Telemetry database not loading
Hi @MasterJ!
This url points to the API endpoint of the satnogs-db which is probably not what you want.
If you want to see the decoded telemetry data, have a look at https://dashboard.satnogs.org
If you want to download frames from db: log-in to the db, then there will be a download option available on the satellite page (if there are frames available for this satellite).
This may be the thread you referred to:
