Transporter-14 Rideshare: Vandenberg SLC-4E: 23 Jun 2025 21:18 UTC
Indeed TPA-1 uses Light-1 framing
For gr-satellites users, here is the yaml file.
norad: 98587
  &tlm Telemetry:
    unknown
  2k4 FSK downlink:
    frequency: 401.900e+6
    modulation: FSK
    baudrate: 2400
    framing: Light-1
    - *tlm
((transmitter . 2k4 FSK downlink))
pdu length =         93 bytes
pdu vector contents =
0000: 01 20 00 e8 ac 02 01 00 00 b0 00 00 00 00 00 00
0010: 00 00 00 4c 00 00 00 02 00 02 00 01 00 24 00 00
0020: 00 fa fa fa fa fa fa fa fa fa 05 7f 7f fa fa 00
0030: 00 80 0c 11 01 00 00 3c b4 00 00 9f 00 00 00 80
0040: 18 85 40 60 58 3f 42 00 00 00 00 00 00 9c c1 00
0050: 00 dc c1 00 00 c0 7f 00 80 ee c1 00 80
pdu length =         91 bytes
0000: 01 20 00 e8 ac 02 02 8a c1 00 00 c0 7f fb 00 fb
0010: 00 a0 87 5a 68 12 61 c3 ff 01 3d cc a1 41 d4 34
0020: 19 c3 bd 68 fb 48 01 00 00 00 02 8c 86 08 3f 00
0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0050: 00 00 00 00 00 00 00 00 00 00 00
0000: 01 20 00 e8 ad 02 01 00 00 ac 00 00 00 00 00 00
0010: 00 00 00 4b 00 00 00 01 00 02 00 02 00 24 00 00
0020: 00 f9 f9 f9 f9 fa fa fa f9 fa 05 7f 7f f9 f9 00
0030: 00 80 0c 11 01 00 00 b5 b4 00 00 9f 00 00 00 00
0040: c6 84 40 90 c8 44 42 00 00 00 00 00 00 c0 c1 00
0050: 00 e0 c1 00 00 c0 7f 00 00 d1 c1 00 80
0000: 01 20 00 e8 ad 02 02 91 c1 00 00 c0 7f fb 00 fb
0010: 00 19 88 5a 68 23 5c c8 ff 01 88 b0 de 41 a6 e6
0020: 1a c3 fa ec fb 48 01 00 00 00 02 fe 86 ac 3e 00
0030: 00 00 00 00 00 80 bf 00 00 80 bf 00 00 80 3f 00
The frequency used is 436.300 MHz, the SatNOGS transmitter is also updated.
A SatNOGS obs IQ replay places the signal 5 kHZ higher.
BRO-18 IQ replay.
Awesome work everyone!
T14 Unknown 1 is JACK-001, thanks @EU1SAT for the demodulated data!
EDIT: fixed in the next post.
Also it’s transmitter is now move at 436.305 MHz per @PE0SAT and Network’s observations.
Good job also by @sv2hwm and @PE0SAT for TPA-1 demodulation. Just to be accurate, we may need some more data to confirm it is TPA-1 but until now this is the best candidate.
Oops my bad… @PE0SAT had already moved the transmitter from 436.295 MHz to 436.300 MHz, I’m changing back my wrong change.
From nanosatellite.eu TPA-1 uses PLATFORM - NanoAvionics for its subsystems, similar to the Bluewalker and Light-1 that have the same framing and modulation and baudrate. So, I guess we can be 99% sure that these signals are from TPA-1.
Oh man - I’ve not even had a pass over 25° elevation yet on the U.S. East Coast and you all have practically identified the entire deployment!
Great work, everyone!!
I guess the challenge now for those of us ‘orbitally challenged’ is to try to figure out which objects remain uncertain or silent. Maybe the SatNogs system can add a ‘10 Most Wanted’ list?
identified as 98570 on 2256 MHz
and the bottom signal identified as 98578 on 2255.510 MHz by the way
And an unknown (yet)
guestimating 2245.400 center and matching 98581 and / or 98591 on either top or bottom of the signal
hoping for a bit stronger signal coming night passes
With some help from Fredy this might match Hyperfield-1B
Since the Bochum decodes in their PARUS-T2 observation are from other transmitters on 145.825, is it correct to say that as of 0120utc on 25-June-2025 that we still don’t have any RX decodes from any of the PARUS-T2 frequencies?
(just trying to narrow the list of Transporter-14 objects to monitor)
Also, has anyone heard any speculation or Team statements as to whether they suspect a failed antenna deployment or what? (since a few very weak signals have been seen in waterfalls)
Decoding JACK001 with gr-satellites.
norad: 98563
  &tlm Telemetry:
    telemetry: ax25
  9k6 FSK downlink:
    frequency: 436.300e+6
    modulation: FSK
    baudrate: 9600
    deviation: 2600
    framing: AX.25 G3RUH
    - *tlm
-> Packet from 9k6 FSK downlink
Container:
    header = Container:
        addresses = ListContainer:
            Container:
                callsign = u'6L433' (total 5)
                ssid = Container:
                    ch = False
                    ssid = 0
                    extension = False
            Container:
                callsign = u'DS35' (total 4)
                ssid = Container:
                    ch = False
                    ssid = 0
                    extension = True
        control = 0x03
        pid = 0xF0
    info = b'\x84\xd2\xa1\x01JACK001\x03>u\x00\xaa\x0bq\x84\x07\x8fH\xc1\xb3\xfc\x14\x00G\xfd\xfe\x01\xde\xfe\xe7\xfe\x14\x00\x00\x00\x00\x00\x00\x00\x00$\r\x00\x84\x00\x00\x00\x00\x00\x00\xf5I>$\x0eV~\xe4e\xe3\\y)~,\x17{\xea\xabH\x0f}\xfd\xe8$H\xf9X!D\xbd\x0cn<\x1c\xab' (total 90)
I have monitored RIDUSAT-1 and PARUS-T2 on VHF each pass and have heard nothing yet.
RIDUSAT-1 is seen transmitting beacon on 145.925 above Europe around 22.00 - 00.00 UTC that was observed by multiple station, but not heard again on my QTH pass about an hour ago.
So far I have not yet heard Parus-T2 from my QTH with manual observation.
One example:
https://network.satnogs.org/observations/11823861/
Tonight’s pass provided enough elevation for me to join the Transporter-14 club…
First a bunch of 9k6 AX.25 decodes from JACK-001 (https://x.com/scott23192/status/1937764900258132311):
… and then my first LoRa decode from FossaSat-2E21 down on 401.700 (https://x.com/scott23192/status/1937768430045921406):
11:27 UTC - Tentative reception and decoding of SkyBee-2, on 401.050 MHz, in GFSK 2400 bd, using UZ7HO’s Light-1 SoundModem.
@K4KDR , @BV2DQ
PARUS-T2
Observed the pass on 2025-06-25 13:30 UTC (max 46° elevation).
No signals on UHF, no signals on VHF and response from digipeater.
RIDU-Sat 1
Observed the pass on 2025-06-25 12:5x UTC (max 68° elevation).
No signals on 145.925, no signals on 145.825 and response from digipeater.
12:05 UTC Reception of telemetry and music from HUBBLE-6.
