT_ID": 799501909,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0029928,
"MEAN_MOTION_DOT": -0.00030209,
"RMS": "0.136",
"OBJECT_NAME": "ICEYE-X81",
"OBJECT_ID": "2026-156BA",
"EPOCH": "2026-07-07T08:15:19.063037",
"MEAN_MOTION": 14.91428934,
"ECCENTRICITY": 0.0006641,
"INCLINATION": 97.7574,
"RA_OF_ASC_NODE": 88.7978,
"ARG_OF_PERICENTER": 132.7999,
"MEAN_ANOMALY": 238.8763,
"NORAD_CAT_ID": 799501956,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0028428,
"MEAN_MOTION_DOT": -0.00028342,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3D",
"OBJECT_ID": "2026-156BB",
"EPOCH": "2026-07-07T08:15:20.162995",
"MEAN_MOTION": 14.91878846,
"ECCENTRICITY": 0.0008235,
"INCLINATION": 97.7545,
"ARG_OF_PERICENTER": 143.0472,
"MEAN_ANOMALY": 228.7029,
"NORAD_CAT_ID": 799501903,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031518,
"MEAN_MOTION_DOT": -0.00031785,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3A",
"OBJECT_ID": "2026-156BC",
"EPOCH": "2026-07-07T08:15:25.963027",
"MEAN_MOTION": 14.9144202,
"ECCENTRICITY": 0.0007092,
"ARG_OF_PERICENTER": 131.1667,
"MEAN_ANOMALY": 240.9435,
"NORAD_CAT_ID": 799501907,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031984,
"MEAN_MOTION_DOT": -0.00031899,
"RMS": "0.135",
"OBJECT_NAME": "FIRESAT1",
"OBJECT_ID": "2026-156BD",
"EPOCH": "2026-07-07T08:15:30.762979",
"MEAN_MOTION": 14.91857178,
"ECCENTRICITY": 0.0007742,
"INCLINATION": 97.7576,
"RA_OF_ASC_NODE": 88.798,
"ARG_OF_PERICENTER": 145.2942,
"MEAN_ANOMALY": 227.1079,
"NORAD_CAT_ID": 799501961,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030261,
"MEAN_MOTION_DOT": -0.00030499,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3E",
"OBJECT_ID": "2026-156BE",
"EPOCH": "2026-07-07T08:15:33.063034",
"MEAN_MOTION": 14.91459528,
"ECCENTRICITY": 0.0006685,
"ARG_OF_PERICENTER": 133.8792,
"MEAN_ANOMALY": 238.6661,
"NORAD_CAT_ID": 799501904,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032024,
"MEAN_MOTION_DOT": -0.0003195,
"RMS": "0.135",
"OBJECT_NAME": "YAM-17",
"OBJECT_ID": "2026-156BF",
"EPOCH": "2026-07-07T08:15:34.162992",
"MEAN_MOTION": 14.91832796,
"ECCENTRICITY": 0.0008067,
"ARG_OF_PERICENTER": 142.1711,
"MEAN_ANOMALY": 230.4482,
"NORAD_CAT_ID": 799501910,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031054,
"MEAN_MOTION_DOT": -0.0003128,
"RMS": "0.135",
"OBJECT_NAME": "MISR-D-1",
"OBJECT_ID": "2026-156BG",
"EPOCH": "2026-07-07T08:15:57.363034",
"MEAN_MOTION": 14.91477289,
"ECCENTRICITY": 0.0007249,
"INCLINATION": 97.7544,
"RA_OF_ASC_NODE": 88.7976,
"ARG_OF_PERICENTER": 131.9785,
"MEAN_ANOMALY": 242.0827,
"NORAD_CAT_ID": 799501962,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031974,
"MEAN_MOTION_DOT": -0.00031918,
"RMS": "0.135",
"OBJECT_NAME": "NAVIGATOR",
"OBJECT_ID": "2026-156BH",
"EPOCH": "2026-07-07T08:15:59.163005",
"MEAN_MOTION": 14.91796255,
"ECCENTRICITY": 0.0007635,
"RA_OF_ASC_NODE": 88.7983,
"ARG_OF_PERICENTER": 143.1901,
"MEAN_ANOMALY": 230.9775,
"NORAD_CAT_ID": 799501969,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0030982,
"MEAN_MOTION_DOT": -0.00031177,
"RMS": "0.135",
"OBJECT_NAME": "ANDURIL-216",
"OBJECT_ID": "2026-156BJ",
"EPOCH": "2026-07-07T08:16:15.662986",
"MEAN_MOTION": 14.91507305,
"ECCENTRICITY": 0.0006915,
"RA_OF_ASC_NODE": 88.7986,
"ARG_OF_PERICENTER": 134.6828,
"MEAN_ANOMALY": 240.5098,
"NORAD_CAT_ID": 799501915,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031009,
"MEAN_MOTION_DOT": -0.00030976,
"RMS": "0.135",
"OBJECT_NAME": "NOVA 1",
"OBJECT_ID": "2026-156BK",
"EPOCH": "2026-07-07T08:16:17.263027",
"MEAN_MOTION": 14.91788984,
"ECCENTRICITY": 0.0007715,
"RA_OF_ASC_NODE": 88.7985,
"ARG_OF_PERICENTER": 142.3756,
"MEAN_ANOMALY": 232.9178,
"NORAD_CAT_ID": 799501954,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0031068,
"MEAN_MOTION_DOT": -0.00031258,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3C",
"OBJECT_ID": "2026-156BL",
"EPOCH": "2026-07-07T08:16:19.662960",
"MEAN_MOTION": 14.91533871,
"ECCENTRICITY": 0.0007598,
"INCLINATION": 97.7535,
"ARG_OF_PERICENTER": 132.831,
"MEAN_ANOMALY": 242.618,
"NORAD_CAT_ID": 799501905,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032392,
"MEAN_MOTION_DOT": -0.00032382,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3B",
"OBJECT_ID": "2026-156BM",
"EPOCH": "2026-07-07T08:16:42.162989",
"MEAN_MOTION": 14.91760848,
"ECCENTRICITY": 0.0007468,
"INCLINATION": 97.7579,
"RA_OF_ASC_NODE": 88.7991,
"ARG_OF_PERICENTER": 142.4859,
"MEAN_ANOMALY": 234.3519,
"NORAD_CAT_ID": 799501902,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032374,
"MEAN_MOTION_DOT": -0.00032548,
"RMS": "0.135",
"OBJECT_NAME": "GRUS-3F",
"OBJECT_ID": "2026-156BN",
"EPOCH": "2026-07-07T08:17:48.363014",
"MEAN_MOTION": 14.9152151,
"ECCENTRICITY": 0.0006862,
"INCLINATION": 97.758,
"RA_OF_ASC_NODE": 88.8001,
"ARG_OF_PERICENTER": 135.1723,
"MEAN_ANOMALY": 245.7767,
"NORAD_CAT_ID": 799501906,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0033249,
"MEAN_MOTION_DOT": -0.00033225,
"RMS": "0.134",
"OBJECT_NAME": "GRUS-3G",
"OBJECT_ID": "2026-156BP",
"EPOCH": "2026-07-07T08:18:03.662986",
"MEAN_MOTION": 14.91686694,
"ECCENTRICITY": 0.0007897,
"INCLINATION": 97.7536,
"ARG_OF_PERICENTER": 137.7276,
"MEAN_ANOMALY": 244.1805,
"NORAD_CAT_ID": 799501908,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0033229,
"MEAN_MOTION_DOT": -0.00033347,
"RMS": "0.134",
"OBJECT_NAME": "MIKROGLOB-1",
"OBJECT_ID": "2026-156BQ",
"EPOCH": "2026-07-07T08:18:15.262963",
"MEAN_MOTION": 14.91540076,
"ECCENTRICITY": 0.0007569,
"INCLINATION": 97.7541,
"RA_OF_ASC_NODE": 88.7989,
"ARG_OF_PERICENTER": 133.5294,
"MEAN_ANOMALY": 249.0984,
"NORAD_CAT_ID": 799501911,
"REV_AT_EPOCH": 1,
"BSTAR": -0.003262,
"MEAN_MOTION_DOT": -0.00032615,
"RMS": "0.134",
"OBJECT_NAME": "MISR-D-2",
"OBJECT_ID": "2026-156BR",
"EPOCH": "2026-07-07T08:19:06.262982",
"MEAN_MOTION": 14.91654119,
"ECCENTRICITY": 0.0007745,
"INCLINATION": 97.7538,
"RA_OF_ASC_NODE": 88.7992,
"ARG_OF_PERICENTER": 137.2646,
"MEAN_ANOMALY": 248.5305,
"NORAD_CAT_ID": 799501966,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0033613,
"MEAN_MOTION_DOT": -0.00033705,
"RMS": "0.133",
"OBJECT_NAME": "FIRESAT2",
"OBJECT_ID": "2026-156BS",
"EPOCH": "2026-07-07T08:19:34.563043",
"MEAN_MOTION": 14.91543515,
"ECCENTRICITY": 0.0006866,
"RA_OF_ASC_NODE": 88.8015,
"ARG_OF_PERICENTER": 135.6131,
"MEAN_ANOMALY": 251.9314,
"NORAD_CAT_ID": 799501960,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032903,
"MEAN_MOTION_DOT": -0.00032897,
"RMS": "0.133",
"OBJECT_NAME": "KITA-53",
"OBJECT_ID": "2026-156BT",
"EPOCH": "2026-07-07T08:19:40.662970",
"MEAN_MOTION": 14.91567398,
"ECCENTRICITY": 0.0007701,
"RA_OF_ASC_NODE": 88.7993,
"ARG_OF_PERICENTER": 134.4459,
"MEAN_ANOMALY": 253.4868,
"NORAD_CAT_ID": 799501913,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0032663,
"MEAN_MOTION_DOT": -0.00032681,
"RMS": "0.133",
"OBJECT_NAME": "PELICAN-11 3012",
"OBJECT_ID": "2026-156BU",
"EPOCH": "2026-07-07T08:21:21.663014",
"MEAN_MOTION": 14.91635744,
"ECCENTRICITY": 0.0007053,
"RA_OF_ASC_NODE": 88.8026,
"ARG_OF_PERICENTER": 138.2948,
"MEAN_ANOMALY": 255.9026,
"NORAD_CAT_ID": 799501959,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0035295,
"MEAN_MOTION_DOT": -0.0003537,
"RMS": "0.132",
"OBJECT_NAME": "ICEYE-X79",
"OBJECT_ID": "2026-156BV",
"EPOCH": "2026-07-07T08:24:25.562995",
"MEAN_MOTION": 14.91586006,
"ECCENTRICITY": 0.0007782,
"RA_OF_ASC_NODE": 88.8017,
"ARG_OF_PERICENTER": 135.9413,
"MEAN_ANOMALY": 269.6866,
"NORAD_CAT_ID": 799501957,
"REV_AT_EPOCH": 1,
"BSTAR": -0.0033831,
"MEAN_MOTION_DOT": -0.00033865,
"RMS": "0.130",
"OBJECT_NAME": "CAS500-4",
"OBJECT_ID": "2026-156BW",
"EPOCH": "2026-07-07T09:41:57.983021",
"MEAN_MOTION": 14.00864998,
"ECCENTRICITY": 0.0008587,
"INCLINATION": 98.9966,
"RA_OF_ASC_NODE": 88.6031,
"ARG_OF_PERICENTER": 253.538,
"MEAN_ANOMALY": 76.7337,
"NORAD_CAT_ID": 799501901,
"REV_AT_EPOCH": 1,
"BSTAR": -0.041437,
"MEAN_MOTION_DOT": -0.00061786,
"RMS": "0.096",
And here are in the TLE format:
OSIRIS-A
1 71928C 26156A 26188.33787573 -.00013492 00000-0 -27695-2 0 9997
2 71928 97.7602 88.7897 0002486 119.0860 219.8729 14.90521421 10
LEMUR-2-ELEONORE
1 71955C 26156B 26188.33790814 -.00013288 00000-0 -25853-2 0 9996
2 71955 97.7577 88.7907 0011472 147.9592 191.1808 14.92615016 16
SUCHAI-4
1 71929C 26156C 26188.33802156 -.00013181 00000-0 -27022-2 0 9992
2 71929 97.7563 88.7914 0003239 109.8550 229.8959 14.90569754 14
KOYO
1 71931C 26156D 26188.33820096 -.00013462 00000-0 -27618-2 0 9991
2 71931 97.7534 88.7926 0003659 102.2687 238.4510 14.90541647 12
CYBERCUBE
1 71938C 26156E 26188.33822758 -.00012978 00000-0 -25226-2 0 9999
2 71938 97.7504 88.7937 0011928 142.6529 198.2166 14.92649585 11
1 71946C 26156F 26188.33823915 -.00013076 00000-0 -25575-2 0 9991
2 71946 97.7573 88.7912 0010575 147.3856 193.5313 14.92414423 14
LEONAV-1
1 71934C 26156G 26188.33840582 -.00013254 00000-0 -25728-2 0 9995
2 71934 97.7534 88.7927 0011979 145.8166 196.0032 14.92702059 11
LEMUR-2-ALYX
1 71948C 26156H 26188.33841740 -.00013143 00000-0 -25803-2 0 9998
2 71948 97.7601 88.7905 0009798 149.4052 192.4627 14.92266596 18
IPOS-TDSM
1 71924C 26156J 26188.33866624 -.00014170 00000-0 -28836-2 0 9990
2 71924 97.7614 88.7905 0003829 130.9056 212.2950 14.90866242 16
MARMOTSAT
1 71923C 26156K 26188.33880050 -.00014091 00000-0 -28711-2 0 9992
2 71923 97.7584 88.7916 0003994 121.8469 222.0806 14.90814289 16
GRITSS
1 71950C 26156L 26188.33882133 -.00013895 00000-0 -27206-2 0 9995
2 71950 97.7542 88.7928 0010476 145.2203 198.8271 14.92371290 10
CUBY-4
1 71921C 26156M 26188.33893129 -.00014248 00000-0 -29024-2 0 9993
2 71921 97.7547 88.7928 0004526 115.5433 229.0938 14.90823096 18
CUBY-5
1 71920C 26156N 26188.33905744 -.00014287 00000-0 -29062-2 0 9994
2 71920 97.7526 88.7934 0005002 114.7262 230.5922 14.90879188 15
LEMUR-2-DELOITTE-6
1 71939C 26156P 26188.33907249 -.00013401 00000-0 -27171-2 0 9992
2 71939 97.7595 88.7916 0004599 130.1668 215.2181 14.91009930 11
1 71933C 26156Q 26188.33908406 -.00014253 00000-0 -27959-2 0 9992
2 71933 97.7520 88.7936 0010290 143.0413 202.4205 14.92299057 18
LEMUR-2-DELOITTE-5
1 71941C 26156R 26188.33920559 -.00013461 00000-0 -27376-2 0 9997
2 71941 97.7573 88.7924 0004451 121.6355 224.4682 14.90889610 12
TOM-3
1 71918C 26156S 26188.33928892 -.00013903 00000-0 -28258-2 0 9990
2 71918 97.7499 88.7943 0005573 111.9697 234.5972 14.90907974 19
N2-P-BODY
1 71932C 26156T 26188.33939772 -.00014124 00000-0 -27653-2 0 9999
2 71932 97.7568 88.7927 0010288 148.4479 198.6875 14.92374329 12
CUBY-3
1 71943C 26156U 26188.33950883 -.00014438 00000-0 -29385-2 0 9999
2 71943 97.7531 88.7937 0005043 113.3266 234.4137 14.90858835 10
CUBY-2
1 71944C 26156V 26188.33963267 -.00014468 00000-0 -29348-2 0 9992
2 71944 97.7512 88.7942 0005715 115.6779 232.7312 14.90986392 12
CENTAURI-9
1 71925C 26156W 26188.33966971 -.00014349 00000-0 -28221-2 0 9993
2 71925 97.7542 88.7935 0009734 144.2824 204.3191 14.92199700 11
CUBY-1
1 71937C 26156X 26188.33998684 -.00014587 00000-0 -29606-2 0 9994
2 71937 97.7517 88.7943 0005670 115.1834 235.1252 14.90966040 15
LEMUR-2-NURAY
1 71958C 26156Y 26188.34017202 -.00013977 00000-0 -27377-2 0 9991
2 71958 97.7493 88.7947 0010718 142.3121 208.9953 14.92353786 10
SCION-X
1 71935C 26156Z 26188.34024379 -.00014655 00000-0 -29743-2 0 9992
2 71935 97.7479 88.7950 0006232 112.0609 239.6332 14.90966055 13
1 71917C 26156AA 26188.34049379 -.00014307 00000-0 -27934-2 0 9993
2 71917 97.7597 88.7935 0010450 153.3517 199.6609 14.92485527 14
LEMUR-2-DELOITTE-4
1 71940C 26156AB 26188.34065698 -.00013832 00000-0 -27048-2 0 9999
2 71940 97.7563 88.7941 0010409 149.7197 204.1762 14.92423465 12
1 71936C 26156AC 26188.34077504 -.00014546 00000-0 -28420-2 0 9991
2 71936 97.7498 88.7949 0010998 145.0777 209.4642 14.92452439 16
1 71942C 26156AD 26188.34079587 -.00013885 00000-0 -27191-2 0 9990
2 71942 97.7585 88.7941 0009998 151.5398 203.0966 14.92369126 10
LEMUR-2-JESS-R
1 71945C 26156AE 26188.34103314 -.00013973 00000-0 -27434-2 0 9997
2 71945 97.7605 88.7942 0009430 152.5195 203.3866 14.92270320 13
BALKAN-3
1 71922C 26156AF 26188.34128198 -.00014266 00000-0 -28951-2 0 9990
2 71922 97.7604 88.7946 0004779 122.4680 234.7738 14.90973932 10
TOM-2
1 71916C 26156AG 26188.34146254 -.00014727 00000-0 -30222-2 0 9992
2 71916 97.7598 88.7949 0004157 97.7063 260.5057 14.90529192 13
TOM-1
1 71919C 26156AH 26188.34166855 -.00014823 00000-0 -30469-2 0 9994
2 71919 97.7540 88.7952 0005170 92.5007 266.8278 14.90459953 15
LEMUR-2-ALEX-FULTON
1 71947C 26156AJ 26188.34179703 -.00014338 00000-0 -29096-2 0 9996
2 71947 97.7596 88.7953 0004969 120.7121 239.2949 14.90977076 14
MAVERIC
1 71952C 26156AK 26188.34183753 -.00015096 00000-0 -29727-2 0 9995
2 71952 97.7585 88.7954 0008957 150.5475 209.6785 14.92155297 17
MARINA
1 71930C 26156AL 26188.34186184 -.00014337 00000-0 -28288-2 0 9990
2 71930 97.7540 88.7954 0009083 145.0736 215.2919 14.92075453 11
HYPERION GR 1
1 71963C 26156AM 26188.34193591 -.00015004 00000-0 -30201-2 0 9996
2 71963 97.7566 88.7955 0006220 129.5741 231.1840 14.91296495 19
RAFS CUBESAT
1 71926C 26156AN 26188.34207133 -.00015248 00000-0 -30080-2 0 9998
2 71926 97.7529 88.7956 0009244 144.1326 217.3601 14.92083176 11
REPLICATOR-2
1 71927C 26156AP 26188.34238962 -.00015138 00000-0 -29788-2 0 9994
2 71927 97.7563 88.7960 0009250 148.8823 214.3122 14.92183436 10
1 71949C 26156AQ 26188.34253661 -.00014191 00000-0 -28597-2 0 9996
2 71949 97.7585 88.7963 0005915 129.0948 234.8834 14.91251195 18
1 71953C 26156AR 26188.34293591 -.00015596 00000-0 -31498-2 0 9991
2 71953 97.7554 88.7964 0006210 123.0113 243.1155 14.91163577 12
FOSSASAT-2E26
1 71951C 26156AS 26188.34307596 -.00014171 00000-0 -28555-2 0 9998
2 71951 97.7540 88.7964 0006643 125.0034 241.8779 14.91251691 11
BRO-31
1 71965C 26156AT 26188.34310027 -.00015159 00000-0 -29981-2 0 9997
2 71965 97.7556 88.7966 0008537 145.5626 221.4467 14.91985986 12
POSIDONIA
1 71964C 26156AU 26188.34315466 -.00015451 00000-0 -30564-2 0 9992
2 71964 97.7542 88.7965 0008675 144.2454 223.0586 14.91978158 16
ION SCV-023
1 71912C 26156AV 26188.34325883 -.00015326 00000-0 -30352-2 0 9995
2 71912 97.7571 88.7970 0008176 145.9616 221.8956 14.91934636 11
ICEYE-X80
1 71968C 26156AW 26188.34354818 -.00014014 00000-0 -28142-2 0 9993
2 71968 97.7567 88.7972 0006695 130.8064 238.6051 14.91388383 17
ICEYE-X77
1 71967C 26156AX 26188.34360953 -.00015569 00000-0 -30834-2 0 9996
2 71967 97.7553 88.7971 0008385 144.3196 225.4236 14.91932589 16
KITA-36
1 71914C 26156AY 26188.34371485 -.00014998 00000-0 -30107-2 0 9998
2 71914 97.7563 88.7973 0006800 130.8877 239.4190 14.91402994 13
FIRESAT3
1 71909C 26156AZ 26188.34374031 -.00015104 00000-0 -29928-2 0 9991
2 71909 97.7567 88.7974 0008132 145.3025 225.1396 14.91915856 14
ICEYE-X81
1 71956C 26156BA 26188.34397064 -.00014171 00000-0 -28428-2 0 9991
2 71956 97.7574 88.7978 0006641 132.7999 238.8763 14.91428934 16
GRUS-3D
1 71903C 26156BB 26188.34398337 -.00015893 00000-0 -31518-2 0 9993
2 71903 97.7545 88.7973 0008235 143.0472 228.7029 14.91878846 17
GRUS-3A
1 71907C 26156BC 26188.34405050 -.00015950 00000-0 -31984-2 0 9999
2 71907 97.7545 88.7973 0007092 131.1667 240.9435 14.91442020 13
FIRESAT1
1 71961C 26156BD 26188.34410605 -.00015249 00000-0 -30261-2 0 9999
2 71961 97.7576 88.7980 0007742 145.2942 227.1079 14.91857178 14
GRUS-3E
1 71904C 26156BE 26188.34413267 -.00015975 00000-0 -32024-2 0 9998
2 71904 97.7574 88.7980 0006685 133.8792 238.6661 14.91459528 11
YAM-17
1 71910C 26156BF 26188.34414541 -.00015640 00000-0 -31054-2 0 9992
2 71910 97.7547 88.7974 0008067 142.1711 230.4482 14.91832796 14
MISR-D-1
1 71962C 26156BG 26188.34441392 -.00015959 00000-0 -31974-2 0 9997
2 71962 97.7544 88.7976 0007249 131.9785 242.0827 14.91477289 12
NAVIGATOR
1 71969C 26156BH 26188.34443476 -.00015589 00000-0 -30982-2 0 9996
2 71969 97.7571 88.7983 0007635 143.1901 230.9775 14.91796255 16
ANDURIL-216
1 71915C 26156BJ 26188.34462573 -.00015488 00000-0 -31009-2 0 9995
2 71915 97.7574 88.7986 0006915 134.6828 240.5098 14.91507305 17
NOVA 1
1 71954C 26156BK 26188.34464425 -.00015629 00000-0 -31068-2 0 9998
2 71954 97.7568 88.7985 0007715 142.3756 232.9178 14.91788984 15
GRUS-3C
1 71905C 26156BL 26188.34467202 -.00016191 00000-0 -32392-2 0 9996
2 71905 97.7535 88.7976 0007598 132.8310 242.6180 14.91533871 18
GRUS-3B
1 71902C 26156BM 26188.34493244 -.00016274 00000-0 -32374-2 0 9990
2 71902 97.7579 88.7991 0007468 142.4859 234.3519 14.91760848 11
GRUS-3F
1 71906C 26156BN 26188.34569865 -.00016613 00000-0 -33249-2 0 9996
2 71906 97.7580 88.8001 0006862 135.1723 245.7767 14.91521510 18
GRUS-3G
1 71908C 26156BP 26188.34587573 -.00016673 00000-0 -33229-2 0 9998
2 71908 97.7536 88.7985 0007897 137.7276 244.1805 14.91686694 12
MIKROGLOB-1
1 71911C 26156BQ 26188.34600999 -.00016307 00000-0 -32620-2 0 9998
2 71911 97.7541 88.7989 0007569 133.5294 249.0984 14.91540076 11
MISR-D-2
1 71966C 26156BR 26188.34660027 -.00016852 00000-0 -33613-2 0 9994
2 71966 97.7538 88.7992 0007745 137.2646 248.5305 14.91654119 14
FIRESAT2
1 71960C 26156BS 26188.34692781 -.00016448 00000-0 -32903-2 0 9992
2 71960 97.7576 88.8015 0006866 135.6131 251.9314 14.91543515 16
KITA-53
1 71913C 26156BT 26188.34699841 -.00016341 00000-0 -32663-2 0 9999
2 71913 97.7534 88.7993 0007701 134.4459 253.4868 14.91567398 17
PELICAN-11 3012
1 71959C 26156BU 26188.34816740 -.00017685 00000-0 -35295-2 0 9994
2 71959 97.7571 88.8026 0007053 138.2948 255.9026 14.91635744 15
ICEYE-X79
1 71957C 26156BV 26188.35029587 -.00016933 00000-0 -33831-2 0 9997
2 71957 97.7535 88.8017 0007782 135.9413 269.6866 14.91586006 13
CAS500-4
1 71901C 26156BW 26188.40414332 -.00030893 00000-0 -41437-1 0 9999
2 71901 98.9966 88.6031 0008587 253.5380 76.7337 14.00864998 10
The above TLE changed to use the tempoary NORAD IDs in SatNOGS DB:
OSIRIS-A
1 98261C 26156A 26188.33787573 -.00013492 00000-0 -27695-2 0 9997
2 98261 97.7602 88.7897 0002486 119.0860 219.8729 14.90521421 10
SUCHAI-4
1 98265C 26156C 26188.33802156 -.00013181 00000-0 -27022-2 0 9992
2 98265 97.7563 88.7914 0003239 109.8550 229.8959 14.90569754 14
KOYO
1 98273C 26156D 26188.33820096 -.00013462 00000-0 -27618-2 0 9991
2 98273 97.7534 88.7926 0003659 102.2687 238.4510 14.90541647 12
CYBERCUBE
1 98277C 26156E 26188.33822758 -.00012978 00000-0 -25226-2 0 9999
2 98277 97.7504 88.7937 0011928 142.6529 198.2166 14.92649585 11
IPOS-TDSM
1 98287C 26156J 26188.33866624 -.00014170 00000-0 -28836-2 0 9990
2 98287 97.7614 88.7905 0003829 130.9056 212.2950 14.90866242 16
MARMOTSAT
1 98272C 26156K 26188.33880050 -.00014091 00000-0 -28711-2 0 9992
2 98272 97.7584 88.7916 0003994 121.8469 222.0806 14.90814289 16
CUBY-4
1 98281C 26156M 26188.33893129 -.00014248 00000-0 -29024-2 0 9993
2 98281 97.7547 88.7928 0004526 115.5433 229.0938 14.90823096 18
CUBY-5
1 98280C 26156N 26188.33905744 -.00014287 00000-0 -29062-2 0 9994
2 98280 97.7526 88.7934 0005002 114.7262 230.5922 14.90879188 15
TOM-3
1 98262C 26156S 26188.33928892 -.00013903 00000-0 -28258-2 0 9990
2 98262 97.7499 88.7943 0005573 111.9697 234.5972 14.90907974 19
CUBY-3
1 98282C 26156U 26188.33950883 -.00014438 00000-0 -29385-2 0 9999
2 98282 97.7531 88.7937 0005043 113.3266 234.4137 14.90858835 10
CUBY-2
1 98283C 26156V 26188.33963267 -.00014468 00000-0 -29348-2 0 9992
2 98283 97.7512 88.7942 0005715 115.6779 232.7312 14.90986392 12
CENTAURI-9
1 98279C 26156W 26188.33966971 -.00014349 00000-0 -28221-2 0 9993
2 98279 97.7542 88.7935 0009734 144.2824 204.3191 14.92199700 11
CUBY-1
1 98284C 26156X 26188.33998684 -.00014587 00000-0 -29606-2 0 9994
2 98284 97.7517 88.7943 0005670 115.1834 235.1252 14.90966040 15
SCION-X
1 98266C 26156Z 26188.34024379 -.00014655 00000-0 -29743-2 0 9992
2 98266 97.7479 88.7950 0006232 112.0609 239.6332 14.90966055 13
1 98278C 26156AA 26188.34049379 -.00014307 00000-0 -27934-2 0 9993
2 98278 97.7597 88.7935 0010450 153.3517 199.6609 14.92485527 14
KOSTKA
1 98395C 26156AC 26188.34077504 -.00014546 00000-0 -28420-2 0 9992
2 98395 97.7498 88.7949 0010998 145.0777 209.4642 14.92452439 17
OASIS ALPHA
1 98269C 26156AC 26188.34077504 -.00014546 00000-0 -28420-2 0 9991
2 98269 97.7498 88.7949 0010998 145.0777 209.4642 14.92452439 16
TOM-2
1 98263C 26156AG 26188.34146254 -.00014727 00000-0 -30222-2 0 9992
2 98263 97.7598 88.7949 0004157 97.7063 260.5057 14.90529192 13
TOM-1
1 98264C 26156AH 26188.34166855 -.00014823 00000-0 -30469-2 0 9994
2 98264 97.7540 88.7952 0005170 92.5007 266.8278 14.90459953 15
MAVERIC
1 98271C 26156AK 26188.34183753 -.00015096 00000-0 -29727-2 0 9995
2 98271 97.7585 88.7954 0008957 150.5475 209.6785 14.92155297 17
MARINA
1 98293C 26156AL 26188.34186184 -.00014337 00000-0 -28288-2 0 9990
2 98293 97.7540 88.7954 0009083 145.0736 215.2919 14.92075453 11
RAFS CUBESAT
1 98268C 26156AN 26188.34207133 -.00015248 00000-0 -30080-2 0 9998
2 98268 97.7529 88.7956 0009244 144.1326 217.3601 14.92083176 11
REPLICATOR-2
1 98267C 26156AP 26188.34238962 -.00015138 00000-0 -29788-2 0 9994
2 98267 97.7563 88.7960 0009250 148.8823 214.3122 14.92183436 10
FOSSASAT-2E26
1 98285C 26156AS 26188.34307596 -.00014171 00000-0 -28555-2 0 9998
2 98285 97.7540 88.7964 0006643 125.0034 241.8779 14.91251691 11
BRO-31
1 98286C 26156AT 26188.34310027 -.00015159 00000-0 -29981-2 0 9997
2 98286 97.7556 88.7966 0008537 145.5626 221.4467 14.91985986 12
ION SCV-023
1 98276C 26156AV 26188.34325883 -.00015326 00000-0 -30352-2 0 9995
2 98276 97.7571 88.7970 0008176 145.9616 221.8956 14.91934636 11
KITA-36
1 98275C 26156AY 26188.34371485 -.00014998 00000-0 -30107-2 0 9998
2 98275 97.7563 88.7973 0006800 130.8877 239.4190 14.91402994 13
NAVIGATOR
1 98270C 26156BH 26188.34443476 -.00015589 00000-0 -30982-2 0 9996
2 98270 97.7571 88.7983 0007635 143.1901 230.9775 14.91796255 16
KITA-53
1 98274C 26156BT 26188.34699841 -.00016341 00000-0 -32663-2 0 9999
2 98274 97.7534 88.7993 0007701 134.4459 253.4868 14.91567398 17
Added one more satellite in DB based on the names from celestrak.org orbital data that transmits at 400.250 MHz:
Here is its TLE:
ANDURIL-216
1 98258C 26156BJ 26188.34462573 -.00015488 00000-0 -31009-2 0 9994
2 98258 97.7574 88.7986 0006915 134.6828 240.5098 14.91507305 16
Between celestrak list of satellites and this of spacex there are some not obvious connections, here are these ones:
ANDURIL-216 → LA3
MIKROGLOB-1 → Pirx-1
MISR-D-1 → Flashpoint 1
MISR-D-2 → Flashpoint 2
Loft-EarthDaily-8 → YAM-17
