An updated TLE for BUCCANEER MAIN:
BUCCANEER MAIN
1 98648U 00000A 25074.56173505 .00000000 00000-0 00000-0 0 08
2 98648 97.7394 329.6182 0003006 96.6292 116.9723 14.90492831 00
BUCCANEER MAIN
NUSHSAT-1
1 98628U 25074.39686004 .00000000 00000-0 -15047-3 0 01
2 98628 97.4529 332.1244 0002930 200.7175 211.8154 15.18155895 06
New unknown satellite has been added in DB with temporary NORAD ID 98616 and frequenc 401.175 MHz found by @PE0SAT with strf observation.
We are using semi-randomly TLE from Lizziesat-3 to initially track it, this doesn’t mean that necessarily is Lizziesat-3 as the objects are still very close it could be any of the satellites in the similar orbit.
Unknown Satellite from T14
1 98616C 25052R 25074.31700498 -.00005366 00000+0 -27273-3 0 02
2 98616 97.4444 328.6504 0002971 340.4926 10.7965 15.16945994 11
Using the gr-satellites UPloader for the TEVEL2 satellites revealed an error in gr-satellites block Check AX.25 address.
Since the TEVEL2 are using “-” in their callsigns, the separation between callsign and SSID won’t work.
As a workaround I’ve switched the block to Check Hex String.
This is the new version for the TEVEL2 only:
gr_satellites-UPloader (TEVEL2 version).zip (6.5 KB)
By the way, please notice that the callsign of only TEVEL2-1 has swapped characters.
It’s
TLV2-1 -1 to TLV2-1.
The others have
TVL2-x -1 to TVL2-x.
-1 is the number in the sender callsign’s SSID.
OTP-2 generated TLE from GNSS onboard:
1 98652U 25074.31820637 .00024738 00000-0 12826-2 0 00006
2 98652 097.4392 329.6486 0006484 342.1113 000.6872 15.16103495000010
Hi all, I’m Vincent, a member of the NUSHSAT-1 team. Thanks for everyone’s efforts thus far in aiding with observations of our satellite!
Over the last few passes over our groundstation (based in Singapore), we have observed significant drift of our satellite from the initial TLE, hampering communication efforts. The TLE provided by @PE0SAT (thank you!) appears to be more accurate, but is still not sufficient for consistent communications.
It would be greatly appreciated if anyone here could assist us with tracking our satellite to produce a more accurate TLE, as well as updating the SatNOGS database with the more accurate TLE provided by @PE0SAT. Thanks all!
Welcome Vincent,
I will check my observations and try to make a more accurate TLE set for NUSHSAT-1.
Congratulations with a successful launch to you and the team.
Based on multiple obs a new TLE set.
NUSHSAT-1
1 98628U 25075.00315773 .00000000 00000-0 -15047-3 0 02
2 98628 97.4529 330.3784 0002930 200.7175 281.5444 15.17474598 04
# 20250315.39-20250316.01, 56 measurements, 0.054 kHz rms
Checking SatNOGS Network - Observation 11234182 with this TLE set.
Thanks Vlad, for this confirmation, that’s great to hear.
Once again, thank you so much for your help! We really appreciate your assistance, as well as @EU1SAT’s in cross checking with another observation.
We have updated the TLE on our end and will keep everyone posted of the outcome of our upcoming observations (occurring in about 6h). Could I also request for the TLE to be updated in the SatNOGS database for more accurate observations?
You can also join the SatNOGS Matrix channel to interact with all members,
There are post-launch TLE sets from Celestrak:
NILA
1 71433C 25052A 25074.31755706 .00002793 00000+0 14403-3 0 02
2 71433 97.4385 329.6535 0005406 348.1428 351.0097 15.16423126 11
TEVEL 2-7 & TEVEL 2-8 &*
1 71471C 25052B 25074.31762419 -.00011287 00000+0 -58131-3 0 09
2 71471 97.4482 329.6499 0005205 328.8574 10.6404 15.16473820 10
ORBASTRO-TR5
1 71452C 25052C 25074.31770637 -.00005223 00000+0 -26806-3 0 06
2 71452 97.4393 329.6533 0004615 348.3478 351.6179 15.16598401 13
IOD1 STARTICAL
1 71464C 25052D 25074.31779201 -.00003502 00000+0 -17283-3 0 02
2 71464 97.4382 329.6537 0001741 128.1801 212.2563 15.17972981 18
ALMUNTHER
1 71447C 25052E 25074.31789502 -.00006750 00000+0 -34708-3 0 07
2 71447 97.4423 329.6523 0004848 342.1103 358.8787 15.16532241 19
NUSHSAT-1 & JINJUSAT-1B
1 71442C 25052F 25074.31812303 -.00003865 00000+0 -18975-3 0 00
2 71442 97.4529 329.6489 0002930 200.7164 141.4953 15.18155853 11
BOTSAT-1
1 71429C 25052G 25074.31831979 -.00003865 00000+0 -19122-3 0 00
2 71429 97.4386 329.6537 0001336 131.8788 211.4367 15.17891091 13
TOMORROW-S5
1 71474C 25052H 25074.31839618 .00026696 00000+0 13678-2 0 02
2 71474 97.4503 329.6502 0004521 325.7403 17.9679 15.16648290 18
OTP-2
1 71454C 25052J 25074.31865776 -.00005726 00000+0 -29302-3 0 09
2 71454 97.4398 329.6534 0004093 351.6401 353.5181 15.16700691 14
TEVEL 2-1 & TEVEL 2-2 &*
1 71465C 25052K 25074.31879317 -.00010700 00000+0 -53102-3 0 00
2 71465 97.4403 329.6533 0000784 141.1330 204.7630 15.17787595 13
TEVEL 2-4 & TEVEL 2-5 &*
1 71468C 25052L 25074.31901655 -.00010670 00000+0 -52595-3 0 05
2 71468 97.4431 329.6528 0001772 174.2790 172.8304 15.18022734 17
RAPSAT
1 71448C 25052M 25074.31909178 -.00004852 00000+0 -24789-3 0 00
2 71448 97.4411 329.6533 0003782 350.0714 357.4532 15.16760212 14
AEROCUBE 18 A
1 71415C 25052N 25074.31938345 .00010535 00000+0 52362-3 0 03
2 71415 97.4487 329.6519 0001362 238.1626 110.9379 15.17726067 17
AEROCUBE 18 B
1 71416C 25052P 25074.31951424 .00010239 00000+0 51068-3 0 00
2 71416 97.4497 329.6519 0001488 261.0357 88.7765 15.17605765 16
ORCA-2B
1 71426C 25052Q 25074.31963229 -.00015680 00000+0 -78080-3 0 07
2 71426 97.4411 329.6536 0000273 151.0788 199.3962 15.17671459 10
LIZZIESAT-3
1 71456C 25052R 25074.31978276 -.00006134 00000+0 -31179-3 0 00
2 71456 97.4444 329.6531 0002971 340.4923 10.7968 15.16945955 12
SPHINX
1 71477C 25052S 25074.32002581 -.00007608 00000+0 -38609-3 0 03
2 71477 97.4477 329.6529 0002900 328.4921 24.1169 15.17002445 15
DROID-002
1 71476C 25052T 25074.32020637 .00027755 00000+0 13863-2 0 01
2 71476 97.4446 329.6534 0000697 281.9597 71.6413 15.17551190 14
TOMORROW-S6
1 71475C 25052U 25074.32066123 .00026884 00000+0 13455-2 0 09
2 71475 97.4525 329.6533 0002134 279.7996 76.2687 15.17476288 14
M-SEL
1 71428C 25052V 25074.32103276 -.00003965 00000+0 -20083-3 0 01
2 71428 97.4432 329.6543 0002339 344.7524 13.3621 15.17068162 15
PIONEER-03
1 71453C 25052W 25074.32122026 -.00001541 00000+0 -77248-4 0 07
2 71453 97.4468 329.6543 0001368 298.8313 60.2996 15.17428089 12
ION SCV-017
1 71431C 25052X 25074.32142975 -.00009291 00000+0 -46982-3 0 08
2 71431 97.4434 329.6545 0002088 342.2991 17.9819 15.17126418 13
DSAR-TD
1 71445C 25052Y 25074.32213113 -.00023011 00000+0 -11558-2 0 02
2 71445 97.4477 329.6554 0001706 304.1255 59.9756 15.17368754 18
SPACEEYE-T1
1 71455C 25052Z 25074.32538924 -.00012500 00000+0 -63178-3 0 00
2 71455 97.4467 329.6590 0001755 346.6123 35.2827 15.17147495 10
CLARITY-1
1 71426C 25052AA 25074.32654664 -.00020239 00000+0 -10186-2 0 06
2 71426 97.4469 329.6604 0001304 325.1930 63.0191 15.17300189 18
LEMUR-2-BALTO
1 71457C 25052AB 25074.37550868 -.00063904 00000+0 -62705-2 0 06
2 71457 97.7506 329.5420 0002288 132.4872 162.1339 14.92332773 19
SOAP
1 71334C 25052AC 25074.37557697 -.00070678 00000+0 -69653-2 0 02
2 71334 97.7472 329.5493 0001561 90.9998 204.0041 14.92164024 13
LEMUR-2-MARACHE-FRAN
1 71462C 25052AD 25074.37565567 -.00064057 00000+0 -62953-2 0 09
2 71462 97.7516 329.5399 0002243 146.9062 148.4982 14.92271465 14
PANDORE
1 71333C 25052AE 25074.37571470 -.00070900 00000+0 -72652-2 0 07
2 71333 97.7532 329.5367 0005863 278.4721 17.2422 14.90589293 19
LEMUR-2-THEFALCONER
1 71463C 25052AF 25074.37581771 -.00064123 00000+0 -62979-2 0 07
2 71463 97.7480 329.5476 0002044 109.8872 186.4041 14.92295997 11
LEMUR-2-EMERSONROSE
1 71459C 25052AG 25074.37588137 -.00064365 00000+0 -63665-2 0 06
2 71459 97.7531 329.5372 0001934 182.8857 113.7230 14.92014887 19
UVSQ-SAT NG
1 71430C 25052AH 25074.37594965 -.00075370 00000+0 -76348-2 0 01
2 71430 97.7477 329.5483 0003498 302.8184 354.1826 14.91061646 10
HYVRID
1 71478C 25052AJ 25074.37615220 -.00068582 00000+0 -67797-2 0 06
2 71478 97.7474 329.5488 0000991 94.5049 203.5838 14.92040277 12
EZIE-A
1 71439C 25052AK 25074.37622975 -.00063176 00000+0 -64266-2 0 00
2 71439 97.7524 329.5394 0004497 279.0804 19.4016 14.90885756 14
EZIE-B
1 71440C 25052AL 25074.37637905 -.00063321 00000+0 -64600-2 0 05
2 71440 97.7515 329.5412 0004904 285.2400 14.0472 14.90768026 18
LEMUR-2-LIA-MARTIN
1 71461C 25052AM 25074.37645428 -.00065149 00000+0 -66179-2 0 00
2 71461 97.7535 329.5377 0004412 273.7232 25.9588 14.90943631 18
BUCCANEER MAIN
1 71432C 25052AN 25074.37657697 -.00022883 00000+0 -23320-2 0 08
2 71432 97.7501 329.5440 0004653 291.6400 8.7156 14.90797985 12
EZIE-C
1 71441C 25052AP 25074.37688368 -.00063663 00000+0 -64850-2 0 01
2 71441 97.7486 329.5465 0004453 298.3725 3.6344 14.90830844 18
LEMUR-2-DELOITTE-1
1 71458C 25052AQ 25074.37695313 -.00062723 00000+0 -62381-2 0 00
2 71458 97.7549 329.5365 0002399 215.4060 86.9481 14.91794928 13
ICEYE-X46
1 71435C 25052AR 25074.37704688 -.00074452 00000+0 -74210-2 0 07
2 71435 97.7511 329.5427 0001243 236.4588 66.4138 14.91712353 15
ARVAKER I
1 71443C 25052AS 25074.37727257 -.00072583 00000+0 -73479-2 0 02
2 71443 97.7493 329.5457 0003327 293.4717 10.6187 14.91086285 11
LEMUR-2-LEIA-PHILIP
1 71460C 25052AT 25074.37782465 -.00066193 00000+0 -67585-2 0 04
2 71460 97.7463 329.5502 0004781 308.8151 358.2479 14.90736963 15
ICEYE-X48
1 71437C 25052AU 25074.37807465 -.00075059 00000+0 -75792-2 0 06
2 71437 97.7495 329.5460 0002848 291.8912 16.5021 14.91190858 10
FIRESAT0
1 71446C 25052AV 25074.37845660 -.00064114 00000+0 -63976-2 0 06
2 71446 97.7513 329.5442 0001490 243.0693 67.3673 14.91664457 16
YAM-8
1 71444C 25052AW 25074.37883276 -.00076198 00000+0 -76858-2 0 07
2 71444 97.7498 329.5463 0002667 289.6399 22.8198 14.91235058 14
ICEYE-X51
1 71438C 25052AX 25074.37891840 -.00075805 00000+0 -75731-2 0 09
2 71438 97.7489 329.5474 0001075 265.1188 47.8035 14.91621790 15
ICEYE-X50
1 71436C 25052AY 25074.37907697 -.00075916 00000+0 -76475-2 0 04
2 71436 97.7517 329.5445 0002692 278.4307 35.3336 14.91287054 16
In a couple of hours I’m going to post and use the TLE based on the temporary NORAD IDs we use in DB.
Another Update from GNSS
1 98652U 25074.61859158 .00025213 00000-0 13143-2 0 00001
2 98652 097.4396 329.9506 0006612 339.5368 201.6810 15.15989002000015
NUSHSAT-1 TLE Update:
NUSHSAT-1
1 98628U 25075.38581590 .00000000 00000-0 -15047-3 0 05
2 98628 97.4529 330.7109 0002930 200.7175 210.6640 15.17486531 00
Using SatNOGS Network - Observation 11234184 to check the set.
Thanks for the update, and to others reading this post, this is OTP-2
